Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
GitHub Advanced SecurityGitHub Advanced Security
Ingest GitHub Advanced Security (GHAS) security events and audit logs.
Extension
Free trialDocumentation
Architecture diagram.Vulnerabilities dashboard.Coverage dashboard.
  • Product information
  • Release notes
Overview
Dynatrace integrates with GitHub Advanced Security to enable visibility, orchestration, and prioritization of security findings.
Capabilities:
  • Single pane of glass: Ingest vulnerability findings, scan events, and audit logs from GitHub products into Dynatrace (powered by OpenPipeline™)
  • Unified analysis: Dynatrace transforms and maps the findings to a unified format for vulnerability findings (powered by Dynatrace Semantic Dictionary)
  • Findings operationalization: Prioritize, visualize, and automate vulnerability findings with runtime context
  • Unveil blind spots: Discover and eliminate coverage gaps in your Software Development Lifecycle (SDLC)
Use cases
  • Overview: Visualize and report your current security posture and trends around vulnerability findings across vulnerability scanners with Dashboards.
  • Prioritization: Analyze and prioritize vulnerability findings across multiple tools and products uniformly with Notebooks.
  • Automation: Create notifications and tickets for critical vulnerability findings with Workflows.
  • Investigation: Use vulnerability findings as an additional dimension for threat hunting and incident forensics using Security Investigator.
Get started
For more information on the installation and configuration, please see GitHub Advanced Security extension in the Dynatrace Documentation.
Details
Compatibility information
GitHub API (2022-11-28)
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to GitHub Advanced Security
Dashboards logo
Dashboards
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Extensions logo
Extensions
Manage Dynatrace extensions for hundreds of technologies.
Full version history
ReleaseDate
Requires Dynatrace 1.318 and ActiveGate 1.299
Features
  • Ability to send Dynatrace runtime context to GitHub (for K8s container images)
Improvements
  • Set vulnerability.cvss namespace attributes on ingested Dependabot alerts
Fixes
  • Includes updated version of PyJWT (2.12.1) to resolve CVE-2026-32597
Improvements
  • dt.security_context, dt.cost.costcenter, and dt.cost.product attributes from the monitoring configuration are now set on all security events
Requires ActiveGate 1.310.0 or later
Features
  • Exposed secret ingestion
Changes
  • Standardization of id's used in different security event ingestion
  • Fixes to pagination to support self-hosted GitHub instances
Requires Dynatrace version 1.310 (ActiveGate version 1.299)
Features
  • Code scanning alert ingestion
Improvements
  • Smart pagination to stop collecting records out of evaluation window
  • Dependabot vulnerability alert object IDs no longer based on file content
    • Would cause a new object ID to be created on file change
    • Now based on file location/path
  • Updated dashboards
  • Correct issue with time filtering for dependabot alerts
  • Update versions of included dashboards
  • Initial release
Dynatrace Hub
All (880)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
