Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Generic Cisco DeviceGeneric Cisco Device
Monitor Cisco devices using SNMP to feed Dynatrace with metrics and alerts.
Extension
Free trialDocumentation
Overview dashboard.Cisco device entity screen.
  • Product information
  • Release notes
Overview
Cisco devices are a critical component in your network infrastructure. The Generic Cisco Device monitoring extension allows for remote monitoring of your Cisco network devices via the Simple Network Management Protocol (SNMP).
Use cases
  • Monitor resource usage of network components
  • Detect and alert on issues with critical protocols such as BGP
  • Identify problems with network interfaces
Get started
For more information on the installation and configuration, please see Generic Cisco Device extension in the Dynatrace Documentation.
Details
Compatibility information
This extension is designed to generically provide visibility into a wide variety of Cisco network devices. Only products still supported by Cisco will be officially supported but it can be used to monitor any devices that meet the requirements for SNMP connectivity and support the MIBs and OIDs used.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
-com.dynatrace.extension.network_device.sysuptime--
-com.dynatrace.extension.network_device.cpu_usage--
-com.dynatrace.extension.network_device.memory_used--
-com.dynatrace.extension.network_device.memory_free--
-com.dynatrace.extension.network_device.if.status--
-com.dynatrace.extension.network_device.if.in.multicast_pkts.count--
-com.dynatrace.extension.network_device.if.out.multicast_pkts.count--
-com.dynatrace.extension.network_device.if.in.broadcast_pkts.count--
-com.dynatrace.extension.network_device.if.out.broadcast_pkts.count--
-com.dynatrace.extension.network_device.if.in.ucast_pkts.count--
-com.dynatrace.extension.network_device.if.out.ucast_pkts.count--
-com.dynatrace.extension.network_device.if.in.crc_errors.count--
Active supervisor CPU utilizationcom.dynatrace.extension.snmp-generic-cisco-device.ha.active_supervisor.cpu_utilizationThe average utilization of CPU on the active supervisor.Percent
Active supervisor memory utilizationcom.dynatrace.extension.snmp-generic-cisco-device.ha.active_supervisor.memory_utilizationThe average utilization of memory on the active supervisor.Percent
Synchronization statecom.dynatrace.extension.snmp-generic-cisco-device.ha.synchronization.enabledThe state of the auto synchronization of images between the active and standby supervisor.State
Auto synchronization statuscom.dynatrace.extension.snmp-generic-cisco-device.ha.synchronization.stateThe status of the current auto synchronization process, or if no such process is in progress, then the state of the most recent one.State
Power supply statecom.dynatrace.extension.snmp-generic-cisco-device.power_supply.stateA state metric representing the details of power supplies on the device. Value is always 1; use the dimensions to understand the status.NotApplicable
Time since the last re-startcom.dynatrace.extension.snmp-generic-cisco-device.sys.uptimeThe time (in hundredths of a second) since the network management portion of the system was last re-initializedUnspecified
CPU busycom.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.total.1min.revOverall CPU busy percentage in the last 1 min.Percent
CPU loadcom.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.loadavg.1minOverall CPU load average in the last 1 min.Count
CPU memory usedcom.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.memory.hc.usedOverall CPU wide sys mem currently under useKiloByte
CPU memory freecom.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.memory.hc.freeOverall CPU wide sys mem freeKiloByte
CPU memory usedcom.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.memory.usedOverall CPU wide sys mem currently under use (legacy 32-bit value)KiloByte
CPU memory freecom.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.memory.freeOverall CPU wide sys mem free (legacy 32-bit value)KiloByte
OSPF neighbor statecom.dynatrace.extension.snmp-generic-cisco-device.ospf.nbr.stateThe state of the relationship with this neighbor. down (1), attempt (2), init (3), twoWay (4), exchangeStart (5), exchange (6), loading (7), full (8). OSPF-MIB.Count
BGP peer connection statecom.dynatrace.extension.snmp-generic-cisco-device.bgp4.peer.stateThe BGP peer connection state. idle(1), connect(2), active(3), opensent(4), openconfirm(5), established(6). BGP4-MIB.State
BGP peer admin statuscom.dynatrace.extension.snmp-generic-cisco-device.bgp4.peer.admin.statusThe desired state of the BGP connection. stop(1), start(2). BGP4-MIB.State
BGP peer established timecom.dynatrace.extension.snmp-generic-cisco-device.bgp4.established_timeThis timer indicates how long (in seconds) this peer has been in the established state or how long since this peer was last in the established state.Second
FRU power operational statuscom.dynatrace.extension.snmp-generic-cisco-device.fru.power_oper_statusThe FRU power operational statusState
FRU fan tray operational statuscom.dynatrace.extension.snmp-generic-cisco-device.fru.fan_tray_oper_statusThe operational state of the fan or fan trayState
Cisco BGP peer established timecom.dynatrace.extension.snmp-generic-cisco-device.cbgp.established_timeThis timer indicates how long (in seconds) this peer has been in the established state or how long since this peer was last in the established state.Second
Cisco BGP updates receivedcom.dynatrace.extension.snmp-generic-cisco-device.cbgp.updates_received_countThe number of BGP UPDATE messages received on the connection with the peer.Count
Cisco BGP updates sentcom.dynatrace.extension.snmp-generic-cisco-device.cbgp.updates_sent_countThe number of BGP UPDATE messages sent on the connection with the peer.Count
Cisco BGP peer statecom.dynatrace.extension.snmp-generic-cisco-device.cbgp.peer.stateThe BGP peer connection state.State
Cisco BGP peer admin statuscom.dynatrace.extension.snmp-generic-cisco-device.cbgp.peer.admin.statusThe desired state of the BGP connection. stop(1), start(2). CISCO-BGP4-MIB.State
TCP active openscom.dynatrace.extension.snmp-generic-cisco-device.tcp.activeopens.countNumber of transitions of TCP connections from CLOSED to SYN-SENTCount
TCP passive openscom.dynatrace.extension.snmp-generic-cisco-device.tcp.passiveopens.countNumber of transitions of TCP connections from CLOSED to SYN-RCVDCount
TCP failed attemptscom.dynatrace.extension.snmp-generic-cisco-device.tcp.attemptfails.countNumber of transitions of TCP connections from SYN-SENT/SYN-RCVD to CLOSED and from SYN-RCVD to LISTENCount
TCP resetscom.dynatrace.extension.snmp-generic-cisco-device.tcp.estab.resets.countNumber of transitions of TCP connections from ESTABLISHED/CLOSE-WAIT to CLOSEDCount
TCP connectionscom.dynatrace.extension.snmp-generic-cisco-device.tcp.curr.estabNumber of TCP connections in the ESTABLISHED/CLOSE-WAIT stateCount
TCP segments receivedcom.dynatrace.extension.snmp-generic-cisco-device.tcp.hc.in.segs.countTotal number of segments received (including errors)Count
TCP segments sentcom.dynatrace.extension.snmp-generic-cisco-device.tcp.hc.out.segs.countTotal number of segments sent (excluding retransmissions)Count
TCP segments retransmittedcom.dynatrace.extension.snmp-generic-cisco-device.tcp.retrans.segs.countTotal number of segments retransmittedCount
TCP segment errorscom.dynatrace.extension.snmp-generic-cisco-device.tcp.in.errs.countTotal number of segments received in errorCount
TCP segment resetscom.dynatrace.extension.snmp-generic-cisco-device.tcp.out.rsts.countNumber of TCP segments sent containing the RST flagCount
UDP datagrams deliveredcom.dynatrace.extension.snmp-generic-cisco-device.udp.hc.in.datagrams.countTotal number of UDP datagrams deliveredCount
UDP datagrams received without portcom.dynatrace.extension.snmp-generic-cisco-device.udp.noports.countNumber of received UDP datagrams (no application at the destination port)Count
UDP datagram errorscom.dynatrace.extension.snmp-generic-cisco-device.udp.in.errors.countNumber of received and not delivered UDP datagrams (other than no application at the destination port)Count
UDP datagrams sentcom.dynatrace.extension.snmp-generic-cisco-device.udp.hc.out.datagrams.countTotal number of UDP datagrams sentCount
EIGRP peer smooth round trip timecom.dynatrace.extension.snmp-generic-cisco-device.eigrp.peer.srttThe computed smooth round trip time for packets to and from the peer (milliseconds). CISCO-EIGRP-MIB.MilliSecond
CRC errorscom.dynatrace.extension.snmp-generic-cisco-device.if.in.crc_errors.countNumber of input packets which had cyclic redundancy checksum errorsCount
Last interface status changecom.dynatrace.extension.snmp-generic-cisco-device.if.lastchangeValue of 'sysUpTime' when the interface entered its current stateCount
Octets receivedcom.dynatrace.extension.snmp-generic-cisco-device.if.in.octets.countThe total number of octets received on the interface including framing charactersCount
Octets transmittedcom.dynatrace.extension.snmp-generic-cisco-device.if.out.octets.countThe total number of octets transmitted out of the interface including framing charactersCount
Inbound errorscom.dynatrace.extension.snmp-generic-cisco-device.if.in.errors.countNumber of inbound packets/transmission units with errorsCount
Inbound discardscom.dynatrace.extension.snmp-generic-cisco-device.if.in.discards.countNumber of inbound packets discardedCount
Outbound errorscom.dynatrace.extension.snmp-generic-cisco-device.if.out.errors.countNumber of outbound packets/transmission units with errorsCount
Outbound discardscom.dynatrace.extension.snmp-generic-cisco-device.if.out.discards.countNumber of outbound packets discardedCount
-com.dynatrace.extension.network_device.if.bytes_in.count--
-com.dynatrace.extension.network_device.if.bytes_out.count--
-com.dynatrace.extension.network_device.if.in.errors.count--
-com.dynatrace.extension.network_device.if.in.discards.count--
-com.dynatrace.extension.network_device.if.out.errors.count--
-com.dynatrace.extension.network_device.if.out.discards.count--
-com.dynatrace.extension.network_device.if.lastchange--
Fan statecom.dynatrace.extension.snmp-generic-cisco-device.envmon.fan.stateCurrent state of the fan instrumentedUnspecified
Fan temperaturecom.dynatrace.extension.snmp-generic-cisco-device.envmon.temperature.status.valueCurrent temperature of the fan instrumentedUnspecified
Messages deliveredcom.dynatrace.extension.snmp-generic-cisco-device.snmp.in.pkts.countTotal number of messages delivered from the transport serviceCount
Silently dropped PDUscom.dynatrace.extension.snmp-generic-cisco-device.snmp.silentdrops.countNumber of silently dropped PDUs due to the large reply sizeCount
Unsupported SNMP version messagescom.dynatrace.extension.snmp-generic-cisco-device.snmp.in.bad.versions.countTotal number of messages delivered with an unsupported SNMP versionCount
Messages with bad community namescom.dynatrace.extension.snmp-generic-cisco-device.snmp.in.bad.community.names.countNumber of messages with an unknown SNMP communityCount
Messages not allowed in communitycom.dynatrace.extension.snmp-generic-cisco-device.snmp.in.bad.community.uses.countNumber of messages not allowed for the used SNMP communityCount
'noSuchName' errorscom.dynatrace.extension.snmp-generic-cisco-device.snmp.in.nosuchnames.countNumber of PDUs delivered with 'noSuchName' errorCount
'badValue' errorscom.dynatrace.extension.snmp-generic-cisco-device.snmp.in.bad.values.countNumber of PDUs delivered with 'badValue' errorCount
-com.dynatrace.extension.snmp-generic-cisco-device.lldp_neighbor--
Memory pool used (32 bit)com.dynatrace.extension.snmp-generic-cisco-device.memory_pool.usedThe number of bytes from the memory pool that are currently in use.Byte
Memory pool free (32 bit)com.dynatrace.extension.snmp-generic-cisco-device.memory_pool.freeThe number of bytes from the memory pool that are currently unused.Byte
Memory pool used (64 bit)com.dynatrace.extension.snmp-generic-cisco-device.enhanced.memory_pool.usedThe number of bytes from the enhanced memory pool that are currently in use.Byte
Memory pool free (64 bit)com.dynatrace.extension.snmp-generic-cisco-device.enhanced.memory_pool.freeThe number of bytes from the enhanced memory pool that are currently unused.Byte
Interface speedcom.dynatrace.extension.snmp-generic-cisco-device.if.highspeedSpeed of the network interface in MegaBits per second.MegaBitPerSecond
Octets received (high capacity)com.dynatrace.extension.snmp-generic-cisco-device.if.hc.in.octets.countThe total number of octets received on the interface including framing characters. This metric uses 64 bit counter and should be used for highspeed devices.Count
Octets transmitted (high capacity)com.dynatrace.extension.snmp-generic-cisco-device.if.hc.out.octets.countThe total number of octets transmitted out of the interface including framing characters. This metric uses 64 bit counter and should be used for highspeed devices.Count
Physical component statecom.dynatrace.extension.snmp-generic-cisco-device.component.stateA state metric representing the details of physical components. This is used to collect details about the Cisco device stack. Value is always 1; use the dimensions to view details.NotApplicable
Sensor valuecom.dynatrace.extension.snmp-generic-cisco-device.sensor.valueThe value of sensors as reported in the Cisco entity sensor MIB. The type/unit of the value (e.g. rpm, hertz, celcius) depends on the type of sensor (sensor.type dimension). The sensor.status dimension reports the operational status of the sensor.Unspecified
Related to Generic Cisco Device
Generic network device logo
Gain insights into the performance of your network devices.
SNMP Traps logo
SNMP Traps
Supplement network monitoring with event-based data reported via SNMP Traps.
Full version history
ReleaseDate
🪲 Fixed in this version:
  • Enriched network device nodes with snmp.ip field.
⚠️WARNING⚠️: Possible breaking changes and warnings - PLEASE READ before upgrading:
  • This version requires a minimum Dynatrace version of 1.338.0 and a minimum EEC version of 1.333.0.
  • This version includes a potentially breaking change for Dynatrace on Grail.
    • With the inclusion of OpenPipeline processing rules, any metrics ingested from the extension will be processed by a dedicated OpenPipeline pipeline instead of the default pipeline.
    • This means that any created custom dynamic rules will no longer be used on metrics ingested from the extension. If you want to keep enforcing them, please create pipeline groups.
New in this version:
  • Smartscape on Grail. This extension will populate new Smartscape nodes and edges via OpenPipeline extraction.
  • Refactored feature sets according to the best practices established here.
⚠️ IMPORTANT: This version contains a change to feature sets that may require enabling a new feature set to continue collecting existing data
⚠️ Changes in this version:
  • Metric com.dynatrace.extension.snmp-generic-cisco-device.component.state moved from default feature set to new entity-enrichment feature set
    • This metric is used to enrich entities created by the extension with stack name, model name, and serial number
⚠️ Metric com.dynatrace.extension.network_device.lldp_neighbor was renamed to com.dynatrace.extension.snmp-generic-cisco-device.lldp_neighbor to avoid conflicts with generic network topology rules
Changes
  • Require all dimensions exist for entity creation
  • Update latest dashboard to use link to IO App Network view for listing entities
Fixes
  • sys.name and mac.address dimensions are required on all network metrics and filtered for empty values. This caused unnecessary stress on topology engine
  • Update Cisco interface entity to only use (and require sys.name OID)
    • Previous version required device.name which would not be available if the IP address cannot be resolved via DNS
✨ New in this version:
  • Add Davis anomaly detector templates to extension package
⚠️ IMPORTANT: This version requires a minimum Dynatrace version of 1.318
✨ New in this version (3.4.0):
  • Added the following new metrics to the Advanced interfaces feature set
    • com.dynatrace.extension.network_device.if.in.multicast_pkts.count
    • com.dynatrace.extension.network_device.if.out.multicast_pkts.count
    • com.dynatrace.extension.network_device.if.in.broadcast_pkts.count
    • com.dynatrace.extension.network_device.if.out.broadcast_pkts.count
    • com.dynatrace.extension.network_device.if.in.ucast_pkts.count
    • com.dynatrace.extension.network_device.if.out.ucast_pkts.count
Changed in this version
  • network:interface entities created by the extension are named after the ifName (name) OID instead of ifDescr (description) OID. This resolves an issue with Network Neighbors not correctly related at interface level
⚠️ Note: any settings/configuration based on the names of network:interface entities may need adjusting due to the above change
✨ New in this version (3.3.0):
  • Added the following metrics to the new Advanced interfaces feature set:
    • com.dynatrace.extension.network_device.if.lastchange
    • com.dynatrace.extension.network_device.if.in.crc_errors
  • Removes the below metrics from the default feature set and moves them to a new Control plane feature set
    • com.dynatrace.extension.snmp-generic-cisco-device.sys.uptime
    • com.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.total.1min.rev
    • com.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.loadavg.1min
    • com.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.memory.hc.used
    • com.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.memory.hc.free
    • com.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.memory.used
    • com.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.memory.free
Minimum Dynatrace version: 1.310
Minimum ActiveGate version: 1.307
Changes
  • Adds BGP peer connection established time to "BGP" feature set
⚠️ IMPORTANT CHANGE:
Metrics in "default" feature set will always be enabled and cannot be disabled. These metrics are mandatory. Take extra caution configuring devices and interfaces for which you are collecting data. Make use of Interface filters to limit the number of interfaces, otherwise, all interfaces on the device will be collected by default. In case you do not wish to collect interfaces on your device, enter $eq(!) in the "Interface Name" filter field on the Feature Sets screen during configuration.
These metrics introduced into the "default" feature set are per interface and cannot be disabled but can be filtered.
  • com.dynatrace.extension.network_device.if.bytes_in.count
  • com.dynatrace.extension.network_device.if.bytes_out.count
  • com.dynatrace.extension.network_device.if.in.errors.count
  • com.dynatrace.extension.network_device.if.in.discards.count
  • com.dynatrace.extension.network_device.if.out.errors.count
  • com.dynatrace.extension.network_device.if.out.discards.count
  • Adds dt.security_context to network:device, network:interface, snmp:com_dynatrace_extension_snmp_generic_cisco_device, and snmp:com_dynatrace_extension_snmp_generic_cisco_network_interface entities
Notice:
  • If upgrading to this version from version 2.x.x, please read the release notes for version 3.1.0 first, before upgrading.
  • Removed duplicate cards on Unified Analysis screens related to FRU feature set.
Major version update - please review release notes fully
Breaking changes
  • In order to support some BGP data that comes from the non-Cisco BGP MIB, the existing BGP feature set was renamed to "Cisco BGP" and the new data is under "BGP". Configurations will be able to be updated without re-creation, but if you were using the BGP feature set you must enable the Cisco BGP feature set in order to keep collecting that data.
New features
  • Several new feature sets for network peer metrics (feature sets named accordingly)
    • BGP (BGP4-MIB)
    • OSPF (OSPF-MIB)
    • EIGRP (CISCO-EIGRP-MIB)
  • New FRUs (Field Replaceable Units) feature set
    • Fan and PSU statuses
    • From CISCO-ENTITY-FRU-CONTROL-MIB
  • CRC (Cyclic Redundancy Checksum) Errors metric is added to the Interfaces feature set
  • Advanced sensors
    • New feature set that can report the 'raw' sensor values and statuses for sensors available in CISCO-ENTITY-SENSOR-MIB
    • Because all sensor types are reported via the same OID, there is no way to properly set metadata
    • Use the available dimensions to properly filter and make use of the values for the needed use cases
  • New gen3 dashboard added
  • Minimum schema requirement correctly enforced
  • Network neighbor discovery through LLDP
  • UI is compatible with AppEngine use
  • Recently introduced metrics for device and interface now apply the existing feature sets and filters to reduce license consumption.
  • New entities and metrics were added to represent Cisco as a network device for the SNMP Autodiscovery Extension
  • Ability to filter interfaces by their alias and type
  • Several new feature-sets for new capabilities:
    • Memory pools
    • BGP
    • High availability status
  • Change to use '1 min' load values instead of '5 min' to align with extension frequency
  • Non-high capacity memory values collected for cases when high-capacity OIDs not available
  • Network interface charts would not display due to incorrect splitting
  • Cisco Stack model and serial number reported as device attributes
  • Device software revision (version) reported as attribute
  • Power supply status available via new feature set
🚀 Improved in this version:
  • Configuration fields for filtering now support up to 5000 characters
  • Fixed: Cisco Network Interface metrics not visible in a Management Zone.
  • High capacity interface traffic metrics extracted to "Interfaces 64-bit" feature set.
  • Default interface traffic metrics extracted to "Interfaces 32-bit" feature set.
Check distribution of metrics in the new feature sets to avoid gaps in the data
Changes:
  • removed a rule for creating an entity from snmp traps. Now traps source entity is connected to cisco device entity only with SAME_AS relation.
v1.9.0
  • Added 4 new metrics:
    • Octets received (high capacity)
    • Octets transmitted (high capacity)
    • Interface outgoing traffic (high capacity)
    • Interface incoming traffic (high capacity)
  • Bandwidth utilization is now calculated using above metrics
  • Added: Injection Cards to Cisco Entities, allows others to inject cards into these entities
  • Added: inject message with back-link into the screen of corresponding snmptraps source.
v1.6.0
  • Added relationships to SNMP Traps Extension & Trap Visualizations on Device Screen
  • Added ability to use filters for Interface Name, Admin and Operational Status
Fix the problem with metadata for count metrics that are not selected properly.
Fix the problem with validation of screen definition.
  • added traffic metrics that shows traffic in bits per seconds
  • added a metric with interface speed
  • added a metrics that calculate bandwidth utilization
  • added definition of UA screen for network interface
  • added alert definition for bandwidth utilization.
  • new metrics has been used on both screens
  • dashboard has been improved
Requires Dynatrace v. 1.238.
5min interval changed to 1min.
Dashboard improvements - tile with errors contains a links to device screens.
No release notes
No release notes
Version 1.2.3 allows to run the extension on previous ActiveGate release (1.227)
Dynatrace Hub
All (907)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility.
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Streamline incident management with automated Pageruty workflows.
Cursor IDE logo
Cursor IDE
Boost developer productivity and get real-time, code-level insights into Cursor.
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
