Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Forcepoint (SNMP)Forcepoint (SNMP)
Forcepoint (SNMP)
Forcepoint (SNMP)
Gain insights into the performance of your Forcepoint Appliances.
Extension
Free trialDocumentation
A New Overview Dashboard is included for Forcepoint Appliances, along with interfaces and partitions, providing an overview of monitoring coverage. Use this as a starting point for troubleshooting and further drilldowns.View the status of Forcepoint Appliances and interfaces in the New Infrastructure & Operations app.In addition to the Overview Dashboard provided for the New Dashboards app, a dashboard is included for Dashboards Classic.View all metrics associated with Forcepoint Appliances, Interfaces, and Partitions with bundled Unified Analysis screens for each type of entity.
  • Product information
  • Release notes
Overview
This extension leverages the SNMP protocol to provide a complete solution to monitor Forcepoint Appliances. The complete configuration is provided out of the box.
This is intended for users, who:
  • Would like to monitor the health state and performance of their Forcepoint Appliances, and provide a unified analysis for Ops, DevOps, and IT Admins.
This enables you to:
  • Monitor the health and performance of your Forcepoint Appliances
  • Use an included alert configuration to be alerted if a monitored interface goes into a 'down' state.
  • Set up alerts to be notified of traffic anomalies
Use cases
  • Monitor Forcepoint Appliances by polling data for Network Devices and Interfaces.
  • Enable alerting on detected anomalies
  • Use with the Infrastructure and Operations App for an overview of all monitored Network Devices in the environment.
Get started
For more information on the installation and configuration, please see Forcepoint (SNMP) extension in the Dynatrace Documentation.
Details
Compatibility information
  • This extension is to be used with Forcepoint Appliances only.
  • SNMPv2c and SNMPv3 supported only.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
-com.dynatrace.extension.network_device.sysuptime--
-com.dynatrace.extension.network_device.cpu_usage--
-com.dynatrace.extension.network_device.memory_used--
-com.dynatrace.extension.network_device.memory_free--
-com.dynatrace.extension.network_device.if.bytes_in.count--
-com.dynatrace.extension.network_device.if.bytes_out.count--
-com.dynatrace.extension.network_device.if.status--
Forcepoint statussnmp.forcepoint.node_oper_stateThe operative (clustering) state of the node : unknown(0), online(1), goingOnline(2), lockedOnline(3), goingLockedOnline(4), offline(5), goingOffline(6), lockedOffline(7), goingLockedOffline(8), standby(9), goingStandby(10)State
-snmp.forcepoint.fw_if_accepted_pkts--
-snmp.forcepoint.fw_if_dropped_pkts--
-snmp.forcepoint.fw_if_logged_pkts--
-snmp.forcepoint.fw_if_accounted_pkts--
-snmp.forcepoint.fw_if_rejected_pkts--
-snmp.forcepoint.fw_if_accepted_bytes--
-snmp.forcepoint.fw_if_dropped_bytes--
-snmp.forcepoint.fw_if_logged_bytes--
-snmp.forcepoint.fw_if_accounted_bytes--
-snmp.forcepoint.fw_if_rejected_bytes--
-snmp.forcepoint.fw_if_forwarded_pkts--
-snmp.forcepoint.fw_if_forwarded_bytes--
Partition sizesnmp.forcepoint.partition.fw_sizeTotal size of the partitionKiloByte
Partition used spacesnmp.forcepoint.partition.fw_usedAmount of used space of the partition (in kilobytes)KiloByte
Partition free spacesnmp.forcepoint.partition.fw_availInformation about amount of free space on partition (in kilobytes)KiloByte
Total physical memorysnmp.forcepoint.fw_mem_bytes_totalAmount of available bytes of physical memoryByte
Used memorysnmp.forcepoint.fw_mem_bytes_usedAmount of memory being in useByte
Unused memorysnmp.forcepoint.fw_mem_bytes_unusedAmount of unused bytes of physical memoryByte
Memory bufferssnmp.forcepoint.fw_mem_bytes_buffersAmount of memory used as buffersByte
Memory cachesnmp.forcepoint.fw_mem_bytes_cachedAmount of memory used as cacheByte
-snmp.forcepoint.fw_cpu_total--
-snmp.forcepoint.fw_cpu_user--
-snmp.forcepoint.fw_cpu_system--
-snmp.forcepoint.fw_cpu_nice--
-snmp.forcepoint.fw_cpu_idle--
-snmp.forcepoint.fw_cpu_io_wait--
-snmp.forcepoint.fw_cpu_hw_irq--
Total swap spacesnmp.forcepoint.fw_swap_bytes_totalAmount of available bytes of swapByte
Used swapsnmp.forcepoint.fw_swap_bytes_usedAmount of swap being in useByte
Unused swapsnmp.forcepoint.fw_swap_bytes_unusedAmount of unused bytes of swapByte
CPU Loadsnmp.forcepoint.node_cpu_loadThe CPU load percentage on the nodePercent
Current connectionssnmp.forcepoint.fw_conn_numberNumber of current connectionsCount
Accepted packetssnmp.forcepoint.fw_acceptedNumber of accepted packetsCount
Dropped packetssnmp.forcepoint.fw_droppedNumber of dropped packetsCount
Logged packetssnmp.forcepoint.fw_loggedNumber of logged packetsCount
Accounted packetssnmp.forcepoint.fw_accountedNumber of accounted packetsCount
Rejected packetssnmp.forcepoint.fw_rejectedNumber of rejected packetsCount
Interface speedsnmp.forcepoint.interface.if_high_speedAn estimate of the interface's current bandwidth in units of 1,000,000 bits per second. If this object reports a value of n' then the speed of the interface is somewhere in the range of n-500,000' to `n+499,999'. For interfaces which do not vary in bandwidth or for those where no accurate estimation can be made, this object should contain the nominal bandwidth. For a sub-layer which has no concept of bandwidth, this object should be zero.MegaBitPerSecond
Octets receivedsnmp.forcepoint.interface.if_in_octets.countThe total number of octets received on the interface including framing charactersCount
Octets transmittedsnmp.forcepoint.interface.if_out_octets.countThe total number of octets transmitted out of the interface including framing charactersCount
Inbound errorssnmp.forcepoint.interface.if_in_errors.countNumber of inbound packets/transmission units with errorsCount
-snmp.forcepoint.interface.if_in_discards.count--
Outbound errorssnmp.forcepoint.interface.if_out_errors.countNumber of outbound packets/transmission units with errorsCount
Outbound discardssnmp.forcepoint.interface.if_out_discards.countNumber of outbound packets discardedCount
Related to Forcepoint (SNMP)
Forcepoint logo
Forcepoint
Monitor your forcepoint appliances and their usage
Full version history
ReleaseDate
Bugfixes
  • Adjusted markdown link in Platform Dashboard to point to the Network devices section in the I&O app.
  • Adjusted DQL tiles in Platform Dashboard to point to the I&O app.
Enhancements
  • Updated entity links in Platform dashboards to redirect to the Infrastructure & Operations app.
Bugfixes
  • Adjusted required dimensions for entity creation to prevent null entities from being created.
⚠️ Note:
  • This release requires a Minimum Dynatrace Version of 1.318.0 or higher.
New in this version:
  • Internal metadata updated.
  • Initial release of SNMP Forcepoint
  • Includes:
    • Monitoring of Forcepoint Appliances, Interfaces, and Partitions
    • Generic Network Topology support
    • New and Classic Dashboards
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
