Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Databricks WorkspaceDatabricks Workspace
Remotely monitor your Databricks Workspaces!
Extension
Free trialDocumentation
Databricks Cost Management DashboardDatabricks AI Gateway DashboardDatabricks Workspace Jobs in Distributed Tracing appDatabricks Job as a trace with task spans in Distributed Tracing app
  • Product information
  • Release notes
Overview
With Dynatrace, you can remotely monitor your Databricks Workspaces. This extension works in harmony with the OneAgent based Databricks extension but, is also ideal for workspaces and clusters where the OneAgent cannot be installed such as Databricks Serverless compute.
Use cases
  • Gather Databricks Job Run metrics including success rate and job duration
  • For Databricks Jobs running on All-purpose and Job Compute Clusters understand cost of these jobs (currently Azure Databricks is supported)
  • Ingest Job and Task run information as traces allowing for further analysis
  • Gather health metrics and detailed usage information from your Databricks model serving endpoints
  • Ingest billing data from Databricks to understand usage across workspaces, SKU & product category, jobs, and more
Get started
For more information on the installation and configuration, please see Databricks Workspace extension in the Dynatrace Documentation.
Details
Compatibility information
Databricks API version 2.2 is used for the APIs below:
  • List job runs
  • Get a single job
API version 2.1 is used for the following:
  • Get cluster info
API version 2.0 is used for the following:
  • Get all serving endpoints
  • Get metrics of a serving endpoint
The following system tables are queried when ingesting model serving endpoint data:
  • system.access.workspaces_latest
  • system.serving.endpoint_usage
  • system.serving.served_entities
And billing & cost data:
  • system.billing.usage
  • system.billing.list_prices
  • system.lakeflow.jobs
To query any of the above system table data, the workspace must also have:
  • Unity Catalog enabled.
  • A SQL warehouse set up.
For the databricks.job.cost metric, currently only Azure Databricks workspaces are supported.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Job Run Durationdatabricks.job.duration.run-MilliSecond
Job Success Ratedatabricks.job.success_rate-Percent
Job Setup Durationdatabricks.job.duration.setup-MilliSecond
Job Execution Durationdatabricks.job.duration.execution-MilliSecond
Job Cleanup Durationdatabricks.job.duration.cleanup-MilliSecond
Job Queue Durationdatabricks.job.duration.queue-MilliSecond
Job Cost (Approx)databricks.job.cost-Unspecified
Model Serving Endpoint Memory Usage Percentagedatabricks.model_endpoint.mem_usage_percentage-Percent
Model Serving Endpoint CPU Usage Percentagedatabricks.model_endpoint.cpu_usage_percentage-Percent
Model Serving Endpoint Request Count Totaldatabricks.model_endpoint.request_count_total-Count
Model Serving Endpoint Request 5xx Count Totaldatabricks.model_endpoint.request_5xx_count_total-Count
Model Serving Endpoint Provisioned Concurrent Requests Totaldatabricks.model_endpoint.provisioned_concurrent_requests_total-Count
Model Serving Endpoint Request 4xx Count Totaldatabricks.model_endpoint.request_4xx_count_total-Count
Model Serving Endpoint GPU Usage Percentagedatabricks.model_endpoint.gpu_usage_percentage-Percent
Model Serving Endpoint GPU Memory Usage Percentagedatabricks.model_endpoint.gpu_memory_usage_percentage-Percent
Model Serving Endpoint Average Request Latencydatabricks.model_endpoint.request_latency_ms_avg-MilliSecond
Model Serving Endpoint P99 Request Latencydatabricks.model_endpoint.request_latency_ms_p99-MilliSecond
Model Serving Endpoint P95 Request Latencydatabricks.model_endpoint.request_latency_ms_p95-MilliSecond
Related to Databricks Workspace
Databricks logo
Databricks
Monitor your Databricks Clusters via its multiple APIs!
Full version history
ReleaseDate
āš ļøBreaking change
Upgrading existing monitoring configurations from previous versions to this version will not be possible and will require recreating those monitoring configurations. New monitoring configurations will not be affected.
✨New in this version:
  • Monitor model serving endpoint usage and billing data from your workspaces with new Gen3 dashboards provided for analysis. See documentation for how to get started collecting this data.
  • Added the option to report running/active jobs as logs.
  • Added the option to report job tags as metric dimensions and trace attributes.
  • Support added for OAuth when querying Databricks APIs and system tables.
  • Credential Vault support added for all secrets provided in the configuration.
  • Updated Jobs API from v2.1 to v2.2.
  • Db.job.* attributes now added to all task spans.
  • Updated all Gen3 dashboard links to point to new entity pages in the Infrastructure and Operations app.
  • Databricks workspace name added to trace service name.
v1.3.11
  • Vulnerability fix for protobuf:6.33.4 (CVE-2026-0994)
1.3.9
  • DXS-3787
    • Update classic entity screen to remove optional dimension preventing data from being shown
1.3.4
  • DXS-3317
    • Add Platform Dashboard
    • Add new Workspace Entity
    • Add Platform Screen
    • Add dt.security_context attribute
  • Updated how auto-detection of trace endpoint URL is done
  • Updated activation schema to allow for custom trace endpoint URL
    • Added custom Root CA path as an optional field
  • Fixes for job status metric and reporting for traces
v1.0.2
  • DXS-3253
    • Update Library Versions
V1.0.1
  • Initial version with updated Platform Dashboard link
Dynatrace Hub
All (884)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
