Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
DatabricksDatabricks
Databricks
Databricks
Monitor your Databricks Clusters via its multiple APIs!.
Extension
Free trialDocumentation
Overview MetricsDatabricks Executor MetricsConfiguration via TagsDatabricks Config Options
  • Product information
  • Release notes
Overview
This OneAgent Extension allows you to collect metrics from your embedded Ganglia instance, the Apache Spark APIs, and/or the Databricks API on your Databricks Cluster.
NOTE: Databricks Runtime v13+ no longer supports Ganglia, please use the Spark and Databricks API Options within the configuration.
This is intended for users who:
  • Have Databricks cluster(s) they would like to monitor job status' and other important job and cluster level metrics
  • Look to analyze uptime and autoscaling issues of your Databricks Cluster(s)
This enables you to:
  • Monitor both job, cluster and infrastructure metrics
  • Detect long upscaling times
  • Detect and filter Driver and Worker types
Get started
For more information on the installation and configuration, please see Databricks extension in the Dynatrace Documentation.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Application Countdatabricks.spark.application_count.gaugeNumber of apps running databricksCount
Streaming Batch Durationdatabricks.spark.streaming.statistics.batch_durationTime interval configured for each streaming batchMilliSecond
Streaming Receiversdatabricks.spark.streaming.statistics.num_receiversTotal number of receivers configured for the streaming jobCount
Streaming Active Receiversdatabricks.spark.streaming.statistics.num_active_receiversNumber of receivers actively ingesting dataCount
Streaming Inactive Receiversdatabricks.spark.streaming.statistics.num_inactive_receiversNumber of receivers that are currently inactiveCount
Streaming Completed Batchesdatabricks.spark.streaming.statistics.num_total_completed_batches.countTotal number of batches that have been fully processedCount
Streaming Retained Completed Batchesdatabricks.spark.streaming.statistics.num_retained_completed_batches.countNumber of completed batches retained in memory for monitoring or debuggingUnspecified
Streaming Active Batchesdatabricks.spark.streaming.statistics.num_active_batchesNumber of streaming batches currently being processedCount
Streaming Processed Recordsdatabricks.spark.streaming.statistics.num_processed_records.countTotal number of records processed across all batchesCount
Streaming Received Recordsdatabricks.spark.streaming.statistics.num_received_records.countTotal number of records received from all sourcesCount
Streaming Avg Input Ratedatabricks.spark.streaming.statistics.avg_input_rateAverage number of records received per second across batchesByte
Streaming Avg Scheduling Delaydatabricks.spark.streaming.statistics.avg_scheduling_delayAverage delay between batch creation and start of processingMilliSecond
Streaming Avg Processing Timedatabricks.spark.streaming.statistics.avg_processing_timeAverage time taken to process each batchMilliSecond
Streaming Avg Total Delaydatabricks.spark.streaming.statistics.avg_total_delayAverage total delay from data ingestion to processing completionMilliSecond
RDD Countdatabricks.spark.rdd_count.gaugeTotal number of Resilient Distributed Datasets currently tracked by the Spark applicationCount
RDD Partitionsdatabricks.spark.rdd.num_partitionsTotal number of partitions across all Resilient Distributed DatasetsCount
RDD Cached Partitionsdatabricks.spark.rdd.num_cached_partitionsNumber of Resilient Distributed Dataset partitions currently cached in memory or diskCount
RDD Memory Useddatabricks.spark.rdd.memory_usedAmount of memory used to store Resilient Distributed Dataset dataByte
RDD Disk Useddatabricks.spark.rdd.disk_usedAmount of disk space used to store Resilient Distributed Dataset dataByte
Databricks Cluster Upsizing Timedatabricks.cluster.upsizing_timeTime spent upsizing clusterMilliSecond
Executor RDD Blocksdatabricks.spark.executor.rdd_blocksNumber of Resilient Distributed Dataset blocks stored in memory or disk by the executorCount
Executor Memory Useddatabricks.spark.executor.memory_usedThe amount of memory currently used by the executor for execution and storage tasksByte
Executor Disk Useddatabricks.spark.executor.disk_usedDisk used by the Spark executorByte
Executor Active Tasksdatabricks.spark.executor.active_tasksTotal number of tasks that are currently executing on the specified executor within the Databricks ClusterCount
Executor Failed Tasksdatabricks.spark.executor.failed_tasksNumber of failed tasks on the Spark executorCount
Executor Completed Tasksdatabricks.spark.executor.completed_tasksNumber of completed tasks on the Spark ApplicationCount
Executor Total Tasksdatabricks.spark.executor.total_tasksTotal number of tasks executed by the executorCount
Executor Durationdatabricks.spark.executor.total_duration.countTime taken by Spark executor to complete a taskMilliSecond
Executor Input Bytesdatabricks.spark.executor.total_input_bytes.countTotal number of Bytes read by a Spark task from its input sourceByte
Executor Shuffle Readdatabricks.spark.executor.total_shuffle_read.countTotal data read by the executor during shuffle operations (from other executors)Byte
Executor Shuffle Writedatabricks.spark.executor.total_shuffle_write.countTotal data written by the executor during shuffle operations (to other executors)Byte
Executor Max Memorydatabricks.spark.executor.max_memoryThe maximum amount of memory allocated to the executor by SparkByte
Executor Alive Countdatabricks.spark.executor.alive_count.gaugeNumber of tasks that are currently running on the Databricks ClusterCount
Executor Dead Countdatabricks.spark.executor.dead_count.gaugeNumber of dead tasks on the Spark applicationCount
CPU User %databricks.hardware.cpu.usrPercentage of CPUs time spent on User processesPercent
CPU Nice %databricks.hardware.cpu.nicePercentage of CPU time used by processes that have a positive niceness, meaning a lower priority than other tasksPercent
CPU System %databricks.hardware.cpu.sysPercentage of CPUs time spent on System processesPercent
CPU IOWait %databricks.hardware.cpu.iowaitPercentage of time CPU spends idle while waiting for I/O operations to completePercent
CPU IRQ %databricks.hardware.cpu.irqInterrupt Request Percentage, Proportion of CPU time spent handling hardware interrupts requestsPercent
CPU Steal %databricks.hardware.cpu.stealPercentage of time a virtual CPU waits for physical CPU while hypervisor is servicing another virtual processorPercent
CPU Idle %databricks.hardware.cpu.idlePercentage of CPU idlingPercent
Memory Useddatabricks.hardware.mem.usedTotal memory currently in use, including buffers and cacheByte
Memory Totaldatabricks.hardware.mem.totalTotal physical memory installed on the systemKiloByte
Memory Freedatabricks.hardware.mem.freePortion of memory that is completely unused and availableKiloByte
Memory Buff/Cachedatabricks.hardware.mem.buff_cacheMemory used by the system for buffers and cache to improve performanceKiloByte
Memory Shareddatabricks.hardware.mem.sharedMemory shared between processesKiloByte
Memory Availabledatabricks.hardware.mem.availableTotal amount of memory available for use by the systemKiloByte
Job Statusdatabricks.spark.job.statusCurrent status of the job (e.g., running, succeeded, failed)Unspecified
Job Durationdatabricks.spark.job.durationTotal time taken by the job from start to finishSecond
Job Total Tasksdatabricks.spark.job.total_tasksTotal number of tasks planned for the jobCount
Job Active Tasksdatabricks.spark.job.active_tasksNumber of tasks currently executing within the jobCount
Job Skipped Tasksdatabricks.spark.job.skipped_tasksNumber of tasks skipped due to earlier failures or optimizationsCount
Job Failed Tasksdatabricks.spark.job.failed_tasksNumber of tasks that failed during job executionCount
Job Completed Tasksdatabricks.spark.job.completed_tasksTotal number of tasks that have successfully completedCount
Job Active Stagesdatabricks.spark.job.active_stagesNumber of stages currently running in a Spark jobCount
Job Completed Stagesdatabricks.spark.job.completed_stagesTotal number of stages that have successfully completedCount
Job Skipped Stagesdatabricks.spark.job.skipped_stagesNumber of stages skipped due to earlier failures or optimizationsCount
Job Failed Stagesdatabricks.spark.job.failed_stagesNumber of stages that failed during job executionUnspecified
Job Countdatabricks.spark.job_count.gaugeTotal number of Spark jobs submittedCount
Stage Active Tasksdatabricks.spark.job.stage.num_active_tasksNumber of tasks currently running in the stageCount
Stage Completed Tasksdatabricks.spark.job.stage.num_complete_tasksNumber of tasks that have successfully completed in the stageCount
Stage Failed Tasksdatabricks.spark.job.stage.num_failed_tasksNumber of tasks that failed during execution in the stageCount
Stage Killed Tasksdatabricks.spark.job.stage.num_killed_tasksNumber of tasks that were killed (e.g., due to job cancellation or speculative execution)Count
Stage Executor Run Timedatabricks.spark.job.stage.executor_run_timeTotal time executors spent running tasks in the stageMilliSecond
Stage Input Bytesdatabricks.spark.job.stage.input_bytesTotal number of bytes read from input sources in the stageByte
Stage Input Recordsdatabricks.spark.job.stage.input_recordsTotal number of records read from input sources in the stageCount
Stage Output Bytesdatabricks.spark.job.stage.output_bytesTotal number of bytes written to output destinations in the stageByte
Stage Output Recordsdatabricks.spark.job.stage.output_recordsTotal number of records written to output destinations in the stageCount
Stage Shuffle Read Bytesdatabricks.spark.job.stage.shuffle_read_bytesTotal bytes read from other executors during shuffle operationsByte
Stage Shuffle Read Recordsdatabricks.spark.job.stage.shuffle_read_recordsTotal records read from other executors during shuffle operationsCount
Stage Shuffle Write Bytesdatabricks.spark.job.stage.shuffle_write_bytesTotal bytes written to other executors during shuffle operationsByte
Stage Shuffle Write Recordsdatabricks.spark.job.stage.shuffle_write_recordsTotal records written to other executors during shuffle operationsCount
Stage Memory Bytes Spilleddatabricks.spark.job.stage.memory_bytes_spilledAmount of data spilled to memory due to shuffle or aggregation operationsByte
Stage Disk Bytes Spilleddatabricks.spark.job.stage.disk_bytes_spilledAmount of data spilled to disk due to insufficient memory during task executionByte
Related to Databricks
Databricks Workspace logo
Remotely monitor your Databricks Workspaces!.
Full version history
ReleaseDate
Update the certifi dependency to address CVE-2026-111943
✨ New in this version:
  • This extension is now using all rich visualization features of Grail within Infrastructure & Operations App
  • The ready-made dashboards shipped with this extension now reference Smartscape on Grail nodes.
⚠️ This version requires Dynatrace version 1.343 or higher.
1.7.5
  • Updated error handling for Databricks Cluster Events API Call
  • Updated how the extension handles monotonic metric ingestion
1.7.3
  • Updated error handling and logging
What's new:
  • Added feature set metadata for recommended metrics
What's new:
  • Updated how Spark Traces are created
  • Added configuration options for how traces are ingested
Fixes:
  • Security updates
v1.6.5
  • Vulnerability fix for protobuf:6.33.4 (CVE-2026-0994)
1.6.2
  • Added descriptions to all metrics
  • Added databricks.hardware.mem.shared and databricks.hardware.mem.available to Hardware Metrics feature set, and databricks.spark.job_count.gauge to Spark Job Metrics feature set
1.6.1
  • Improved error handling (Dynatrace Error Codes) and Endpoint Statuses.
  • NOTE : This version requires OneAgent version 1.313 or newer.
1.6.0
  • DXS-3317
    • Add Host Injections for Platform Screens
    • Add new Platform Dashboard
v1.5.6
  • DXS-3250
    • Update Library Versions
v1.5.5
  • New Feature Set - Hardware Metrics
  • DXS-1597
    • Adds new configuration option - Aggregate Dimensions for Spark API Metrics
  • Updates to how Spark API is called
  • UA Screen updates
  • DXS-1920
    • Adds retry logic to determine driver node during start up of extension
  • Adds ability to ingest Spark Jobs as traces
    • NOTE : Depending on the number of Spark Jobs, this could be a significant amount of traces and could increase licensing costs.
  • Adds ability to ingest Spark Config as Log Messages
##v1.02
  • Initial Release of Extensions 2.0 version of Databricks Extension
  • Offers Support for Ganglia APIs (Legacy), Apache Spark APIs, and Databricks APIs
Dynatrace Hub
All (958)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
