Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Gremlin Reliability ManagementGremlin Reliability Management
View the status of Gremlin experiments and their impact on your applications.
Technology by Community
Frontend service showing 10 recent Gremlin test runs across CPU, Memory, Latency, and Certificate Expiry scenarios.Cart service showing three closed Dynatrace incidents — two slowdowns and a ~80% failure rate spike — correlated with Gremlin testsFrontend service showing 10 recent Gremlin test runs across CPU, Memory, Latency, and Certificate Expiry scenarios.Frontend service failing latency health check with AI-generated circuit-breaker and fallback remediation suggestions.Email service metrics showing response time variability up to ~250ms across fault injection runs with 0% failure rate.Frontend service response time spiking to ~140,000ms during active fault injection, with failure rate peaking near 20%.
  • Product information
Overview
Get a real time view of your Gremlin Experiments natively in Dynatrace and understand the business impact of experiments.
Manage reliability the way you manage everything else - with data
Gremlin delivers a standardized, scalable way to measure, manage, and improve the reliability of your services. Through automated testing, risk detection, and dependency mapping, Gremlin shows you what will break and proves your fixes are working. Building on Gremlin’s native integration with Dynatrace, Gremlin Reliability Management brings the ability to proactively manage your reliability into the observability platform you’re already using to track your system’s metrics.
Confidence in every service
Reliability scores from dependency mapping and failure testing show what's resilient and where the risk is.
  • Reliability scores tracked over time
  • Failure tests validate resilience mechanisms
  • Detects drift and hidden vulnerabilities
Standards you can prove
Standardized test suites and benchmarking set the bar, remediation guidance closes the gap, backed by Gremlin's work at Amazon and Netflix.
  • Test suites define and enforce standards, with cross-team benchmarking
  • Targeted remediation guidance with continuous score tracking
  • Works across bare metal, on-prem, multi-cloud, serverless
Use cases
  • Continuous reliability testing: Run automated, standardized resilience test suites across all services. Produce reliability scores. Track trends. Replace one-off chaos experiments with systematic measurement.
  • Disaster recovery validation: Simulate zone outages, region evacuations, and catastrophic failures from a central console. Turn weeks of manual preparation into repeatable, auditable exercises at a fraction of the lift.
  • Risk detection & dependency mapping: Passively detect configuration drift, status errors, and deviations from standards. Map hidden dependencies. Surface risks without requiring active tests.
  • Reliability reporting & governance: Give executives data-backed evidence that reliability investments are working. Benchmark across teams, track improvement over time, and make reliability fundable with real metrics.
Get started
Gremlin Reliability Management is available as a Dynatrace app to all customers upon request.
To request access, please send us a short message to community-apps@dynatrace.com stating you would like access to Gremlin Reliability Management, the name of the account, as well as the tenant ID. Once we have verified your request, we will provide you with all relevant information on how to add it to your environment. For further install and configuration instructions please have a look at the documentation.
Details
Disclaimer: Gremlin Reliability Management is a community-supported project and is not officially supported by Dynatrace. If you need help, please contact the team via GitHub.
Community
By the community
Dynatrace community
Copy to clipboard
Related to Gremlin Reliability Management
Gremlin logo
Gremlin
Gremlin helps you find and fix reliability risks before they become outages.
Dynatrace Hub
All (954)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
