Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Cloud SRE AgentsCloud SRE Agents
Cloud SRE Agents
Cloud SRE Agents
Orchestrate cloud-native AI agents for autonomous incident resolution.
Technology by Community
Documentation
The Overview tab's interactive graph, showing a live view on problems and its activity status grouped by related SRE agent.Activity tab showing an expanded investigation card with agent findings and rating control.Problem detected by Dynatrace Intelligence, investigated and remediated by AWS DevOps Agent (see documentation on the right)Perform historical investigations with the replay functionalityThe Statistics tab showing key metrics and per-agent insights across a selected time range.Setup wizard guiding admin through the initial setup process
  • Product information
Overview
Cloud SRE Agents connects Dynatrace Intelligence to the hyperscaler SRE agents running in your cloud environment. When Dynatrace detects a problem, Cloud SRE Agents evaluates your configured Interaction Profiles, dispatches the problem to matching agents in parallel, and writes their findings back to the Dynatrace problem record. For AWS and Azure, the response includes a suggested remediation path alongside the investigation findings.
The app supports all three hyperscaler SRE agents:
  • AWS DevOps Agent: investigation and remediation in AWS
  • Azure SRE Agent: investigation and remediation in Azure
  • Google Gemini Cloud Assist: incident analysis across GCP
Interaction Profiles define which problems get dispatched to which agents. Each profile combines routing conditions with one or more agent assignments. Profiles can include a monthly duration budget per agent; when the budget is reached, dispatch stops or logs a warning depending on your configuration. The Test mode lets you validate a profile against recent problems before any live dispatch occurs.
Use cases
  • Automatic multi-cloud routing: direct each problem to the agent that owns the cloud it touches, based on account ID, subscription, project, or resource tag, without manual triage at 2 a.m.
  • Budget governance: set a monthly duration budget per agent; once the cap is reached, new dispatches stop or log a warning, keeping cloud-side spend inside the boundaries you set.
  • Tiered investigation by problem type: dispatch agents only for the problem categories that justify it (availability, error, resource contention) and narrow by entity type to focus autonomous work on the infrastructure tiers that matter most.
  • Audit trail for every autonomous action: the Activity tab records every investigation and mitigation as an expandable timeline card with full agent findings, evidence, and any action taken or recommended.
  • ROI visibility: the Statistics tab surfaces problems handled, mitigation counts, and satisfaction scores by agent, turning autonomous operations into a number you can show to a leadership team.
Get started
Note: To install the app via Dynatrace Hub, you first need to subscribe your tenant to a Hub subscription. Click here to learn more.
Once you are done and have successfully added the app to your tenant:
  1. Set up (3 min): open the Setup tab and follow the guided flow to install the required IAM policy, service user, and three orchestration workflows.
  2. Connect one agent (1 min): in Configuration, add an agent of any cloud type, paste the endpoint URL and credential from your cloud provider's console, and save.
  3. Add one profile (1 min): create an Interaction Profile with one global filter (for example, Has AWS Resources), assign the agent, and enable the profile.
  4. Validate (30 sec): open Trigger Investigation, pick a recent problem, and run Test (Dry Run). If the profile matches as expected, uncheck Dry Run and dispatch live.
The next matching problem dispatches automatically, and findings appear on the Dynatrace problem screen as each agent completes.
Details
Disclaimer: Cloud SRE Agents is a community-supported project and is not officially supported by Dynatrace. If you need help, please contact the team via GitHub.
Community
Documentation
By the community
Dynatrace community
Copy to clipboard
Related to Cloud SRE Agents
AWS DevOps Agent logo
AWS DevOps Agent
Resolve issues autonomously with Dynatrace and the AWS DevOps Agent.
Azure SRE Agent logo
Azure SRE Agent
Unlock autonomous cloud operations fueled by Dynatrace insights.
Dynatrace Intelligence logo
Action based on answers with deterministic insights and agentic operations.
Dynatrace Hub
All (955)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
