Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
AWS Security HubAWS Security Hub
AWS Security Hub
AWS Security Hub
Ingest AWS Security Hub vulnerabilities, detections, and compliance findings.
App
Free trialDocumentation
Sample generic security findings dashboard.Sample vulnerability findings dashboard.Sample security products coverage dashboard.Sample workflow.
  • Product information
  • Release notes
Overview
Dynatrace integrates with AWS Security Hub to enable visibility, orchestration, and prioritization of security findings over cross-tools and environments.
Capabilities:
  • Single pane of glass: Ingest security findings from AWS Security Hub into Dynatrace (powered by OpenPipeline™)
  • Unified analysis: Dynatrace transforms and maps the security findings to a unified format (powered by Dynatrace Semantic Dictionary)
  • Findings operationalization: Prioritize, visualize, and automate security findings with runtime context
  • Unveil blind spots: Discover and eliminate coverage gaps in your Software Development Lifecycle (SDLC)
Use cases
  • Overview: Visualize and report your current security posture and trends around security findings across environments with Dashboards.
  • Prioritization: Analyze and prioritize security findings across multiple tools and products uniformly with Notebooks.
  • Automation: Create notifications and tickets for critical security findings with Workflows.
  • Investigation: Use security findings as an additional dimension for threat hunting and incident forensics using Security Investigator.
Get started
To ingest AWS Security Hub security findings into Dynatrace, you need to set up a forwarding rule in Amazon EventBridge.
For instructions, go to Ingest AWS Security Hub security findings.
Details
This integration app delivers several sample dashboards and workflows to help you
  • Visualize security findings (dashboard)
  • Summarize product security coverage (dashboard)
  • Send email notification for critical security findings (workflow)
Compatibility information
AWS Security Finding Format.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to AWS Security Hub
Workflows logo
Workflows
Dashboards logo
Dashboards
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Full version history
ReleaseDate
2.4.5
  • Security Updates
  • Dashboard Updates
2.4.4
  • Security Updates
  • Dashboard Updates
2.4.3
Patch Changes
  • Security and other dependency updates.
2.4.1
  • Security Updates
  • Connection filter now only filters for the connection's name.
2.3.1
  • Added support for Security Hub (OCSF) events
    • Updated connection creation workflow with new Cloud Formation Template
  • Rename existing support to Security Hub CSPM
  • Updated included Ready-Made Dashboards
2.1.0
  • Update Cloud Formation Template with changes to the Lambda function
2.0.2
Patch Changes
  • Update included Dashboards and Workflow
2.0.0
Major Changes
  • Update app to fetch from new security.events table
1.1.3
Patch Changes
  • f088bd9: Update dependency that patches a vulnerable component
1.1.1
Patch Changes
  • 73d0f34: Fix security finding dashboard filter
1.1.0
Minor Changes
  • 4b84290: Migrate app to headless
1.1.0
Minor Changes
  • Connection management and monitoring are now available in Settings.
1.0.1
Patch Changes
  • Fix link to CloudFormation template
1.0.0 - Initial Release
  • Step-by-step user onboarding with CLI commands and CloudFormation template for download.
  • Ready-made documents with sample dashboards and workflows
Dynatrace Hub
All (886)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
