Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Aruba AOSAruba AOScoming soon
Aruba AOS
Aruba AOS
coming soon
Monitor the health and network interface performance of your Aruba AOS switches.
Extension
Documentation
Get an overview of your Aruba AOS switches using the pre-packaged dashboard.Track CPU and memory utilization for each Aruba AOS device.
  • Product information
Overview
The Aruba AOS extension provides monitoring of Aruba AOS switches using SNMP. It gives you visibility into device health and network interface performance, so you can view your switching infrastructure alongside the rest of your environment in Dynatrace.
Track the CPU and memory utilization and the uptime of each switch, and monitor the traffic, errors, and discards of every network interface.
Use cases
  • Monitor CPU and memory utilization of Aruba AOS switches to detect resource pressure early.
  • Track device uptime and identify switches that have recently restarted.
  • Monitor interface throughput, errors, and packet discards to find congested or faulty links.
  • Identify interfaces that are administratively or operationally down.
  • Focus monitoring on selected interfaces by filtering on name, administrative status, or operational status.
Get started
For more information on the installation and configuration, please see Aruba AOS extension in the Dynatrace Documentation.
Details
Compatibility information
Supported devices
  • Aruba AOS switches (formerly HP ProCurve) with SNMP v2c or v3 support.
Supported monitoring approach
  • Remote monitoring via Dynatrace ActiveGate using Extensions Framework 2.0 SNMP data source.
Configuration
  • Configurable polling intervals for device metrics and network interface metrics independently.
  • Interface filtering by name, administrative status, and operational status.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Dynatrace Hub
All (953)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
