Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Amazon GuardDutyAmazon GuardDuty
Amazon GuardDuty
Amazon GuardDuty
Ingest Amazon GuardDuty detection findings.
Technology
Free trialDocumentation
Security findings sample dashboard.Product coverage sample dashboard.Email notification sample workflow.
  • Product information
Overview
Dynatrace integrates with Amazon GuardDuty to enable visibility, orchestration, and prioritization of security findings across tools and environments.
  • Single pane of glass: Ingest security findings from Amazon GuardDuty into Dynatrace (powered by OpenPipeline™).
  • Unified analysis: Dynatrace transforms and maps the security findings to a unified format (powered by Dynatrace Semantic Dictionary).
  • Findings operationalization: Prioritize, visualize, and automate security findings with runtime context.
  • Unveil blind spots: Discover and eliminate coverage gaps in your security product deployment and assessments.
Use cases
  • Overview: Visualize and report security detections and trends across tools and environments with Dashboards.
  • Prioritization: Analyze and prioritize security findings uniformly with Notebooks.
  • Automation: Automate the orchestration of the critical security findings by creating notifications and tickets using Workflows.
  • Investigation: Use security findings as an additional dimension for threat hunting and incident forensics using Security Investigator.
Get started
For setup instructions, go to Ingest Amazon GuardDuty security findings.
Details
This integration delivers several sample dashboards and workflows to help you
  • Visualize vulnerability findings insights
  • Summarize product security coverage
  • Send email notifications for critical findings
Compatibility information
AWS Security Finding Format.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to Amazon GuardDuty
Dashboards logo
Dashboards
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Security Operations logo
Security Operations
Ingest and operationalize security data.
Workflows logo
Workflows
Dynatrace Hub
All (955)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
