Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Timedrift MonitoringTimedrift Monitoring
Monitor your host's NTP/Chrony Time Offset!
Extension
Free trialDocumentation
  • Product information
  • Release notes
Overview
Timedrift extension measures time deviation on the host compared to the time source and reports time offset, which can be later used to alert on hosts going out of sync.
Use cases
Network Time Protocol is used to synchronize time across a network of computers. Time synchronization is vital to many distributed systems. You can use Dynatrace to monitor the time offset of your hosts and chart it on your dashboards.
Because Dynatrace detects host time drift, you can also track NTP synchronization failures. If your host isn't synced to any NTP server, you can manually add an NTP server of your choice.
The extension also supports hosts that use chrony. If autoconfiguration is used, the extension will read the /etc/chrony.conf file to find either pool or server configurations. It will also follow any configured confdir and sourcedir configurations.
Dynatrace won't synchronize time on your host but will measure the offset.
Get started
For more information on the installation and configuration, please see Timedrift Monitoring extension in the Dynatrace Documentation.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
1.1.9
What's New:
  • Added keyword key value pairs to extension
Improved in this version
  • Changed Entity selector for Host Screen
v1.1.7
  • Update to fix validation when manual server configuration is present
  • Add Platform Host Screen Injection
v1.1.5
  • DXS-2080
    • Update to fix timestamp issue with metric datapoints
v1.1.4
  • Update SDK to v1.2.10 to help with potential keep-alive issue
v1.1.3
  • Fixes issue when manually specifying the NTP version for a time server
v1.1.2
  • Update to show metric on Host Screen
  • Switch to dt-extensions-sdk
  • v1.1.1
    • Extension now will report errors as log message and not metric
    • Updates to wording for configuration
No release notes
Dynatrace Hub
All (882)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
