Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Text ProcessingText Processing
Text Processing
Text Processing
Edit different types of files, for instance JSON/YAML
App
Free trialDocumentation
Edit text in JSON or YAML files to set values or add properties.Address easily required key-value pairs, read and adjust the value, or a complete structure.Easily adopt scaling parameters in your manifest, following a GitOps-based approach for remediation.
  • Product information
  • Release notes
Overview
This text processing app empowers users to seamlessly modify parameters in YAML and JSON files within Dynatrace workflows.
Whether updating configuration values, toggling flags, or restructuring arrays, users can make precise changes without worrying about formatting or syntax. It’s designed for simplicity, speed, and reliability—ideal for dynamic infrastructure updates based on Dynatrace signals and GitOps-based remediation scenarios.
Use cases
  • Preventive GitOps-based remediation: Adjust scaling parameters in your state repository to prevent bottlenecks before a problem occurs
  • CI/CD Pipelines: Dynamically adjust deployment configs (e.g., replicas, image tags)
  • Feature Flags: Toggle boolean values across environments by adjusting manifests
Get started
Text Processing app is already pre-installed on all tenants.
Details
This action allows users to programmatically modify structured text files—specifically YAML and JSON—within Dynatrace workflows.
Main capabilities
  • Reads values from existing YAML or JSON files
  • Locates specific keys, paths, or values
  • Applies changes such as updates and additions
  • Outputs a clean, valid file with the modifications
Common Operations for yaml- and json-files
  • Read a value
  • Update a value
  • Add a new key/value pair
  • Modify a list or add an item to an array
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
  • Added workflow template for a get and set yaml showcase
  • Added workflow template for a package version sync
  • Updated dependencies
  • Updated internationalization
  • Released Text Processing App 1.0.1
Dynatrace Hub
All (884)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
