Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Storage ManagementStorage Management
Storage Management
Storage Management
Organize your data and define retention times with custom Grail buckets.
App
Free trialDocumentation
List your existing built-in and custom Grail buckets for different data types, such as logs, systems events, or business events.Easily create new buckets, and edit or remove existing ones.Stay informed by customizing your bucket view.Search buckets by name.Filter buckets by type.
  • Product information
  • Release notes
Overview
Storage management app is the easiest way to manage Grail buckets in your Dynatrace environments. Grail buckets are the core building blocks of the Grail data model. All your records in Grail are stored in buckets, which exists for logs, events, metrics, business events etc. In addition to default buckets for your records, you can create and manage custom buckets.
Use cases
Use Storage Management app to create and manage custom buckets to:
  • Segment data per use case. Use buckets to segment high velocity data like synthetic logs or debug logs from other data, that is less frequent, like audit logs.
  • Set retention times for data. Per each custom bucket, you can pick a custom retention time for the data from 1 to 3657 days, which allows you to be very granular for how long you store data in Grail.
  • Manage access. You can set access policies which limit who can access data in which custom bucket in Grail.
  • Optimize performance and cost. By segmenting data into separate buckets, you can speed up your queries by only fetching data from a dedicated bucket.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Storage Management
Segments logo
Segments
Segments help to logically structure and conveniently filter observability data.
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Learn DQL logo
Learn DQL
Learn the Dynatrace Query Language (DQL) with hands-on interactive tutorials
More resources
Enhance data management with Grail: Ultimate guide to custom buckets and security policies
Read more
Full version history
ReleaseDate
  • Added tooltips on disabled buttons to provide more info
  • Enabled retention period update for user events and user sessions buckets
  • Enabled truncate for default_metrics bucket
  • Fixed validation for Included queries period field just when "Retain with Included Queries" options is selected
  • Added support for i18n
  • Adapted bucket deletion modal
  • Fixed sorting for iqRP column
  • Show includedRetentionLimitDays in Edit Mode for special buckets
1.41.0
Minor Changes
  • Add unsaved changes handling in case user navigates away from the app while having edited elements
  • Show user list of endpoints/pipelines which block bucket deletion
  • Add "Included query retention period" support for logs buckets
  • Improved UI of the table
  • Updated dependencies
  • Disabled Add-bucket button if user has no write permissions
  • Added more descriptive hint message
  • Improved compliance with GUIDE
  • Fixed bucket name validation pattern.
  • Dependencies updated
  • Added maxRetention info to create/edit modal
  • Fixed storage management intent to load data properly
  • App moved to Settings and only accessible from there
  • Implement intent-handling in order to be able to send filter queries via intent
  • Column state saved in the app-user-state
  • Disabled "Delete bucket" button for default buckets
  • Fixed minor things on the UI
  • Enabled editing for spans buckets when license is present
  • Allow editing display name for metrics buckets
  • Changed preselected columns
  • Added Storage Management to Settings
  • Added update functionality for metrics buckets
  • Fixed modal issue where it doesn't seem to reset properly after closing
  • Fixed missing toast issue in Settings
  • Added truncate option for buckets
  • Added record count and estimated uncompressed bytes
  • Changed error page for users with insufficient permission
  • Deleted side details
  • Removed side-menu and added dropdown for filtering buckets
  • Added filter bar
  • Update dependencies
  • Logo changed
  • Kinga's and Wojtek's review
  • Updated README.md and Testing.md to current status and skipped API tests in CI pipeline
  • Overrided ip package dependency
  • Fixed security audit
  • disabled Snyk until it's full integration
  • Fix lint
  • Refactor code
  • Fix storybook
  • Refactor
  • Created indivdually desgined error toast for every API response
  • Rebase
  • Ignore empty reports when listing them in the pipeline
  • Add and apply icon with 'new' label
  • remove redundant export statement
  • fix E2E tests
  • remove default E2E tests on every main build
  • Test E2E tests on CI
  • Fix E2E tests
  • Fix lint/typecheck
  • Add UI/UX corrections
  • fix: last bucket deletion did not cause list refresh
  • Fixed helm charts deployment
  • Fixed IOException with 'Agent version 4.13 or newer is required.' message
  • Update dockar tag of node-ecr image
  • Fixed fetching version from hardening
  • Fix pod configuration
  • Change command for fetching tags
  • Add Snyk configuration (org, team)
  • Adapt Snyk snippets for working Jenkins Pipeline
  • Fix lint
  • Refactor code
  • Fix storybook
  • Refactor
  • Rebase
  • fix E2E tests
  • Fix E2E tests
  • Move Snyk container to (templated) pipeline
  • fix E2E tests
  • Fix E2E tests
  • Security audit fix
  • Standarized helm chart
  • test: increase status wait time
  • e2e tests
  • Corrections from review of ui copies
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
