Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Red Hat AnsibleRed Hat Ansible
Red Hat Ansible
Red Hat Ansible
Integrate with Red Hat Ansible (EDA, AAC, AWX) to trigger job templates
App
Free trialDocumentation
Launch a job template in Red Hat Ansible Automation Controller, list job status or retry a job.The integration of Dynatrace workflows with Red Hat Event-Driven Ansible provides the highest flexibility to remediate detected problems or to mitigate security vulnerabilities by leveraging rulebooks to identify the correct playbook.
  • Product information
  • Release notes
Overview
Integrate your Dynatrace environment with the Red Hat Ansible Automation Platform or with AWX to trigger job templates based on your monitoring data or send events to Red Hat Event-Driven Ansible for highest flexibility to remediate detected problems or to mitigate security vulnerabilities.
Use cases
This enables you to:
  • Integrate workflows with Red Hat Event-Driven Ansible to remediate detected problems or to mitigate security vulnerabilities
  • Integrate workflows with Red Hat Ansible Automation Controller or AWX to trigger job templates
  • List job-status
  • Retry a failed job
Get started
Follow the instructions detailed in Dynatrace Documentation.
Ensure that you have installed Red Hat Ansible, that outbound connections are configured, and that the connection to the Automation Controller is authorized.
If your Red Hat Ansible Automation Platform is behind your firewall, configure EdgeConnect to tunnel the traffic securely.
Details
Red Hat Ansible enables users to model remediation processes within Dynatrace:
Define various incident triggers:
  • Use the power of DQL and leverage events to react to any problem, security incident, or attack to trigger a reconfiguration of your system
  • Use Biz-Events as a trigger to react on extended events like a failed release validation, certain logs messages, or external system events
  • Define a scheduler for periodic tasks
Flexible Remediation processes
  • Send events to Red Hat Event-Driven Ansible for the highest flexibility to remediate problems or vulnerabilities with rulebooks
  • Trigger any job template within a Dynatrace workflow
  • Hand over extra vars to fine-tune any playbook execution
  • List job status or retry a job
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Red Hat Ansible
Workflows logo
Workflows
Full version history
ReleaseDate
This release improves the stability and performance of the Red Hat Ansible app.
This release improves the stability of the Red Hat Ansible app.
This maintenance release is bundled with some minor quality of life improvements.
Improved app stability and performance through updated dependencies
  • Updated dependencies
  • Memorize the event stream setting between creating connections
  • add support for Red Hat event streams
2.0.2
Patch Changes
2.0.1
Patch Changes
  • Improved visual fidelity of connection management in modals
2.0.0
Major changes
  • Migrated to owner based access control (ACL)
2.0.0
Major changes
1.1.1
Patch Changes
1.1.0
Minor Changes
  • App is headless again. To control your connections, please use the Settings app.
Patch Changes
  • Add grouping of input fields in workflow widget.
1.1.0
Minor Changes
Patch Changes
1.0.1
Patch Changes
  • Change: "for Workflows" was removed from the app title
  • Chore: Increase URL limit to 255 characters
  • Fix: Launch job template did not wait until the job finished
1.0.0
This marks the first initial release of Red Hat Ansible for Workflows.
1.0.0
0.3.2
Patch Changes
  • Fix: eventData is now more resilient to different input types
  • Fix: Ensure that there is a default widget state to avoid data validation issues
0.3.1
Patch Changes
0.3.0
  • Breaking: connections have been changed from an ordered list to an unordered list. This was done in preparation for better ACL support. However, inserting connections via API or Monaco using insertAfter will no longer be possible.
0.3.1
Patch Changes
0.3.0
0.3.0
0.2.4
Patch Changes
0.2.3
Patch Changes
  • Fix typo in display name of settings schema
0.2.2
Patch Changes
  • Update app icon
  • Ensure proper handling of trailing slashes in API
  • Add sample results for all actions
  • Fix a typo in description
0.2.1
Patch Changes
  • Update dependencies
0.2.0
Minor Changes
  • Improve support for multi-line extraVars in Launch job template action
Patch Changes
  • Update app description and value statement
0.2.3
Patch Changes
  • ce0a373: fix typo in display name of settings schema
0.2.2
Patch Changes
  • 0d98026: Update app icon
  • b5c1248: Ensure proper handling of trailing slashes in API
  • 918d4a1: Add sample results for all actions
  • 6797e83: Fixed a typo in description
0.2.1
Patch Changes
0.2.0
Minor Changes
  • 19cf5a6: Improve support for multi-line extraVars in Launch job template action
Patch Changes
  • 041e0b9: Update dependencies
  • 11f148e: Update app description and value statement
0.2.1
Patch Changes
0.2.0
Minor Changes
Patch Changes
0.1.4
Patch Changes
0.1.3
Patch Changes
0.1.2
Patch Changes
  • 8f38470: Update dependencies
0.1.1
Patch Changes
  • 6e7a75d: Force resubmission of API token before saving connection configuration.
0.1.0
Minor Changes
  • da91c19: Introduced new actions launch-job-template, list-job-status and relaunch-job
No release notes
Dynatrace Hub
All (889)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
