Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
PostgreSQLPostgreSQL
PostgreSQL
PostgreSQL
Monitor your Postgres performance via our new EF2.0 extension framework.
Extension
Free trialDocumentation
Get fast, actionable insights into the health of your databases.Analyze top SQL statements and deep dive into your most impactful queries.Get detailed recommendations on your Postgres configuration parameters.Link database infrastructure monitoring to client-side service-level entities.
  • Product information
  • Release notes
Overview
Our PostgreSQL database monitoring is based on a remote monitoring approach implemented as a Dynatrace ActiveGate SQL extension. The extension queries databases for key performance and health metrics, extending your visibility, and allowing Dynatrace Intelligence to provide anomaly detection and problem analysis.
Use cases
  • Understand the impact of resource shortages, locks, slow statements or other database issues have on your application by observing the database server itself.
  • Track health and performance of your PostgreSQL servers
Get started
For more information on the installation and configuration, please see PostgreSQL extension in the Dynatrace Documentation.
Details
Compatibility information
Compatible with all currently maintained Postgres versions.
The extension is designed to work with PostgreSQL version 11 and later.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Instance uptimepostgres.uptimeTime since the instance has been startedSecond
I/O readspostgres.io.reads.countNumber of read operations as reported by pg_stat_io.Count
I/O read timepostgres.io.read_time.countTime spent waiting for read operations as reported by pg_stat_io.MilliSecond
I/O writespostgres.io.writes.countNumber of write operations as reported by pg_stat_io.Count
I/O write timepostgres.io.write_time.countTime spent waiting for write operations as reported by pg_stat_io.MilliSecond
I/O writebackspostgres.io.writebacks.countNumber of units of size BLCKSZ (typically 8kB) which the process requested the kernel write out to permanent storage as reported by pg_stat_io.Count
I/O writeback timepostgres.io.writeback_time.countTime spent waiting for writeback operations as reported by pg_stat_io.MilliSecond
I/O extendspostgres.io.extends.countNumber of relation extend operations as reported by pg_stat_io.Count
I/O extend timepostgres.io.extend_time.countTime spent waiting for extend operations as reported by pg_stat_io.MilliSecond
I/O hitspostgres.io.hits.countThe number of times a desired block was found in a shared buffer as reported by pg_stat_io.Count
I/O evictionspostgres.io.evictions.countNumber of times a block has been written out from a shared or local buffer in order to make it available for another use as reported by pg_stat_io.Count
I/O reusespostgres.io.reuses.countThe number of times an existing buffer in a size-limited ring buffer outside of shared buffers was reused as part of an I/O operation as reported by pg_stat_io.Count
I/O fsyncspostgres.io.fsyncs.countNumber of fsync calls as reported by pg_stat_io.Count
I/O fsync timepostgres.io.fsync_time.countTime spent waiting for fsync operations as reported by pg_stat_io.MilliSecond
I/O read bytespostgres.io.read_bytes.countThe total size of read operations as reported by pg_stat_io.Byte
I/O write bytespostgres.io.write_bytes.countThe total size of write operations as reported by pg_stat_io.Byte
I/O extend bytespostgres.io.extend_bytes.countThe total size of relation extend operations as reported by pg_stat_io.Byte
Latest transaction XID agepostgres.xid_ageDifference between the current transaction's XID and datfrozenxid. If this value exceeds 2^31, this can cause a database crash due to transaction ID wraparound.Count
Number of backendspostgres.numbackendsNumber of backends currently connected to this databaseCount
Committed transactionspostgres.xact_commit.countNumber of transactions in this database that have been committedCount
Rolled back transactionspostgres.xact_rollback.countNumber of transactions in this database that have been rolled backCount
Block read from diskpostgres.blks_read.countNumber of disk blocks read in this databaseCount
Blocks found in buffer cachepostgres.blks_hit.countNumber of times disk blocks were found already in the buffer cache, so that a read was not necessaryCount
Live rows returnedpostgres.tup_returned.countNumber of live rows fetched by sequential scans and index entries returned by index scans in this databaseCount
Live rows fetched by index scanspostgres.tup_fetched.countNumber of live rows fetched by index scans in this databaseCount
Rows insertedpostgres.tup_inserted.countNumber of rows inserted by queries in this databaseCount
Rows updatedpostgres.tup_updated.countNumber of rows updated by queries in this databaseCount
Rows deletedpostgres.tup_deleted.countNumber of rows deleted by queries in this databaseCount
Queries canceled due to conflictpostgres.conflicts.countNumber of queries canceled due to conflicts with recovery in this databaseCount
Temporary files createdpostgres.temp_files.countNumber of temporary files created by queries in this databaseCount
Data written to temporary filespostgres.temp_bytes.countTotal amount of data written to temporary files by queries in this databaseByte
Deadlockspostgres.deadlocks.countNumber of deadlocks detected in this databaseCount
Data file blocks reading timepostgres.blk_read_time.countTime spent reading data file blocks by backends in this databaseMilliSecond
Data file blocks writing timepostgres.blk_write_time.countTime spent writing data file blocks by backends in this databaseMilliSecond
Database Sizepostgres.db_sizeSize of the database in bytesByte
Data page checksum failurespostgres.checksum_failures.countNumber of data page checksum failures detected in this database. Only available if data checksums are enabled.Count
Time spent by sessionspostgres.session_time.countTime spent by database sessions in this databaseMilliSecond
Time spent executing SQL statementspostgres.active_time.countTime spent executing SQL statements in this databaseMilliSecond
Time spent idlingpostgres.idle_in_transaction_time.countTime spent idling while in a transaction in this databaseMilliSecond
Established sessionspostgres.sessions.countTotal number of sessions establishedCount
Abandoned sessionspostgres.sessions_abandoned.countNumber of database sessions to this database that were terminated because connection to the client was lostCount
Fatal error terminated sessionspostgres.sessions_fatal.countNumber of database sessions to this database that were terminated by fatal errorsCount
Killed sessionspostgres.sessions_killed.countNumber of database sessions to this database that were terminated by operator interventionCount
Active backend processespostgres.activity.activeNumber of server processes executing a queryCount
Active waiting backend processespostgres.activity.active_waitingNumber of server processes actively waitingCount
Idle backend processespostgres.activity.idleNumber of server processes waiting for a new client commandCount
Idle in transaction backends processespostgres.activity.idle_in_transactionNumber of server processes in transaction not currently executing a queryCount
Idle in transaction aborted backends processespostgres.activity.idle_in_transaction_abortedNumber of server processes in transaction not currently executing a query where one of the statements caused an errorCount
Fast-path function backend processespostgres.activity.fastpath_function_callNumber of server processes executing a fast-path function callCount
Number of lockspostgres.locksNumber of locks as reported by pg_locksCount
Instance recovery modepostgres.recovery.stateIndicate that the instance is in recovery mode. 1 if in recovery, 0 otherwise.State
User function callspostgres.user_functions.calls.countNumber of times this function has been called, as reported by pg_stat_user_functions.Count
User functions total timepostgres.user_functions.total_time.countTotal time spent in this function and all other functions called by it, as reported by pg_stat_user_functions.Millisecond
User functions self timepostgres.user_functions.self_time.countTotal time spent in this function itself, not including other functions called by it, as reported by pg_stat_user_functions.Millisecond
Tablespace sizepostgres.tablespace.sizeTablespace size in bytesByte
Scheduled checkpoints performedpostgres.checkpoints_timed.countNumber of scheduled checkpoints that have been performedCount
Requested checkpoints performedpostgres.checkpoints_req.countNumber of requested checkpoints that have been performedCount
Checkpoints write timepostgres.checkpoint_write_time.countTotal amount of time that has been spent in the portion of checkpoint processing where files are written to diskMilliSecond
Checkpoint sync timepostgres.checkpoint_sync_time.countTotal amount of time that has been spent in the portion of checkpoint processing where files are synchronized to diskMilliSecond
Buffers written during checkpointspostgres.buffers_checkpoint.countNumber of buffers written during checkpointsCount
Buffers written by background writerpostgres.buffers_clean.countNumber of buffers written by the background writerCount
Cleaning scan stopspostgres.maxwritten_clean.countNumber of times the background writer stopped a cleaning scan because it had written too many buffersCount
Buffers written by backendpostgres.buffers_backend.countNumber of buffers written directly by a backendCount
Backend fsync executionspostgres.buffers_backend_fsync.countNumber of times a backend had to execute its own fsync callCount
Buffers allocatedpostgres.buffers_alloc.countNumber of buffers allocatedCount
Replication WAL restart delaypostgres.replication.restart_delayDifference between current WAL LSN and the restart_lsn as reported by pg_replication_slots.Byte
Replication WAL confirmed flush lagpostgres.replication.confirmed_flush_lagDifference between current WAL LSN and the confirmed_flush_lsn as reported by pg_replication_slots.Byte
Replication WAL confirmed flush lagpostgres.replication.slot_xmin_ageAge of the oldest transaction that this logical replication slot needs the database to retain, as reported by pg_replication_slots.Byte
Database conflicts tablespacepostgres.database_conflicts.tablespace.countNumber of queries in this database that have been canceled due to dropped tablespaces, as reported by pg_stat_database_conflicts. Standby only.Count
Database conflicts lockpostgres.database_conflicts.lock.countNumber of queries in this database that have been canceled due to lock timeouts, as reported by pg_stat_database_conflicts. Standby only.Count
Database conflicts snapshotpostgres.database_conflicts.snapshot.countNumber of queries in this database that have been canceled due to old snapshots, as reported by pg_stat_database_conflicts. Standby only.Count
Database conflicts buffer pinpostgres.database_conflicts.bufferpin.countNumber of queries in this database that have been canceled due to pinned buffers, as reported by pg_stat_database_conflicts. Standby only.Count
Database conflicts deadlockpostgres.database_conflicts.deadlock.countNumber of queries in this database that have been canceled due to deadlocks, as reported by pg_stat_database_conflicts. Standby only.Count
Replication WAL write lagpostgres.replication.write_lagTime elapsed between flushing recent WAL locally and receiving notification that this standby server has written it, as reported by pg_stat_replication.Second
Replication WAL flush lagpostgres.replication.flush_lagTime elapsed between flushing recent WAL locally and receiving notification that this standby server has written and flushed it, as reported by pg_stat_replication.Second
Replication WAL replay lagpostgres.replication.replay_lagTime elapsed between flushing recent WAL locally and receiving notification that this standby server has written, flushed and applied it, as reported by pg_stat_replication.Second
Replication backend transaction agepostgres.replication.backend_xmin_ageAge of the backend's xmin horizon, as reported by pg_stat_replication.Count
Replication replay delaypostgres.replication.replay_delayDifference in bytes between the current WAL position and the last WAL position replayed on the standby server, as reported by pg_stat_replication.Byte
WAL receiver received timeline IDpostgres.wal_receiver.received_tliTimeline number of the last WAL received and flushed to disk, as reported by pg_stat_wal_receiver. Standby only.Count
WAL receiver last message send agepostgres.wal_receiver.last_msg_send_ageTime elapsed since last message sent to origin WAL sender, as reported by pg_stat_wal_receiver. Standby only.Second
WAL receiver last message receipt agepostgres.wal_receiver.last_msg_receipt_ageTime elapsed since last message received from origin WAL sender, as reported by pg_stat_wal_receiver. Standby only.Second
WAL receiver latest end agepostgres.wal_receiver.latest_end_ageTime elapsed since last write-ahead log location reported to origin WAL sender, as reported by pg_stat_wal_receiver. Standby only.Second
WAL files sizepostgres.wal_files_sizeTotal size of all WAL files in the WAL directoryByte
WAL files countpostgres.wal_filesTotal number of WAL files in the WAL directoryCount
WAL files agepostgres.wal_files_ageTime elapsed since the oldest WAL file was modifiedSecond
WAL writepostgres.wal_write.countNumber of times WAL buffers were written out to disk via XLogWrite requestCount
WAL syncpostgres.wal_sync.countNumber of times WAL files were synced to disk via issue_xlog_fsync requestCount
WAL write timepostgres.wal_write_time.countTotal amount of time spent writing WAL buffers to disk via XLogWrite request, in millisecondsMilliSecond
WAL sync timepostgres.wal_sync_time.countTotal amount of time spent syncing WAL files to disk via issue_xlog_fsync request, in millisecondsMilliSecond
WAL diff sizepostgres.wal_diff_sizeSize of difference between current WAL and last WAL replayByte
WAL records per minutepostgres.wal_records.countNumber of WAL records generated per minuteCount
WAL fpi per minutepostgres.wal_fpi.countNumber of WAL full page images generated per minuteCount
WAL bytespostgres.wal_bytes.countTotal amount of WAL generated in bytesCount
WAL buffers fullpostgres.wal_buffers_full.countNumber of times WAL data was written to disk because WAL buffers became fullCount
SLRU blocks zeroedpostgres.slru.blks_zeroed.countNumber of blocks zeroed during initializations, as reported by pg_stat_slru.Count
SLRU blocks hitpostgres.slru.blks_hit.countNumber of times disk blocks were found already in the SLRU cache, so that a read was not necessary, as reported by pg_stat_slru.Count
SLRU blocks readpostgres.slru.blks_read.countNumber of disk blocks read, as reported by pg_stat_slru.Count
SLRU blocks writtenpostgres.slru.blks_written.countNumber of disk blocks written, as reported by pg_stat_slru.Count
SLRU blocks existspostgres.slru.blks_exists.countNumber of blocks checked for existence, as reported by pg_stat_slru.Count
SLRU flushespostgres.slru.flushes.countNumber of SLRU flushes of dirty data, as reported by pg_stat_slru.Count
SLRU truncatespostgres.slru.truncates.countNumber of SLRU truncates, as reported by pg_stat_slru.Count
Subscription stats - apply errorpostgres.subscription_stats.apply_error.countNumber of times an error occurred while applying changes, as reported by pg_stat_subscription_stats.Count
Subscription stats - sync errorpostgres.subscription_stats.sync_error.countNumber of times an error occurred during the initial table synchronization, as reported by pg_stat_subscription_stats.Count
Subscription stats conflict - insert existspostgres.subscription_stats.confl_insert_exists.countNumber of times a row insertion violated a NOT DEFERRABLE unique constraint during the application of changes, as reported by pg_stat_subscription_stats.Count
Subscription stats conflict - update origin differspostgres.subscription_stats.confl_update_origin_differs.countNumber of times an update operation was applied to a row that had been previously modified by another source during the application of changes, as reported by pg_stat_subscription_stats.Count
Subscription stats conflict - update existspostgres.subscription_stats.confl_update_exists.countNumber of times that an updated row value violated a NOT DEFERRABLE unique constraint during the application of changes, as reported by pg_stat_subscription_stats.Count
Subscription stats conflict - update missingpostgres.subscription_stats.confl_update_missing.countNumber of times the tuple to be updated was not found during the application of changes, as reported by pg_stat_subscription_stats.Count
Subscription stats conflict - delete origin differspostgres.subscription_stats.confl_delete_origin_differs.countNumber of times a delete operation was applied to row that had been previously modified by another source during the application of changes, as reported by pg_stat_subscription_stats.Count
Subscription stats conflict - missing deletepostgres.subscription_stats.confl_delete_missing.countNumber of times the tuple to be deleted was not found during the application of changes, as reported by pg_stat_subscription_stats.Count
Subscription stats conflict - multiple unique conflictspostgres.subscription_stats.confl_multiple_unique_conflicts.countNumber of times a row insertion or an updated row values violated multiple NOT DEFERRABLE unique constraints during the application of changes, as reported by pg_stat_subscription_stats.Count
Related to PostgreSQL
ActiveGate logo
ActiveGate
Route traffic, monitor clouds and remote technologies & run Synthetic monitors
Full version history
ReleaseDate
Bugfixes
  • Revert change from extension version 2.9.7 , regarding metric description & graphs for postgres.xid_age, to use 2^31 instead of 2^32 for the wraparound value.
Enhancements
  • Updated entity links in Platform dashboards to redirect to the Infrastructure and Operations app
Bugfixes
  • Adjusted required dimensions for entity creation to prevent null entities from being created.
Features
  • Added an SLRU feature set with the following metrics:
    • postgres.slru.blks_zeroed.count
    • postgres.slru.blks_hit.count
    • postgres.slru.blks_read.count
    • postgres.slru.blks_written.count
    • postgres.slru.blks_exists.count
    • postgres.slru.flushes.count
    • postgres.slru.truncates.count
  • Added an IO feature set with the following metrics (PG16+):
    • postgres.io.reads.count
    • postgres.io.read_time.count
    • postgres.io.writes.count
    • postgres.io.write_time.count
    • postgres.io.writebacks.count
    • postgres.io.writeback_time.count
    • postgres.io.extends.count
    • postgres.io.extend_time.count
    • postgres.io.hits.count
    • postgres.io.evictions.count
    • postgres.io.reuses.count
    • postgres.io.fsyncs.count
    • postgres.io.fsync_time.count
    • postgres.io.read_bytes.count
    • postgres.io.write_bytes.count
    • postgres.io.extend_bytes.count
  • Added a User Functions feature set with the following metrics:
    • postgres.user_functions.calls.count
    • postgres.user_functions.total_time.count
    • postgres.user_functions.self_time.count
  • Added a Subscription feature set with the following metrics:
    • postgres.subscription_stats.apply_error.count
    • postgres.subscription_stats.sync_error.count
    • postgres.subscription_stats.confl_insert_exists.count
    • postgres.subscription_stats.confl_update_origin_differs.count
    • postgres.subscription_stats.confl_update_exists.count
    • postgres.subscription_stats.confl_update_missing.count
    • postgres.subscription_stats.confl_delete_origin_differs.count
    • postgres.subscription_stats.confl_delete_missing.count
    • postgres.subscription_stats.confl_multiple_unique_conflicts.count
  • Added the following metrics to the Replication feature set:
    • postgres.replication.backend_xmin_age
    • postgres.replication.slot_xmin_age
    • postgres.replication.replay_delay
    • postgres.wal_receiver.last_msg_send_age
    • postgres.wal_receiver.last_msg_receipt_age
    • postgres.wal_receiver.latest_end_age
    • postgres.database_conflicts.tablespace.count
    • postgres.database_conflicts.lock.count
    • postgres.database_conflicts.snapshot.count
    • postgres.database_conflicts.bufferpin.count
    • postgres.database_conflicts.deadlock.count
  • Added the following metrics to the WAL feature set:
    • postgres.wal_files_size
    • postgres.wal_files_age
  • Added the following metric to the Activity feature set:
    • postgres.activity.active_waiting
  • Adjusted Database activity charts.
  • Added feature set descriptions.
Features
  • Added Davis Anomaly Detection alert templates.
Bugfixes
  • Fixed Postgres instance in recovery alert splitting by a non-existing dimension.
Features
  • Postgres Instances can now be viewed from the host page.
Bugfixes
  • Fixed DQL for Query Performance and Blocking Activity in Platform dashboard.
Bugfixes
  • Fixed bug where some background writer metrics would not be collected for Postgres 17.
Features
  • Added ready-made Platform dashboard.
  • Database version is now an attribute of the Postgres instance entities.
Bugfixes
  • Fixed bug where the Connection Usage % chart would sometimes show no data.
Features
  • Database configuration parameters are now monitored as part of the default feature set. By default, this data is fetched every 24 hours, but this can be adjusted with the Configuration query interval (minutes) variable. This data will be available soon in the Databases App.
  • Added a new feature set Replication which collects replication lag metrics, postgres.replication.*.
  • Added a new feature set Locks which collects lock related metrics as well as information about blocking statements in the form of logs.
  • A new database size metric is now collected, postgres.db_size.
  • In order to monitor transaction wraparound issues, transaction ID age is now collected in the metric postgres.xid_age.
  • Added a database unreachable alert template. Note that all alert templates now default to disabled. The recommended approach to use these alerts is to clone them before enabling/changing them.
Enhancements
  • Top statements are now associated to the database they correspond to. Block hit/read/dirtied/written counts and read/write times are now collected.
  • When possible, top statements are correlated with pg_stat_activity data to obtain wait event times.
  • Additional charts added to various sections of the databases app and entity screens.
ℹ️ This version requires ActiveGate version 1.301.0 or higher.
Features:
  • When OneAgent monitoring is configured in the database server, a SAME_AS relationship will be established between the sql:postgres_instance and the corresponding PROCESS_GROUP_INSTANCE.
Bug fixes:
  • Fixed bug where the WAL diff size metric would not be collected for replication instances. This metric will now have value 0 instead of null when there is no recovery happening.
Bug fixes:
  • Fixed bug where the heavy-query-interval variable's default value would not be set correctly.
Bug fixes:
  • Fixed bug where top statements would appear duplicated in the Databases app
Features:
  • There are now two variables which can be defined at the configuration level, query-interval and heavy-query-interval, which control the frequency with which the Dynatrace queries the database/ingests data. Please see the FAQ section for more details.
Bugfixes:
  • Fixed the top queries not showing for certain non-Grail environment in the Postgres Instance screen.
ℹ️ This version requires ActiveGate version 1.293.0 or higher.
Improvements
  • Top queries will now no longer collect ALTER statements for security reasons.
Bugfixes:
  • Fixed the Top queries by execution time section in the Databases app.
  • Fixed the displayed columns for top statements in the Databases app.
WARNING This extension requires minimum ActiveGate version 1.293. Please check your version before upgrading.
Bugfixes:
  • Fixed bug where top queries would not be collected from pg_stat_statements for PostgreSQL 13.
Features:
  • (SaaS only) Added execution plan query support with the database app. For users on SaaS who have access to the Databases app execution plan fetching is now supported. View the Getting started section on the hub tile for more details on how to set it up.
Bug fixes:
  • Query duration as collected by longest_queries is now calculated as clock_timestamp() - query_start. Previously it was computed as now() - query_start which sometimes caused the query duration to be negative.
    The reason behind this is that now() or CURRENT_TIMESTAMP represent the start of the transaction and an individual query within the transaction can start later. The clock_timestamp() however returns an actual system cpu clock and can change over the course of the transaction, producing a correct value to subtract query_start from to compute a valid duration.
Bug fixes:
  • [BREAKING CHANGE] Renamed postgres.blk_hit.count metric key to postgres.blks_hit.count to match official Postgres statistics collector name.
Features:
  • Added an optional endpoint metadata configuration parameter to each endpoint in the monitoring configuration. This parameter will populate the endpoint_metadata attribute of sql:postgres_instance entities and can be used in entity selectors (to facilitate tagging, for example).
  • The Queries feature set will now collect queries (ingested as logs) from the pg_stat_statements table as well. These new logs can be queried by filtering by event_group = top_queries. Note that for this to work, the pg_stat_statements table needs to be enabled at the database level as per the official docs.
  • Added metric charts to the Postgres instance view in the Databases app.
Improvements:
  • Aggregated activities from pg_stat_activity is now collected for all activities, not just the ones associated with a specific datid. That adds monitoring for activites such as autovacuum worker.
Improvements:
  • Monitoring for databases was improved to support all versions of Postgres starting with 11. Previously, it only worked for Postgres 14+.
  • All metrics were linked to their corresponding Entity Type to make sure the metrics are displayed correctly when Management Zones are activated and are filtered by entity.
Bug fixes:
  • client_port dimension was removed from the following metrics, because the field bring no valuable information and is too volatile, causing too many distinct timeseries to be generated.
    • postgres.activity.fastpath_function_call
    • postgres.activity.idle_in_transaction_aborted
Breaking changes: Existing monitoring configurations must be recreated through API or manually
New features:
  • New feature sets
  • New topology type: Tablespace
  • WAL diff metric
  • Query level visibility for longest running queries
  • New metrics and charts on entity screens
Bug fixes:
  • Duplicate topology entities
  • Incorrect metric types
  • Incorrect recovery metric
  • Dashboard and entity screen links
Fix for schema change
  • Fix link to configurations in overview dashboard
No release notes
Dynatrace Hub
All (882)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
