Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
MongoDB AtlasMongoDB Atlas
MongoDB Atlas
MongoDB Atlas
Remotely monitor your SaaS installation of MongoDB (Atlas)
Extension
Free trialDocumentation
OverviewMongo Atlas MetricsProject Unified Analysis ScreenCluster Unified Analysis ScreenProcess Unified Analysis ScreenPartition Unified Analysis ScreenAtlas ConfigurationAtlas Log Events
  • Product information
  • Release notes
Overview
The extension remotely monitors your MongoDB Atlas projects through the MongoDB Atlas Administration API
Use cases
For SaaS deployments of MongoDB where the Dynatrace OneAgent cannot be installed. This extension enables insights into the overall health of your Atlas projects, clusters and nodes.
Get started
For more information on the installation and configuration, please see MongoDB Atlas extension in the Dynatrace Documentation.
Details
Compatibility information
Only compatible with MongoDB Atlas
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
-mongo.atlas.DATABASE_COLLECTION_COUNT--
-mongo.atlas.DATABASE_INDEX_COUNT--
-mongo.atlas.DATABASE_EXTENT_COUNT--
-mongo.atlas.DATABASE_OBJECT_COUNT--
-mongo.atlas.DATABASE_VIEW_COUNT--
ASSERT_MSGmongo.atlas.ASSERT_MSGRate of MSG asserts for a MongoDB processPerSecond
ASSERT_REGULARmongo.atlas.ASSERT_REGULARRate of REGULAR asserts for a MongoDB processPerSecond
ASSERT_USERmongo.atlas.ASSERT_USERRate of USER asserts for a MongoDB processPerSecond
ASSERT_WARNINGmongo.atlas.ASSERT_WARNINGRate of WARNING asserts for a MongoDB processPerSecond
OPLOG_MASTER_LAG_TIME_DIFFmongo.atlas.OPLOG_MASTER_LAG_TIME_DIFF-Second
OPLOG_MASTER_TIMEmongo.atlas.OPLOG_MASTER_TIME-Second
OPLOG_RATE_MB_PER_MINmongo.atlas.OPLOG_RATE_MB_PER_MINOplog rate (MB/min) - calculated from Atlas metric OPLOG_RATE_GB_PER_HOURMegaBytePerMinute
OPLOG_SLAVE_LAG_MASTER_TIMEmongo.atlas.OPLOG_SLAVE_LAG_MASTER_TIME-Second
-mongo.atlas.OPLOG_REPLICATION_LAG--
SYSTEM_NETWORK_INmongo.atlas.SYSTEM_NETWORK_INIncoming network throughput in bytes per second.BytePerSecond
SYSTEM_NETWORK_OUTmongo.atlas.SYSTEM_NETWORK_OUTOutgoing network throughput in bytes per second.BytePerSecond
MAX_SYSTEM_NETWORK_INmongo.atlas.MAX_SYSTEM_NETWORK_INMAX Incoming network throughput in bytes per second.BytePerSecond
MAX_SYSTEM_NETWORK_OUTmongo.atlas.MAX_SYSTEM_NETWORK_OUTMAX Outgoing network throughput in bytes per second.BytePerSecond
DISK_PARTITION_IOPS_READmongo.atlas.DISK_PARTITION_IOPS_READThroughput of I/O read operations for the disk partition used for MongoDB.PerSecond
DISK_PARTITION_IOPS_WRITEmongo.atlas.DISK_PARTITION_IOPS_WRITEThroughput of I/O write operations for the disk partition used for MongoDB.PerSecond
DISK_PARTITION_IOPS_TOTALmongo.atlas.DISK_PARTITION_IOPS_TOTALThroughput of total I/O operations for the disk partition used for MongoDB.PerSecond
MAX_DISK_PARTITION_IOPS_READmongo.atlas.MAX_DISK_PARTITION_IOPS_READMAX Throughput of I/O read operations for the disk partition used for MongoDB.PerSecond
MAX_DISK_PARTITION_IOPS_WRITEmongo.atlas.MAX_DISK_PARTITION_IOPS_WRITEMAX Throughput of I/O write operations for the disk partition used for MongoDB.PerSecond
MAX_DISK_PARTITION_IOPS_TOTALmongo.atlas.MAX_DISK_PARTITION_IOPS_TOTALMAX Throughput of total I/O operations for the disk partition used for MongoDB.PerSecond
SYSTEM_NORMALIZED_CPU_GUESTmongo.atlas.SYSTEM_NORMALIZED_CPU_GUESTGuest CPU usage of processes on the host scaled to a range of 0 to 100% by dividing by the number of CPU cores.Percent
SYSTEM_NORMALIZED_CPU_KERNELmongo.atlas.SYSTEM_NORMALIZED_CPU_KERNELKernel CPU usage of processes on the host scaled to a range of 0 to 100% by dividing by the number of CPU cores.Percent
SYSTEM_NORMALIZED_CPU_NICEmongo.atlas.SYSTEM_NORMALIZED_CPU_NICECPU usage of processes with a positive nice value, scaled to a range of 0 to 100% by dividing by the number of CPU cores.Count
SYSTEM_NORMALIZED_CPU_IOWAITmongo.atlas.SYSTEM_NORMALIZED_CPU_IOWAITCPU usage of processes spent waiting for IO operations to complete, scaled to a range of 0 to 100% by dividing by the number of CPU cores.Percent
SYSTEM_NORMALIZED_CPU_IRQmongo.atlas.SYSTEM_NORMALIZED_CPU_IRQCPU usage of harware interrupts, scaled to a range of 0 to 100% by dividing by the number of CPU cores.Percent
SYSTEM_NORMALIZED_CPU_SOFTIRQmongo.atlas.SYSTEM_NORMALIZED_CPU_SOFTIRQCPU usage of software interrupts, scaled to a range of 0 to 100% by dividing by the number of CPU cores.Percent
SYSTEM_NORMALIZED_CPU_STEALmongo.atlas.SYSTEM_NORMALIZED_CPU_STEALThe percentage of time the CPU had something runnable, but the hypervisor chose to run something else, scaled to a range of 0 to 100% by dividing by the number of CPU cores.Percent
SYSTEM_NORMALIZED_CPU_USERmongo.atlas.SYSTEM_NORMALIZED_CPU_USERUser CPU usage of processes on the host scaled to a range of 0 to 100% by dividing by the number of CPU coresPercent
MAX_SYSTEM_NORMALIZED_CPU_GUESTmongo.atlas.MAX_SYSTEM_NORMALIZED_CPU_GUESTMAX Guest CPU usage of processes on the host scaled to a range of 0 to 100% by dividing by the number of CPU cores.Percent
MAX_SYSTEM_NORMALIZED_CPU_KERNELmongo.atlas.MAX_SYSTEM_NORMALIZED_CPU_KERNELMAX Kernel CPU usage of processes on the host scaled to a range of 0 to 100% by dividing by the number of CPU cores.Percent
MAX_SYSTEM_NORMALIZED_CPU_NICEmongo.atlas.MAX_SYSTEM_NORMALIZED_CPU_NICEMAX CPU usage of processes with a positive nice value, scaled to a range of 0 to 100% by dividing by the number of CPU cores.Count
MAX_SYSTEM_NORMALIZED_CPU_IOWAITmongo.atlas.MAX_SYSTEM_NORMALIZED_CPU_IOWAITMAX CPU usage of processes spent waiting for IO operations to complete, scaled to a range of 0 to 100% by dividing by the number of CPU cores.Percent
MAX_SYSTEM_NORMALIZED_CPU_IRQmongo.atlas.MAX_SYSTEM_NORMALIZED_CPU_IRQMAX CPU usage of harware interrupts, scaled to a range of 0 to 100% by dividing by the number of CPU cores.Percent
MAX_SYSTEM_NORMALIZED_CPU_SOFTIRQmongo.atlas.MAX_SYSTEM_NORMALIZED_CPU_SOFTIRQMAX CPU usage of software interrupts, scaled to a range of 0 to 100% by dividing by the number of CPU cores.Percent
MAX_SYSTEM_NORMALIZED_CPU_STEALmongo.atlas.MAX_SYSTEM_NORMALIZED_CPU_STEALMAX The percentage of time the CPU had something runnable, but the hypervisor chose to run something else, scaled to a range of 0 to 100% by dividing by the number of CPU cores.Percent
MAX_SYSTEM_NORMALIZED_CPU_USERmongo.atlas.MAX_SYSTEM_NORMALIZED_CPU_USERMAX User CPU usage of processes on the host scaled to a range of 0 to 100% by dividing by the number of CPU coresPercent
DISK_PARTITION_SPACE_PERCENT_USEDmongo.atlas.DISK_PARTITION_SPACE_PERCENT_USEDThe percentage of disk used on the disk partition used by MongoDB.Percent
DISK_PARTITION_SPACE_PERCENT_FREEmongo.atlas.DISK_PARTITION_SPACE_PERCENT_FREEThe percentage of disk free on the disk partition used by MongoDB.Percent
DISK_PARTITION_SPACE_USEDmongo.atlas.DISK_PARTITION_SPACE_USEDAmount of disk space used in Bytes, on the disk partition used by MongoDB.Byte
DISK_PARTITION_SPACE_FREEmongo.atlas.DISK_PARTITION_SPACE_FREEAmount of disk space free in Bytes, on the disk partition used by MongoDB.Byte
MAX_DISK_PARTITION_SPACE_PERCENT_USEDmongo.atlas.MAX_DISK_PARTITION_SPACE_PERCENT_USEDMAX The percentage of disk used on the disk partition used by MongoDB.Percent
MAX_DISK_PARTITION_SPACE_PERCENT_FREEmongo.atlas.MAX_DISK_PARTITION_SPACE_PERCENT_FREEMAX The percentage of disk free on the disk partition used by MongoDB.Percent
MAX_DISK_PARTITION_SPACE_USEDmongo.atlas.MAX_DISK_PARTITION_SPACE_USEDMAX Amount of disk space used in Bytes, on the disk partition used by MongoDB.Byte
MAX_DISK_PARTITION_SPACE_FREEmongo.atlas.MAX_DISK_PARTITION_SPACE_FREEMAX Amount of disk space free in Bytes, on the disk partition used by MongoDB.Byte
COMPUTED_MEMORYmongo.atlas.COMPUTED_MEMORYAmount of COMPUTED process memory, in mebibytes (MiB)MebiByte
MEMORY_RESIDENTmongo.atlas.MEMORY_RESIDENTAmount of RESIDENT process memory, in mebibytes (MiB)MebiByte
MEMORY_VIRTUALmongo.atlas.MEMORY_VIRTUALAmount of VIRTUAL process memory, in mebibytes (MiB)MebiByte
MEMORY_MAPPEDmongo.atlas.MEMORY_MAPPEDAmount of MAPPED process memory, in mebibytes (MiB)MebiByte
DB_DATA_SIZE_TOTALmongo.atlas.DB_DATA_SIZE_TOTALTotal On-disk data size - dbstatsByte
DB_STORAGE_TOTALmongo.atlas.DB_STORAGE_TOTALTotal On-disk storage size - dbstatsByte
SWAP_USAGE_FREEmongo.atlas.SWAP_USAGE_FREETotal amount of swap space free.Byte
SWAP_USAGE_USEDmongo.atlas.SWAP_USAGE_USEDTotal amount of swap space in use.Byte
MAX_SWAP_USAGE_FREEmongo.atlas.MAX_SWAP_USAGE_FREEMAX amount of swap space free.Byte
MAX_SWAP_USAGE_USEDmongo.atlas.MAX_SWAP_USAGE_USEDMAX amount of swap space in use.Byte
FTS_DISK_UTILIZATIONmongo.atlas.FTS_DISK_UTILIZATIONTotal bytes of disk space that search processes use.Byte
FTS_MEMORY_MAPPEDmongo.atlas.FTS_MEMORY_MAPPEDTotal bytes of mapped memory that search processes occupy.Byte
FTS_MEMORY_RESIDENTmongo.atlas.FTS_MEMORY_RESIDENTTotal bytes of resident memory that search processes occupy.Byte
FTS_MEMORY_VIRTUALmongo.atlas.FTS_MEMORY_VIRTUALTotal bytes of virtual memory that search processes occupy.Byte
FTS_PROCESS_NORMALIZED_CPU_KERNELmongo.atlas.FTS_PROCESS_NORMALIZED_CPU_KERNELPercentage of time that the CPU spent servicing operating system calls for the search process.Percent
FTS_PROCESS_NORMALIZED_CPU_USERmongo.atlas.FTS_PROCESS_NORMALIZED_CPU_USERPercentage of time that the CPU spent servicing user calls for the search process.Percent
QUERY_EXECUTOR_SCANNEDmongo.atlas.QUERY_EXECUTOR_SCANNEDAverage rate per second to scan index items during queries and query-plan evaluations.PerSecond
QUERY_EXECUTOR_SCANNED_OBJECTSmongo.atlas.QUERY_EXECUTOR_SCANNED_OBJECTSAverage rate of documents scanned per second during queries and query-plan evaluations.PerSecond
QUERY_TARGETING_SCANNED_OBJECTS_PER_RETURNEDmongo.atlas.QUERY_TARGETING_SCANNED_OBJECTS_PER_RETURNEDRatio of the number of documents scanned to the number of documents returned.Ratio
QUERY_TARGETING_SCANNED_PER_RETURNEDmongo.atlas.QUERY_TARGETING_SCANNED_PER_RETURNEDRatio of the number of index items scanned to the number of documents returned.Ratio
OPCOUNTER_CMDmongo.atlas.OPCOUNTER_CMDRate of database operations on a MongoDB process since the process last startedCount
OPCOUNTER_DELETEmongo.atlas.OPCOUNTER_DELETERate of database DELETE operations on a MongoDB process since the process last startedCount
OPCOUNTER_GETMOREmongo.atlas.OPCOUNTER_GETMORERate of database GETMORE operations on a MongoDB process since the process last startedCount
OPCOUNTER_INSERTmongo.atlas.OPCOUNTER_INSERTRate of database INSERT operations on a MongoDB process since the process last startedCount
OPCOUNTER_QUERYmongo.atlas.OPCOUNTER_QUERYRate of database QUERY operations on a MongoDB process since the process last startedCount
OPCOUNTER_UPDATEmongo.atlas.OPCOUNTER_UPDATERate of database UPDATE operations on a MongoDB process since the process last startedCount
OPCOUNTER_REPL_CMDmongo.atlas.OPCOUNTER_REPL_CMDRate of database operations on MongoDB secondariesCount
OPCOUNTER_REPL_UPDATEmongo.atlas.OPCOUNTER_REPL_UPDATERate of database UPDATE operations on MongoDB secondariesCount
OPCOUNTER_REPL_DELETEmongo.atlas.OPCOUNTER_REPL_DELETERate of database DELETE operations on MongoDB secondariesCount
OPCOUNTER_REPL_INSERTmongo.atlas.OPCOUNTER_REPL_INSERTRate of database INSERT operations on MongoDB secondariesCount
DISK_PARTITION_LATENCY_READmongo.atlas.DISK_PARTITION_LATENCY_READRead Latency of the disk partition that hosts MongoDB.MilliSecond
DISK_PARTITION_LATENCY_WRITEmongo.atlas.DISK_PARTITION_LATENCY_WRITEWrite Latency of the disk partition that hosts MongoDB.MilliSecond
MAX_DISK_PARTITION_LATENCY_READmongo.atlas.MAX_DISK_PARTITION_LATENCY_READMAX Read Latency of the disk partition that hosts MongoDB.MilliSecond
MAX_DISK_PARTITION_LATENCY_WRITEmongo.atlas.MAX_DISK_PARTITION_LATENCY_WRITEMAX Write Latency of the disk partition that hosts MongoDB.MilliSecond
GLOBAL_ACCESSES_NOT_IN_MEMORYmongo.atlas.GLOBAL_ACCESSES_NOT_IN_MEMORY-Count
GLOBAL_LOCK_CURRENT_QUEUE_READERSmongo.atlas.GLOBAL_LOCK_CURRENT_QUEUE_READERSThe number of operations that are currently queued and waiting for the read lock.Count
GLOBAL_LOCK_CURRENT_QUEUE_TOTALmongo.atlas.GLOBAL_LOCK_CURRENT_QUEUE_TOTALThe total number of operations queued waiting for the lock (readers + writers)Count
GLOBAL_LOCK_CURRENT_QUEUE_WRITERSmongo.atlas.GLOBAL_LOCK_CURRENT_QUEUE_WRITERSThe number of operations that are currently queued and waiting for the write lock.Count
GLOBAL_PAGE_FAULT_EXCEPTIONS_THROWNmongo.atlas.GLOBAL_PAGE_FAULT_EXCEPTIONS_THROWN-Count
CONNECTIONSmongo.atlas.CONNECTIONSNumber of connections to a MongoDB processCount
CURSORS_TOTAL_OPENmongo.atlas.CURSORS_TOTAL_OPENTotal number of cursors for a MongoDB process.Count
CURSORS_TOTAL_TIMED_OUTmongo.atlas.CURSORS_TOTAL_TIMED_OUTTotal number of cursors that have timed-out for a MongoDB process.Count
PROCESS_NORMALIZED_CPU_CHILDREN_KERNELmongo.atlas.PROCESS_NORMALIZED_CPU_CHILDREN_KERNELChildren Kernel CPU usage scaled to a range of 0% to 100% by dividing by the number of CPU cores.Percent
PROCESS_NORMALIZED_CPU_CHILDREN_USERmongo.atlas.PROCESS_NORMALIZED_CPU_CHILDREN_USERChildren User CPU usage scaled to a range of 0% to 100% by dividing by the number of CPU cores.Percent
PROCESS_NORMALIZED_CPU_KERNELmongo.atlas.PROCESS_NORMALIZED_CPU_KERNELKernel CPU usage scaled to a range of 0% to 100% by dividing by the number of CPU cores.Percent
PROCESS_NORMALIZED_CPU_USERmongo.atlas.PROCESS_NORMALIZED_CPU_USERUser CPU usage scaled to a range of 0% to 100% by dividing by the number of CPU cores.Percent
MAX_PROCESS_NORMALIZED_CPU_CHILDREN_KERNELmongo.atlas.MAX_PROCESS_NORMALIZED_CPU_CHILDREN_KERNELMAX Children Kernel CPU usage scaled to a range of 0% to 100% by dividing by the number of CPU cores.Percent
MAX_PROCESS_NORMALIZED_CPU_CHILDREN_USERmongo.atlas.MAX_PROCESS_NORMALIZED_CPU_CHILDREN_USERMAX Children User CPU usage scaled to a range of 0% to 100% by dividing by the number of CPU cores.Percent
MAX_PROCESS_NORMALIZED_CPU_KERNELmongo.atlas.MAX_PROCESS_NORMALIZED_CPU_KERNELMAX Kernel CPU usage scaled to a range of 0% to 100% by dividing by the number of CPU cores.Percent
MAX_PROCESS_NORMALIZED_CPU_USERmongo.atlas.MAX_PROCESS_NORMALIZED_CPU_USERMAX User CPU usage scaled to a range of 0% to 100% by dividing by the number of CPU cores.Percent
BACKGROUND_FLUSH_AVGmongo.atlas.BACKGROUND_FLUSH_AVGAmount of data flushed in the background.Count
RESTARTS_IN_LAST_HOURmongo.atlas.RESTARTS_IN_LAST_HOURNumber of times the host restarted within the previous hour.Count
OPERATIONS_SCAN_AND_ORDERmongo.atlas.OPERATIONS_SCAN_AND_ORDERThe total number of queries that return sorted data that cannot perform the sort operation using an index.Count
EXTRA_INFO_PAGE_FAULTSmongo.atlas.EXTRA_INFO_PAGE_FAULTSThe total number of page faultsCount
JOURNALING_COMMITS_IN_WRITE_LOCKmongo.atlas.JOURNALING_COMMITS_IN_WRITE_LOCKNumber of journaling COMMIT operations.Count
JOURNALING_MBmongo.atlas.JOURNALING_MB-MegaByte
JOURNALING_WRITE_DATA_FILES_MBmongo.atlas.JOURNALING_WRITE_DATA_FILES_MB-MegaByte
TICKETS_AVAILABLE_READSmongo.atlas.TICKETS_AVAILABLE_READSThe number of read tickets available to the WiredTiger storage engine.Count
TICKETS_AVAILABLE_WRITEmongo.atlas.TICKETS_AVAILABLE_WRITEThe number of write tickets available to the WiredTiger storage engine.Count
CACHE_BYTES_READ_INTOmongo.atlas.CACHE_BYTES_READ_INTORead - Amount of bytes in the WiredTiger storage engine cacheByte
CACHE_BYTES_WRITTEN_FROMmongo.atlas.CACHE_BYTES_WRITTEN_FROMWrite - Amount of bytes in the WiredTiger storage engine cacheByte
CACHE_DIRTY_BYTESmongo.atlas.CACHE_DIRTY_BYTESAmount of dirty bytes in the WiredTiger storage engine cacheByte
CACHE_USED_BYTESmongo.atlas.CACHE_USED_BYTESAmount of used bytes in the WiredTiger storage engine cacheByte
OP_EXECUTION_TIME_COMMANDSmongo.atlas.OP_EXECUTION_TIME_COMMANDSThe average execution time in milliseconds per command operation over the selected sample period.MilliSecond
OP_EXECUTION_TIME_READSmongo.atlas.OP_EXECUTION_TIME_READSThe average execution time in milliseconds per read operation over the selected sample period.MilliSecond
OP_EXECUTION_TIME_WRITESmongo.atlas.OP_EXECUTION_TIME_WRITESThe average execution time in milliseconds per write operation over the selected sample period.MilliSecond
DOCUMENT_METRICS_DELETEDmongo.atlas.DOCUMENT_METRICS_DELETEDAverage rate of documents DELETED.PerSecond
DOCUMENT_METRICS_INSERTEDmongo.atlas.DOCUMENT_METRICS_INSERTEDAverage rate of documents INSERTED.PerSecond
DOCUMENT_METRICS_RETURNEDmongo.atlas.DOCUMENT_METRICS_RETURNEDAverage rate of documents RETURNED.PerSecond
DOCUMENT_METRICS_UPDATEDmongo.atlas.DOCUMENT_METRICS_UPDATEDAverage rate of documents UPDATED.PerSecond
INDEX_COUNTERS_BTREE_ACCESSESmongo.atlas.INDEX_COUNTERS_BTREE_ACCESSESNumber of index btree ACCESSES.Count
INDEX_COUNTERS_BTREE_HITSmongo.atlas.INDEX_COUNTERS_BTREE_HITSNumber of index btree HITS.Count
INDEX_COUNTERS_BTREE_MISS_RATIOmongo.atlas.INDEX_COUNTERS_BTREE_MISS_RATIOindex btree miss ratioRatio
INDEX_COUNTERS_BTREE_MISSESmongo.atlas.INDEX_COUNTERS_BTREE_MISSESNumber of index btree MISSES.Count
SYSTEM_MEMORY_USEDmongo.atlas.SYSTEM_MEMORY_USEDPhysical memory used, in bytesByte
SYSTEM_MEMORY_AVAILABLEmongo.atlas.SYSTEM_MEMORY_AVAILABLEPhysical memory available, in bytesByte
SYSTEM_MEMORY_FREEmongo.atlas.SYSTEM_MEMORY_FREEPhysical memory free, in bytesByte
MAX_SYSTEM_MEMORY_USEDmongo.atlas.MAX_SYSTEM_MEMORY_USEDMAX Physical memory used, in bytesByte
MAX_SYSTEM_MEMORY_AVAILABLEmongo.atlas.MAX_SYSTEM_MEMORY_AVAILABLEMAX Physical memory available, in bytesByte
MAX_SYSTEM_MEMORY_FREEmongo.atlas.MAX_SYSTEM_MEMORY_FREEMAX Physical memory free, in bytesByte
DATABASE_AVERAGE_OBJECT_SIZEmongo.atlas.DATABASE_AVERAGE_OBJECT_SIZEAverage size of each document in bytes.Byte
DATABASE_DATA_SIZEmongo.atlas.DATABASE_DATA_SIZETotal size of the uncompressed data held in the database.Byte
DATABASE_STORAGE_SIZEmongo.atlas.DATABASE_STORAGE_SIZESum of the disk space allocated to all collections in the database for document storage, including free space.Byte
DATABASE_INDEX_SIZEmongo.atlas.DATABASE_INDEX_SIZESum of the disk space allocated to all indexes in the database, including free index space.Byte
NETWORK_BYTES_INmongo.atlas.NETWORK_BYTES_INMongoDB process incoming network throughput, in bytes per second.BytePerSecond
NETWORK_BYTES_OUTmongo.atlas.NETWORK_BYTES_OUTMongoDB process outgoing network throughput, in bytes per second.BytePerSecond
NETWORK_NUM_REQUESTSmongo.atlas.NETWORK_NUM_REQUESTSThe total number of distinct requests that the MongoDB process has received.Count
Full version history
ReleaseDate
🐛 Bugs fixed in this version:
  • Resolve bug in which some metrics were reporting an incorrect value based on the unit
Release notes:
⚠️ BREAKING CHANGE ⚠️
Upgrading existing monitoring configurations from previous versions to this version will not be possible and will require recreating those monitoring configurations. New monitoring configurations will not be affected.
New in this version:
  • Added the option to ingest Atlas cluster logs as log events (mongodb, mongos, mongodb-audit-log, mongos-audit-log)
  • Added a new platform dashboard to display Atlas cluster logs
  • When ingesting Atlas events, expanded the configuration options to either: ingest all events, provide a list of event types to include, provide a list of event types to exclude
  • Expanded Atlas event logs to report all event fields
  • Update platform dashboard
  • Add dt.security_context
  • Add new platform analysis screens
  • Improved thread per-minute rate limit handling
  • Add new platform dashboard
  • Improved feature set query filtering
  • Improved rate limit handling (429 errors)
    • Only query for Database level metrics every 20mins: Atlas retrieves database metrics every 20 minutes
  • Add support for Dynatrace Enrichment Attributes
  • Add Dynatrace credential vault support for the API public/private key configuration
  • Poll for database measurements: Process -> Database
  • Database metric metadata, topology, screens
  • Quality of life features
    • Custom extension schedule
    • Filters to only monitor specific clusters, databases or partitions
  • Map metrics to MongoDB entities for tagging and management zones
  • Use the MongoDB icon for created entities
  • Update the version of extension dependencies
  • Collects Atlas Metric OPLOG_RATE_GB_PER_HOUR and converts it to Dynatrace metric OPLOG_RATE_MB_PER_MIN
  • Links processes to clusters via the connection string and user alias
  • Support for ingesting all Atlas Event Types
  • User Configuration option to restrict capturing of specific events
  • Update the project unified analysis screen to view all events
  • Update to use v2 of the MongoDB Atlas Administration API
  • Support for all listed Metric Types: Metrics Reference
  • Updated Dashboard and Unified Analysis Screens
  • Custom entity type for Partitions
  • Resolves a bug where metric scraping returned early for clusters with multiple nodes.
  • Support for monitoring multiple Projects from the same configuration
  • Dashboard image and metric updates
  • Improved metric parsing to skip over null values
Dynatrace Hub
All (886)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
