Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Microsoft Hyper-V InfrastructureMicrosoft Hyper-V Infrastructure
Monitor health and performance of the Hyper-V clusters, hosts and VMs.
Extension
Free trialDocumentation
Hyper-V top level dashboardFailover cluster overviewFailover cluster performance metricsHyper-V host overview
  • Product information
  • Release notes
Overview
Get insights into performance of the Hyper-V fabric, tracking health, performance and resource utilization of the Hyper-V VMs, together with the context of their host and cluster resources. Monitor Hyper-V clusters, detect problems ahead of serious impact, and pinpoint the bottlenecks in the virtualization and application layer, including:
  • Processor bottlenecks
  • Memory shortages
  • Network overload
  • Storage shortages
  • Slowness in the dependent applications hosted on the Hyper-V cluster
Hyper-V extension leverages PowerShell cmdlets and WMI queries to collect data from the Windows hypervisor, following best practices employed by Microsoft, as well as Dynatrace customers who contributed to validation of this extension in real-life situations.
Use cases
  • Monitor health and performance of your Hyper-V cluster, using built-in analysis screens and easy-to-navigate dashboards
  • Make sure resources are split optimally between the virtual machines
  • Relate performance of the applications and VMs monitored with OneAgent to the underlying Hyper-V resources allotted to the VMs
Get started
For more information on the installation and configuration, please see Microsoft Hyper-V Infrastructure extension in the Dynatrace Documentation.
Details
Compatibility information
This extension requires:
  • x64 OS with BIOS-activated virtualization:
    • Windows 10 Enterprise/Pro/Education
    • Windows Server 2016 or newer
  • Hyper-V VM Configuration Version 9.0 or higher
Note on topological relationships between discovered Hyper-V VMs and OneAgent-monitored VM instances:
  • This extension maintains SAME_AS relationship between discovered VMs and OneAgent-monitored instances of the guest OS, using IP address as the join property.
  • This relationship enables:
    • Davis AI analytics to look together at metrics obtained by this extension and from OneAgent, to completely characterize monitored guest OS instances performance
    • Discovery and Coverage app to suggest which discovered VMs should be instrumented with OneAgent for full visibility into performance
  • This relationship works for known Windows guest OSes, but has limitations when guest OS is Linux. This limitation stems from the fact that on Hyper-V, Linux guest OS should be instrumented with the Microsoft's Linux Integration Service, while this service supports limited spectrum of the Linux distributions. See the link for details.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Total Spacehyperv.cluster_shared_volume.total_space-Byte
Used Disk Spacehyperv.cluster_shared_volume.used_space-Byte
Available Disk Spacehyperv.cluster_shared_volume.free_space-Byte
Read Ratehyperv.cluster_shared_volume.read_rate-PerSecond
Write Ratehyperv.cluster_shared_volume.write_rate-PerSecond
Network Packets Senthyperv.host.network_interface_card.packets_sent-BytePerSecond
Network Packets Receivedhyperv.host.network_interface_card.packets_received-BytePerSecond
Network Packets Transferredhyperv.host.network_interface_card.packets_transferred-BytePerSecond
Disk Read Ratehyperv.virtual_machine.storage_device.read_rate-PerSecond
Disk Write Ratehyperv.virtual_machine.storage_device.write_rate-PerSecond
Disk IOPShyperv.virtual_machine.storage_device.iops-PerSecond
Disk Read Ratehyperv.host.disk.read_rate-PerSecond
Disk Write Ratehyperv.host.disk.write_rate-PerSecond
Disk IOPShyperv.host.disk.iops-PerSecond
Network Bytes Senthyperv.host.network_interface_card.bytes_sent-BytePerSecond
Network Bytes Receivedhyperv.host.network_interface_card.bytes_received-BytePerSecond
Network Bytes Transferredhyperv.host.network_interface_card.bytes_transferred-BytePerSecond
Disk Utilizationhyperv.host.disk.disk_util-Percent
Total Disk Sizehyperv.host.disk.total_size-Byte
Used Disk Spacehyperv.host.disk.used_space-Byte
Available Disk Spacehyperv.host.disk.space_free-Byte
CPU Counthyperv.virtual_machine.cpu_count.gauge-Cores
CPU Reservehyperv.virtual_machine.cpu_reserve-Percent
CPU Utilizationhyperv.virtual_machine.cpu_utilizationCPU Utilization % relative to the hosts total capacity.Percent
Real CPU Utilizationhyperv.virtual_machine.real_cpu_utilizationCPU Utilization % as seen on the VMPercent
Total Memoryhyperv.virtual_machine.total_memory-Byte
Available Memoryhyperv.virtual_machine.available_memory-Byte
Used Memoryhyperv.virtual_machine.used_memory-Byte
Memory Utilizationhyperv.virtual_machine.memory_util-Percent
Memory Pressurehyperv.virtual_machine.memory_pressure-Percent
Virtual Machine Counthyperv.host.virtual_machine_count.gauge-Count
Running Virtual Machine Counthyperv.host.running_virtual_machine_count.gauge-Count
Uptimehyperv.host.uptime-Second
Network Bytes Senthyperv.virtual_machine.network_interface_card.bytes_sent-BytePerSecond
Network Bytes Receivedhyperv.virtual_machine.network_interface_card.bytes_received-BytePerSecond
Network Bytes Transferredhyperv.virtual_machine.network_interface_card.bytes_transferred-BytePerSecond
Memory Utilizationhyperv.host.memory_util-Percent
Total Memoryhyperv.host.total_memory-KiloByte
Used Memoryhyperv.host.used_memory-Byte
Available Memoryhyperv.host.available_memory-KiloByte
Disk Utilization of the Virtual Hard Disk file according the the Host OShyperv.virtual_machine.storage_device.disk_util-Percent
Free Disk Spacehyperv.virtual_machine.storage_device.free_disk_space-Byte
Total Disk Spacehyperv.virtual_machine.storage_device.total_disk_space-Byte
Used Disk Spacehyperv.virtual_machine.storage_device.used_disk_space-Byte
Network Packets Senthyperv.virtual_machine.network_interface_card.packets_sent-PerSecond
Network Packets Receivedhyperv.virtual_machine.network_interface_card.packets_received-PerSecond
Network Packets Transferredhyperv.virtual_machine.network_interface_card.packets_transferred-PerSecond
CPU Utilizationhyperv.host.cpu_utilization-Percent
Logical CPU Counthyperv.host.logical_cpu_count.gauge-Cores
Physical CPU Counthyperv.host.physical_cpu_count.gauge-Cores
CPU Reservehyperv.host.cpu_reserve-Percent
Related to Microsoft Hyper-V Infrastructure
Microsoft Hyper-V Virtual Machines logo
Monitor Microsoft Hyper-V virtual machines from the guest OS perspective.
Full version history
ReleaseDate
Improved in this version
  • Repackaged Python libraries for future Python 3.14 compatibility
  • Improved detection of elevated-privileges user.
  • Removed .NET commands to allow the extension to run even in PowerShell's Constrained Language mode.
  • Resolved issue with dashboard links not opening on pure Gen3 tenants.
⚠️ Breaking change
  • The semantic of the hyperv.host.disk.iops metric updated to fix an issue where it reported the sum of read and write data size instead of disk operations. As a result, this metric values lose continuity after the upgrade. Other metrics are not affected by this change.
  • Resolved an issue with Host CPU utilization metric not matching the value visible on the Hyper-V console.
  • Proper feature-set assignment of all the metrics that were sitting under no feature set.
⚠️ Important Change:
  • This release requires a Minimum Dynatrace Version version of 1.318.0 or higher.
New in this version:
  • Added ALERT_TEMPLATES for anomaly detectors in the Davis Anomaly Detection app (latest Dynatrace only).
Hyper-V extension release notes
3.0.9
Published Thu Dec 4 2025
Patch level changes
  • Expire virtual machines so they don't appear on multiple hosts after a VM has been migrated
  • Clean up the DB to avoid re-ingesting existing datapoints
3.0.7
Published Thu Aug 28 2025
Patch level changes
  • Fixed an issue with improper filtering when the Hyper-V host is not part of a cluster or fails to retrieve the cluster name
  • Refreshed alert definitions
3.0.5
Published Fri Aug 08 2025
⚠️IMPORTANT CHANGES
  1. This extension release requires Dynatrace cluster version 1.313 or later.
  2. The extension now runs with elevated privileges, which requires editing the extensionsuser.conf to allow the extension to run with such privileges. In return, you get much improved scalability and stability of the monitoring. See the tile text for more details.
  3. Breaking change this upgrade will require recreation of the monitoring configurations.
New features
  • Added the ability to interpret entity filters as an allow or deny rule, which simplifies filtering configuration and makes it more flexible.
  • The dt.security_context attribute is now propagated to all entities created by the extension. When enabling entity access control based on dt.security_context ensure you set the Grail security context destination property to dt.security_context.
  • Enabled the extension to present the Dynatrace Platform (a.k.a. Gen3) entity details screens in the future platform apps that will expect these screens.
2.2.39
Published Tue Jun 24 2025
⚠️IMPORTANT CHANGE This extension release requires Dynatrace cluster version 1.310 or later. ⚠️If your Dynatrace cluster is on an earlier version, use previous release of this extension, tagged 2.2.38.
New features
  • Added the Dynatrace Platform (a.k.a. Gen3) dashboard
Plus, carry-on from release 2.2.38
  • Added an option to choose between Interactive and Batch logon types
  • Bug fixes related to the Cluster Shared Volume and Disk metrics reporting
  • Switch to use FQDNs instead of hostnames wherever possible in the cluster and host identification
2.2.38
New features
Patch level changes
2.2.21
Published Thu Mar 27 2025
Patch level changes
  • fixed CPU utilization metric readouts that were artificially inflated for multicore processors
2.2.15
Published Mon Feb 10 2025
New features
  • Added Real CPU Utilization metric
Patch level changes
  • Fixed slow memory leak showing up in some environments where PowerShell calls were not cleared entirely after each execution due to race conditions
2.2.11
Published Fri Aug 16 2024
Patch level changes
  • Changed way of reading the cluster name to PowerShell instead of WMI - to address an issue with access permissions
2.2.10
Published Tue Aug 06 2024
New features
  • Generate a log event when a VM is moved between hosts
Patch level changes
  • Fixed issue with multiple threads modifying the same list of VMs
  • Improve error handling for WMI queries
2.2.5
Published Fri Jul 12 2024
Patch level changes
  • Added ability to set a debug log level and the collection frequency
  • A fix for an incorrect count of VMs on one of the UA screens
2.2.4
Published Wed Jul 03 2024
Patch level changes
  • Fix locks that hindered performance and clean up the VM stats
2.0.15
Published Wed May 15 2024
New features
  • Added option to use the credential vault to manage user credentials required by the extension
Patch level changes
  • Split VM collection into 3 separate "query" methods to improve execution time
  • Added sourceEntityType for all metrics
2.0.14
Published Fri Apr 05 2024
Patch level changes
  • Fixed alert json for func metrics since they were using metricId instead of metricSelector.
2.0.13
Published Thu Apr 04 2024
New features
  • Added SAME_AS relationship between discovered VMs and OneAgent-monitored instances of the guest OS, using IP address as the join property. This relationship enables
Patch level changes
  • Stated the requirement that Windows user account who runs the extension requires Read and Write access to the Windows TEMP directory.
2.0.12
Published Mon Feb 26 2024
New features
  • This release introduces an important change Hyper-V extension requires local activation now (i..e. activation on an OneAgent-instrumented host).
  • Previous releases allowed remote installation (i.e. activation on an ActiveGate), but because of Hyper-V specifics, this very often caused permission issues that severely limited extension functionality and weren't solvable. So anyway - we have been advising you to move to local activation. Now it's the only way to activate this extension.
Patch level changes
  • Additionally, this release fixes some issues with filtering monitored entities.
2.0.10
Published Fri Feb 09 2024
Patch level changes
  • Fixed reporting of the rate metrics and occasional issues with metric extraction from nested environments.
2.0.3
Published Wed Nov 29 2023
Patch level changes
  • Fixed a bug affecting extension activation under certain conditions. Extension logs on affected systems reported "AttributeError 'dict' object has no attribute 'feature_sets' "
2.0.0
Published Wed Sep 27 2023
Dynatrace Hub
All (880)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
