Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
IBM MQ ApplianceIBM MQ Appliance
IBM MQ Appliance
IBM MQ Appliance
Monitor your IBM MQ Appliances over SNMP
Extension
Free trialDocumentation
Gen 3 dashboard for the IBM MQ Appliance, displaying infrastructure metrics and links.Unified analysis view of an IBM MQ Appliance, with infrastructure and storage-level metrics.Unified analysis view of an IBM MQ Appliance, with its related queue managers and environmental sensor metrics.
  • Product information
  • Release notes
Overview
This extension collects metrics to monitor the health and performance of your IBM MQ Appliances. Metrics are collected via SNMP protocol.
Use cases
  • Monitor relevant infrastructure metrics related to your IBM MQ Appliances, such as CPU, memory, and disk usage.
  • Retrieve health information from your physical environmental sensors, ensuring their temperature or power supply status is correct.
Get started
For more information on the installation and configuration, please see IBM MQ Appliance extension in the Dynatrace Documentation.
Details
Compatibility information
  • SNMP v2c or SNMP v3
  • Dynatrace version 1.310+
  • ActiveGate version 1.310+
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
System Uptime (ms)ibm_mq.sys.uptimeThe time (in hundredths of a second) since the network management portion of the system was last re-initialized.MilliSecond
Appliance Uptime (ms)ibm_mq.status.uptimeThe total amount of time the appliance has been up since the last reload or reboot. (hundredths of a second).MilliSecond
Free encrypted storage spaceibm_mq.filesystemstatus.freeencryptedFree, or unused and available, encrypted storage space on the device. All files placed in encrypted storage are automatically encrypted for security by the device.MegaByte
Total encrypted storage spaceibm_mq.filesystemstatus.totalencryptedTotal encrypted storage space on the device (the maximum capacity). All files placed in encrypted storage are automatically encrypted for security by the device.MegaByte
Free internal storage spaceibm_mq.filesystemstatus.freeinternalFree, or unused and available, internal storage space on the device. The device uses internal storage for import, export, firmware upgrades and debug captures.MegaByte
Total internal storage spaceibm_mq.filesystemstatus.totalinternalTotal internal storage space on the device. The device uses internal storage for import, export, firmware upgrades and debug captures.MegaByte
Free temporary storage spaceibm_mq.filesystemstatus.freetemporaryFree, or unused and available, temporary storage space on the device. The device uses temporary storage for processing, logging and debugging.MegaByte
Total temporary storage spaceibm_mq.filesystemstatus.totaltemporaryTotal temporary storage space on the device. The device uses temporary storage for processing, logging and debugging.MegaByte
Sensor case open - Statusibm_mq.environmental_sensor.case_openYes: 1 No: 2State
Sensor intrusion - Statusibm_mq.environmental_sensor.check_intrusionYes: 1 No: 2State
Sensor CPU 1 tempibm_mq.environmental_sensor.cpu.temp.1-Unspecified
Sensor CPU 2 tempibm_mq.environmental_sensor.cpu.temp.2-Unspecified
Sensor Power Supplyibm_mq.environmental_sensor.power_supplyOK: 1, Power 1 Failure: 2, Power 2 Failure: 3, Power 1 AC Lost: 4, Power 2 AC Lost: 5State
Sensory System Tempibm_mq.environmental_sensor.system_temp-Unspecified
CPU usage %ibm_mq.cpu.usage.percentThe instantaneous CPU usage as a percentage of the CPU load.Percent
CPU average load 5 minibm_mq.cpu.load5min.percentThe average CPU load over the last 5 minutes.Percent
Used memory percentageibm_mq.memory.used.percentThe instantaneous memory usage as a percentage of the total memory.Percent
Free memoryibm_mq.memory.freeThe amount of memory that is currently not in use and is therefore available. The free memory value includes any hold memory that is not currently in use.MegaByte
Total memoryibm_mq.memory.totalThe total memory of the system in megabytes. The total memory equals the amount of installed memory minus the amount of reserved memory.MegaByte
Used memoryibm_mq.memory.usedThe amount of memory that is currently in use. The used memory equals the amount of total memory minus the amount of free memory. The used memory does not include any hold memory.MegaByte
Disk usedibm_mq.disk.usedThe amount of MQ storage in use in megabytes.MegaByte
Disk totalibm_mq.disk.totalThe total storage in megabytes available for MQ data.MegaByte
Used error storage spaceibm_mq.errorstorage.usedFree, or unused and available, error storage space on the device.MegaByte
Total error storage spaceibm_mq.errorstorage.totalTotal error storage space on the device.MegaByte
Used trace storage spaceibm_mq.tracestorage.usedFree, or unused and available, trace storage space on the device.MegaByte
Total trace storage spaceibm_mq.tracestorage.totalTotal trace storage space on the device.MegaByte
Queue manager CPU usage %ibm_mq.queue_manager.cpu.usageThe instantaneous CPU usage by the queue manager as a percentage of the CPU load.Percent
Queue manager memory usedibm_mq.queue_manager.memory.usedThe amount of memory that is currently in use by the queue manager.MegaByte
Queue manager filesystem usedibm_mq.queue_manager.filesystem.usedThe amount of filesystem space that is currently in use by the queue manager.MegaByte
Queue manager filesystem totalibm_mq.queue_manager.filesystem.totalThe total amount of filesystem space that is available for the queue manager.MegaByte
Total network bytes inibm_mq.network.bytes.in.countThe number of bytes received in the network interface of the device.Byte
Total network bytes outibm_mq.network.bytes.out.countThe number of bytes sent by the network interface of the device.Byte
Related to IBM MQ Appliance
IBM MQ logo
IBM MQ
Monitor performance of your IBM MQ queue manager objects.
Full version history
ReleaseDate
🪲 Fixed in this version (1.0.3):
  • Updated dashboard entity links to redirect to Infrastructure & Operations app
🪲 Fixed in this version (1.0.1):
  • Added device.address and queue_manager.name as required dimensions for generic entities.
✨ New in this version (1.0.0):
  • Added keyword key-value pairs to the extension.
  • Added gen 3 dashboard.
šŸš€ Improved in this version:
  • Improve entity assignment and dimension naming for metrics.
  • Refactored feature sets into a clearer grouping.
(IMPORTANT!: You will have to re-create your configurations to toggle the new feature sets when upgrading.)
āš™ļø Changed in this version:
  • Metrics ibm_mq.network.bytes.in and ibm_mq.network.bytes.out renamed to ibm_mq.network.bytes.in.count and ibm_mq.network.bytes.out.count to fit naming standards.
  • Renamed custom generated entities to ibm_mq_appliance:device and ibm_mq_appliance:queue_manager.
(IMPORTANT!: Any existing settings dependent upon these names will have to be changed accordingly after upgrading to this version.)
🪲 Fixed in this version:
  • Corrected broken extension links in entity pages.
30+ metrics in 8 feature sets 2 entities Gen 2 / Gen 3 dashboards and screens
Dynatrace Hub
All (876)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
