Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
IBM DatapowerIBM Datapower
IBM Datapower
IBM Datapower
Enable remote monitoring of your DataPower gateways with this extension.
Extension
Free trialDocumentation
One ready-made dashboard maps every DataPower entity - instances, domains, services, load balancers, and more - at activation.Drill into a single DataPower instance to follow load, connections, and pending messages as they move.Catch a DataPower error right on the affected component before it spreads across your environment.Rank your DataPower services by throughput and spot the slow or unhealthy ones before users notice.
  • Product information
  • Release notes
Overview
DataPower gateways provide mission-critical service/application integration, security, and control. For these devices, Dynatrace offers remote monitoring through the DataPower ActiveGate extension. By ingesting key device data, the extension provides Dynatrace with real-time insight into device health and performance.
Now available in Extensions Framework 2.0, click on Add to environment to get started.
Get started
For more information on the installation and configuration, please see IBM Datapower extension in the Dynatrace Documentation.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Document cache countIBM.DataPower.XMLManager.documentCacheCountNumber of documents in the cacheCount
Document countIBM.DataPower.XMLManager.documentCountNumber of documentsCount
Document cache sizeIBM.DataPower.XMLManager.documentCacheSize-Count
Document byte countIBM.DataPower.XMLManager.documentByteCountNumber of documents in bytesKibiByte
Document expired countIBM.DataPower.XMLManager.documentExpiredCount-Count
SLM Policy messagesIBM.DataPower.SLMPolicy.messagesNumber of messages processed by the statementCount
SLM Policy errorsIBM.DataPower.SLMPolicy.errorsNumber of errors by the statementCount
SLM Policy throttledIBM.DataPower.SLMPolicy.throttled-Count
SLM Policy average timeIBM.DataPower.SLMPolicy.timeAverage-MilliSecond
SLM Policy maximum timeIBM.DataPower.SLMPolicy.timeMaximum-MilliSecond
SLM Policy minimum timeIBM.DataPower.SLMPolicy.timeMinimum-MilliSecond
Active SubscribersIBM.DataPower.activeSubscribersNumber of active subscribersCount
Crypto Engine StatusIBM.DataPower.cryptoEngineStatus-Percent
Records lostIBM.DataPower.recordsLost.count-Count
Pending recordsIBM.DataPower.pendingRecordsQueueNumber of records pending in queueCount
Complete recordsIBM.DataPower.completeRecordsQueueNumber of records completedCount
Pending messagesIBM.DataPower.worklist-Count
LoadIBM.DataPower.load-Percent
Connections acceptedIBM.DataPower.connectionsAcceptedPer minute rate of connections acceptedPerMinute
Active transactionsIBM.DataPower.activeTransactions-Count
UptimeIBM.DataPower.UptimeTotal uptime of the deviceSecond
XML name free percentIBM.DataPower.XMLName.Free-Percent
XML name used countIBM.DataPower.XMLName.Used-Count
XML name maximumIBM.DataPower.XMLName.Maximum-Count
MQQM received faultsIBM.DataPower.MQQM.receiveFaultsNumber of received faults in the MQ queue managerCount
MQQM received messagesIBM.DataPower.MQQM.receivedNumber of received messages in the MQ queue managerCount
MQQM sent faultsIBM.DataPower.MQQM.sendFaultsNumber of sent faults in the MQ queue managerCount
MQQM sent messagesIBM.DataPower.MQQM.sentNumber of sent messages in the MQ queue managerCount
MQQM total connection limitIBM.DataPower.MQQM.totalConnectionLimit-Count
MQQM connectionsIBM.DataPower.MQQM.totalConnectionsNumber of connections for the MQ queue managerCount
MQQM active connectionsIBM.DataPower.MQQM.totalActiveConnectionsNumber of active connections for the MQ queue managerCount
MQQM idle connectionsIBM.DataPower.MQQM.totalIdleConnectionsNumber of idle connections for the MQ queue managerCount
MQQM active frontend connectionsIBM.DataPower.MQQM.activeFrontendConnectionsNumber of active frontend connections for the MQ queue managerCount
MQQM active backend connectionsIBM.DataPower.MQQM.activeBackendConnectionsNumber of active backend connections for the MQ queue managerCount
Task loadIBM.DataPower.Task.load-Percent
Task pending messagesIBM.DataPower.Task.workList-Count
Task CPU usageIBM.DataPower.Task.CPU-Percent
Task Memory usageIBM.DataPower.Task.Memory-Percent
Task file countIBM.DataPower.Task.FileCount-Count
TCP established connectionsIBM.DataPower.TCP.establishedCount of established TCP connectionsCount
TCP SYN SentIBM.DataPower.TCP.synSentCount of SYN requests sentCount
TCP SYN ReceivedIBM.DataPower.TCP.synReceivedCount of SYN requests receivedCount
TCP FIN_WAIT_1 countIBM.DataPower.TCP.finWait1-Count
TCP FIN_WAIT_2 countIBM.DataPower.TCP.finWait2-Count
TCP TIME_WAITIBM.DataPower.TCP.timeWaitCount of TIME_WAITCount
TCP Closed connectionsIBM.DataPower.TCP.closedNumber of closed TCP connectionsCount
TCP CLOSE_WAITIBM.DataPower.TCP.closeWaitCount of CLOSE_WAITCount
TCP LAST_ACKIBM.DataPower.TCP.lastAckCount of LAST_ACKCount
TCP ListenIBM.DataPower.TCP.listen-Count
TCP ClosingIBM.DataPower.TCP.closingNumber of TCP closing connectionsCount
Web service last response timeIBM.DataPower.WebService.lastResponseTime-MilliSecond
Web service failed requestsIBM.DataPower.WebService.failedRequests.count-Count
Web service total requestsIBM.DataPower.WebService.totalRequests.count-Count
Web service successful requestsIBM.DataPower.WebService.successfulRequests.count-Count
Web service timeIBM.DataPower.WebService.serviceTime.count-MilliSecond
HTTP Connection requestsIBM.DataPower.XMLManager.RequestsConnection requests to the XML ManagerCount
HTTP Connections reusedIBM.DataPower.XMLManager.ReuseConnection reuses to the XML ManagerCount
HTTP Connections createdIBM.DataPower.XMLManager.CreateConnections created to the XML ManagerCount
HTTP Connection returnsIBM.DataPower.XMLManager.ReturnConnection returns to the XML ManagerCount
HTTP Connections offeredIBM.DataPower.XMLManager.OfferedConnections offered for the XML ManagerCount
HTTP Connections destroyedIBM.DataPower.XMLManager.DestroyConnections destroyed to the XML ManagerCount
Log events processedIBM.DataPower.LogTarget.process.countTotal amount of log events processed per log targetCount
Log events droppedIBM.DataPower.LogTarget.drop.countTotal amount of log events dropped per log targetCount
Log events pendingIBM.DataPower.LogTarget.pendingTotal amount of log events pending per log targetCount
Log requested memoryIBM.DataPower.LogTarget.requestedMemoryRequested memory of the log targetByte
Free - EncryptedIBM.DataPower.Disk.freeEncryptedFree and encrypted disk sizeMegaByte
Total - EncryptedIBM.DataPower.Disk.totalEncryptedTotal encrypted disk sizeMegaByte
Free - TemporaryIBM.DataPower.Disk.freeTemporaryFree temporary disk sizeMegaByte
Total - TemporaryIBM.DataPower.Disk.totalTemporaryTotal temporary disk sizeMegaByte
Free - InternalIBM.DataPower.Disk.freeInternalFree internal disk sizeMegaByte
Total - InternalIBM.DataPower.Disk.totalInternalTotal internal disk sizeMegaByte
Stylesheet cache sizeIBM.DataPower.XMLManager.stylesheetCacheSize-Count
Stylesheet cache countIBM.DataPower.XMLManager.stylesheetCacheCount-Count
Stylesheet document countIBM.DataPower.XMLManager.stylesheetDocumentCount-Count
Stylesheet pending countIBM.DataPower.XMLManager.stylesheetPendingCount-Count
Stylesheet bad countIBM.DataPower.XMLManager.stylesheetBadCount-Count
Stylesheet duplicate countIBM.DataPower.XMLManager.stylesheetDuplicateCount-Count
Stylesheet executionsIBM.DataPower.XMLManager.stylesheetExecutions-Count
Calls per minuteIBM.DataPower.Service.httpTransactionThroughput-PerMinute
Total transaction timeIBM.DataPower.Service.httpTransactionsTimeTotal amount of time used on transactions per serviceMilliSecond
Service statusIBM.DataPower.Service.status-Percent
Operational stateIBM.DataPower.operationalStateOperational state of a classes' objectCount
Administrative stateIBM.DataPower.adminStateAdministrative state of a classes' objectCount
Link Aggregation StatusIBM.DataPower.LinkAggregationStatus-Percent
Link Aggregation MII StatusIBM.DataPower.LinkAggregationMIIStatus-Percent
Power supplyIBM.DataPower.powerSupplyCurrent status of the power supplyPercent
Case openIBM.DataPower.caseopenIndicates if the case is open or notPercent
Check intrusionIBM.DataPower.checkintrusionIndicates if check intrusion is active or notPercent
System temperatureIBM.DataPower.systemTemp-Count
CPU 1 temperatureIBM.DataPower.cpu1Temp-Count
CPU 2 temperatureIBM.DataPower.cpu2Temp-Count
CPU 1 RPMIBM.DataPower.cpu1rpm-Count
CPU 2 RPMIBM.DataPower.cpu2rpm-Count
Chassis 1 RPMIBM.DataPower.chassis1rpm-Count
Chassis 2 RPMIBM.DataPower.chassis2rpm-Count
Chassis 3 RPMIBM.DataPower.chassis3rpm-Count
Volt 5 sensorIBM.DataPower.volt5-Count
Volt 12 sensorIBM.DataPower.volt12-Count
Volt 33 sensorIBM.DataPower.volt33-Count
ConnectivityIBM.DataPower.connectivityPercentage of successful connectionsPercent
Load Balancer Group - Administrative stateIBM.DataPower.LoadBalancer.adminStateAdministrative state of the load balancer groupCount
Load Balancer - Administrative stateIBM.DataPower.LoadBalancer.memberStateAdministrative state of the load balancerCount
Load Balancer - Operational stateIBM.DataPower.LoadBalancer.operationalStateOperational state of the load balancerCount
Messaging request count totalIBM.DataPower.Messaging.requestCountTotal.count-Count
Messaging error count totalIBM.DataPower.Messaging.errorCountTotal.count-Count
Messaging response count totalIBM.DataPower.Messaging.responseCountTotal.count-Count
Messaging end-to-end average durationIBM.DataPower.Messaging.e2eAverageDuration-MicroSecond
Messaging backend average durationIBM.DataPower.Messaging.backendAverageDuration-MicroSecond
Messaging DataPower client processing average durationIBM.DataPower.Messaging.dpClientProcessingAverageDuration-MicroSecond
Messaging DataPower server processing average durationIBM.DataPower.Messaging.dpServerProcessingAverageDuration-MicroSecond
Messaging end-to-end duration measurementsIBM.DataPower.Messaging.e2eDurationMeasurements.count-Count
Messaging backend duration measurementsIBM.DataPower.Messaging.backendDurationMeasurements.count-Count
Messaging DataPower client processing duration measurementsIBM.DataPower.Messaging.dpClientProcessingDurationMeasurements.count-Count
Messaging DataPower server processing duration measurementsIBM.DataPower.Messaging.dpServerProcessingDurationMeasurements.count-Count
Packets receivedIBM.DataPower.Interface.receivePackets.countNumber of packets received per interfaceCount
Bytes receivedIBM.DataPower.Interface.receiveBps.countNumber of bytes received per interfaceByte
Errors receivedIBM.DataPower.Interface.receiveErrors.countNumber of errors received per interfaceCount
Dropped packages receivedIBM.DataPower.Interface.receiveDrops.countNumber of received packages that have been dropped per interfaceCount
Packets transmittedIBM.DataPower.Interface.transmitPackets.countNumber of transmitted packages per interfaceCount
Bytes transmittedIBM.DataPower.Interface.transmitBps.countNumber of bytes transmitted per interfaceByte
Errors transmittedIBM.DataPower.Interface.transmitErrors.countNumber of errors transmitted per interfaceCount
Dropped packages transmittedIBM.DataPower.Interface.transmitDrops.countNumber of transmitted packages that have been dropped per interfaceCount
Collision countIBM.DataPower.Interface.collisions.countNumber of collisions per interfaceCount
Interface statusIBM.DataPower.Interface.statusCurrent status of the interfacePercent
Api Security Token PeeringIBM.DataPower.Gateway.apiRateLimitingPeering-Percent
Api Rate Limiting PeeringIBM.DataPower.Gateway.apiSecurityTokenPeering-Percent
Api Gateway PeeringIBM.DataPower.Gateway.apiGatewayPeering-Percent
Api Gatewayscript PeeringIBM.DataPower.Gateway.apiGatewayscriptPeering-Percent
Api Probe PeeringIBM.DataPower.Gateway.apiProbePeering-Percent
Api Subscription PeeringIBM.DataPower.Gateway.apiSubscriptionPeering-Percent
Total - RAIDIBM.DataPower.RAID.totalSizeTotal RAID SizeKiloByte
Free - RAIDIBM.DataPower.RAID.freeSpaceFree RAID SizeKiloByte
CPU loadIBM.DataPower.cpuload-Percent
Memory usageIBM.DataPower.Memory.Usage-Percent
Memory totalIBM.DataPower.Memory.Total-KiloByte
Memory usedIBM.DataPower.Memory.Used-KiloByte
Memory freeIBM.DataPower.Memory.Free-KiloByte
Memory requestedIBM.DataPower.Memory.Req-KiloByte
Full version history
ReleaseDate
Update the certifi dependency to address CVE-2026-111943
  • Fix typo in configuration page
This version requires a minimum Dynatrace version of 1.345.0.
Bugfixes
  • Fix missing topology dimensions in alert templates.
  • Added new metric IBM.DataPower.adminState to monitor domain status.
  • Added support for primary tags and primary fields.
⚠️WARNING⚠️: Possible breaking changes and warnings - PLEASE READ before upgrading:
  • This version requires a minimum Dynatrace version of 1.338.0 and a minimum EEC version of 1.313.0.
    • With the inclusion of OpenPipeline processing rules, any metrics ingested from the extension will be processed by a dedicated OpenPipeline pipeline.
    • This means that any dynamic route configured to process any metrics from the extension will be dropped in favor of the dedicated pipeline. Please, refer to pipeline groups to continue using dynamic routes.
    • With the inclusion of OpenPipeline processing rules, any logs ingested from the extension will be processed by a dedicated OpenPipeline pipeline instead of the classic log pipeline.
    • This means that classic rules will no longer be used on logs ingested from the extension. Please be sure to migrate any you still need to OpenPipeline rules.
  • Classic Topology has been modified for all entity types to take into account the port of the configured instance in the ID calculation of the entity in order to properly represent environments where multiple Datapower instances run on the same host.
    • This means that once you enable this version, all Datapower entities in the Classic Topology will change ID and will effectively generate a new entity. Any configuration such as alerts, dashboards, etc. that make use of the explicit ID of a Datapower entity will break.
New in this version:
  • Smartscape on Grail.
    • IBM.DataPower.activeSubscribers is now a default metric and will always be captured.
  • Added 4 metrics to Gateway Peering feature set:
    • IBM.DataPower.Gateway.apiGatewayPeering
    • IBM.DataPower.Gateway.apiGatewayscriptPeering
    • IBM.DataPower.Gateway.apiProbePeering
    • IBM.DataPower.Gateway.apiSubscriptionPeering
  • Added 11 new metrics to the new Messaging feature set:
    • IBM.DataPower.Messaging.requestCountTotal.count
    • IBM.DataPower.Messaging.errorCountTotal.count
    • IBM.DataPower.Messaging.responseCountTotal.count
    • IBM.DataPower.Messaging.e2eAverageDuration
    • IBM.DataPower.Messaging.backendAverageDuration
    • IBM.DataPower.Messaging.dpClientProcessingAverageDuration
    • IBM.DataPower.Messaging.dpServerProcessingAverageDuration
    • IBM.DataPower.Messaging.e2eDurationMeasurements.count
    • IBM.DataPower.Messaging.backendDurationMeasurements.count
    • IBM.DataPower.Messaging.dpClientProcessingDurationMeasurements.count
    • IBM.DataPower.Messaging.dpServerProcessingDurationMeasurements.count
  • Expose port dimension on all metrics
  • Added support for python 3.14
⚠️ Important Change:
  • This release requires a Minimum Dynatrace Version of 1.318.0 or higher.
  • Added ALERT_TEMPLATES for anomaly detectors in the Davis Anomaly Detection app (latest Dynatrace only).
  • Added keyword key value pairs to extension
NOTE:
  • This extension requires ActiveGate version 1.313.0 or later.
New in this version
  • Implemented EndpointStatuses.
Improved in this version
  • Improved error messaging with DECs.
🚀 Improved in this version:
  • Timeout when calling Datapower increased
  • Logs are much less verbose now with INFO level for easier troubleshooting
✨ New in this version:
  • Add support for the dt.security_context attribute
  • DNS resolution to obtain the device.address now runs only after a specific frequency and not every time we push a metric. This frequency can be modified with the new Hostname resolution frequency configuration parameter, which defaults to every 24 hours.
🐛 Fixed in this version:
  • Dimensions now properly never go above the limit of 256 characters
  • Further parse dimensions to avoid metric rejections based on tab characters
  • Fixed overview dashboard referencing an inexistent metric
  • urrllib3 library updated to avoid security risk
  • Added support for gen3 charts/screens for future compatibility with I&O app
  • Adds device.address dimension to all ingested metrics.
  • Adds RAID metrics feature set and metrics (Chart can be found in DataPower Instance UA Screen):
    • IBM.DataPower.RAID.totalSize
    • IBM.DataPower.RAID.freeSpace
  • Adds Gateway Peering metrics feature set and metrics (Chart can be found in Datapower Domain UA Screen):
    • IBM.DataPower.Gateway.apiRateLimitingPeering
    • IBM.DataPower.Gateway.apiSecurityTokenPeering
  • Fixes MQQM metrics for versions 9+.
  • Fixed a bug where MQ metrics were not being captured correctly for versions 9 and above of Datapower.
  • Fixed a bug where the metric IBM.DataPower.LoadBalancer.adminState was not being linked to any entity.
  • Added 3rd gen dashboard
  • Fixed a bug where data stopped being ingested for older versions of Datapower
  • Added support for MQ Manager metrics for IBM Datapower version 9+.
  • Added support for API Gateway service metrics.
  • Fixed a bug where object status metrics were not being captured correctly.
  • Fixed issue where username/password fields were still appearing if credential vault toggle was on.
  • Increased maximum number of splits per metric from 1000 to unlimited.
  • Added support for configuring credentials directly from the credential vault.
  • Added 5 new metrics for Web Services, with their relevant generic entity, relationships and chart:
    • IBM.DataPower.WebService.lastResponseTime
    • IBM.DataPower.WebService.failedRequests.count
    • IBM.DataPower.WebService.totalRequests.count
    • IBM.DataPower.WebService.successfulRequests.count
    • IBM.DataPower.WebService.serviceTime.count
  • Properly escape special characters to prevent invalid lines.
  • Automatically shrink dimension values to avoid exceeding the limit.
  • Fixed a bug where the relationship between a datapower instance and a datapower task was inexistent
  • Disabling feature sets now prevents the extension from performing the queries related to the metrics included in said feature sets.
Attention: This version brings breaking changes to existing configurations, meaning you will need to re-create your configurations from scratch when updating them.
New additions:
  • A total of 65 metrics split between 9 feature sets
  • Charts where relevant for the above metrics
  • Topology for MQ Managers and SLM Policies, entities introduced with the new metrics, including their relationships to the rest of the topology
  • Configuration parameters for filtering the above entities
  • Configuration parameter to accept client certificate configuration
  • Configuration parameter bucket size for configuring how many endpoints should run on each - ActiveGate of the selected ActiveGate group for better balancing
Add support for python 3.14
  • Fixed a bug where metrics were not attached to any entity
  • Fix an issue where sometimes the connectivity metric was not pushed correctly
  • Fixed a bug where the availability metric was not ingested correctly when Datapower worked with too many IPs
  • Fixed a bug where Load Balancer entities where not being generated
  • Fixed a bug where MINT lines were too long to be ingested
  • Fixed a bug where incorrect timezone/timestamp would prevent metrics from being ingested
  • Added option for exclude rules instead of only include.
  • Added support for multiple endpoint configuration.
    • This changes the activation schema which will prevent you from updating your older configurations to this new version. You will need to create your configurations from scratch.
  • Fixed a bug with topology where entities of different domains were being merged.
Modified the overview dashboard to show interface traffic instead of status, as the status is missing from many datapower installations.
  • Added new metric IBM.DataPower.activeTransactions and added graph for it on the DataPower instance screen.
  • Extension no longer pushes events but pushes logs instead.
    • This new feature allows you to create your own alerting based on these logs.
    • A new configuration parameter has been included to control log ingestion to either enable or disable it.
      • Because of this new parameter, old configurations of the extension cannot be migrated to this version and instead you have to re-create them from scratch.
  • Fixed a bug where non-existing load balancer metrics would crash the entire extension.
  • Fixed a bug where interface metrics where never captured
Extension conversion to Extensions Framework 2.0:
  • Added custom topology for Datapower entities and their relationships
  • Added screens for all the entities
  • Added metric metadata
  • Added metric events for alerting
  • Added out of the box dashboard
  • Added feature sets
  • Added metrics for interfaces, services, load balancers and admin/oper status of objects
  • Replaced regex with Dynatrace-friendly rules
  • Removed configuration for client certificate
All metrics ingested by the new extension are prefixed with IBM.DataPower and drop the builtin:tech prefix. Any older configuration such as metric events or dashboards that use the old metric key will need to be replaced with the new one.
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
