Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
HPE Integrated Lights-Out (iLO)HPE Integrated Lights-Out (iLO)
Remotely collect iLO data via the Redfish API.
Extension
Free trialDocumentation
Gen3 dashboard showing monitored iLO hosts.First set of metrics on the iLO entity. Shows a log record.Expanded properties of the iLO host.Portion of the iLO entity screen showing additional metrics.
  • Product information
  • Release notes
Overview
Integrated Lights-Out (iLO) is a proprietary management technology built into HPE products that allows for remote control access to ProLiant servers even without being connected to the main network. The iLO extension allows for remote monitoring of such instances via their Redfish API (first introduced in iLO 4).
Use cases
  • Monitor iLO instance health and availability
  • Quickly alert on health or availability related issues
  • View and alert on instance activity such as logins, virtual power events, log clears, and some configuration changes
Get started
For more information on the installation and configuration, please see HPE Integrated Lights-Out (iLO) extension in the Dynatrace Documentation.
Details
Compatibility information
  • iLO 4
  • iLO 5
  • iLO 6 (limited testing)
iLO 4 was the first version with the Redfish API and as such reports a much smaller amount of data as compared to later versions, primarily limited to instance properties and high-level health statuses.
iLO 6 has been tested to a limited extent but has not been confirmed to have run on a live iLO 6 instance. While safe to use, if you experience issues or feel something is missing reach out to support to help us better cover this latest version.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Chassis healthhp.ilo.chassis.healthOverall chassis healthState
Chassis power supply healthhp.ilo.chassis.power_supply.healthChassis power supply healthState
Chassis temperature healthhp.ilo.chassis.temperature.healthChassis temperature healthState
Chassis temperature readinghp.ilo.chassis.temperature.readingCurrent chassis temperature readingCount
Chassis fan healthhp.ilo.chassis.fan.healthChassis fan healthState
Chassis fan readinghp.ilo.chassis.fan.readingCurrent chassis fan temperature readingCount
Chassis power supply redundancyhp.ilo.chassis.power_supply_redundancy_healthIndicates whether the chassis power supply is redundant or notState
Chassis smart storage battery healthhp.ilo.chassis.smart_storage_battery.healthChassis smart storage battery health (iLO 5)State
Chassis smart storage battery charge levelhp.ilo.chassis.smart_storage_battery.charge_level_percentChassis smart storage battery charge level (iLO 5)Percent
Total system memoryhp.ilo.memory.total_system_memoryTotal system memoryGibiByte
Power on timehp.ilo.uptimePower on time/uptime as reported by the APISecond
CPU utilizationhp.ilo.cpu_utilReported CPU utilizationPercent
I/O bus utilizationhp.ilo.io_bus_utilInput/output bus utilizationPercent
Memory bus utilizationhp.ilo.memory_bus_utilMemory bus utilizationPercent
BIOS or hardware healthhp.ilo.health_status.bios_or_hardware_healthBIOS or hardware healthState
Fan healthhp.ilo.health_status.fansFan healthState
Fans redundancyhp.ilo.health_status.fans_redundancyIndicates whether the fans are redundant or notState
Memory healthhp.ilo.health_status.memoryMemory healthState
Network healthhp.ilo.health_status.networkNetwork healthState
Power supply healthhp.ilo.health_status.power_suppliesPower supply healthState
Power supply redundancyhp.ilo.health_status.power_supplies_redundancyIndicates whether power supplies are redundantState
Processor healthhp.ilo.health_status.processorsOverall processor(s) health statusState
Temperature healthhp.ilo.health_status.temperaturesTemperature healthState
Smart storage battery healthhp.ilo.health_status.smart_storage_batterySmart storage battery health (iLO 5)State
Smart storage logical drive capacityhp.ilo.smart_storage.logical_drive.capacitySmart storage logical drive capacity (iLO 5)GigaByte
Availabilityhp.ilo.availabilityThe ability to connect and login to the iLO instancePercent
Aggregate server healthhp.ilo.health_status.aggregate_server_healthOverall health stateState
Graphical console enabledhp.ilo.manager.graphical_console_enabledIndicates whether the graphical console is enabled or notState
Processor healthhp.ilo.processor.healthIndividual processor healthState
Drive healthhp.ilo.storage.drive.healthIndividual storage drive healthState
Full version history
ReleaseDate
✨ New in this version:
  • Added support for python 3.14
  • iLO Integrated Management Logs (IML) can now be ingested as Logs.
  • Vulnerability fix for ply:3.11 (CVE-2025-56005).
  • Ensure required dimensions exist for entity creation
  • Update Dashboard App dashboards to use latest entity list urls
🚀 Improved in this version:
  • Standardized reporting for device.address dimension.
  • Monitoring configuration statuses are now returned per endpoint.
  • Resolved an issue that affected execution due to daylight time change.
ℹ️ This version requires ActiveGate version 1.313.0 or higher.
Minimum Dynatrace version: 1.310
  • Platform dashboard and screen definitions
  • Security context added to entities
  • Handling of lack of support for Odata query parameters in early iLO 4
    • Will make individual calls for processor level data if expand doesn't work
    • Detects and disables querying for logs if parameters do not work to avoid errors and overhead
Minimum ActiveGate version: 1.310 (no change from previous version)
Fixes
  • Change endpoint level username and password configurations to optional
  • Adds "device.address" dimension to all ingested metric data
  • Initial version including packaging error fix
Dynatrace Hub
All (888)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
