Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
GitHubGitHub
GitHub
GitHub
Amend files in GitHub repositories for GitOps-based remediation
App
Free trialDocumentation
- Follow a GitOps-compliant approach and amend configuration files in the underlying state repository
- Retrieve files from a GitHub repository
  • Product information
  • Release notes
Overview
Integrate your Dynatrace environment with GitHub for GitOps-compliant automation and remediation: retrieve files from repositories, update files in a state repository, and create pull requests.
Use cases
This enables you to:
  • Perform GitOps-compliant automation and remediation scenarios, for example, rightsizing a PVC by amending the configuration in the underlying state repository
Get started
Follow the instructions detailed in Dynatrace Documentation.
Ensure that you have installed GitHub, that outbound connections are configured, and that the connection to GitHub is authorized.
Details
GitHub enables users to amend files in state repositories to follow a GitOps-compliant approach for automation and remediation:
Define various incident triggers:
  • Use the power of DQL and leverage events to react to any problem, security incident, or attack to trigger a pipeline run
  • Use SDLC events as a trigger to react on extended events like a deployment event, failed release validation with Site Reliability Guardian, specific log messages, or external system events
  • Define a scheduler for periodic tasks
Repository Management
  • Get File content
  • Create a new file, replace or delete an existing file in your repository
  • Create a pull request, list pull requests, or merge an existing pull request
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
  • Added workflow template for pull request review reminder
  • Added workflow tempalte to notify on failed GitHub Actions run
  • Adapted connection settings page according to style guide
  • Updated dependencies
  • Updated internationalization
  • Trigger workflow run: Added new action
  • Create issue: Added new action
  • Create comment: Added new action
  • Get latest workflow run: Added new action
  • Update issue: Added new action
  • Fixed scroll bars in create/edit connection dialogs
  • Improved error messages for connectors management
  • Changed the styling of the table in the connection overview
  • Improved internationalization
  • Changed the legacy hint text in the connection overview
  • Added history revision for connection settings
  • Fixed wrong background color in light theme
  • Reworked message containers design and hint texts in the modal, intent and connection overview
  • Fixed bug where the connection settings form stayed open after editing a connection
  • Increased schema version
  • Improved error handling of GitHub server-side issues
  • Added expression validation
  • Adjusted height in create and edit connection intent
  • Added further validation to the create/edit connection form to deny connection names that begin or end with whitespaces
  • Migrated to owner based access control
  • Improved user facing error message if a directory path is provided instead of a file path.
1.4.2
  • Renamed app to "GitHub" (former "GitHub for Workflows")
1.4.1
  • Group related input fields by headers
  • Fixed unnecessary scrollbar in ConnectionOverview by updating dependencies
1.4.0
  • Added query parameters when creating or editing a connection
  • Grouped related input-fields visually
1.3.0
  • Added expression support for connection picker
  • Made app headless
1.2.1
1.2.0
  • Added confirmation modal for closing unsaved connection settings
  • Updated dependencies and resolved deprecation warnings
1.1.0
  • Aligned footer and use case text in connection overview
  • Hint text improvements
  • Updated app icon
1.0.1
  • Fixed missing scroll bar in dropdowns for Chrome versions 129.0.6668.xx or higher
1.0.0
  • Introduce a new, streamlined connection management experience with a modernized interface. This update makes adding and editing connections directly within workflows easier and provides connection control and convenience in one place.
0.8.0
  • Added connector management overview
  • Added create and edit connection intents
Dynatrace Hub
All (884)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
