Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
GitHub Enterprise - SNMPGitHub Enterprise - SNMP
Monitor your GitHub Enterprise instance remotely with SNMP
Extension
Free trialDocumentation
Overview dashboardExtension ConfigurationExtension MetricsCustom GitHub Instance entity screen
  • Product information
  • Release notes
Overview
This extension collects infrastructure metrics to provide insights into the resource usage, health and availability of your GitHub Enterprise instances. Metrics are collected through SNMP get polling
  • Instance - CPU, Memory, Disk, Processes, Uptime
  • Disk - space, inodes, usage
  • Interfaces - bytes (octets) received, transmitted
Use cases
Remotely monitor the infrastructure health of your GitHub Enterprise instances
Get started
For more information on the installation and configuration, please see GitHub Enterprise - SNMP extension in the Dynatrace Documentation.
Details
Compatibility information
  • SNMPv2c and SNMPv3
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Time since the last re-startgithub.sys.uptimeThe time (in hundredths of a second) since the network management portion of the system was last re-initializedCount
Number of processesgithub.sys.processesThe number of process contexts currently loaded or running on the host.Count
Host memorygithub.memory.sizeAmount of RAM on the hostKiloByte
Total swap sizegithub.memory.swap.sizeThe total amount of swap space configured for this host.KiloByte
Available swap spacegithub.memory.swap.availableThe amount of swap space currently unused or available.KiloByte
Amount of free memorygithub.memory.freeThe total amount of memory free or available for use on this host.KiloByte
Amount of shared memorygithub.memory.sharedThe total amount of real or virtual memory currently allocated for use as shared memory.KiloByte
Amount of buffered memorygithub.memory.bufferedThe total amount of real or virtual memory currently allocated for use as memory buffers.KiloByte
Amount of cached memorygithub.memory.cachedThe total amount of real or virtual memory currently allocated for use as cached memory.KiloByte
User CPU timegithub.cpu.user.usagePercentage of user CPU timePercent
System CPU timegithub.cpu.system.usagePercentage of system CPU timePercent
Idle CPU timegithub.cpu.idle.usagePercentages of idle CPU timePercent
Octets received (high capacity)github.if.hc.in.octets.countThe total number of octets received on the interface including framing characters. This metric uses 64 bit counter and should be used for highspeed devices.Count
Octets transmitted (high capacity)github.if.hc.out.octets.countThe total number of octets transmitted out of the interface including framing characters. This metric uses 64 bit counter and should be used for highspeed devices.Count
Disk sizegithub.disk.sizeTotal size of the disk/partionKiloByte
Available disk spacegithub.disk.space.availableAvailable space on the diskKiloByte
Used disk spacegithub.disk.space.usedUsed space on the diskKiloByte
Disk space usagegithub.disk.space.usagePercentage of space used on diskPercent
Disk inodes usagegithub.disk.inodes.usagePercentage of inodes used on diskPercent
Full version history
ReleaseDate
  • Add platform dashboard
  • Update Unified analysis screens for platform apps
  • Add dt.security_context
  • Fix child_of relationship mappings
  • Remove 32 bit counter interface metrics
  • Update metric unit from Count to KiloByte for disk and memory
  • Clean up metric names and descriptions
  • Fix the metricgithub.memory.used to report the correct memory used stat. Note the key is now: func:github.memory.used
  • Bug fix: Poll for additional storage devices
  • Collect SNMP infrastructure metrics
  • Metric metadata
  • Custom topology entity types and relationships
  • Overview dashboard
Dynatrace Hub
All (884)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
