Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
DashboardsDashboards
Dashboards
Dashboards
App
Try in PlaygroundDocumentation
Get real-time insights by transforming complex data into dynamic, interactive dashboards.Start fast using our ready-made dashboards, designed for your everyday needs.Build your dashboard effortlessly with only a few clicks.Customize any visualization with ease.Experience dynamic and interactive dashboards with versatile variable filtering.Share your insights with others in seconds.
  • Product information
  • Release notes
Overview
Dashboards is one of the built-in apps shipped with Dynatrace. It provides you with the quickest and most convenient way to go from selecting your data, to visualizing, and observing it.
Along with the creation of dashboards, the app provides you with the flexibility to present your data your way. When you create a dashboard, the Dashboards app allows you and others to quickly gain real-time insights into the most important aspects of your data. For example, you can use Dashboards to track major software releases or to observe the digital experience of your customers during peak business periods, such as Black Friday.
This is intended for users who:
  • Need to get fast and easily accessible insights into their observability, business, or security data.
  • Want to create unique, powerful dashboards utilizing an impressive and comprehensive toolkit.
Use cases
Dashboards enables you to:
  • Use readymade dashboards to monitor your system status in real-time.
  • Create custom dashboards effortlessly with an easy-to-use editor or Davis CoPilot™.
  • Drill down into your data through seamless integration with other Dynatrace Apps.
  • Utilize the power of Davis AI for spotting anomalies and forecasting directly on your charts.
  • Search for any data type across the platform and combine them even with external data in a single view.
  • Configure variable filters to monitor different resources within a single dashboard.
Get started
The Dashboards app comes preinstalled with all Dynatrace SaaS environments.
We recommend that you open Dashboards and run through the Getting started dashboard to become familiar with Dynatrace Dashboards. The Getting started dashboard appears when you open Dashboards for the first time. You can return to this dashboard anytime from the help (?) menu in the upper-right corner of the app.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Dashboards
Grail logo
Grail
Dynatrace's data lakehouse providing unified storage for any type of data.
Investigations logo
Investigations
Notebooks logo
Notebooks
Smartscape logo
Smartscape
Full version history
ReleaseDate
1.343.1
Patch Changes
  • Fixed queries being incorrectly blocked from running when they contained a $ that was not a variable reference. PAPA-34400
  • Kept dashboard validations as warnings. PAPA-34410
1.343.0
Minor Changes
  • Added entry to the tile menu to create a new annotation. PAPA-34092
  • Moved the version history of dashboards to the document actions menu. PAPA-33476
  • Introduced the Image tile for displaying images on dashboards. PAPA-34058
  • Added Shift+I keyboard shortcut to insert an Image tile and moved the Prompt tile shortcut to Shift+P. PAPA-34022
Patch Changes
  • Fixed Cmd/Ctrl+Click on tile headers and links not behaving as expected. PAPA-34254
  • Fixed an issue where undefined columns in the SLO tile threw an error. APPOBS-36349
  • Fixed an issue where unknown columns in the SLO tile threw an error. APPOBS-36461
  • Fixed Prompt tiles retaining a stale query after a failed prompt translation. PAPA-34064
  • Included the full path of nested properties in JSON editor error messages. PAPA-34184
  • Limited message "Showing first 5 results" to be displayed only if the result of the Variable/Annotation exceeds 5 records. PAPA-33936
  • Fixed an issue where Davis Analyzers used a wrong segment. DI-28530
  • Fixed an issue with tiles being fetched even if their input is empty when the user triggers a refresh or changes the timeframe. PAPA-34066
1.342.2
Patch Changes
1.342.1
Patch Changes
  • Prevented queries that still reference an unresolved variable from being sent to the backend. PAPA-34152
1.342.0
Minor Changes
  • Added alert annotation type. PAPA-32572
  • Improved tile data fetching on variable change. PAPA-33790
  • Added suggestions for code and DQL snippets to the Variables editor when the input is empty. PAPA-32364
Patch Changes
  • Prevented tiles from fetching data while another tile is maximized. PAPA-33385
  • Fixed issue with the scrollbar appearing shortly when opening a dashboard with pre-selected tiles.
  • Improved usability on mobile. PAPA-29781
  • Fixed an issue that prevented displaying the code review banner on shared or imported dashboards with code annotations. PAPA-33893
1.341.4
Patch Changes
1.341.3
Patch Changes
  • Restored the previous polling behavior for Grail queries. PAPA-33887
1.341.2
Patch Changes
  • Fixed the "Names" data mapping for some timeseries results. PAPA-33811
1.341.1
Patch Changes
  • Changed the DQL editor autosuggestion behavior to only open on typing, pressing Ctrl + Space, or focusing an empty editor. PAPA-33736
1.341.0
Minor Changes
  • Added custom action handlers for the annotation marker tooltip. PAPA-28084
  • Changed the way hidden select variables handle their default value. Hidden single-select variables always resolve to the first available option and hidden multi-select variables always resolve to * (WILDCARD). Hidden variables are now always fetched. PAPA-29443
Patch Changes
  • Fixed JSON editor showing stale content after deleting an invalid tile through the UI. PAPA-33489
  • Fixed an issue where showing a tile preview results in a layout shift due to the appearance of the scrollbar. PAPA-33369
  • Improved undo/redo for CoPilot tiles. PAPA-33215
  • Removed extra whitespace from the bottom of the dashboard grid. PAPA-32121
  • Fixed rounded corners on loading table tiles. PAPA-33342
  • Updated error message styling of SLO tiles to be consistent with other tile types. APPOBS-34035
1.341.3
Patch Changes
1.341.2
Patch Changes
1.341.1
Patch Changes
1.341.0
Minor Changes
Patch Changes
1.340.1
Patch Changes
1.340.0
Minor Changes
  • Improved validation error messages in the JSON editor to help identify and fix configuration issues. PAPA-32997
  • Added a toast on document validation failure. PAPA-32962
  • Added error and warning status icons to annotations picker and added support for displaying warnings in the form. PAPA-32124
  • Enabled query limit settings to be preserved when sharing tiles via intents. PAPA-25802
Patch Changes
  • Improved usability on mobile and small screens. PAPA-29781
  • Fixed the placement of tile previews in certain situations. PAPA-33108
1.339.0
Minor Changes
  • Introduced a JSON editor for the dashboard document. PAPA-29511
  • Added Variables support in Annotations. PAPA-31792
  • Added support for scrolling to a specific tile via the "view-dashboard" intent. PAPA-32312
  • Added multi tile selection via the mouse by pressing SHIFT and drawing a selection rectangle. PAPA-31286
  • Improved JSON editor readability by sorting object keys in a consistent order when the editor opens. PAPA-25792
  • Adjusted variable and annotation UI copy for consistent actions and labels. PAPA-31942
  • Added hidden variables to the URL and enabled changing their values via URL. PAPA-31993
  • Added a warning banner in JSON editor when content is pasted from clipboard. PAPA-29523
Patch Changes
  • Fixed cursor jumping while writing in variables editor. PAPA-32699
  • Fixed annotations not fetching when tile visualization is set to auto-select. PAPA-32986
  • Made tile placement in single column mode more consistent. PAPA-32923
  • Corrected the positioning of the microguide overlay. PAPA-32887
  • Fixed SLO selector flashing a loading spinner and briefly unmounting the whole selector the first time an SLO is picked. APPOBS-29061
1.338.2
Patch Changes
  • Fixed the persistence of custom geometries for chart visualizations. PAPA-33049
1.338.1
Patch Changes
1.338.0
Minor Changes
  • Changed the behavior of which tab is active in the right side panel to keep the current tab if possible. PAPA-9033
  • Excluded read-only Dashboards from auto-mapping for Annotations. PAPA-31148
Patch Changes
  • Fixed an issue with the Variable form that would flicker when the key is changed. PAPA-32498
  • Fixed SLO tile to show a loading spinner when retrying after an error and to always refetch fresh data when switching segments. APPOBS-34411
  • Fixed an issue where newly added or duplicated tiles did not reflect the active zoom selection. PAPA-32624
1.337.5
Patch Changes
1.337.4
Patch Changes
1.337.3
Patch Changes
  • Fixed an issue with single value visualizations displaying no data instead of 0. PAPA-32660
  • Improved the handling of "Connect data points" to avoid potential UI freezes. PAPA-32219
1.337.2
Patch Changes
  • Fixed issues with Segment selector closing unintentionally. APPDEV-16878
1.337.1
Patch Changes
  • Ensured the compatibility with existing backend services. PAPA-32564
1.337.0
Minor Changes
  • Added icons to the tile indicator settings dropdown to help visually identify each indicator type. PAPA-32107
  • Added support for setting tile descriptions for SLO tiles. PAPA-9033
  • Hid the links section for unsupported visualizations and tiles using Dynatrace Intelligence Data Analyzers. PAPA-30957
Patch Changes
  • Fixed variable status indicator alignment when all variables are hidden and the global annotation picker is visible. PAPA-32237
  • Fixed the timeframe not being correctly set on annotations. PAPA-32249
1.337.4
Patch Changes
1.337.3
Patch Changes
1.337.2
Patch Changes
1.337.1
Patch Changes
1.337.0
Minor Changes
Patch Changes
1.336.3
Patch Changes
1.336.2
Patch Changes
  • Fixed table coloring when variables are used. PAPA-32341
1.336.1
Patch Changes
  • Fixed annotations fetching with wrong timeframe and segments on initial dashboard load. PAPA-32249
1.336.0
Minor Changes
  • Adjusted the size of the dotted grid background to always cover the full screen. PAPA-31828
  • Added settings for hiding tile indicators. PAPA-22129
  • Added "Owned by me" and "Shared with me" tabs to the dashboards table page. PAPA-30859 The ?ownedBy= URL parameter is no longer supported. Use the new ?activeTab= parameter instead.
    New tab values:
    • ?activeTab=all – All dashboards (default)
    • ?activeTab=owned-by-me – Dashboards owned by the current user
    • ?activeTab=shared-with-me – Dashboards shared with the current user
    • ?activeTab=ready-made – Ready-made dashboards (replaces ?ownedBy=all-ready-made)
    • ?activeTab=deleted – Deleted dashboards
  • Added Treemap snippets. PAPA-31974
  • Added support for custom and SLO timeframes for SLO tiles. APPOBS-29492
  • Displayed loading message in section title for CoPilot tiles while generating DQL. PAPA-31658
Patch Changes
  • Prevented tile previews from staying on the dashboard after the tile got deleted. PAPA-32027
  • Fixed scrolling into view of tiles in Google Chrome. PAPA-31999
  • Fixed an issue where adding back deleted tiles via undo/redo caused an additional query execution. PAPA-32037
1.336.2
Patch Changes
1.336.1
Patch Changes
1.336.0
Minor Changes
    New tab values:
Patch Changes
1.335.5
Patch Changes
1.335.4
Patch Changes
  • Fixed threshold-based color rules not being applied in the table. PAPA-32210
1.335.3
Patch Changes
  • Fixed coloring issues for table view. PAPA-31805
1.335.2
Patch Changes
  • Sanitized invalid color-palette rules. PAPA-32036
1.335.1
Patch Changes
  • Moved the actions to pin a column to the correct position and added the pin option to the column configuration dialog. PAPA-31908
1.335.0
Minor Changes
  • Introduced annotations feature. PAPA-27284
  • Added undo/redo functionality for changes to the dashboard. PAPA-25767
  • Added the ability to place new tiles relative to the selected one. PAPA-30776
  • Added the annotations toolbar to the maximized tile view. PAPA-31061
  • Integrated annotation code and DQL snippets. PAPA-30382
  • Added a placement preview when duplicating tiles. PAPA-30774
Patch Changes
  • Ensured that duplicated tiles are always scrolled into view. PAPA-31616
  • Fixed incorrect tile alignment when upgrading dashboards from classic dashboards. PAPA-31876
  • Improved performance when selecting other tiles while editing a tile. PAPA-31826
  • Improved navigation blocker alert stability. PAPA-31377
1.334.6
Patch Changes
1.334.5
Patch Changes
  • Fixed an issue where categorical colors were not applied correctly. PAPA-31875
1.334.4
Patch Changes
  • Fixed issue with tiles getting aligned wrong when upgrading a dashboard from Dashboards Classic. PAPA-31876
1.334.3
Patch Changes
  • Fixed Honeycomb issue when applying color palette to the whole chart. PAPA-31851
1.334.2
Patch Changes
  • Fixed some migration issues for color and threshold settings.
1.334.1
Patch Changes
  • Updated the Japanese translations. PAPA-31533
1.334.0
Minor Changes
  • Added the ability to add and edit variables from within the variables form editor. PAPA-30952
  • Added AI-powered tile description generation. PAPA-31292
  • Enabled resizing of multiple tiles at once. PAPA-30361
  • Added markdown compatibility to tile description. PAPA-23780
  • Limited the number of variable values passed to intents to a maximum of 1000. PAPA-31193
  • Improved tile duplication by placing the duplicated tile close to the original one. PAPA-30772
Patch Changes
  • Fixed the loading indicator not showing the correct loading state. PAPA-30864
  • Improved the loading state indication for tiles. PAPA-30799
  • Fixed unnecessary data refetching for tiles with custom segments when global segments changed. PAPA-31025
  • Fixed an issue where tiles would be cut off after resizing if the grid became scrollable. PAPA-31328
  • Made tiles semi transparent while they are being moved or resized to make the grid placement more visible.
  • Fixed an issue where the toolbar is not correctly positioned for selected tiles. PAPA-31297
  • Fixed an issue with meter bar visualizations getting cut off for tiles with a small height. PAPA-30601
  • Reintroduced loading spinner for empty tile states. PAPA-30799
  • Fixed unnecessary data refetching for tiles with segments after closing the detail view. PAPA-30996
1.334.5
Patch Changes
1.334.4
Patch Changes
1.334.3
Patch Changes
1.334.2
Patch Changes
1.334.1
Patch Changes
1.334.0
Minor Changes
Patch Changes
1.332.4
Patch Changes
  • Fixed an issue showing wrong content in the history preview. PAPA-31191
1.332.3
Patch Changes
  • Adapted the snippets to use the correct DQL functions for Smartscape nodes. PAPA-30962
1.332.2
Patch Changes
  • Improved the handling of malformed tile configs. PAPA-30955
  • Added storage:user.replays:read scope to enable querying the user replays table via DQL. PAPA-30919
1.332.1
Patch Changes
  • Fixed a data mapping issue, causing fields of type duration being selected automatically as name fields. PAPA-30875
1.332.0
Minor Changes
  • Improved zooming in combination with complex query analysis timeframes. PAPA-26593
  • Improved screen reader descriptions when focusing tiles. PAPA-30149
Patch Changes
  • Fixed the "New alert" button in charts, now the segment is correctly configured in the created alert. PAPA-30497
  • Adjusted positioning of tile split handlers on tiles with a very small height. PAPA-30585
  • Improved keyboard accessibility of the tile title input. PAPA-30817
  • Fixed the settings panel not closing when no dashboard was selected. PAPA-30511
  • Fixed segment selector adaptive layout to only resize in dashboard header. PAPA-30696
  • Fixed variables auto fetching when referenced in copy-pasted tiles. PAPA-30265
1.331.4
Patch Changes
1.331.3
Patch Changes
  • Improved the suggestion behavior for Explore tile filters. Suggestions for dt.entity._ and dt.smartscape._ fields now include .name and .tags. PAPA-30716
1.331.2
Patch Changes
  • Prevented unnecessary error logs for when switching documents. PAPA-30629
1.331.1
Patch Changes
  • Improved the performance for large dashboards. APPDEV-15811
1.331.0
Minor Changes
  • Added tile Links to the data sent and received via intents. The section's "Add to Dashboard" option from Notebooks App now preserves configured Links. PAPA-30190
  • Changed tile duplication to place tiles below the original when multiple tiles are selected. PAPA-30303
  • Adjusted the distances to the selection border of a tile when moved via keyboard. PAPA-17189
  • Updated the Getting Started dashboard to showcase the variety of possible visualizations. PAPA-30241
  • Reduced the spacing between tiles for improved data density. PAPA-17189
  • Added dashboard fullscreen functionality. PAPA-22834
  • Adjusted the color of the copy variable button. PAPA-26044
  • Added buttons to split tiles. PAPA-28845
  • Added support for DQL interactions in "duration" fields for Explore tiles. PAPA-29760
Patch Changes
  • Prevented keyboard shortcuts while dragging or resizing tiles. PAPA-30277
  • Changed the "Add to notebook" and "Open with" actions in the tile toolbar to allow right-click and middle-click. PAPA-30210
  • Fixed an issue with the hint being shown behind the visualization while moving or resizing a tile with the keyboard. PAPA-30521
  • Improved auto-scrolling behavior when modifying tiles. PAPA-30232
  • Fixed an issue where tiles using the "Raw response" visualization could not be copy-pasted in Firefox. PAPA-30353
  • Improved alignment of the tile toolbar when adding tiles. PAPA-30281
  • Fixed notification chip for variable results to correctly show and hide error, warning, and info messages. PAPA-30381
  • Improved handling for dashboards with invalid variable configurations. PAPA-30180
  • Fixed variable replacement in query when creating an alert via the tile toolbar. PAPA-30365
1.330.2
Patch Changes
  • Fixed metric identifiers for "Reduce to single value" when rate or default is applied. PAPA-30419
1.330.1
Patch Changes
  • Added support for unknown keys in the filter field. PAPA-30368
1.330.0
Minor Changes
  • Added second resize handler (south west) to tiles. PAPA-29499
  • Refined the behavior of duplicating tiles. PAPA-28852
Patch Changes
  • Fixed an issue with tiles phasing through other tiles while moving a tile. PAPA-29499
  • Fixed corrupted variables throwing an error. PAPA-29938
  • Improved grid performance while moving and resizing tiles. PAPA-29499
  • Fixed keyboard navigation when tabbing through tiles. PAPA-29499
  • Improved the scrolling behavior while moving and resizing tiles. PAPA-29499
  • Fixed an issue where the visualization of a tile would change after polling new changes. PAPA-28536
  • Prevented to show an unnecessary browser confirmation dialog when leaving the app after the changes were already discarded. PAPA-29986
  • Fixed an issue where tiles using reserved variables (e.g. $dt_timeframe_from) couldn't be duplicated. PAPA-29887
  • Added segments support for "New alert" button. DI-24471
1.329.3
Patch Changes
  • Fixed the scrolling of suggestions in the FilterField for "Explore" tiles via keyboard. APPDEV-15353
1.329.2
Patch Changes
  • Fixed the persistance of min and max axis values for chart visualizations. PAPA-29783
  • Corrected the handling of quoted variables in the variable dependency checks. PAPA-29596
1.329.1
Patch Changes
  • Optimized migrating of stored dashboards. PAPA-29785
1.329.0
Minor Changes
  • Improved error message for faulty or non-existent dashboard variables. PAPA-23471
  • Added a confirmation modal to let the user review pasted code (from pasted tiles and variables) before adding it to the document. PAPA-27174
  • Added variable execution information in edit view. PAPA-25881
Patch Changes
  • Fixed an issue while duplicating dashboards owned by other users. PAPA-29492
  • Fixed an issue with Davis AI visualization settings not showing up in the 'Visual' tab. PAPA-29479
  • Fixed focus border being partially/not visible for SLO tiles. APPOBS-29483
1.327.4
Patch Changes
  • Removed redundant error logs. PAPA-29409
1.327.3
Patch Changes
  • Prevented very small SLO tiles from getting empty. PAPA-29448
1.327.2
Patch Changes
  • Fixed issue of Show-context-values setting not being persisted for sparklines in single value charts. PAPA-29126
1.327.1
Patch Changes
  • Fixed initialization of predefined timeframe variables. PAPA-29238
1.327.0
Minor Changes
  • Added shortcut for selecting all tiles. PAPA-27967
  • Enabled all interactions for fetch type Explore tiles. PAPA-27588
  • Added zoom functionality to Heatmap and Scatterplot. PAPA-27450
  • Changed delete confirmation dialog text for tiles and variables. PAPA-19803
Patch Changes
  • Fixed an issue with the variable form not updating after polling new changes. PAPA-28768
  • Aligned visual hover state of tile indicator icons. PAPA-28762
  • Prevented code tiles from refreshing when closing the detail view and the input has not changed. PAPA-28701
  • Fixed an issue where the variables list was incorrectly closed when variables were added or removed in another browser instance on the same dashboard. PAPA-28772
  • Fixed an issue that lead to variables $dt_timeframe_from/to having a wrong value when a dashboard is opened. PAPA-28429
1.327.3
Patch Changes
1.327.2
Patch Changes
1.327.1
Patch Changes
1.327.0
Minor Changes
Patch Changes
1.326.5
Patch Changes
  • Fixed a data mapping issue affecting categorical bar charts, which made certain fields not selectable. PAPA-28973
1.326.4
Patch Changes
  • Fixed an issue with unexpected types in a DQL query result. PAPA-28909
1.326.3
Patch Changes
  • Fixed axes label toggle switch for Scatterplot visualization. PAPA-28829
1.326.2
Patch Changes
  • Improved the handling of invalid filter inputs in Explore tiles. PAPA-28145
1.326.1
Patch Changes
  • Fixed some rendering issues in the scatterplot visualization. PAPA-28763
1.326.0
Minor Changes
  • Provided a "New alert" button in the tile toolbar. PAPA-28308
  • Changed empty view for variables list. PAPA-28083
Patch Changes
  • Excluded false-positive warnings from query execution results when variables are used. PAPA-28261
  • Improved navigation blocking when the user has unsaved changes. PAPA-28409
  • Prevented the keyboard focus outline around SLO tiles from being cut off. PAPA-28460
  • Fixed "Add to notebook" functionality for markdown and code tiles. PAPA-28322
  • Fixed an issue where the dashboard could result in an error after polling changes. PAPA-28739
  • Fixed an issue with variables not updating correctly after polling changes. PAPA-28679
  • Fixed an issue with variables wrongly displaying an "unused" warning. PAPA-28337
  • Fixed an issue with the "Review code" banner re-appearing after polling new changes. PAPA-28466
1.325.6
Patch Changes
1.325.5
Patch Changes
1.325.4
Patch Changes
  • Disabled unsuitable visualization. PAPA-28692
1.325.3
Patch Changes
  • Fixed a performance issue with the Heatmap visualization. PAPA-28584
1.325.2
Patch Changes
  • Fixed an issue displaying COUNT units in the "Units and formats" settings section entries. PAPA-28468
1.325.1
Patch Changes
  • Fixed an error in the scatterplot zoom interactions. APPDEV-14708
  • Fixed issue with the "Review code" banner re-appearing after polling new changes. PAPA-28466
1.325.0
Minor Changes
  • Added a toast telling the user that tiles have been successfully added via an intent. PAPA-27353
  • Increased performance by not loading tiles while the user is scrolling over them fast. PAPA-27098
  • Added scatterplot snippets. PAPA-26854
  • Notify user about columns being hidden by default. PAPA-27526
Patch Changes
  • Fixed an issue with DQL tiles not showing the visualization correctly when using davis. PAPA-28403
  • Hide "Add to notebook" menu option from SLO tiles. PAPA-28336
  • Provided migration for legacy 'Explore' tiles. PAPA-28164
1.325.5
Patch Changes
1.325.4
Patch Changes
1.325.3
Patch Changes
1.325.2
Patch Changes
1.325.1
Patch Changes
1.325.0
Minor Changes
Patch Changes
  • Fixed an issue with DQL tiles not showing the visualization correctly when using Davis. PAPA-28403
  • Hid "Add to notebook" menu option from SLO tiles. PAPA-28336
1.324.5
Patch Changes
1.324.4
Patch Changes
  • Fixed performance issues with large dashboards, potentially leading to tiles not being editable anymore. PAPA-28344
1.324.3
Patch Changes
  • Solved issue with units overrides for Y axes in timeseries visualizations. PAPA-28314
1.324.2
Patch Changes
  • Fixed app recommendation when opening result values with other apps. PAPA-28169
1.324.1
Patch Changes
  • Fixed data-mapping persistence for pie/donut charts. PAPA-28152
  • Fixed display value errors on suggestion groups for "Explore data" tiles. PAPA-28065
1.324.0
Minor Changes
  • Improved resize performance for Davis and SLO tiles. PAPA-27280
  • Added warning/error info button to variables toolbar. PAPA-27285
  • Updated the 'Units and formats' visual settings with a redesigned, more intuitive interface. PAPA-22025
Patch Changes
  • Added divider between "Add to Notebook" and "Open With" actions. PAPA-27812
  • Prevented the "Switch Layout" banner from appearing again after being dismissed. PAPA-27885
  • Aligned the styling of tiles in loading state. PAPA-27817
1.324.4
Patch Changes
1.324.3
Patch Changes
1.324.2
Patch Changes
1.324.1
Patch Changes
1.324.0
Minor Changes
Patch Changes
1.323.5
Patch Changes
1.323.4
Patch Changes
1.323.3
Patch Changes
1.323.2
Patch Changes
  • Set interval field as not required in timeseries datamapping. PAPA-27938
1.323.1
Patch Changes
1.323.0
Minor Changes
  • Included add to notebook option to context menu. PAPA-26562
  • Improved dashboard loading performance. PAPA-27145
  • Allowed "Run Query" action by using Cmd/Ctrl + Enter hotkeys. PAPA-27078
  • Removed threshold navigation button for Scatterplot visualization. PAPA-26726
  • Replaced the variables action menu with a new icon and moved it to the start of the toolbar. PAPA-27301
Patch Changes
  • Introduced a toast when the dashboard duplication failed. PAPA-27625
  • Fixed an issue with the discard changes buttons appearing when opening ready made dashboards. PAPA-27614
  • Fixed an issue with the discard changes buttons appearing when changing the timeframe. PAPA-26949
  • Fixed an issue with the discard changes buttons appearing without any changes. PAPA-26949
  • Fixed an issue where tiles can go into an error state after polling. PAPA-27506
1.323.4
Patch Changes
1.323.3
Patch Changes
1.323.2
Patch Changes
1.323.1
Patch Changes
1.323.0
Minor Changes
Patch Changes
1.322.6
Patch Changes
1.322.5
Patch Changes
1.322.4
Patch Changes
  • Fixed persisting the data mapping for pie and donut charts. PAPA-27801
1.322.3
Patch Changes
  • Fixed default behavior for Show icon setting when using "Open with...". PAPA-27594
  • Fixed displaying chart when there are some options still available for the user. PAPA-27535
  • Improved style for "Unsupported Visualization" error state. PAPA-27600
  • Fixed dynamic label dropdown so it is no longer disabled when there are options for Single Value. PAPA-27606
1.322.2
1.322.1
Patch Changes
1.322.0
Minor Changes
  • Made result of query execution accessible for screen readers. PAPA-26954
  • Made segments selector responsive. PAPA-27139
  • Renamed 'Open with' in the tile toolbar to 'Open with…'. PAPA-26982
Patch Changes
  • Removed autofocus from the minimize tile button after maximizing a tile. PAPA-27247
  • Added validation when pasting a tile to a dashboard. DTSEC-18204
  • Fixed and issue with persisting the output selection for davis visualizations. DI-21804.
  • Disabled keyboard shortcuts where they could lead to issues. PAPA-27119
  • Improved accessibility in keyboard mode by autofocusing newly created dashboards. PAPA-27041
  • Fixed an issue where discarding local changes would not have an effect. PAPA-27190
1.322.5
Patch Changes
  • Set the interval field as not required in timeseries data mapping. PAPA-27938
1.322.4
Patch Changes
1.322.3
Patch Changes
1.322.2
1.322.1
Patch Changes
1.322.0
Minor Changes
Patch Changes
1.321.1
Patch Changes
  • Fixed an issue with the "Show threshold in a row" option for tables only highlighting the cell. PAPA-27295
1.321.0
Minor Changes
  • Added dt.queryRaw to 'Open with' from 'Explore' tiles. PAPA-26901
  • Unified intents for 'Explore' and DQL tiles. PAPA-26606
  • Updated the icon used for dashboard documents. PAPA-27052
  • Improved the maximized tile view. PAPA-26101
  • Made timeframe selector responsive. PAPA-26546
Patch Changes
  • Fixed an issue where changes to the SLO tile's visualization options were not being reflected correctly. APPOBS-8747
  • Fixed minor visual details for the ready-made banner. PAPA-26864
  • Fixed an issue where chart tooltips remained while scrolling. PAPA-26848
  • Fixed discarding a draft after variable reordering. PAPA-27114
1.320.3
Patch Changes
  • Fixed an issue of the heatmap visualization when using booleans within the 'Data mapping' settings. PAPA-26749
  • Fixed an issue where the user could not set 'Custom colors' for categorical, pie, donut, and histogram charts. PAPA-26875
1.320.2
Patch Changes
  • Unpinned chart tooltips while scrolling. PAPA-26848
1.320.1
Patch Changes
1.320.0
Minor Changes
  • Improved the scrolling performance by keeping tile contents mounted. PAPA-26182
  • Enabled persisting table settings when the detail view is closed. PAPA-26168
  • Updated the app description. PAPA-26737
Patch Changes
  • Ensured dashboards were filtered by search value when receiving the "show-all" intent. PAPA-26496
  • Fixed the invalid focus behavior on variable select. PAPA-26605
1.319.5
Patch Changes
1.319.4
Patch Changes
  • Fixed an issue where invalid unit settings could crash the Visual tab. PAPA-26403
1.319.3
Patch Changes
  • Fixed table flickering when lots of columns are displayed. PAPA-26768
1.319.2
Patch Changes
  • Fixed an issue where "Split by" suggestions for certain metrics in Explore tiles would not show any fields. PAPA-26628
1.319.1
Patch Changes
  • Added sum as an aggregation for gauge metrics. PAPA-26616
1.319.0
Minor Changes
  • Added stepper buttons to the timeframe selector. PAPA-24246
  • Persisted visibility and sorting for dashboards list table columns. PAPA-25887
  • Added raw CSV download option to the table visualization. PAPA-25890
Patch Changes
  • Improved error states to always show errorRef. PAPA-24407
  • Improved performance when resizing the dashboard grid. PAPA-26180
  • Fixed an issue where interacting with the tooltip in heatmap visualizations did not open the options panel. PAPA-26022
1.319.4
Patch Changes
  • Fixed an issue where invalid unit settings could break the Visual tab. PAPA-26403
1.319.3
Patch Changes
1.319.2
Patch Changes
1.319.1
Patch Changes
1.319.0
Minor Changes
Patch Changes
1.318.4
Patch Changes
  • Prevented the DQL2NL query explanation to overflow and render some text unreadable. PAPA-26319
  • Fixed the units override not working for the table visualization. PAPA-26213
1.318.3
Patch Changes
  • Prevented page layout shifts that can hide the top elements of the app. PAPA-26262
1.318.2
Patch Changes
  • Adapted internal limits for storing user specific settings. PAPA-26177
1.318.1
Patch Changes
  • Fixed an issue preventing to change the alerting condition for threshold analyzer. DI-21005
1.318.0
Minor Changes
  • Added banner for ready-made documents to the documents table. PAPA-25282
Patch Changes
  • Added the sidebar toggle button to the empty states. PAPA-25911
  • Fixed an issue where duplicating a tile during an active NL2DQL translation caused the duplicated tile to break. PAPA-25470
  • Fixed query limits being deleted on running an invalid Nl2Dql prompt for a Davis CoPilot tile. PAPA-25871
  • Canceled dashboard autosave when deleting the current opened dashboard. PAPA-26094
  • Fixed tiles crashing when maximizing them while they use variables with circular dependencies. PAPA-26057
  • Fixed Visual tab sections not being scrolled into view when opened via a button on the tile error state. PAPA-25171
  • Fixed an issue where changes to the NL2DQL prompt were not correctly detected after reloading the dashboard. PAPA-25470
  • Fixed issue with used nested variables not being copied when copy and pasting a tile. PAPA-26158
  • Introduced a query limit of 5000 characters for "Explain query with AI" feature. PAPA-20653
  • Added to ignore invalid encoded variable values when a dashboard is loaded. PAPA-26006
1.317.3
Patch Changes
  • Fixed padding in SingleValue tiles. PAPA-26167
1.317.2
Patch Changes
1.317.1
Patch Changes
  • Fix interaction not being applied in the DQLBuilder (PAPA-25913)
1.317.0
Minor Changes
  • Adapted error handling to display Davis CoPilot errors within the tile content and the Options panel. PAPA-24566
  • Added the option for DQL-Builder tiles to convert into DQL tiles for certain interactions. PAPA-24502
Patch Changes
  • Adapted variables unreferenced message in toolbar to appear also if part of the variables are hidden. PAPA-25330
  • Changed comment of the permission storage:files:read. GRAIL-40447
  • Fix Set color and Visual options interactions for Honeycomb. PAPA-25760
1.316.3
Patch Changes
  • Fixed issue of variables not being replaced in the query when creating alerts from chart interactions. PAPA-25601
1.316.2
Patch Changes
  • Fixed an issue where the Data Mapping settings for the Heatmap were reset when rerunning the query. PAPA-25654
1.316.1
Patch Changes
  • 1.316.0
Minor Changes
  • Added a clock icon to the timeframe selector. PAPA-21571
  • Moved SummarizeDQL and DQLDocs buttons to the section header. PAPA-21572
  • Refined the layout of the "Review code" state for tiles. PAPA-24302
  • Add storage:files:read permission. GRAIL-39028
Patch Changes
  • Fixed tile deselection not working when a dashboard reaches a certain height. PAPA-25218
  • Added handlers for new explore panels security events, user sessions and user events. (PAPA-25311)
  • Fixed an issue where the detail view reloaded when a variable selectbox was clicked during variable editing. (PAPA-25495)
  • Removed visibility of the 'Discard changes' button when adding a new tile if no changes were made. PAPA-24997
  • Added download button to heatmap visualization. PAPA-25251
  • Fixed showing Download options for Heatmap. PAPA-25611
  • Added json file extension when downloading a dashboard from the list. PAPA-25147
  • Added a validation check for variables when migrating them. PAPA-25047
1.315.6
Patch Changes
  • Fixed an issue where the Data Mapping settings for the Heatmap visualization were reset when rerunning the query. PAPA-25654
1.315.5
Patch Changes
  • Fixed tile errors when changing the field in threshold overrides. PAPA-25529
  • Fixed tile errors when setting custom colors for map visualizations with a numeric dimension. PAPA-25483
1.315.4
Patch Changes
  • Fixed equal filter for queries with quotes in "Explore" tiles. PAPA-25476
1.315.3
Patch Changes
  • Fixed an issue where tiles remained stuck in loading mode during initial load when hidden variables depended on other hidden variables. PAPA-25297
  • Ensure safe BigInt conversion for table sorting and thresholds. PAPA-25322
1.315.2
Patch Changes
  • Resolved an issue to show the data type for "Copy value" action of table cell. PAPA-25308
1.315.1
Patch Changes
  • Corrected formatting in generated dql for expressions containing aliases in Explore Metrics tiles. PAPA-25235
1.315.0
Patch Changes
  • Fixed the "Custom" option for the Min/Max value of the Left Y-axis setting. PAPA-24957
  • Updated the timeframe indicator tooltip to display future end timestamps correctly. PAPA-24963
  • Resolved an issue where table headers were rendered in front of dragged tiles. PAPA-24965
  • Added search feature to ExpandableDetailsViewSection. PAPA-24795
Dashboards
1.314.7
Patch Changes
1.314.6
Patch Changes
  • Fixed crashing dql-builder when no suggestions are returned from the endpoint.
1.314.5
Patch Changes
  • Fixed expression error handling and resetting the alias for subqueries in "Explore" tiles.
1.314.4
Patch Changes
  • Fixed table headers being rendered in front of dragged tiles.
1.314.3
Patch Changes
  • Fixed column resize issue for "content" column in table visualization for logs.
1.314.2
Patch Changes
1.314.1
Patch Changes
1.314.0
Minor Changes
  • Introduced disabling the "Displayed Timeframe" X-Axis setting when the user is zooming.
  • Added world map snippets.
  • Added column configuration modal to the settings for the table visualization.
  • Adapted behavior of an unreferenced variable warning and the variables action menu inside the variables form.
  • Improved tile resilience to HTTP 429 errors by supporting multiple data request retries.
  • Added buttons for creating a new Service-level objective (SLO) or editing the currently selected one in the SLO tile edit menu.
Patch Changes
  • Removed variables with undefined keys, which caused errors e.g. on upload of a dashboard.
  • Applied the correct visualization for tiles received via intents.
Dashboards
1.314.6
Patch Changes
1.314.5
Patch Changes
1.314.4
Patch Changes
1.314.3
Patch Changes
1.314.2
Patch Changes
1.314.1
Patch Changes
1.314.0
Patch Changes
Dashboards
1.314.5
Patch Changes
1.314.4
1.314.3
Patch Changes
1.314.2
Patch Changes
1.314.1
1.314.0
Minor Changes
Patch Changes
Dashboards
1.313.3
Patch Changes
  • Fixed issue when updating settings for circle charts.
1.313.2
Patch Changes
  • Applied correct visualization for tiles received via intents.
  • Improved the migration of Explore tiles to avoid dashboards without any changes appearing as modified.
1.313.1
Patch Changes
  • Hid snippets for unsupported visualization.
1.313.0
Minor Changes
  • Updated the help menu to align with the common structure for all apps.
  • Added a feedback button to the "Switch Layout" banner displayed after upgrading from Dashboards Classic.
  • Hid thresholds configuration for heatmap visualization.
  • Adapted data and code tiles to still display an error content during subsequent loading.
Patch Changes
  • Applied correct default visualization for tiles received via intents.
  • Fixed charts displaying the wrong timeframe on the x-axis when switching documents.
  • Fixed "Displayed Timeframe Data" setting not being applied to the x-axis of the chart.
  • Added DQL migrated value in Explore tiles, avoiding a state change between Explore tiles version on read-only dashboards.
  • Improved the handling of app error view.
  • Added tile titles to visualization and health snippets.
Dashboards
1.312.4
Patch Changes
  • Fixed "copy to clipboard" interaction: sometimes numbers had a wrong value when copied.
1.312.3
Patch Changes
  • Hid numeric fields by default in series name in timeseries based visualizations.
1.312.2
Patch Changes
  • Fixed 'Displayed Timeframe Data' setting not being applied to the x-axis of the chart.
1.312.1
Patch Changes
  • Fixed issue filtering datapoints out for longitudes greater than 90 and lower than -90 for DotMap, BubbleMap and ConnectionMap.
1.312.0
Minor Changes
  • Adapted the tile states for data mapping errors.
  • Adapted the zoom behavior to show a toast when zooming into a tile with a timeframe set in the query.
Patch Changes
  • Prevented showing the unsaved changes dialog when switching between dashboards and no changes were made.
  • Removed the character limit in the tile description.
  • Fixed nested variables not being counted as a usage of a variable.
  • Ensured to show the code review banner when importing a dashboard containing code tiles or code variables.
  • Prevented broken tiles after the dashboard is reloaded due to changes by another user.
  • Resolved a visual glitch that could occur when refreshing tiles after discarding a draft.
  • Improved the handling of the "view-dashboard" intent to allow navigating back in the browser.
Dashboards
1.311.4
Patch Changes
1.311.3
Patch Changes
1.311.2
Patch Changes
  • Fixed issue with filtering datapoints out for longitudes greater than 90 and lower than -90 for DotMap, BubbleMap and ConnectionMap.
1.311.1
Patch Changes
  • Fixed persistence of "Displayed Timeframe" x-axis setting. Fixed data mapping and custom colors migration for honeycomb visualization.
  • Fixed the issue with breaking the application by choosing an unsupported interaction for a chart.
1.311.0
Minor Changes
  • Integrated a full-screen value inspector for data tiles.
  • Removed unnecessary scopes "app-settings:objects:read", "davis-copilot:conversations:execute", and "slo:objective-templates:read".
  • Aligned the styling of all error, empty, and invalid tile states.
  • Added the scope "storage:security.events:read" to allow access to read security events from Grail.
  • Removed "environment-api:deployment:download" from scopes usable by Code tiles.
  • Hid thresholds tile settings for map visualizations.
  • Adapted styling for variables form and added warning for unreferenced variables.
  • Added support for segments in SLO tiles.
Patch Changes
  • Improved the styling of the header for tiles without a title in maximized mode.
  • Retained the "maximized" parameter in the URL when opening a dashboard link.
  • Fixed x-axis timeframe not being updated for timeseries charts out of view during loading.
  • Applied default values during dashboard validation.
  • Removed incorrectly displayed tile timeframe indicator for newly added tiles.
  • Improved vertical autoscrolling when dragging a tile in Firefox.
Dashboards
1.310.5
Patch Changes
  • Fixed issue of multiple queries with the same metric key in Explore tiles, overwriting actual data.
1.310.4
Patch Changes
  • Integrated a full screen value inspector for data tiles.
  • Fixed displayed timeframe setting persistence for all data types.
1.310.3
Patch Changes
  • Fixed error in table visualization for column type 'log'.
1.310.2
Patch Changes
  • Fixed migration of undefined filters on "Explore" tiles.
1.310.1
Patch Changes
  • Fixed the issue where a custom color displays an empty legend or wrong legend when the color's categorical value is unset or does not match any category.
  • Fixed the assignment of latitude and longitude values when the field contains invalid coordinate data.
  • Fixed selection of old destination dashboard when receiving a tile intent.
1.310.0
Minor Changes
  • Added code tiles that fetch data from remote environments to the snippet menu.
  • Adapted intents to apply an optional "querySettings" property on receive.
Patch Changes
  • Disabled "Not equal" command for Explorer tiles.
  • Changed placeholder in tile description textarea.
  • Corrected a case that was preventing dashboards from loading in Safari.
  • Fixed to navigate image links in markdown tiles.
  • Improved UI for maximized tiles with a long tile title.
  • Corrected the share link not working for tiles in fullscreen mode.
  • Enabled all visualization types when using intents.
  • Selected correct visualization type when enabling 'Davis AI' for 'Explore' tiles.
Dashboards
1.309.6
Patch Changes
  • Fix issue of multiple queries with the same metric key in Explore tiles, avoiding overwriting the value to string.
1.309.5
Patch Changes
1.309.4
Patch Changes
1.309.3
Patch Changes
  • List of values in "Record list" interaction extended to show up to five different entries.
1.309.2
Patch Changes
  • Disable 'Not equal' command for DQL builder tiles.
1.309.1
Patch Changes
  • Fixed an issue where sparkline settings for the Single value visualization were reset when re-running a query.
1.309.0
Minor Changes
  • Added meter and gauge visualizations to the snippets menu.
  • Added health tiles to the snippets menu.
Patch Changes
  • Fixed migration of "Explore" tiles.
  • Hid "Starts with" and "Ends with" operator suggestions for "Explore" tiles.
  • Fixed generated DQL for "Explore" tiles by wrapping wildcards into quotation marks.
  • Removed unused invisible character on "Starts with" suggestion for "Explore" tiles.
  • Fixed endlessly loading dashboards for dashboards with CoPilot tiles in error state.
  • Fixed "Summarize DQL" action to show the correct response.
  • Changed loading for dashboards with an invalid tile configuration.
  • Changed behavior to ignore commented-out variables in code and data tiles.
  • Improved the dashboard validation so that it doesn't interfere with the initial loading.
  • Adapted error handling when the "user app state" service is unavailable.
  • Adapted variables to keep the wildcard selection when a tile using this variable is copied or duplicated.
Dashboards
1.309.5
Patch Changes
1.309.4
Patch Changes
1.309.3
Patch Changes
  • Extended list of values in "Record list" interaction to show up to five different entries.
1.309.2
Patch Changes
  • Disabled 'Not equal' command for 'Explore' tiles.
1.309.1
Patch Changes
1.309.0
Minor Changes
Patch Changes
Dashboards
1.308.7
Patch Changes
  • Fixed issue where visualization resets custom colors even when the data mapping type remains unchanged.
1.308.6
Patch Changes
  • Adapted compatibility of APIs.
1.308.5
Patch Changes
1.308.4
Patch Changes
1.308.3
Patch Changes
  • Fixed timeframe selection format.
1.308.2
Patch Changes
1.308.1
Patch Changes
1.308.0
Minor Changes
  • Updated the variables list by removing the search, added a link to documentation and changed the styling.
  • Removed thresholds for Meter and Gauge visualizations.
  • Adapted result statistics to also display the CoPilot notifications.
Patch Changes
  • Adapted tiles to reload after draft was discarded.
  • Adapted the behavior of nested variables to load even if their dependent variable returns an empty result.
  • Fixed broken Japanese translations.
Dashboards
1.307.7
Patch Changes
  • Fixed issue where visualization resets custom colors when the data mapping type remains unchanged.
1.307.6
Patch Changes
  • Fixed calendar timeframe format.
1.307.5
Patch Changes
  • Improved the dashboard validation so that it does not interfere with the initial loading.
1.307.4
Patch Changes
  • Fixed Explore tiles that were not migrating.
1.307.3
Patch Changes
  • Fixed dashboards not loading due to an invalid tile configuration.
1.307.2
Patch Changes
  • Improved Explore tiles.
  • Fixed hidden variables to load with wildcard as default value.
  • Fixed nested variables to load even if their dependent variable returns an empty result.
1.307.1
Patch Changes
  • Fixed an issue with the chart legend.
1.307.0
Minor Changes
  • Changed visual highlighting of tiles during drag.
  • Changed padding of variables action menu button.
  • Adapted layout and wording for the refresh button.
  • Added an info banner for dashboards with canvas layout.
Patch Changes
  • Fixed not applied dashboard timeframe from intents that contain a document name.
  • Fixed the initial tile selection state to be applied from the URL.
  • Fixed border radius of maximized tiles.
  • Unified behavior for variables which are new and have not been executed yet with variables that have no result.
  • Fixed functionality for discarding local changes in read-only documents.
  • Fixed missing left padding and tile width in mobile mode and added padding beyond dashboard page header.
  • Fixed issue when loading a dashboard.
  • Fixed issue with inputs in tile settings not responding to keyboard events.
  • Fixed result re-rendering on tile selection changes.
  • Fixed tile moving to top when inserted by an intent on canvas layout.
  • Reduced unnecessary tile re-renders on tile timeframe settings change.
  • Prevented automatic execution of a query tile, when a new variable is added in the query.
  • Fixed unwanted “Unsaved changes” popups on read-only dashboards.
Dashboards
1.306.7
Patch Changes
  • Prevent dashboard validation from blocking the loading of a dashboard.
1.306.6
Patch Changes
1.306.5
Patch Changes
  • Load nested variables even if their dependent variable returns an empty result.
1.306.4
Patch Changes
  • Fixed issue for area charts using relative value representation.
1.306.3
Patch Changes
  • Fixed the initial tile selection state not being applied from the URL.
  • Fixed result rerendering on tile selection changes.
1.306.2
Patch Changes
  • Removed the empty-code-tile for ready-made documents.
  • Prevented automatic execution of a query tile when a new variable is added to the query.
1.306.1
Patch Changes
  • Fixed discarding the local changes for read-only documents.
1.306.0
Minor Changes
  • Added search functionality for visualizations.
  • Improved the design of maximized tiles.
  • Redesigned selector for timeframe and refresh and added functionality to see the last refresh rate.
  • Adjusted paddings for dashboard tiles.
  • Allowed modification of read-only and snapshot documents.
  • Extended Dashboard validation.
  • Enabled the auto select for tile visualizations by default and fixed the alignment of the segment selector.
  • Aligned chevron of the segment selector to the right.
  • Added Problems tile.
  • Changed the default text for markdown and updated the refresh icon in the variable menu.
Patch Changes
  • Fixed multi select variable initialization.
  • Fixed loading indicator not shown when input field is cleared during initial loading of a tile.
  • Fixed issue with nonexistent dashboard being loaded after transferring ownership or deleting a dashboard.
  • Improved dashboard migration steps.
  • Improved render performance for tiles with ellipses in the title.
  • Changed the behavior of variables to wait until variables referenced in tiles are ready before loading the content.
  • Disabled visualization auto selection for snippets.
  • Fixed an issue where settings were not saved for tiles with an error result.
Dashboards
1.306.5
Patch Changes
1.306.4
Patch Changes
1.306.3
Patch Changes
1.306.2
Patch Changes
  • Fixed missing left padding and tile width in mobile mode and added padding beyound dashboard page header.
  • Update DQLBuilder to fix migration bug
  • Removed the empty-code-tile ready-made document.
  • Do not execute a query tile automatically, when a new variable is added in the query.
1.306.1
Patch Changes
  • Fix discard local changes for read-only documents.
1.306.0
Minor Changes
  • Timeframe and Refresh selector re-design and added functionality to see last refresh rate.
  • Allow modification of readonly and snapshot documents.
  • Extended DashboardDto's validation.
  • Enabled auto select for tile visualization by default and fixed alignment of segment selector.
  • Added tracking for read only documents and block navigation.
  • Align chevron of segment selector to the right.
  • Add Problems tile.
  • Changed default text for markdown, switched to refresh icon in variable menu.
Patch Changes
  • Apply DQLBuilder external migrations.
  • Fix multiselect variable initializaton.
  • Fixed EmptyTileResultGuard shows empty tile instead of analyzer results.
  • Fixed loading indicator not shown when input field is cleared during initial loading of tile.
  • Fixed issue with non existant dashboard being loaded, after transfering ownership or deleting a dashboard.
  • Set the version if missing in the DTO. Improve validation.
  • Log Zod validation errors as "info".
  • Improve dashboard migration steps.
  • Improve render performance for tiles with ellipsis in the title.
  • Wait until tile variables are ready before loading the content.
  • Disabled autoSelect visualization toggle for snippets.
Dashboards
1.305.8
Patch Changes
  • Fix multi-select variable initialization.
1.305.6
Patch Changes
  • Solve the problem with redundant change set, and version generation
1.305.3
Patch Changes
  • Fix cell padding in the data table.
1.305.2
Patch Changes
  • Fixed the problem with displaying an empty tile instead of the analyzer results.
1.305.1
Patch Changes
  • Exclude values from dimensions in timeseries charts.
1.305.0
Minor Changes
  • Add improvements to the chart zoom feature.
  • Allow opening relative links without reloads.
  • Add description to tiles.
  • Add a feedback button to the dashboard menu.
  • Integrated synchronized crosshair lines for Timeseries Charts.
  • Add layout switch to dashboard settings for canvas mode.
Patch Changes
  • Delayed refresh of tiles if a 429 error is returned (too many requests).
  • Multi-select variable values with commas no longer select wrong values when they are stored in the URL.
  • Rephrased the reload dashboard button in case of an error.
  • Fixed issues where the empty tile view was not displayed correctly.
  • Aligned the look of the timeframe picker and segment selector in the details view.
  • Changed the app icon.
Dashboards
1.304.3
Patch Changes
  • Disabled temporarily "log-content" column type override for data tables.
1.304.2
Patch Changes
  • Fixed thresholds not working for duration fields in data table.
1.304.1
Patch Changes
  • Fix resolveSingleValueDataMappers to enable the trend using the previously selected value.
1.304.0
Minor Changes
  • Removed support for annotation intents.
  • Left sidebar links can be opened in a new tab.
  • Display empty state on ownership change.
  • Added scope "hub:catalog:read".
  • Added markdown toolbar and auto focus the editors when editing a tile.
  • Enable roudned timframes yesterday and today.
Patch Changes
  • Adjust font weight for document sidebar on the left side.
  • Fix unresponsive 'Change limit' button.
Dashboards
1.303.7
Patch Changes
  • Disabled temporarily "log-content" column type override for DataTable view.
1.303.6
Patch Changes
  • Fixed thresholds not working for duration fields in DataTable.
  • Fixed broken line wrap in DataTable.
1.303.5
Patch Changes
  • Fix resolveSingleValueDataMappers to use the previous selected value.
1.303.3
Patch Changes
  • Updated framer-motion package to fix broken DQL auto-completion dropdown.
1.303.2
Patch Changes
  • Add all patch versions to hub release notes.
1.303.1
Patch Changes
  • Fix missing dependencies in manifest.
1.303.0
Minor Changes
  • Added tile specific segments.
  • Improvements for the chart zoom interaction (pan mode and reset).
  • Rename tab title for Code data.
  • Extend view-dashboard intent with global timeframe.
  • Add SLO tile.
Patch Changes
  • Fixed an issue with the size of the variable dropdown.
  • Removed copilot preview label.
  • Fix endless loading for variables without options.
  • Fix issue when expandable surfaces could not be closed if default value was open.
  • Fixed an issue with quoted options in the FilterField.
Dashboards
1.302.10
Patch Changes
1.302.8
Patch Changes
1.302.7
Patch Changes
1.302.6
Patch Changes
  • Fix missing dependencies in app manifest.
1.302.5
Patch Changes
1.302.4
Patch Changes
  • Fixed behavioral events tracking.
1.302.3
Patch Changes
  • Fix scrolling in variable dropdown.
  • For zoom interactions on tiles, disable reset when reset is not possible and do not switch to explore edit mode when using pan mode.
1.302.2
Patch Changes
  • Fix app crash when disabling switch in analyzer inputs.
1.302.1
Patch Changes
1.302.0
Minor Changes
  • Enable zoom interaction for tiles with custom tile timeframe and disable zoom for histogram visualizations.
  • Prevent segments from being added in the url if none is set.
  • Extend intents to apply variable values and segments.
  • Do not trust code variables and tiles in transferred documents.
  • Sync zoomed timeframe to other tiles and to dashboard timeframe.
Patch Changes
  • Fix navigation to color surface from interactions menu.
  • Fix broken DQLEditor drop-down.
  • Dashbboard help menu contains unnecessary line breaks.
  • Fix global search drill down metric to DQLBuilder intent.
  • Fix disappearing davis visualization.
  • Apply variable values from the url correctly on inital load.
Dashboards
1.302.8
Patch Changes
1.302.7
Patch Changes
1.302.6
Patch Changes
1.302.5
Patch Changes
1.302.4
Patch Changes
1.302.3
Patch Changes
1.302.2
Patch Changes
1.302.1
Patch Changes
1.302.0
Minor Changes
Patch Changes
1.301.8
Patch Changes
1.301.7
Patch Changes
  • Fixed issue with behavioral events tracking.
1.301.6
Patch Changes
  • Fixed issues for scolling in the variable dropdown.
1.301.5
Patch Changes
  • Fixed an issue with quoted options in the filter field for the DQL Builder.
1.301.4
Patch Changes
  • Fixed issue when disabling the switch in the analyzer inputs.
1.301.3
Patch Changes
  • Apply variable values from the URL correctly on initial loading.
1.301.2
Patch Changes
  • Fixed disappearing Davis visualization.
1.301.1
Patch Changes
  • Fixed broken drop-down for DQL editor.
  • Fix nested variables behavior with wildcard select all.
1.301.0
Minor Changes
  • Integrated Dynatrace Open Feature provider.
  • Added a menu entry to pin a document to doc.
  • Updated dashboard name when previewing a previous version after renaming it.
  • Now, code warnings are no longer displayed for ready-made documents.
Patch Changes
  • Fixed result statistics for query and CoPilot tiles.
  • Prevent issues when checking whether the old imported documents are trusted.
  • Ensure the new variable key in the variable form resets correctly.
  • Replace URL on redirecting from /document to /dashboard to fix browser back.
  • Fix infinite loading state in "No dashboard selected" view.
  • Allow to select all with the newly introduced "select all (*)" feature, including dependent variables.
  • The detail view does not get dismissed anymore when the window size changes.
  • Add Traces and Events tiles.
  • Fix issue where the loading indicator of a tile was not being displayed.
  • The upload button now only accepts JSON files per default.
  • Ensured, that the detail view always has a content.
  • Tiles now do not flicker when the dashboard timeframe is changed.
  • Updated variables correctly if they depend on another variable.
  • Changed name and add icons for the settings tab.
  • Integrated segments selector behind feature flag.
  • Fixed issues on renaming document during debounced delay.
Fix the issue with adding text in the filter field for the DQL Builder.
Patch Changes
  • Fixed a problem with the size of the variable dropdown.
  • Fixed an issue with the filter input field of DQL Builder tiles.
Patch Changes
  • Improvement of nested-variable behavior.
Patch Changes
  • Remove logging.
Patch Changes
  • Fixed issue with chart interactions leading to an error.
No release notes
Patch Changes
  • Fix timeframe selector issue with en-AU and en-CA locales.
Patch Changes
  • Query builder: Apply filters in the correct order.
Patch Changes
  • Fix dashboard loading forever if user-app-state contains invalid timeframe.
Patch Changes
  • Fix focus being blocked when adding a variable.
Patch Changes
  • All apps supporting the field dt-entity-host should be indicated in the intent modal for selecting the receiving app.
  • Refactored logic for clearing selection of tiles and variables.
Patch Changes
  • Integrate the bugfix release for documents-management.
"dynatrace.dashboards": patch
  • Update results correctly on intermediate query results.
Patch Changes
  • rollback wrapping DQLBuilder in FormField
Patch Changes
  • Fix part of dashboard state not being reset on document switch.
Patch Changes
Patch Changes
Patch Changes
  • Fixed bugs with the markdown tile and with variables replacement. (PAPA-17658) (PAPA-17676) (P
Patch Changes
  • Fixed select width of dropdown for variables. P
Patch Changes
Patch Changes
  • Fix data table sorting issue. P
Patch Changes
  • Fixed issue with variable not getting renamed correctly in the tile title.
  • Show an error if a variables in a tile is ready but has no value instead of an endless loading spinner.
  • Fixed issue with variables not getting applied when copy / pasting a tile with referenced variables.
  • Fixed issue with tile input changing when the variables in the tile title change.
Patch Changes
  • Fix davis analyzer missing query input. DI-13507
Patch Changes
Patch Changes
  • Fix grey font color issue in editors. P
Patch Changes
  • Fix single value visualisation layout.
Patch Changes
  • Data-exploration version bump.
Patch Changes
  • Apply a migration step for AnalyticsWorkflowState.
Minor Changes
  • Added migration for chart data mappings.
  • Show tooltip on document entries in the sidebar.
  • Hide tile count on single tile selection.
  • Register app shortcuts.
  • Migrate old single value background property to the newest one.
Patch Changes
  • Fix data mapping config being reset on page reload.
  • Performance improvements.
  • Fix warnings & errors in JEST.
  • Enable davis suggest threshold widget.
  • Do not display thresholds settings section when visualization is davis
Patch Changes
Patch Changes
  • Update data-exploration from 2.0.2 to 2.0.3.
Minor Changes
Patch Changes
Patch Changes
Patch Changes
  • Fixed data mapping ui for bar charts.
Patch Changes
  • Fix document name ellipsis in side bar.
Patch Changes
  • Fix metric suggestion overlay issues in the details view.
Patch Changes
  • Fix for enabling line wrap for table visualizations by updating dependency for strato-components-preview.
Patch Changes
  • Fix visualization settings for categorical charts.
Minor Changes
  • Improve performance for large dashboards when selecting tiles and switching to tile edit mode.
Patch Changes
  • Apply layout from intents.
  • Prevent conflicts when the network is too slow.
Patch Changes
Minor Changes
  • Add expandable error section to details view.
  • Revise DetailsView hierarchy and visualization selection.
  • Allow creating a query tile out of an existing DQL Builder tile.
Patch Changes
  • Do not autorun an Explore section when first created.
  • Prevent variable code to be executed on the untrusted dashboard.
  • Run dql builder intents automatically.
Patch Changes
Patch Changes
  • New read-scopes added.
Patch Changes
  • Respect user timezone for Grail queries.
Patch Changes
  • Fixed error evaluating quoted variable value.
    Reset the tile error state when tile content changes.
Patch Changes
  • Fixed the error evaluating quoted variable value.
Minor Changes
  • Fix accessibility issues.
  • Fix a11y issues for low resolutions.
Patch Changes
  • Fixed detail view closing when selecting code or query with the mouse.
  • Fixed autofocus issues with keyboard accessibility.
  • Add "Welcome to dashboards" Microguide.
  • Update design system.
  • Improved view for review code modal.
Minor Changes
  • Changed edit tile text to options.
  • Using fragments instead of search parameters.
  • New visuals for tiles by using the surface component.
  • Display code banner and disable code tiles and variables for untrusted dashboards.
Patch Changes
  • Fix accessibility issue: Expand/collapse state of the element is missing or incorrect.
  • Fix accessibility issue: Accessible name missing.
  • Fix accessibility issue: Hidden or empty element receives focus and are readable by a screen reader.
  • Fix accessibility issue: Visual heading text is not marked as heading.
  • Fix missing instructions for assistive technology users for move tile button.
  • Prevent app from crashing when user cancels code variable execution.
  • Fixed performance issue by fixing the table virtualization.
Patch Changes
Patch Changes
Patch Changes
  • Fix dashboard overwrite issue
Patch Changes
Patch Changes
  • Fixed issue with code results showing visualization not applicable.
No release notes
No release notes
Minor Changes
  • Allow sharing Code tiles
  • Send and receive visualization settings and tile layouts via intents.
  • Show toast when copying tiles to the clipboard
  • Added dedicated release notes for hub.
Patch Changes
  • Append variables which are referenced within a tile to the intent to be processed by the receiving application
  • Adapted default message for annotations.
  • Fix focusing behind the modals/sheets
  • Fix initialization of Getting Started dashboard.
  • Added autocompletion for markdown input
  • Improve scrolling to new tiles.
  • Allow broken tiles to be added.
  • Fix browser history after handling an intent.
Full version history
0.9.1
Patch Changes
  • 6999e09: Getting started document flag stored in LocalStorage.
  • 649eab1: Getting started dashboard now displayed.
0.9.0
Minor Changes
  • 4d843f1: Fixed glitch with selection box being displayed above the variable bar. EXA-3336.
  • c0aa35c: Introduced document sharing for the Dashboards app.
  • 13209ae: Variables are now supported in Code tiles.
  • 8a35f2f: Added entry for "Keyboard shortcuts" to the help menu. EXA-3399.
  • bc9f48d: Variables are now always visible at the top of the dashboard even when scrolling. EXA-3336.
  • a620988: Fixed routing for Add, Manage, Edit, and Delete variables window. EXA-3653.
Patch Changes
  • 8bf33e2: Fixed "editing from maximized" animation.
  • 1c2daa9: Deus query not triggered if multi-value variable has no selected value (e.g., while evaluating).
  • 30a78ab: Reset error boundaries for analytics workflow when tile configuration changes. EXA-3146
  • 95ee88d: Allowed clicks inside tiles to enable links in annotations. EXA-3568
  • cf00e25: Added tracking of behavioral for tile interactions.
  • b3230df: Added variable loading state for fetching tile data depending on async variables. EXA-2476
  • 0444c85: Introduced tracking events for adding tiles and variables.
  • 128033e: Added a new help menu. EXA-2821
  • 0b33198: Added "What's new" to help menu to show the latest changelog. EXA-2821
  • f132e13: Reimplemented fetching and caching data on dashboard. EXA-3213
0.9.0
Minor Changes
  • 4d843f1: Fix glitch with selection box getting drawn above the variable bar. EXA-3336.
  • c0aa35c: Introduce document sharing for the dashboard app.
  • 13209ae: Variables support in Code tiles.
  • c1385fc: Refactored the code to use the AnalyticsWorkflow's store and inputValueProcessor.
  • 29f53d7: Move PR-Deployment to hbp81562 (notebooks preview tenant). EXA-3674.
  • b5eda0d: Adapted app to new routing structure
  • cb1db51: Fix pr-remove issue. APM-388120
  • 8a35f2f: Add entry for "Keyboard shortcuts" to help menu. EXA-3399.
  • a2b91b4: Added wrapper for DashboardSheet content to take full height. EXA-2914
  • bc9f48d: Variables should always be visible on the top of the dashboard even when scrolling. EXA-3336.
  • 9cd5622: labs package update to canary
  • a620988: Fix routing for add, manage, edit and delete variables modal. EXA-3653.
Patch Changes
  • 8bf33e2: Fix "editing from maximized" animation.
  • 1c2daa9: Don't trigger deus query if multi-value variable has no selected value (e.g. while evaluating)
  • 30a78ab: Reset error boundaries for analytics workflow when tile config changes. EXA-3146
  • 50a857d: Fixed a set of typescript strict mode errors. EXA-2745
  • 7337b95: Updated gitignore for dtp-cli.
  • 95ee88d: Allow clicks inside tiles to enable links in annotations. EXA-3568
  • cf00e25: Add tracking of behavioral for tile interactions.
  • 0444c85: Introduce tracking events for adding tiles and variables.
  • 128033e: New help menu. EXA-2821
  • 0b33198: Added what's new to help menu to show the latest changelog. EXA-2821
  • ef08a46: Pass normalized timeframe to AnalyticsWorkflow to be able to re-evaluate on every run
  • ac86871: Fixed the search not working in variables.
  • d946ab1: Fixed maximize tile action navigating to temp dashboard. EXA-3828
  • e873243: Fix scrollbar jumping in the tile sheet when changing the tile title. EXA-3302
  • fb8d985: Update to latest wave-components.
  • 9e5c14b: EXA-2745: Fixed a set of typescript strict mode errors.
  • 0c24226: Updated dependecies.
Dynatrace Hub
All (914)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility.
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Streamline incident management with automated Pageruty workflows.
Cursor IDE logo
Cursor IDE
Boost developer productivity and get real-time, code-level insights into Cursor.
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
