Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Connection Pools: C3P0Connection Pools: C3P0
Application server method of pooling and sharing connections to a database.
Extension
Free trialDocumentation
Quickly glance over the status of your C3P0 connection pools accross your whole environment with the included dashboard with the extension.Get insights into a specific connection pool thanks to the granularity of the metrics and their segregation into the new generic entities generated by the extension automatically.
  • Product information
  • Release notes
Overview
Several built-in OneAgent extensions provide insight into connection pool performance and issues such as connection leaks. The extensions cover the following technologies: Apache Tomcat, Oracle WebLogic, IBM WebSphere Application Server, IBM WebSphere Liberty, Red Hat JBoss and Wildfly, and C3P0.
Use cases
This extension collects connection pool performance, usage and availability metrics for C3P0.
Prerequisites:
  • Java process that uses C3P0 connection pools that runs on a supported Linux or Windows operating system.
  • OneAgent version 1.275+
  • Dynatrace version 1.275+
To get metric insight:
  1. Install OneAgent on the virtual machine or server of your JBoss process.
  2. Activate the OneAgent feature Java Metric Extensions 2.0 (JMX).
  3. Select in this same tile Add to environment to configure the extension.
  4. Open the C3P0 Connection Pool Overview dashboard.
Get started
For more information on the installation and configuration, please see Connection Pools: C3P0 extension in the Dynatrace Documentation.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Num Idle Connectionsc3p0.connectionPool.numIdleConnections-Count
Num Active threadsc3p0.connectionPool.threadPoolNumActiveThreads-Count
Thread Pool Sizec3p0.connectionPool.threadPoolSize-Count
Max Pool Sizec3p0.connectionPool.maxPoolSize-Count
Num Connectionsc3p0.connectionPool.numConnections-Count
Num Busy Connectionsc3p0.connectionPool.numBusyConnections-Count
Num Unclosed Orphaned Connectionsc3p0.connectionPool.numUnclosedOrphanedConnections-Count
Full version history
ReleaseDate
New in this version:
  • Added keyword key value pairs to extension
  • New Platform/Gen3 dashboard bundled with extension
  • Added DQL support for Platform/Gen3 screens
  • Enriched entities with dt.security_context attribute
First version of the extension. It includes:
  • 9 metrics, 2 of which are calculated, split up into 2 feature sets
  • 1 generic entity type (c3p0 connection pool)
  • 1 relationship between the connection pool and the process
  • Screen for the generic type and injections for the host and process group instance
  • Overview dashboard
Dynatrace Hub
All (886)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
