Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Cisco FirepowerCisco Firepower
Cisco Firepower
Cisco Firepower
Monitor Cisco Firepower devices using SNMP
Extension
Free trialDocumentation
DashboardFirepower device detail
  • Product information
  • Release notes
Overview
The Cisco Firepower extension uses SNMP to collect metrics from your Cisco Firepower devices. Metric data is collected each minute to track the performance and health of your Firepower devices. Dynatrace's Unified Analysis screens provide at-a-glance access and analysis for your Ops, DevOps and IT Admins.
Get started
For more information on the installation and configuration, please see Cisco Firepower extension in the Dynatrace Documentation.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
-com.dynatrace.extension.network_device.memory_used--
-com.dynatrace.extension.network_device.memory_free--
-com.dynatrace.extension.network_device.sysuptime--
-com.dynatrace.extension.network_device.cpu_usage--
-com.dynatrace.extension.network_device.if.bytes_in.count--
-com.dynatrace.extension.network_device.if.bytes_out.count--
-com.dynatrace.extension.network_device.if.in.errors.count--
-com.dynatrace.extension.network_device.if.in.discards.count--
-com.dynatrace.extension.network_device.if.out.errors.count--
-com.dynatrace.extension.network_device.if.out.discards.count--
-com.dynatrace.extension.network_device.if.status--
CRAS Active Sessionssnmp.cisco.firepower.asa.cras.num_sessionsThe number of currently active sessions. A session is 'active' if it is ready to carry application traffic.Count
Fault severitysnmp.cisco.firepower.fault.severity0 => 'cleared', 1 => 'info', 2 => 'condition', 3 => 'warning', 4 => 'minor', 5 => 'major', 6 => 'critical'State
-com.dynatrace.extension.network_device.if.in.multicast_pkts.count--
-com.dynatrace.extension.network_device.if.out.multicast_pkts.count--
-com.dynatrace.extension.network_device.if.in.broadcast_pkts.count--
-com.dynatrace.extension.network_device.if.out.broadcast_pkts.count--
-com.dynatrace.extension.network_device.if.in.ucast_pkts.count--
-com.dynatrace.extension.network_device.if.out.ucast_pkts.count--
-com.dynatrace.extension.network_device.if.lastchange--
HA Statussnmp.cisco.firepower.ha.statusThis object contains the current HA status of the resource.Count
Declined connectionssnmp.cisco.firepower.connections.cufwConnGlobalNumResDeclinedThe number of connections which were attempted to be setup but which were declined due to non-availability of required resources. This value is accumulated from the last reboot of the firewall.Count
Active connectionssnmp.cisco.firepower.connections.cufwConnGlobalNumActiveThe number of connections which are currently active.Count
Connection rate (per 1 minute)snmp.cisco.firepower.connections.cufwConnGlobalConnSetupRate1The averaged number of connections which the firewall establishing per second, averaged over the last 60 seconds.Count
UDP connection rate (per 1 minute)snmp.cisco.firepower.connections.cufwConnGlobalConnSetupRate1.udpThe averaged number of UDP connections which the firewall establishing per second, averaged over the last 60 seconds.Count
TCP connection rate (per 1 minute)snmp.cisco.firepower.connections.cufwConnGlobalConnSetupRate1.tcpThe averaged number of TCP connections which the firewall establishing per second, averaged over the last 60 seconds.Count
Total amount of memory in kBsnmp.cisco.firepower.cfprSmMonitorMemTotalKb-KiloByte
Total amount of used memory in kBsnmp.cisco.firepower.cfprSmMonitorMemUsedKb-KiloByte
Used memory poolsnmp.cisco.firepower.memory.cempMemPoolUsedIndicates the number of bytes from the memory pool that are currently in use by applications on the physical entity.Byte
Free memory poolsnmp.cisco.firepower.memory.cempMemPoolFreeIndicates the number of bytes from the memory pool that are currently not in use by applications on the physical entity.Byte
Interface speedsnmp.cisco.firepower.interface.ifHighSpeedAn estimate of the interface's current bandwidth in units of 1,000,000 bits per second. If this object reports a value of n' then the speed of the interface is somewhere in the range of n-500,000' to `n+499,999'. For interfaces which do not vary in bandwidth or for those where no accurate estimation can be made, this object should contain the nominal bandwidth. For a sub-layer which has no concept of bandwidth, this object should be zero.MegaBitPerSecond
Octets receivedsnmp.cisco.firepower.interface.ifInOctets.countThe total number of octets received on the interface including framing charactersCount
Octets received (high capacity)snmp.cisco.firepower.interface.ifHCInOctets.countThe total number of octets received on the interface including framing characters. This metric uses a 64-bit counter and should be used for highspeed devices.Count
Octets transmittedsnmp.cisco.firepower.interface.ifOutOctets.countThe total number of octets transmitted out of the interface including framing charactersCount
Octets transmitted (high capacity)snmp.cisco.firepower.interface.ifHCOutOctets.countThe total number of octets transmitted out of the interface including framing characters. This metric uses a 64-bit counter and should be used for highspeed devices.Count
Inbound errorssnmp.cisco.firepower.interface.ifInErrors.countNumber of inbound packets/transmission units with errorsCount
Inbound discardssnmp.cisco.firepower.interface.ifInDiscards.countNumber of inbound packets discardedCount
Outbound errorssnmp.cisco.firepower.interface.ifOutErrors.countNumber of outbound packets/transmission units with errorsCount
Outbound discardssnmp.cisco.firepower.interface.ifOutDiscards.countNumber of outbound packets discardedCount
CPU Usage - 1 minsnmp.cisco.firepower.cpu.total.1minThe overall CPU busy percentage in the last minute.Percent
CPU Usage - 5 minsnmp.cisco.firepower.cpu.total.5minThe overall CPU busy percentage in the last 5 minute period.Percent
1550 (Ethernet) blockssnmp.cisco.firepower.blocks.ethernetUsed to store Ethernet packets for processing through the threat defense deviceCount
80 (TCP intercept) blockssnmp.cisco.firepower.blocks.tcpinterceptUsed in TCP intercept to generate acknowledgment packets and for failover hello messagesCount
Memory usedsnmp.cisco.firepower.memory.usedIndicates the number of bytes from the memory pool that are currently used on the physical entity.Byte
Total amount of disk space for the specified file systemsnmp.cisco.firepower.disk.cfprSmDiskFileSystemTotalKb-KiloByte
Used disk space for the specified file systemsnmp.cisco.firepower.disk.cfprSmDiskFileSystemUsedKb-KiloByte
Related to Cisco Firepower
Generic Cisco Device logo
Monitor Cisco devices using SNMP to feed Dynatrace with metrics and alerts.
Generic network device logo
Gain insights into the performance of your network devices.
Full version history
ReleaseDate
v1.5.3 Hub Release
This version requires a minimum cluster version of 1.318.
  • Fix for relationship between Firepower device and Generic network device
  • Added High capacity details chart card to Firepower network interface detail screen.
  • Updated supplied dashboard with new metrics
Other changes and improvements
  • Add filtering for Firepower network interfaces.
  • Fixed a bug that was preventing some metrics from displaying correctly on Unified Analysis screens.
✨ New in this version (1.5.0):
  • Added the following new metrics to the Advanced interfaces feature set:
    • com.dynatrace.extension.network_device.if.in.multicast_pkts.count
    • com.dynatrace.extension.network_device.if.out.multicast_pkts.count
    • com.dynatrace.extension.network_device.if.in.broadcast_pkts.count
    • com.dynatrace.extension.network_device.if.out.broadcast_pkts.count
    • com.dynatrace.extension.network_device.if.in.ucast_pkts.count
    • com.dynatrace.extension.network_device.if.out.ucast_pkts.count
    • com.dynatrace.extension.network_device.if.lastchange
  • Added the following new metrics to the default feature set:
    • snmp.cisco.firepower.interface.ifHCInOctets.count
    • snmp.cisco.firepower.interface.ifHCOutOctets.count
  • Added calculated metrics for bandwidth and traffic.
šŸš€ Improved in this version:
  • Added extra filtering to Firepower network interfaces.
🪲 Fixed in this version:
  • Corrected OIDs for the legacy_memory feature set.
v.1.3.5
Fixes
  • Fix for snmp.cisco.asa.cras.num_sessions metric
This version requires a minimum cluster version of 1.314.0
āš ļø IMPORTANT CHANGE:
Metrics in "default" feature set will always be enabled and cannot be disabled. These metrics are mandatory. Take extra caution configuring devices and interfaces for which you are collecting data. Make use of Interface filters to limit the number of interfaces, otherwise, all interfaces on the device will be collected by default. In case you do not wish to collect interfaces on your device, enter $eq(!) in the "Interface Name" filter field on the Feature Sets screen during configuration.
These metrics introduced into the "default" feature set are per interface and cannot be disabled but can be filtered.
  • com.dynatrace.extension.network_device.if.bytes_in.count
  • com.dynatrace.extension.network_device.if.bytes_out.count
  • com.dynatrace.extension.network_device.if.in.errors.count
  • com.dynatrace.extension.network_device.if.in.discards.count
  • com.dynatrace.extension.network_device.if.out.errors.count
  • com.dynatrace.extension.network_device.if.out.discards.count
Other changes:
  • Added Platform dashboard
  • Added dt.security_context to entities
  • Added Platform unified analysis screens
  • Added snmp.cisco.asa.cras.num_sessions metric and related UA chart
Initial release
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
