Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Varnish CacheVarnish Cache
Varnish Cache
Varnish Cache
Monitor the statistics of your Varnish Cache instances
Extension
Free trialDocumentation
Platform overview dashboardClassic overview dashboardInstance view
  • Product information
  • Release notes
Overview
Monitor the statistics of Varnish Cache instances
Use cases
  • Monitor the health and state of Varnish cache instances
  • Detect and alert on anomalous behavior
  • Understand the load and operational performance of the cache
Get started
For more information on the installation and configuration, please see Varnish Cache extension in the Dynatrace Documentation.
Details
Compatibility information
Varnish v. 6.2.1+
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Created locksvarnish.cache.lck.creat.countCreated locksUnspecified
Destroyed locksvarnish.cache.lck.destroy.countDestroyed locksUnspecified
Lock Operationsvarnish.cache.lck.locks.countLock OperationsUnspecified
Contended lock operationsvarnish.cache.lck.dbg_busy.countIf the lck debug bit is set: Lock operations which returned EBUSY on the first locking attempt. If the lck debug bit is unset, this counter will never be incremented even if lock operations are contended.Unspecified
Contended trylock operationsvarnish.cache.lck.dbg_try_fail.countIf the lck debug bit is set: Trylock operations which returned EBUSY. If the lck debug bit is unset, this counter will never be incremented even if lock operations are contended.Unspecified
In usevarnish.cache.mempool.liveIn useUnspecified
In Poolvarnish.cache.mempool.poolIn PoolUnspecified
Size requestedvarnish.cache.mempool.sz_wantedSize requestedByte
Size allocatedvarnish.cache.mempool.sz_actualSize allocatedByte
Allocationsvarnish.cache.mempool.allocs.countAllocationsUnspecified
Freesvarnish.cache.mempool.frees.countFreesUnspecified
Recycled from poolvarnish.cache.mempool.recycle.countRecycled from poolUnspecified
Timed out from poolvarnish.cache.mempool.timeout.countTimed out from poolUnspecified
Too small to recyclevarnish.cache.mempool.toosmall.countToo small to recycleUnspecified
Too many for poolvarnish.cache.mempool.surplus.countToo many for poolUnspecified
Pool ran dryvarnish.cache.mempool.randry.countPool ran dryUnspecified
stat summ operationsvarnish.cache.main.summs.countNumber of times per-thread statistics were summed into the global counters.Unspecified
Child process uptimevarnish.cache.main.uptime.countHow long the child process has been running.Second
Sessions acceptedvarnish.cache.main.sess_conn.countCount of sessions successfully acceptedUnspecified
Session accept failuresvarnish.cache.main.sess_fail.countCount of failures to accept TCP connection. This counter is the sum of the sess_fail_* counters, which give more detailed information.Unspecified
Session accept failures: connection abortedvarnish.cache.main.sess_fail_econnaborted.countDetailed reason for sess_fail: Connection aborted by the client, usually harmless.Unspecified
Session accept failures: interrupted system callvarnish.cache.main.sess_fail_eintr.countDetailed reason for sess_fail: The accept() call was interrupted, usually harmlessUnspecified
Session accept failures: too many open filesvarnish.cache.main.sess_fail_emfile.countDetailed reason for sess_fail: No file descriptor was available. Consider raising RLIMIT_NOFILE (see ulimit -n).Unspecified
Session accept failures: bad file descriptorvarnish.cache.main.sess_fail_ebadf.countDetailed reason for sess_fail: The listen socket file descriptor was invalid. Should never happen.Unspecified
Session accept failures: not enough memoryvarnish.cache.main.sess_fail_enomem.countDetailed reason for sess_fail: Most likely insufficient socket buffer memory. Should never happenUnspecified
Session accept failures: othervarnish.cache.main.sess_fail_other.countDetailed reason for sess_fail: neither of the above, see SessError log (varnishlog -g raw -i SessError).Unspecified
Client requests received, subject to 400 errorsvarnish.cache.main.client_req_400.count400 means we couldn't make sense of the request, it was malformed in some drastic way.Unspecified
Client requests received, subject to 417 errorsvarnish.cache.main.client_req_417.count417 means that something went wrong with an Expect: header.Unspecified
Good client requests receivedvarnish.cache.main.client_req.countThe count of parseable client requests seen.Unspecified
ESI subrequestsvarnish.cache.main.esi_req.countNumber of ESI subrequests made.Unspecified
Cache hitsvarnish.cache.main.cache_hit.countCount of cache hits. A cache hit indicates that an object has been delivered to a client without fetching it from a backend server.Unspecified
Cache grace hitsvarnish.cache.main.cache_hit_grace.countCount of cache hits with grace. A cache hit with grace is a cache hit where the object is expired. Note that such hits are also included in the cache_hit counter.Unspecified
Cache hits for pass.varnish.cache.main.cache_hitpass.countCount of hits for pass. A cache hit for pass indicates that Varnish is going to pass the request to the backend and this decision has been cached in it self. This counts how many times the cached decision is being used.Unspecified
Cache hits for miss.varnish.cache.main.cache_hitmiss.countCount of hits for miss. A cache hit for miss indicates that Varnish is going to proceed as for a cache miss without request coalescing, and this decision has been cached. This counts how many times the cached decision is being used.Unspecified
Cache missesvarnish.cache.main.cache_miss.countCount of misses. A cache miss indicates the object was fetched from the backend before delivering it to the client.Unspecified
Uncacheable backend responsesvarnish.cache.main.beresp_uncacheable.countCount of backend responses considered uncacheable.Unspecified
Shortlived objectsvarnish.cache.main.beresp_shortlived.countCount of objects created with ttl+grace+keep shorter than the 'shortlived' runtime parameter.Unspecified
Backend conn. successvarnish.cache.main.backend_conn.countHow many backend connections have successfully been established.Unspecified
Backend conn. not attemptedvarnish.cache.main.backend_unhealthy.countBackend conn. not attemptedUnspecified
Backend conn. too manyvarnish.cache.main.backend_busy.countBackend conn. too manyUnspecified
Backend conn. failuresvarnish.cache.main.backend_fail.countBackend conn. failuresUnspecified
Backend conn. reusesvarnish.cache.main.backend_reuse.countCount of backend connection reuses. This counter is increased whenever we reuse a recycled connection.Unspecified
Backend conn. recyclesvarnish.cache.main.backend_recycle.countCount of backend connection recycles. This counter is increased whenever we have a keep-alive connection that is put back into the pool of connections. It has not yet been used, but it might be, unless the backend closes it.Unspecified
Backend conn. retryvarnish.cache.main.backend_retry.countBackend conn. retryUnspecified
Fetch no body (HEAD)varnish.cache.main.fetch_head.countberesp with no body because the request is HEAD.Unspecified
Fetch with Lengthvarnish.cache.main.fetch_length.countberesp.body with Content-Length.Unspecified
Fetch chunkedvarnish.cache.main.fetch_chunked.countberesp.body with Chunked.Unspecified
Fetch EOFvarnish.cache.main.fetch_eof.countberesp.body with EOF.Unspecified
Fetch bad T-Evarnish.cache.main.fetch_bad.countberesp.body length/fetch could not be determined.Unspecified
Fetch no bodyvarnish.cache.main.fetch_none.countberesp.body emptyUnspecified
Fetch no body (1xx)varnish.cache.main.fetch_1xx.countberesp with no body because of 1XX response.Unspecified
Fetch no body (204)varnish.cache.main.fetch_204.countberesp with no body because of 204 response.Unspecified
Fetch no body (304)varnish.cache.main.fetch_304.countberesp with no body because of 304 response.Unspecified
Fetch failed (all causes)varnish.cache.main.fetch_failed.countberesp fetch failed.Unspecified
Background fetch failed (no thread)varnish.cache.main.bgfetch_no_thread.countA bgfetch triggered by a grace hit failed, no thread available.Unspecified
Number of thread poolsvarnish.cache.main.poolsNumber of thread pools. See also parameter thread_pools. NB: Presently pools cannot be removed once created.Unspecified
Total number of threadsvarnish.cache.main.threadsNumber of threads in all pools. See also parameters thread_pools, thread_pool_min and thread_pool_max.Unspecified
Threads hit maxvarnish.cache.main.threads_limited.countNumber of times more threads were needed, but limit was reached in a thread pool. See also parameter thread_pool_max.Unspecified
Threads createdvarnish.cache.main.threads_created.countTotal number of threads created in all pools.Unspecified
Threads destroyedvarnish.cache.main.threads_destroyed.countTotal number of threads destroyed in all pools.Unspecified
Thread creation failedvarnish.cache.main.threads_failed.countNumber of times creating a thread failed. See VSL::Debug for diagnostics. See also parameter thread_fail_delay.Unspecified
Length of session queuevarnish.cache.main.thread_queue_lenLength of session queue waiting for threads. NB: Only updates once per second. See also parameter thread_queue_limit.Unspecified
Number of requests sent to sleep on busy objhdrvarnish.cache.main.busy_sleep.countNumber of requests sent to sleep without a worker thread because they found a busy object.Unspecified
Number of requests woken after sleep on busy objhdrvarnish.cache.main.busy_wakeup.countNumber of requests taken off the busy object sleep list and rescheduled.Unspecified
Number of requests killed after sleep on busy objhdrvarnish.cache.main.busy_killed.countNumber of requests killed from the busy object sleep list due to lack of resources.Unspecified
Sessions queued for threadvarnish.cache.main.sess_queued.countNumber of times session was queued waiting for a thread. See also parameter thread_queue_limit.Unspecified
Sessions dropped for threadvarnish.cache.main.sess_dropped.countNumber of times an HTTP/1 session was dropped because the queue was too long already. See also parameter thread_queue_limit.Unspecified
Requests droppedvarnish.cache.main.req_dropped.countNumber of times an HTTP/2 stream was refused because the queue was too long already. See also parameter thread_queue_limit.Unspecified
object structs madevarnish.cache.main.n_objectApproximate number of HTTP objects (headers + body, if present) in the cache.Unspecified
unresurrected objectsvarnish.cache.main.n_vampireobjectNumber of unresurrected objectsUnspecified
objectcore structs madevarnish.cache.main.n_objectcoreApproximate number of object metadata elements in the cache. Each object needs an objectcore, extra objectcores are for hit-for-miss, hit-for-pass and busy objects.Unspecified
objecthead structs madevarnish.cache.main.n_objectheadApproximate number of different hash entries in the cache.Unspecified
Number of backendsvarnish.cache.main.n_backendNumber of backends known to us.Unspecified
Number of expired objectsvarnish.cache.main.n_expired.countNumber of objects that expired from cache because of old age.Unspecified
Number of LRU nuked objectsvarnish.cache.main.n_lru_nuked.countHow many objects have been forcefully evicted from storage to make room for a new object.Unspecified
Number of LRU moved objectsvarnish.cache.main.n_lru_moved.countNumber of move operations done on the LRU list.Unspecified
Reached nuke_limitvarnish.cache.main.n_lru_limited.countNumber of times more storage space were needed, but limit was reached in a nuke_limit. See also parameter nuke_limit.Unspecified
HTTP header overflowsvarnish.cache.main.losthdr.countHTTP header overflowsUnspecified
Total sessions seenvarnish.cache.main.s_sess.countTotal sessions seenUnspecified
Number of ongoing pipe sessionsvarnish.cache.main.n_pipeNumber of ongoing pipe sessionsUnspecified
Pipes hit pipe_sess_maxvarnish.cache.main.pipe_limited.countNumber of times more pipes were needed, but the limit was reached. See also parameter pipe_sess_max.Unspecified
Total pipe sessions seenvarnish.cache.main.s_pipe.countTotal pipe sessions seenUnspecified
Total pass-ed requests seenvarnish.cache.main.s_pass.countTotal pass-ed requests seenUnspecified
Total backend fetches initiatedvarnish.cache.main.s_fetch.countTotal backend fetches initiated, including background fetches.Unspecified
Total backend background fetches initiatedvarnish.cache.main.s_bgfetch.countTotal backend background fetches initiatedUnspecified
Total synthetic responses madevarnish.cache.main.s_synth.countTotal synthetic responses madeUnspecified
Request header bytesvarnish.cache.main.s_req_hdrbytes.countTotal request header bytes receivedByte
Request body bytesvarnish.cache.main.s_req_bodybytes.countTotal request body bytes receivedByte
Response header bytesvarnish.cache.main.s_resp_hdrbytes.countTotal response header bytes transmittedByte
Response body bytesvarnish.cache.main.s_resp_bodybytes.countTotal response body bytes transmittedByte
Pipe request header bytesvarnish.cache.main.s_pipe_hdrbytes.countTotal request bytes received for piped sessionsByte
Piped bytes from clientvarnish.cache.main.s_pipe_in.countTotal number of bytes forwarded from clients in pipe sessionsByte
Piped bytes to clientvarnish.cache.main.s_pipe_out.countTotal number of bytes forwarded to clients in pipe sessionsByte
Session Closedvarnish.cache.main.sess_closed.countSession ClosedUnspecified
Session Closed with errorvarnish.cache.main.sess_closed_err.countTotal number of sessions closed with errors. See sc_* diag counters for detailed breakdownUnspecified
Session Read Aheadvarnish.cache.main.sess_readahead.countSession Read AheadUnspecified
Session herdvarnish.cache.main.sess_herd.countNumber of times the timeout_linger triggeredUnspecified
Session OK REM_CLOSEvarnish.cache.main.sc_rem_close.countNumber of session closes with REM_CLOSE (Client Closed)Unspecified
Session OK REQ_CLOSEvarnish.cache.main.sc_req_close.countNumber of session closes with REQ_CLOSE (Client requested close)Unspecified
Session Err REQ_HTTP10varnish.cache.main.sc_req_http10.countNumber of session closes with Error REQ_HTTP10 (Proto < HTTP/1.1)Unspecified
Session Err RX_BADvarnish.cache.main.sc_rx_bad.countNumber of session closes with Error RX_BAD (Received bad req/resp)Unspecified
Session Err RX_BODYvarnish.cache.main.sc_rx_body.countNumber of session closes with Error RX_BODY (Failure receiving req.body)Unspecified
Session Err RX_JUNKvarnish.cache.main.sc_rx_junk.countNumber of session closes with Error RX_JUNK (Received junk data)Unspecified
Session Err RX_OVERFLOWvarnish.cache.main.sc_rx_overflow.countNumber of session closes with Error RX_OVERFLOW (Received buffer overflow)Unspecified
Session Err RX_TIMEOUTvarnish.cache.main.sc_rx_timeout.countNumber of session closes with Error RX_TIMEOUT (Receive timeout)Unspecified
Session Err RX_CLOSE_IDLEvarnish.cache.main.sc_rx_close_idle.countNumber of session closes with Error RX_CLOSE_IDLE: timeout_idle has been exceeded while waiting for a client request.Unspecified
Session OK TX_PIPEvarnish.cache.main.sc_tx_pipe.countNumber of session closes with TX_PIPE (Piped transaction)Unspecified
Session Err TX_ERRORvarnish.cache.main.sc_tx_error.countNumber of session closes with Error TX_ERROR (Error transaction)Unspecified
Session OK TX_EOFvarnish.cache.main.sc_tx_eof.countNumber of session closes with TX_EOF (EOF transmission)Unspecified
Session OK RESP_CLOSEvarnish.cache.main.sc_resp_close.countNumber of session closes with RESP_CLOSE (Backend/VCL requested close)Unspecified
Session Err OVERLOADvarnish.cache.main.sc_overload.countNumber of session closes with Error OVERLOAD (Out of some resource)Unspecified
Session Err PIPE_OVERFLOWvarnish.cache.main.sc_pipe_overflow.countNumber of session closes with Error PIPE_OVERFLOW (Session pipe overflow)Unspecified
Session Err RANGE_SHORTvarnish.cache.main.sc_range_short.countNumber of session closes with Error RANGE_SHORT (Insufficient data for range)Unspecified
Session Err REQ_HTTP20varnish.cache.main.sc_req_http20.countNumber of session closes with Error REQ_HTTP20 (HTTP2 not accepted)Unspecified
Session Err VCL_FAILUREvarnish.cache.main.sc_vcl_failure.countNumber of session closes with Error VCL_FAILURE (VCL failure)Unspecified
Delivery failed due to insufficient workspace.varnish.cache.main.client_resp_500.countNumber of times we failed a response due to running out of workspace memory during delivery.Unspecified
workspace_backend overflowsvarnish.cache.main.ws_backend_overflow.countNumber of times we ran out of space in workspace_backend.Unspecified
workspace_client overflowsvarnish.cache.main.ws_client_overflow.countNumber of times we ran out of space in workspace_client.Unspecified
workspace_thread overflowsvarnish.cache.main.ws_thread_overflow.countNumber of times we ran out of space in workspace_thread.Unspecified
workspace_session overflowsvarnish.cache.main.ws_session_overflow.countNumber of times we ran out of space in workspace_session.Unspecified
SHM recordsvarnish.cache.main.shm_records.countNumber of log records written to the shared memory log.Unspecified
SHM writesvarnish.cache.main.shm_writes.countNumber of individual writes to the shared memory log. A single write may batch multiple records for bufferred tasks.Unspecified
SHM flushes due to overflowvarnish.cache.main.shm_flushes.countNumber of writes performed before the end of a bufferred task because adding a record to a batch would exceed vsl_buffer.Unspecified
SHM lock contentionvarnish.cache.main.shm_cont.countNumber of times a write had to wait for the lock.Unspecified
SHM cycles through VSL spacevarnish.cache.main.shm_cycles.countNumber of times a write of log records would reach past the end of the shared memory log, cycling back to the beginning.Unspecified
SHM bytesvarnish.cache.main.shm_bytes.countNumber of bytes written to the shared memory log.Byte
Backend requests madevarnish.cache.main.backend_req.countBackend requests madeUnspecified
Number of loaded VCLs in totalvarnish.cache.main.n_vclNumber of loaded VCLs in totalUnspecified
Number of VCLs availablevarnish.cache.main.n_vcl_availNumber of VCLs availableUnspecified
Number of discarded VCLsvarnish.cache.main.n_vcl_discardNumber of discarded VCLsUnspecified
VCL failuresvarnish.cache.main.vcl_fail.countCount of failures which prevented VCL from completing.Unspecified
Count of bansvarnish.cache.main.bansNumber of all bans in system, including bans superseded by newer bans and bans already checked by the ban-lurker.Unspecified
Number of bans marked 'completed'varnish.cache.main.bans_completedNumber of bans which are no longer active, either because they got checked by the ban-lurker or superseded by newer identical bans.Unspecified
Number of bans using obj.*varnish.cache.main.bans_objNumber of bans which use obj.* variables. These bans can possibly be washed by the ban-lurker.Unspecified
Number of bans using req.*varnish.cache.main.bans_reqNumber of bans which use req.* variables. These bans can not be washed by the ban-lurker.Unspecified
Bans addedvarnish.cache.main.bans_added.countCounter of bans added to ban list.Unspecified
Bans deletedvarnish.cache.main.bans_deleted.countCounter of bans deleted from ban list.Unspecified
Bans tested against objects (lookup)varnish.cache.main.bans_tested.countCount of how many bans and objects have been tested against each other during hash lookup.Unspecified
Objects killed by bans (lookup)varnish.cache.main.bans_obj_killed.countNumber of objects killed by bans during object lookup.Unspecified
Bans tested against objects (lurker)varnish.cache.main.bans_lurker_tested.countCount of how many bans and objects have been tested against each other by the ban-lurker.Unspecified
Ban tests tested against objects (lookup)varnish.cache.main.bans_tests_tested.countCount of how many tests and objects have been tested against each other during lookup. 'ban req.url == foo && req.http.host == bar' counts as one in 'bans_tested' and as two in 'bans_tests_tested'Unspecified
Ban tests tested against objects (lurker)varnish.cache.main.bans_lurker_tests_tested.countCount of how many tests and objects have been tested against each other by the ban-lurker. 'ban req.url == foo && req.http.host == bar' counts as one in 'bans_tested' and as two in 'bans_tests_tested'Unspecified
Objects killed by bans (lurker)varnish.cache.main.bans_lurker_obj_killed.countNumber of objects killed by the ban-lurker.Unspecified
Objects killed by bans for cutoff (lurker)varnish.cache.main.bans_lurker_obj_killed_cutoff.countNumber of objects killed by the ban-lurker to keep the number of bans below ban_cutoff.Unspecified
Bans superseded by other bansvarnish.cache.main.bans_dups.countCount of bans replaced by later identical bans.Unspecified
Lurker gave way for lookupvarnish.cache.main.bans_lurker_contention.countNumber of times the ban-lurker had to wait for lookups.Unspecified
Bytes used by the persisted ban listsvarnish.cache.main.bans_persisted_bytesNumber of bytes used by the persisted ban lists.Byte
Extra bytes in persisted ban lists due to fragmentationvarnish.cache.main.bans_persisted_fragmentationNumber of extra bytes accumulated through dropped and completed bans in the persistent ban lists.Byte
Number of purge operations executedvarnish.cache.main.n_purges.countNumber of purge operations executedUnspecified
Number of purged objectsvarnish.cache.main.n_obj_purged.countNumber of purged objectsUnspecified
Number of objects mailed to expiry threadvarnish.cache.main.exp_mailed.countNumber of objects mailed to expiry thread for handling.Unspecified
Number of objects received by expiry threadvarnish.cache.main.exp_received.countNumber of objects received by expiry thread for handling.Unspecified
HCB Lookups without lockvarnish.cache.main.hcb_nolock.countHCB Lookups without lockUnspecified
HCB Lookups with lockvarnish.cache.main.hcb_lock.countHCB Lookups with lockUnspecified
HCB Insertsvarnish.cache.main.hcb_insert.countHCB InsertsUnspecified
ESI parse errors (unlock)varnish.cache.main.esi_errors.countESI parse errors (unlock)Unspecified
ESI parse warnings (unlock)varnish.cache.main.esi_warnings.countESI parse warnings (unlock)Unspecified
Loaded VMODsvarnish.cache.main.vmodsLoaded VMODsUnspecified
Gzip operationsvarnish.cache.main.n_gzip.countGzip operationsUnspecified
Gunzip operationsvarnish.cache.main.n_gunzip.countGunzip operationsUnspecified
Test gunzip operationsvarnish.cache.main.n_test_gunzip.countThose operations occur when Varnish receives a compressed object from a backend. They are done to verify the gzip stream while it's inserted in storage.Unspecified
Premature iovec flushesvarnish.cache.main.http1_iovs_flush.countNumber of additional writes performed on HTTP1 connections because the number of IO vectors was too small to submit all possible IO in one go. This number is configured through the http1_iovs parameter for client connections and implicitly defined by the amount of free workspace for backend connections.Unspecified
Allocator requestsvarnish.cache.sma.c_req.countNumber of times the storage has been asked to provide a storage segment.Unspecified
Allocator failuresvarnish.cache.sma.c_fail.countNumber of times the storage has failed to provide a storage segment.Unspecified
Bytes allocatedvarnish.cache.sma.c_bytes.countNumber of total bytes allocated by this storage.Byte
Bytes freedvarnish.cache.sma.c_freed.countNumber of total bytes returned to this storage.Byte
Allocations outstandingvarnish.cache.sma.g_allocNumber of storage allocations outstanding.Unspecified
Bytes outstandingvarnish.cache.sma.g_bytesNumber of bytes allocated from the storage.Byte
Bytes availablevarnish.cache.sma.g_spaceNumber of bytes left in the storage.Byte
Allocator requestsvarnish.cache.smu.c_req.countNumber of times the storage has been asked to provide a storage segment.Unspecified
Allocator failuresvarnish.cache.smu.c_fail.countNumber of times the storage has failed to provide a storage segment.Unspecified
Bytes allocatedvarnish.cache.smu.c_bytes.countNumber of total bytes allocated by this storage.Byte
Bytes freedvarnish.cache.smu.c_freed.countNumber of total bytes returned to this storage.Byte
Allocations outstandingvarnish.cache.smu.g_allocNumber of storage allocations outstanding.Unspecified
Bytes outstandingvarnish.cache.smu.g_bytesNumber of bytes allocated from the storage.Byte
Bytes availablevarnish.cache.smu.g_spaceNumber of bytes left in the storage.Byte
Allocator requestsvarnish.cache.smf.c_req.countNumber of times the storage has been asked to provide a storage segment.Unspecified
Allocator failuresvarnish.cache.smf.c_fail.countNumber of times the storage has failed to provide a storage segment.Unspecified
Bytes allocatedvarnish.cache.smf.c_bytes.countNumber of total bytes allocated by this storage.Byte
Bytes freedvarnish.cache.smf.c_freed.countNumber of total bytes returned to this storage.Byte
Allocations outstandingvarnish.cache.smf.g_allocNumber of storage allocations outstanding.Unspecified
Bytes outstandingvarnish.cache.smf.g_bytesNumber of bytes allocated from the storage.Byte
Bytes availablevarnish.cache.smf.g_spaceNumber of bytes left in the storage.Byte
N struct smfvarnish.cache.smf.g_smfN struct smfUnspecified
N small free smfvarnish.cache.smf.g_smf_fragN small free smfUnspecified
N large free smfvarnish.cache.smf.g_smf_largeN large free smfUnspecified
Return codevarnish.cache.returncodeReturn code of the varnishstat commandUnspecified
Management process uptimevarnish.cache.mgt.uptime.countUptime in seconds of the management processSecond
Child process startedvarnish.cache.mgt.child_start.countNumber of times the child process has been startedUnspecified
Child process normal exitvarnish.cache.mgt.child_exit.countNumber of times the child process has been cleanly stoppedUnspecified
Child process unexpected exitvarnish.cache.mgt.child_stop.countNumber of times the child process has exited with an unexpected return codeUnspecified
Child process died (signal)varnish.cache.mgt.child_died.countNumber of times the child process has died due to signalsUnspecified
Child process core dumpedvarnish.cache.mgt.child_dump.countNumber of times the child process has produced core dumpsUnspecified
Child process panicvarnish.cache.mgt.child_panic.countNumber of times the management process has caught a child panicUnspecified
Happy health probesvarnish.cache.vbe.happyRepresents the last probe results as a bitmap. Happy probes are bits set to 1, and the unhappy ones are set to 0. The highest bits represent the oldest probes.Unspecified
Request header bytesvarnish.cache.vbe.bereq_hdrbytes.countTotal backend request header bytes sentByte
Request body bytesvarnish.cache.vbe.bereq_bodybytes.countTotal backend request body bytes sentByte
Response header bytesvarnish.cache.vbe.beresp_hdrbytes.countTotal backend response header bytes receivedByte
Response body bytesvarnish.cache.vbe.beresp_bodybytes.countTotal backend response body bytes receivedByte
Pipe request header bytesvarnish.cache.vbe.pipe_hdrbytes.countTotal request bytes sent for piped sessionsByte
Piped bytes to backendvarnish.cache.vbe.pipe_out.countTotal number of bytes forwarded to backend in pipe sessionsByte
Piped bytes from backendvarnish.cache.vbe.pipe_in.countTotal number of bytes forwarded from backend in pipe sessionsByte
Concurrent connections usedvarnish.cache.vbe.connThe number of currently used connections to the backend. This number is always less or equal to the number of connections to the backend (as, for example shown as ESTABLISHED for TCP connections in netstat) due to connection pooling.Unspecified
Backend requests sentvarnish.cache.vbe.req.countBackend requests sentUnspecified
Fetches not attempted due to backend being unhealthyvarnish.cache.vbe.unhealthy.countFetches not attempted due to backend being unhealthyUnspecified
Fetches not attempted due to backend being busyvarnish.cache.vbe.busy.countNumber of times the max_connections limit was reached .. === Anything below is actually per VCP entry, but collected per === backend for simplicityUnspecified
Connections failedvarnish.cache.vbe.fail.countCounter of failed opens. Detailed reasons are given in the fail_* counters (DIAG level) and in the log under the FetchError tag. This counter is the sum of all detailed fail_* counters. All fail_* counters may be slightly inaccurate for efficiency.Unspecified
Connections failed with EACCES or EPERMvarnish.cache.vbe.fail_eacces.countConnections failed with EACCES or EPERMUnspecified
Connections failed with EADDRNOTAVAILvarnish.cache.vbe.fail_eaddrnotavail.countConnections failed with EADDRNOTAVAILUnspecified
Connections failed with ECONNREFUSEDvarnish.cache.vbe.fail_econnrefused.countConnections failed with ECONNREFUSEDUnspecified
Connections failed with ENETUNREACHvarnish.cache.vbe.fail_enetunreach.countConnections failed with ENETUNREACHUnspecified
Connections failed ETIMEDOUTvarnish.cache.vbe.fail_etimedout.countConnections failed ETIMEDOUTUnspecified
Connections failed for other reasonvarnish.cache.vbe.fail_other.countConnections failed for other reasonUnspecified
Connection opens not attemptedvarnish.cache.vbe.helddown.countConnections not attempted during the backend_local_error_holddown or backend_remote_error_holddown interval after a fundamental connection issue.Unspecified
Full version history
ReleaseDate
New in this version:
  • Add support for python 3.14
Improvements in this version:
  • Update recommended feature sets
✨ New in this version:
  • Added additional binary verification for increased security
  • Update entity links on gen 3 dashboard to link to I&O app
⚠️ WARNING: This version introduces a breaking change requiring the monitoring configuration to be updated
  • The Path to varnishstat executable field must no longer contain the varnishstat binary in it, but only the path to the directory containing the executable with a trailing slash
    • i.e. /usr/bin/
🐛 Bugs fixed:
  • Improved filtering for command path execution to prevent any injection vulnerability.
Dynatrace Hub
All (883)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
