Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Synthetic for WorkflowsSynthetic for Workflows
Execute Dynatrace synthetic monitors within Workflows.
App
Free trialDocumentation
Select synthetic monitors to execute:
Specify a list of monitors, those monitors tagged with specific identifiers, or those monitors assigned to particular applications.
Select locations from existing monitoring locations.Create a reusable workflow by extracting a list of monitors and their execution locations from incoming events.
  • Product information
  • Release notes
Overview
Enhance your automation capabilities with Synthetic Monitoring. Synthetic for Workflows allows you to execute synthetic monitors on demand at selected locations within your workflows.
You can choose which monitors to execute. Specify:
  • A list of selected monitors.
  • Monitors tagged with specific identifiers.
  • Monitors assigned to a particular frontend application.
Besides, you can use expressions to extract the list of monitors and locations from incoming events, enabling you to build a reusable workflow.
Use cases
  • Integrate Synthetic for Workflows with your CI/CD pipelines and build an automated process for release validation along with Site Reliability Guardian.
  • Use Synthetic for Workflows to automate checks on your critical user journeys, ensuring they function correctly every time there's a change, such as in the infrastructure configuration or when a problem occurs.
  • Customize your Synthetic schedules to accommodate various platform events, particularly when operational conditions can change rapidly.
Get started
To integrate Synthetic Monitoring into your custom workflows, first install Synthetic for Workflows in your environment. Then use the synthetic_for_workflows action in your automated workflows.
Before you begin, ensure that all monitors are properly defined.
Please use the Synthetic app to create a new synthetic monitor.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Synthetic for Workflows
Workflows logo
Workflows
Synthetic logo
Synthetic
Monitor your application's health around the world and around the clock.
Full version history
ReleaseDate
2.1.0
Minor Changes
  • 452a2dd: Adjusted query fetching batch status events.
  • 246cd20: Changed source of fetching tags, which is now Grail for DPS customers.
2.0.0
Major Changes
  • 240c868: As previously announced, the support for attributes returned in the old synthetic events format has ended. For details, please refer to the documentation.
1.4.0
Minor Changes
  • 9e01c23: Due to recent updates, we have unified the attribute names of synthetic events, which introduces incompatibilities with the format of result events. For details, please refer to the documentation.
1.3.0
Minor Changes
  • 2043c31: Added new format of the synthetic events to the action result (for DPS customers)
1.2.1
Patch Changes
  • e73d7ad: Fixed workflow execution for non-DPS customers
1.2.0
Minor Changes
  • 3833b4c: Added "Configure workflow execution" section where user can customize settings for workflow task behavior
1.2.0
Minor Changes
1.1.1
Patch Changes
  • Fix showing action in "Choose action" panel in Workflows app
1.1.0
Minor Changes
  • 13ead72: Added workflow support for non-DPS customers
1.0.2
Patch Changes
  • 02f73d2: Fix preselecting options in widget
1.0.1
Patch Changes
  • 023fc6f: Added parsing array from event
1.0.0
Synthetic for Workflows is an extension to Workflows app. It allows you to execute synthetic monitors on demand at selected locations within your workflows.
Dynatrace Hub
All (877)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
