Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Sybase ASESybase ASE
Sybase ASE
Sybase ASE
Monitor Sybase ASE database for performance and health, using remote monitoring
Extension
Free trialDocumentation
Sybase ASE sample dashboardSybase ASE unified analysis
  • Product information
  • Release notes
Overview
This Dynatrace extension monitors Sybase Adaptive Server Enterprise's health and performance. It is a remote monitoring solution implemented as an extension for Dynatrace ActiveGates. Metrics are obtained from the Sybase ASE monitoring tables using the Dynatrace JDBC datasource.
This is intended for users, who:
  • Want to monitor the health and performance of their individual Sybase ASE databases
  • Look for a dedicated out-of-the-box dashboard for Sybase Monitoring
This extension enables you to:
  • Monitor Sybase ASE Databases, Devices, IO Controllers, and Cache Pools
  • Monitor database transactions, IO rates, and statement operations
  • Receive alerts on performance and health issues detected in your ASE
  • Take proactive actions based on anomalies detected in the database infrastructure before they affect your applications
Use cases
  • Operational monitoring of your Sybase Adaptive Server Enterprise setup.
  • Monitor resource utilization and receive alerts for detected anomalies; detect anomalies and alert on them.
  • Take pre-emptive measures to avoid service degradations.
Get started
For more information on the installation and configuration, please see Sybase ASE extension in the Dynatrace Documentation.
Details
Compatibility information
  • This extension supports remote monitoring via ActiveGate. It can't be installed on Sybase servers.
  • ActiveGate must be running version 1.300 or higher
  • Network connection between ActiveGate where this extension runs and monitored ASE is required.
  • This extension was tested on and supports Sybase ASE 15.7 and higher.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Database Statussybase.database.database_statusThe status of a databaseUnspecified
Deadlockssybase.database.deadlocks.countTotal number of deadlocks that have occurred.PerMinute
Connectionssybase.database.active_connections.countNumber of active inbound connections.PerMinute
Transactionssybase.database.transactions.countNumber of transactions run, server-wide.PerMinute
Transaction Rollbackssybase.database.transaction_rollbacks.countTotal number of transactions rolled backPerMinute
Select Operationssybase.database.selects.countTotal number of select operations executedPerMinute
Update Operationssybase.database.updates.countTotal number of update operations executedPerMinute
Insert Operationssybase.database.inserts.countTotal number of insert operations executedPerMinute
Delete Operationssybase.database.deletes.countTotal number of delete operations executedPerMinute
Merge Operationssybase.database.merges.countTotal number of merge operations executedPerMinute
Temporary Tablessybase.database.temporary_tables.countTotal number of temporary tables createdPerMinute
Readssybase.device.io_reads.countNumber of reads from the devicePerMinute
APF Readssybase.device.io_apf_writes.countNumber of asynchronous prefetch (APF) reads from the devicePerMinute
Writessybase.device.io_write.countNumber of writes to the devicePerMinute
Mirrored Device IO Requestssybase.device.io_mirrored_device_requests.countNumber of I/O requests to a mirrored device (if mirrored)PerMinute
Mirrored Device Tasks Waitingsybase.device.io_mirrored_device_tasks_waiting.countNumber of tasks forced to wait for synchronization of an I/O request to a mirrored device (if mirrored)PerMinute
Device IO Timesybase.device.io_time.countTotal amount of time (in milliseconds) spent waiting for I/O requests to be satisfiedMilliSecond
Packets Sentsybase.database.network.io_packets_sent.countNumber of packets sentPerMinute
Packets Receivedsybase.database.network.io_packets_received.countNumber of packets receivedPerMinute
Bytes Sentsybase.database.network.io_bytes_sent.countNumber of bytes sentPerMinute
Bytes Receivedsybase.database.network.io_bytes_received.countNumber of bytes receivedPerMinute
Blocking Pollssybase.io_controller.blocking_polls.countNumber of blocking pollsPerMinute
Non-Blocking Pollssybase.io_controller.non_blocking_polls.countNumber of nonblocking pollsPerMinute
Event Pollssybase.io_controller.blocking_event_polls.countNumber of polls returning an eventPerMinute
Non-Blocking Event Pollssybase.io_controller.non_blocking_event_polls.countNumber of nonblocking polls returning an eventPerMinute
Full Pollssybase.io_controller.full_polls.countNumber of polls returning the maximum number of eventsPerMinute
Events Polledsybase.io_controller.events.countNumber of events polledPerMinute
Pending IOPSsybase.io_controller.iops_pending.countNumber of pending I/O operationsPerMinute
Completed IOPSsybase.io_controller.iops_completed.countNumber of completed I/O operationsPerMinute
Deferred IOPSsybase.io_controller.iops_deferred.countNumber of I/O operations deferred or delayedPerMinute
IO Controller Readssybase.io_controller.io_reads.countNumber of read or receive operationsPerMinute
IO Controller Writessybase.io_controller.io_writes.countNumber of write or send operationsPerMinute
License Quantitysybase.database.license_quantityQuantity of licenses used for this feature.Count
License Expirationsybase.database.license_expiryTime Until License ExpirationSecond
Grace Period Expirationsybase.database.grace_expiryTime Until Grace Period ExpirationSecond
User CPU Busysybase.database.percent_user_busyPercent User CPU BusyPercent
System CPU Busysybase.database.percent_system_busyPercent System CPU BusyPercent
IO CPU Busysybase.database.percent_io_busyPercent IO CPU BusyPercent
Run Queue Lengthsybase.database.run_queue_lengthRun queue lengthCount
Kernel Run Queue Lengthsybase.database.kernel_run_queue_lengthKernel run queue lengthCount
Outstanding disk I/Ossybase.database.outstanding_disk_iosOutstanding disk I/OsCount
Disk Readssybase.database.disk_reads_per_secondDisk reads per secondPerSecond
Disk Writessybase.database.disk_writes_per_secondDisk writes per secondPerSecond
Network Readssybase.database.network_reads_per_secondNetwork reads per secondPerSecond
Network Writessybase.database.network_writes_per_secondNetwork writes per secondPerSecond
CPU Timesybase.database.cpu_time.countTotal time, in seconds, the engine has been running.Second
System CPU Timesybase.database.system_cpu_time.countTime, in seconds, the engine has been executing system database services.Second
User CPU Timesybase.database.user_cpu_time.countTime, in seconds, the engine has been executing user commands.Second
IO CPU Timesybase.database.io_cpu_time.countThe amount of time, in seconds, the engine has been waiting for issued IOs to complete.Second
IDLE CPU Timesybase.database.idle_cpu_time.countTime, in seconds, the engine has been in idle spin mode.Second
Database Connectionssybase.database.connections.countNumber of connections this engine handles.PerMinute
Disk IO Checkssybase.database.disk_io_checks.countNumber of times the engine or disk controller (for process or threaded mode, respectively) checks for asynchronous disk I/O. In process mode, use i/o polling process count to modify the frequency of these checks.PerMinute
Disk IO Polledsybase.database.disk_io_polled.countNumber of times the engine or disk controller (for process or threaded mode, respectively) polls for completion of outstanding asynchronous disk I/O, which occurs when disk I/O checks indicate that asynchronous I/O has been posted, but is not yet complete.PerMinute
Disk IO Completedsybase.database.disk_io_completed.countNumber of asynchronous disk I/Os completed when the engine or disk controller (for process or threaded mode, respectively) polls for outstanding asynchronous disk I/O.PerMinute
Context Switchessybase.database.context_switches.countNumber of context switches.PerMinute
Max GC Queue Sizesybase.database.max_gc_queue_sizeMaximum number of items the SAP ASE server can queue for housekeeper garbage collection in this engine.PerMinute
GC Pending Itemssybase.database.gc_pending_itemsNumber of items yet to be collected by housekeeper garbage collector on this engine.PerMinute
GC Overflowssybase.database.gc_overflowsNumber of items that could not be queued to housekeeper garbage collector due to queue overflows.PerMinute
Active Sessionssybase.database.active_sessions.countNumber of active sessions on this DatabaseCount
-sybase.database.distinct_users--
Database Sizesybase.database.total.sizeThe total size of a Database in MbMegaByte
Database Free Sizesybase.database.free.sizeThe free space of a Database in MbMegaByte
Device Sizesybase.device.sizeSize of the device, in megabytesMegaByte
Filesystem Sizesybase.device.fs_sizeSize of the file system, in megabytesMegaByte
Filesystem Free Spacesybase.device.fs_freeAmount of available free space, in megabytes, on the file systemMegaByte
Number of Buffer Poolssybase.cache.buffer_poolsNumber of buffer pools within the cacheCount
Cache Searchessybase.cache.searches.countCache searches directed to the cachePerMinute
Data Cache Physical Readssybase.cache.physical_reads.countNumber of buffers read into the cache from diskPerMinute
Data Cache Logical Readssybase.cache.logical_reads.countNumber of buffers retrieved from the cachePerMinute
Data Cache Physical Writessybase.cache.physical_writes.countNumber of buffers written from the cache to diskPerMinute
Data Cache Stallssybase.cache.io_stalls.countNumber of times I/O operations were delayed because no clean buffers were available in the wash areaPerMinute
Data Cache Sizesybase.cache.sizeTotal size of cache, in kilobytesKiloByte
Data Cache APF Readssybase.cache.apf_reads.countNumber of asynchronous prefetch (APF) reads for this data cachePerMinute
APF Limitsybase.cache.apf_limitThe configured asynchronous prefetch limit for this poolPercent
Cache Hit Ratesybase.cache.hit_percentThe percent of reads that hit the Data CachePercent
Cache Miss Ratesybase.cache.miss_percentThe percent of reads that missed the Data Cache and read from diskPercent
IO Buffer Sizesybase.cache.io_buffer_sizeSize (in bytes) of the I/O buffer for the poolByte
Allocated Bytessybase.cache.memory_allocatedNumber of bytes allocated for the poolKiloByte
Cache Pool Wash Sizesybase.cache.wash_sizeThe wash size, in kilobytes, for a memory poolKiloByte
Waiting Lockssybase.database.waiting_locks.countLocks that are in a waiting stateCount
Related to Sybase ASE
SAP HANA Database (remote monitoring) logo
Easily understand the health and performance of your SAP HANA databases.
SAP JVM logo
SAP JVM
Automatically and intelligently monitor, analyze, and optimize the performance of your virtual machine.
SAP GUI and ABAP Platform logo
Monitor your SAP Application Server's user transactions, RFC and jobs.
Full version history
ReleaseDate
Improved in this version
  • Resolved issue with dashboard links not opening on pure Gen3 tenants.
  • Improved detection of the database status, following the Sybase documentation advice.
⚠️IMPORTANT CHANGE: This extension release requires Dynatrace cluster version 1.313 or later.
New features:
  • The dt.security_context attribute is now propagated to all entities created by the extension. When enabling entity access control based on dt.security_context ensure you set the Grail security context destination property to dt.security_context
  • Enabled the extension to present the Dynatrace Platform (a.k.a. Gen3) entity details screens in the future platform apps that will expect these screens
  • Added metrics:
    • Database Size
    • Database Free Size
    • Number of active sessions on Database
    • Number of Locks that are in a waiting state
⚠️IMPORTANT CHANGE: This extension release requires Dynatrace cluster version 1.310 or later.
New features:
  • Added the Dynatrace Platform (a.k.a. Gen3) dashboard
New features:
  • Added sysdatabases status metric
New features
  • This is the initial release of this extension. Looking for your feedback through Community!
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
