Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Remote Desktop ProtocolRemote Desktop Protocol
Gather metrics and gain insights into the performance of user sessions over RDP.
Extension
Free trialDocumentation
The extension creates user sessions and actions for your users' RDP activity. Report on both session dynamics and performance leveraging by Dynatrace's Real User Monitoring and User Session Query Language.Every RDP session is represented in Dynatrace.Gain a view into RDP Performance at a glance by opening the detail page of your session Hosts. The extension adds a tile with key metrics collected.
  • Product information
  • Release notes
Overview
The Microsoft Remote Desktop Protocol (RDP) provides remote display and input capabilities over network connections for Windows-based applications running on a server. RDP is designed to support different types of network topologies and multiple LAN protocols. RDP also forms the basis for enterprise level solutions like Azure Virtual Desktop (formerly Windows Virtual Desktop), a desktop and app virtualization service that runs on the cloud.
This extension is designed to run on RDP session hosts, alongside the OneAgent. It leverages Windows Event Logs and Performance Counters to gather details about ongoing RDP sessions, providing insights into sessions performance as well as the health of the session host. The data gathered is represented in Dynatrace as Real User Monitoring (RUM) Sessions and Actions, or Metrics.
This is intended for users who:
  • Manage the infrastructure responsible for delivering virtual desktops to their users over RDP
  • Want to understand the performance of the RDP protocol and health of their session hosts
  • Need insights into the dynamics of user activity in remote desktop environments
This extension enables you to:
  • Track basic RDP activity for users across different session hosts
  • Monitor the Network and Graphics performance of the RDP protocol on session hosts
  • Correlate poor user experience with insufficiencies in client, server, or network resources
Use cases
  • Network Performance - is the user accessing the remote host over a slow network? does the client have enough bandwidth? is the session host skipping frames due to network insufficiencies?
  • Graphics Performance - what is the frame quality of the user's session? does the session host skip frames due to network, client, or server insufficiencies? is frame encoding taking the appropriate amount of time?
  • Input Delays - is the RDP kernel registering delays from when the user interacted with an application until the application reacted to that input?
  • Capacity - are active users being impacted by large amounts of inactive sessions holding resources on the host? is your session host clearing these appropriately?
  • Security - is there a large amount of failed logins to the hosts? what are the accounts that result in auhtentication failures, and for what reason?
Compatibility information
Minimum supported OneAgent version: 1.280
Supported RDP clients:
  • Direct RDP connections (mstsc.exe)
  • Microsoft Remote Desktop App (older than October 2022 release)
Session Input Delay and Process Input Delay are only supported for Windows Server 2019, or Windows 10 (1809), or later.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Base TCP RTTrdp.network.base_tcp_rttBase TCP round-trip time (RTT) detected in millisecondsMilliSecond
Base UDP RTTrdp.network.base_udp_rttBase UDP round-trip time (RTT) detected in millisecondsMilliSecond
Current TCP RTTrdp.network.current_tcp_rttCurrent TCP round-trip time (RTT) detected in millisecondsMilliSecond
Current UDP RTTrdp.network.current_udp_rttCurrent UDP round-trip time (RTT) detected in millisecondsMilliSecond
TCP bandwidthrdp.network.tcp_bandwidthCurrent TCP bandwidth detected in bits per second (bps)BitPerSecond
UDP bandwidthrdp.network.udp_bandwidthCurrent UDP bandwidth detected in bits per second (bps)BitPerSecond
Loss raterdp.network.loss_rateThe number of packets lost in transmission, expressed as a percentage of all packets.Percent
Retransmission raterdp.network.retransmission_rateThe number of packets retransmitted due to loss or damage, expressed as a percentage of all packetsPercent
Encoding timerdp.graphics.encoding_timeThe average time spent encoding frames. For RDP encoding time should be under 33 milliseconds.MilliSecond
Frame qualityrdp.graphics.frame_qualityThe quality of the output frame represented as a percentage of the quality of the source frame.Percent
Frames skipped (client)rdp.graphics.frames_skipped_clientThe number of frames skipped per second due to insufficient client resourcesPerSecond
Frames skipped (network)rdp.graphics.frames_skipped_networkThe number of frames skipped per second due to insufficient network resourcesPerSecond
Frames skipped (server)rdp.graphics.frames_skipped_serverThe number of frames skipped per second due to insufficient server resourcesPerSecond
Total sessionsrdp.terminal.total_sessionsThe total number of RDP Sessions on the host. This includes both active and inactive sessions.Count
Session input delayrdp.session_input_delayThe longest time it takes for an input (user click/keypress) to reach the application inside an RDP session. The value is reported per session.MilliSecond
Process input delayrdp.process_input_delayThe longest time it takes for an input (user click/keypress) to reach the application inside an RDP session. The value is reported per process.MilliSecond
Active sessionsrdp.terminal.active_sessionsThe number of Active RDP Sessions on the host. Active Sessions are actively being used by users logged onto their Virtual Desktop.Count
Inactive sessionsrdp.terminal.inactive_sessionsThe number of Inactive RDP Sessions on the host. Inactive Sessions are not currently being used by users but have not been terminated, users still being able to resume.Count
Active usersrdp.terminal.active_usersThe number of Active Users on the RDP Host. Active Users are actively logged onto their Virutal Desktops.Count
Login failuresrdp.terminal.login_failures_countThe number of failed login attempts along with failure details.Count
Related to Remote Desktop Protocol
OneAgent logo
OneAgent
The simplest way to capture all observation signals automatically and in context
Windows logo
Windows
Windows server performance with real-time metrics and automated issue detection
Full version history
ReleaseDate
New in this version:
  • A platform dashboard was added to showcase some of the extension's data
  • RDP Hosts will show extension metrics when opened in the Infrastructure Operations app
Improved in this version:
  • The extension's default logging has been reduced to allow the support archive to cover a larger timeframe. Verbose logging is now enabled through a checkbox in the configuration.
  • Error messages are now logged with Dynatrace error codes
Fixed in this version:
  • No permission to read OneAgent connectivity details
  • RDP Performance card would show up on all hosts' screens
🚀 Improved in this version
  • OpenKit initialization and recovery times are much quicker
🪲 Fixed in this version:
  • Auto-detected beacon endpoint URLs were wrongly formatted
🚀 Improved in this version:
  • When beacon auto-detect is enabled, the extension will find a new beacon endpoint and reconnect in case the original endpoint fails. The recovery time will vary depending on the amount of endpoints available to that OneAgent.
✨ New in this version:
  • First release of this extension, built on Extension Framework 2.0
  • Automatic distribution to OneAgent hosts
  • Rich metadata for collected metrics
  • Metrics are displayed on the Host detail page
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
