Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Redis (2.0)Redis (2.0)
Redis (2.0)
Redis (2.0)
Collect important additional data for your Redis instances.
Extension
Free trialDocumentation
The overview dashboard for the Redis extension including a link to the configuration screen and some high-level Redis metrics.A view of the classic Redis process group instance page, highlighting the Metrics and logs analysis button used to access the Unified Analysis screen with the Redis metrics.A screen showing several Redis metrics including client, database, and general information.A screen showing several Redis metrics including memory, slowlog, and statistics information.An example configuration showing several overrides including usage of the credential vault and a custom configuration file path.
  • Product information
  • Release notes
Overview
Redis is an open-source, in-memory, key-value database (or "data structure server") with optional durability. Redis is commonly used as a database, cache, queue, and message broker (publish and subscribe). Out of the box, Dynatrace monitors the standard Redis process level metrics. Using this extension you can collect additional Redis metrics including response time, memory fragmentation, cache hit ratio, cache usage, number of connections, hits, misses, and more.
Use cases
  • Monitor for critical issues such as unsynchronized replicas or synchronization tasks taking longer than expected
  • Identify memory related issues such as excessive memory fragmentation or keys being evicted due to memory limits being reached
  • Detect if clients are being rejected due to the maxclients limit
  • Identify if there is an increasing number of queries exceeding their specified execution times (reported in the slow log)
Get started
For more information on the installation and configuration, please see Redis (2.0) extension in the Dynatrace Documentation.
Details
Compatibility information
Requirements and limitations
  • Redis Server 2.8 or higher
  • Linux OS
  • Redis must listen on localhost. Binding between localhost and the Redis port is required.
Docker support
  • Redis docker image version 5.0.0+
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Connected replicasredis.connected_replicasNumber of connected replicas. This metric is visible for the master and those replicas that are connected to other replicas.Count
Last master interaction timeredis.master_last_io_seconds_agoTime since interaction with the masterSecond
Keysredis.keysThe number of keys in the selected database.Count
Expiresredis.expiresThe number of keys that have the TTL parameter.Count
Average time-to-liveredis.avg_ttlThe estimated average TTL of keys on the server.MilliSecond
Roleredis.roleThe role of the Redis instance (e.g. master, slave, or sentinel)State
Responsivenessredis.responsivenessThe time elapsed while the Redis server responds to INFO requests. Redis typically responds within milliseconds.MilliSecond
Slow queriesredis.slowlog_len.countThe number of queries added in the Redis slow log.Count
Keyspace hitsredis.keyspace_hits.countNumber of successful key lookups in the main dictionary.Count
Keyspace missesredis.keyspace_misses.countNumber of failed key lookups.Count
Evicted keysredis.evicted_keys.countNumber of keys removed from cache to free up memory for new itemsCount
Expired keysredis.expired_keys.countNumber of key expiration events.Count
Commands processedredis.total_commands_processed.countNumber of commands processed by Redis.Count
Cache hit ratioredis.hit_ratioThe percentage of key lookups in the main dictionary that were successful.Percent
Connected clientsredis.connected_clientsNumber of client connections (excluding connections from replicas).Count
Blocked clientsredis.blocked_clientsThe number of blocked clientsCount
Connections receivedredis.total_connections_received.countNumber of connections accepted by the server.Count
Rejected connectionsredis.rejected_connections.countThe number of connections rejected because of the maxclients limit.Count
Used memoryredis.used_memoryThe amount of memory in-useByte
Max memoryredis.maxmemoryThe maximum memory allowed in Redis cache.Byte
Memory fragmentation ratioredis.mem_fragmentation_ratioThe ratio of memory used by the operating system compared to the amount of memory allocated by Redis.Percent
Memory usageredis.memory_usageThe percentage of utilized Redis memory. This metric is visible only when the Redis maxmemory parameter is configured.Percent
Full version history
ReleaseDate
Fixes
  • Resolve issue with parsing running process snapshots without any internal listening ports
Improved in this version:
  • Improved handling of internal listing ports for managing configuration mapping in Docker containers
This version requires a minimum Dynatrace and EEC version of 1.318
New in this version:
  • Templates for Davis anomaly detectors added to extension package
Minimum OneAgent version is 1.314.0
Features
  • Support for client-side certificate based authentication
Changes
  • Improved error handling (Dynatrace Error Codes) and Endpoint Statuses.
Minimum Dynatrace version now 1.314!
Changes
  • Included platform dashboard
  • Metrics displayed for process group instance in Infrastructure & Operations App
Features
  • TLS/SSL support
  • Parsing of redis configuration file to automatically retrieve and use password for default user
  • Fixes bug that prevented redis.hit_ratio from being reported.
  • Fix bug in snapshot processing that could prevent some intervals from collecting data
  • Correct data type of top-level password to be an encrypted secret
  • Correct logic in parsing of snapshot file to avoid breaking in some scenarios
  • detect and handle sentinel processes more cleanly
  • attempt to connect without a password if scenario detected where a password was provided but is not needed
  • Initial 2.0 release
Dynatrace Hub
All (876)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
