Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Prometheus Alertmanager (v2)Prometheus Alertmanager (v2)
Receive Prometheus Alertmanager events and open problems in Dynatrace
Extension
Free trialDocumentation
The Alertmanager extension allows Dynatrace to receive events from Prometheus Alertmanager and automatically convert them to Dynatrace Problems when appropriate. The extension also closes problems when the events are resolved in Alertmanager.
  • Product information
  • Release notes
Overview
Receive Alertmanager events and turn them into Dynatrace Problems
Get started
For more information on the installation and configuration, please see Prometheus Alertmanager (v2) extension in the Dynatrace Documentation.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Prometheus Alertmanager (v2)
Prometheus logo
Prometheus
Unlock Prometheus power with intelligent analytics and automated insights.
Full version history
ReleaseDate
Version 2.1.13
  • The extension will now attempt to check if the CUSTOM_DEVICE entity was created before sending the event to Dynatrace, it will wait 1 second, then 5, 10 and 20 between checks.
This requires entities.read scope for the API Token. If the API request to check the entity creation fails the event will be sent as usual.
This fixes an issue where the event takes a long time to appear if Dynatrace is not yet aware of the entity that was created for the event.
Version 2.1.11
  • Add a 30 seconds timeout on the dynatrace api client
Version 2.1.10
  • Fix an issue with jobs that stopped the extension from starting.
Bugfixes
  • Add exception handling to the cache in case of failures.
Version 2.1.7
  • Use the label device if available, and host if device is not available, for the custom device name
Version 2.1.5
  • Fix an issue where the AG location could not be determined in custom installs
Version 2.1.4
  • Fix an issue where a 500 error was returned when attempting to delete a problem that was not present on the cache
Version 2.1.3
  • Fix an issue for AG installations that don't have a custom.properties file
Version 2.1.2
  • Fix an issue where the extension could not find the correct directory for custom AG installations
Version 2.1.1
Breaking change
Version 2.1.1 uses the Event v2 API, which allow us to close problems gracefully instead of manually.
This means that the token now must have the Ingest events scope.
Problems closed this way can be reopened by Alertmanager, which solves an issue where a problem that is resent with the same body was supressed, even though the alert was active in Alertmanager.
Version 2.0.1
  • First EF2 version release
Dynatrace Hub
All (877)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
