Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
PagerDutyPagerDuty
PagerDuty
PagerDuty
Create incidents in PagerDuty and list all of the on-calls
App
Free trialDocumentation
An overview of the actions offered by PagerDuty for Workflows.An example workflow for creating an incident using actions provided by PagerDuty for Workflows.An example configuration for the "Create an incident" action
  • Product information
  • Release notes
Overview
Integrate PagerDuty with Dynatrace to automate the creation of incidents whenever a problem, security vulnerability, or attack is detected. The app can also share who's on call to respond to the incident.
Use cases
This enables you to:
  • Integrate workflows with PagerDuty incident management
  • Create PageDuty incidents based on a Davis problem, a security incident, or an attack
  • List on-calls to inform available users
Get started
Follow the instructions detailed in Dynatrace Documentation.
Ensure that you have installed PagerDuty for Workflows, outbound connections are configured, and the connection to PagerDuty is authorized.
Details
PagerDuty for Workflows enables users to model incident and remediation processes within Dynatrace:
Define various incident triggers:
  • Use the power of DQL and leverage events to react to any problem, security incident, or attack within workflows
  • Use Biz-Events as a trigger to react on extended events like a failed release validation, certain logs messages, or external system events
  • Define a scheduler for periodic tasks
Flexible Incident Creation
  • Create incidents in PagerDuty within a Dynatrace workflow
  • Define assignee or escalation policy, service identifiers, priority, and urgency
  • List on-calls
  • Retrieve additional information like escalation policies, services, priorities and users
  • Combine incident creation with closed-loop communication via Slack, Teams, and E-Mail
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to PagerDuty
Workflows logo
Workflows
Full version history
ReleaseDate
This maintenance release is bundled with some minor quality of life improvements.
  • Updated dependencies
2.0.4
  • Schema version increased
2.0.3
2.0.2
2.0.1
  • Improved visual fidelity of connection management in modals
2.0.0
  • enable access control for settings
  • Enable ACL
2.0.3
2.0.2
2.0.1
2.0.0
  • Enable ACL
2.0.2
Patch Changes
2.0.1
Patch Changes
2.0.0
Major Changes
  • Enable ACL
2.0.0
Major Changes
  • Enable ACL
1.1.2
Patch Changes
1.1.1
Patch Changes
  • Improved Japanese language support
1.1.0
Minor Changes
  • App is headless again. To control your connections, please use the Settings app.
1.1.1
Patch Changes
1.1.0
Minor Changes
1.1.0
Minor Changes
1.0.1
Patch Changes
  • Change: "for Workflows" was removed from the app title
1.0.0
Marks the first major release of PagerDuty.
1.0.0
0.5.0
Introduce a new, streamlined connection management experience with a modernized interface. This update makes adding and editing connections directly within workflows easier and provides connection control and convenience in one place.
Patch Changes
  • Add NO_WHITESPACE constraint to URL in settings schema
0.4.1
Patch Changes
  • Updated dependencies & added a new app icon
0.4.0
Minor Changes
  • Breaking: connections have been changed from an ordered list to an unordered list. This was done in preparation for better ACL support. However, inserting connections via API or Monaco using insertAfter will no longer be possible.
0.4.0
Minor Changes
0.3.3
Patch Changes
0.3.2
Patch Changes
0.3.1
Patch Changes
0.3.0
Minor Changes
  • 98a2fdc: Add support for conference bridge (conference number and URL) to create incident action
0.3.1
Patch Changes
  • Dependency Updates
0.3.0
Minor Changes
0.2.5
Patch Changes
0.2.4
Patch Changes
  • 3cb11b3: Update app icon
  • f782a36: Create Incident Action: Add DT_ prefix to default value of event id
  • cf4a872: Add incident_key field to create incident action
  • 21f209f: Add sample results for all actions
0.2.3
Patch Changes
  • Update dependencies
0.2.2
Patch Changes
0.2.1
Patch Changes
0.2.0
Minor Changes
  • c769a8d: Added placeholders with examples
0.2.4
Patch Changes
0.2.3
Patch Changes
0.2.2
Patch Changes
0.2.1
Patch Changes
0.2.0
Minor Changes
0.2.3
Patch Changes
0.2.2
Patch Changes
0.2.1
Patch Changes
0.2.0
Minor Changes
0.2.0
Minor Changes
0.1.7
Patch Changes
0.1.3
Patch Changes
  • 8ee310e: Improve language used in display names and hints in action widgets
0.1.2
Patch Changes
  • 5b916cb: Added error log in case retrieving connection details failed
0.1.1
Patch Changes
  • 1377465: Improve wording for actions, descriptions and fields
  • b7e0055: Update strato-components and dt-app dependencies for improved UX and A11y
0.1.0
Minor Changes
  • ceae4b8: Simplify workflow action results to only include parsed JSON, log all requests and responses, and fail for HTTP status >= 400
  • d90e726: Added supportive workflow actions: list-services, list-escalation-policies, list-priorities and list-users
  • 3e1766a: Added list on-calls workflow action
  • a399104: Require API token to be re-entered if API URL is changed
  • 373ece6: Added create-incident workflow action
Patch Changes
  • f423ad1: Update app dependencies via dt-cli
  • 86ce8ab: Streamlined wording
0.1.6
Patch Changes
  • Dependency updates
0.1.3
Patch Changes
0.1.2
Patch Changes
0.1.1
Patch Changes
0.1.0
Minor Changes
Patch Changes
0.1.3
Patch Changes
0.1.2
Patch Changes
0.1.1
Patch Changes
0.1.0
Minor Changes
Patch Changes
Dynatrace Hub
All (876)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
