Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Oracle Cloud Infrastructure (OCI)Oracle Cloud Infrastructure (OCI)
Monitor health and performance of the Oracle Cloud Infrastructure.
Extension
Free trialDocumentation
OCI dashboardOCI Compute screenOCI metrics in the metric browser
  • Product information
  • Release notes
Overview
This extension monitors basics of the Oracle Cloud Infrastructure.
This is intended for users, who:
Want to monitor foundation of their Oracle Cloud Infrastructure, including:
  • Compute resources
  • Cloud networking resources
  • Site-to-Site VPN
  • Load Balancing
  • Block storage
  • Object storage
  • Filesystem storage
  • API gateway
  • OCI serverless functions
  • Alarms generated in the tenancy, so these show up as events in Dynatrace
This extension does not cover every single service available on Oracle Cloud.
This extension focuses on basic Oracle Cloud Infrastructure services and does not look to monitor Oracle SaaS offerings like e.g. CX, HCM, ERP, SCM, EPM and alike.
Are you looking to extend OCI services visibility to all service available on Oracle Cloud? Look here: Any OCI service metric and log ingestion can be set up leveraging Oracle Connector Hub and push-based ingest. Look for this technology hub tile for instructions how to do it and limitations that come with it.
In brief: push-based ingest requires you to set up ingest functions in OCI and doesn't provide analysis screens for ingested metrics, but it can cover any service metrics. More at Oracle Connector Hub signals ingest
Use cases
This extension enables you to:
  • Monitor health and performance of the Oracle Cloud Infrastructure
  • focusing on compute, storage and networking foundation of the infrastructure.
Get started
For more information on the installation and configuration, please see Oracle Cloud Infrastructure (OCI) extension in the Dynatrace Documentation.
Details
Compatibility information
  • OCI API access from ActiveGate is required
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
OCI Compartment Alarms Configuredcloud.oci.compartment.configured_alarm_count.gaugeNumber of Alarms configured for this OCI CompartmentsCount
Ingress Packets Dropped by Security Listcloud.oci.vcn.ingress.packets.dropped.slPackets received from the network, destined for the VNIC, dropped due to security rule violations.Count
Egress Packets Dropped by Security Listcloud.oci.vcn.egress.packets.dropped.slPackets sent by the VNIC, destined for the network, dropped due to security rule violations.Count
Packets from Networkcloud.oci.vcn.packets.from.networkPackets received at the VNIC from the network, after drops.Count
Packets to Networkcloud.oci.vcn.packets.to.networkPackets sent from the VNIC to the network, before drops.Count
Bytes from Networkcloud.oci.vcn.bytes.from.networkBytes received at the VNIC from the network, after drops.Byte
Bytes to Networkcloud.oci.vcn.bytes.to.networkBytes sent from the VNIC to the network, before drops.Byte
Throttled Ingress Packetscloud.oci.vcn.throttled.ingress.packetsPackets sent from the VNIC, destined for the network, dropped due to throttling.Count
Throttled Egress Packetscloud.oci.vcn.throttled.egress.packetsPackets received from the network, destined for the VNIC, dropped due to throttling.Count
Ingress Packets Dropped by Full Connection Tracking Tablecloud.oci.vcn.ingress.packets.dropped.fcttPackets received from the network, destined for the VNIC, dropped due to full connection tracking table.Count
Egress Packets Dropped by Full Connection Tracking Tablecloud.oci.vcn.egress.packets.dropped.fcttPackets sent from the VNIC, destined for the network, dropped due to full connection tracking table.Count
Connection Tracking Table Utilizationcloud.oci.vcn.ctt.utilTotal utilization percentage (0-100%) of the connection tracking table.Percent
Connection Tracking Table Fullcloud.oci.vcn.ctt.fullBoolean (0/false, 1/true) that indicates the connection tracking table is full.State
Inbound Requestscloud.oci.load_balancer.http.requestsThe number of incoming client requests to the backend set.Count
Active Connectionscloud.oci.load_balancer.active.connectionsThe number of active connections.Count
Active SSL Connectionscloud.oci.load_balancer.active.ssl.connectionsThe number of active SSL connections.Count
Bytes Receivedcloud.oci.load_balancer.bytes.receivedThe number of bytes received by the load balancer.Byte
Bytes Sentcloud.oci.load_balancer.bytes.sentThe number of bytes sent by the load balancer.Byte
Accepted Connectionscloud.oci.load_balancer.accepted.connectionsThe number of connections accepted by the load balancer.Count
Handled Connectionscloud.oci.load_balancer.handled.connectionsThe number of connections handled by the load balancer.Count
Failed SSL Handshakescloud.oci.load_balancer.failed.ssl.handshakeThe number of failed SSL handshakes.Count
Accepted SSL Handshakescloud.oci.load_balancer.accepted.ssl.handshakeThe number of accepted SSL handshakes.Count
Failed Client SSL Cert Verificationscloud.oci.load_balancer.failed.ssl.client.cert.verifyThe number of failed client SSL certificate verifications.Count
Peak Bandwidthcloud.oci.load_balancer.peak.bandwidthMaximum bits per second bandwidth used during the specified interval.MegaBytePerSecond
Processed Bytescloud.oci.network_load_balancer.processed.bytesThe total number of bytes processed by the network load balancer, including TCP/IP headers.Byte
Processed Packetscloud.oci.network_load_balancer.processed.packetsThe total number of packets processed by the network load balancer.Count
Ingress Packets Dropped by Security Listcloud.oci.network_load_balancer.ingress.packets.droppedThe packets received from the network, destined for the network load balancer, dropped because of security rule violations.Count
Egress Packets Dropped by Security Listcloud.oci.network_load_balancer.egress.packets.droppedThe packets sent by the network load balancer, destined for the network, dropped because of security rule violations.Count
Healthy Backendscloud.oci.network_load_balancer.healthy.backendsThe number of healthy backend servers present in the network load balancer.Count
Unhealthy Backendscloud.oci.network_load_balancer.unhealthy.backendsThe number of unhealthy backend servers present in the network load balancer.Count
New Connectionscloud.oci.network_load_balancer.new.connectionsThe total number of new connections established between client and a backend server.Count
New TCP Connectionscloud.oci.network_load_balancer.new.connections.tcpThe total number of new TCP connections established between client and a backend server.Count
New UDP Connectionscloud.oci.network_load_balancer.new.connections.udpThe total number of new UDP connections established between client and a backend server.Count
Volume Read Throughputcloud.oci.block_volume.read.throughputRead throughput, expressed as bytes read per interval.Byte
Volume Write Throughputcloud.oci.block_volume.write.throughputWrite throughput, expressed as bytes written per interval.Byte
Volume Read Operationscloud.oci.block_volume.read.opsActivity level from I/O reads, expressed as reads per interval.Count
Volume Write Operationscloud.oci.block_volume.write.opsActivity level from I/O writes, expressed as writes per interval.Count
Volume Throttled Operationscloud.oci.block_volume.throttled.opsTotal sum of all the I/O operations that were throttled during a given time interval.Count
Volume Guaranteed VPUs/GBcloud.oci.block_volume.guaranteed.vpus.gb-Count
Volume Guaranteed IOPScloud.oci.block_volume.guaranteed.iops-Count
Instance Pool Sizecloud.oci.instance_pool.sizeNumber of instances in the pool.Count
Instances Provisioningcloud.oci.instance_pool.provisioningNumber of instances in the pool that are provisioning.Count
Instances Runningcloud.oci.instance_pool.runningNumber of running instances in the pool.Count
Instances Terminatedcloud.oci.instance_pool.terminatedNumber of instances in the pool that are terminating or terminated.Count
Backend Serverscloud.oci.load_balancer.backend.serversThe number of backend servers in the backend set.Count
Unhealthy Backend Serverscloud.oci.load_balancer.unhealthy.backend.serversThe number of unhealthy backend servers in the backend set.Count
HTTP Responsescloud.oci.load_balancer.http.responsesThe number of HTTP responses received.Count
Average HTTP Response Timecloud.oci.load_balancer.response.time.httpAverage response time of backend servers, HTTP only.MilliSecond
Average TCP Response Timecloud.oci.load_balancer.response.time.tcpAverage time to the first byte of response from backend servers, TCP only.MilliSecond
Backend Timeoutscloud.oci.load_balancer.backend.timeoutsThe number of timeouts across all backend servers.Count
Keep-alive Connectionscloud.oci.load_balancer.keepalive.connectionsThe number of keep-alive connections.Count
Closed Connectionscloud.oci.load_balancer.closed.connectionsThe number of connections closed between the load balancer and backend servers.Count
Invalid Header Responsescloud.oci.load_balancer.invalid.header.responsesThe number of invalid header responses across all backend servers.Count
HTTP 200 Responsescloud.oci.load_balancer.http.responses.200The number of HTTP 200 responses received.Count
HTTP 2xx Responsescloud.oci.load_balancer.http.responses.2xxThe number of HTTP 2xx responses received.Count
HTTP 3xx Responsescloud.oci.load_balancer.http.responses.3xxThe number of HTTP 3xx responses received.Count
HTTP 4xx Responsescloud.oci.load_balancer.http.responses.4xxThe number of HTTP 4xx responses received.Count
HTTP 5xx Responsescloud.oci.load_balancer.http.responses.5xxThe number of HTTP 5xx responses received.Count
HTTP 502 Responsescloud.oci.load_balancer.http.responses.502The number of HTTP 502 responses received.Count
HTTP 504 Responsescloud.oci.load_balancer.http.responses.504The number of HTTP 504 responses received.Count
API Requestscloud.oci.api_gateway.http_requestsNumber of incoming API client requests to the API gatewayCount
API Responsescloud.oci.api_gateway.http_responsesNumber of http responses that the API gateway has sent backCount
Bytes Sentcloud.oci.api_gateway.bytes_sentNumber of bytes sent by the API gateway to API clientsByte
Bytes Receivedcloud.oci.api_gateway.bytes_receivedNumber of bytes received by the API gateway from API clientsByte
Gateway Latencycloud.oci.api_gateway.latencyAverage time that it takes for a request to be processed and its response to be sentSecond
Internal Latencycloud.oci.api_gateway.internal_latencyTime spent internally in the API gateway to process the requestSecond
Backend Latencycloud.oci.api_gateway.integration_latencyTime between the API gateway sending a request to the back-end service and receiving a response from the back-end serviceSecond
Backend Responsescloud.oci.api_gateway.backend_http_responsesCount of the HTTP responses returned by the back-end servicesCount
Usage Plan Requestscloud.oci.api_gateway.usage_plan_requestsNumber of requests to a given entitlementCount
Subscriber Requestscloud.oci.api_gateway.subscriber_requestsNumber of requests made by a subscriberCount
Subscriber Quota Proportion Usedcloud.oci.api_gateway.subscriber_quota_proportion_usedProportion of an entitlement's quota that has been consumed by a subscriberCount
Subscriber Rate Limit Proportion Usedcloud.oci.api_gateway.subscriber_rate_limit_proportion_usedProportion of an entitlement's rate limit that has been consumed by a subscriberCount
Bucket Sizecloud.oci.object_store.sizeTotal size of objects in a bucketKibiByte
Number of Objectscloud.oci.object_store.count.gaugeTotal number of objects in a bucketCount
DRG Packet Dropscloud.oci.dynamic_routing_gateway.packet_dropsThe number of packets sent from the DRG attachment and dropped by the DRG.Count
CPU Utilizationcloud.oci.compute.cpu.utilActivity level from CPU, expressed as a percentage of total time.Percent
Disk Read Bytescloud.oci.compute.disk.read.bytesRead Throughput, expressed as bytes read per interval.Byte
Disk Write Bytescloud.oci.compute.disk.write.bytesWrite throughput, expressed as bytes written per interval.Byte
Disk Read I/Ocloud.oci.compute.disk.read.ioActivity level from I/O reads, expressed as reads per interval.Count
Disk Write I/Ocloud.oci.compute.disk.write.ioActivity level from I/O writes, expressed as writes per interval.Count
Load Averagecloud.oci.compute.loadAverage system load.Count
Memory Allocation Stallscloud.oci.compute.memory.allocation.stallsNumber of times page reclaim was called directly.Count
Memory Utilizationcloud.oci.compute.memory.utilSpace currently in use, measured by pagtes, expressed as a percentage of used pages.Percent
Network Receive Bytescloud.oci.compute.network.receive.bytesNetwork receipt throughput, expressed as bytes received.Byte
Network Transmit Bytescloud.oci.compute.network.transmit.bytesNetwork transmission throughput, expressed as bytes transmitted.Bytes
Read Throughputcloud.oci.filesystem.read.throughputFile System Read ThroughputCount
Write Throughputcloud.oci.filesystem.write.throughputFile System Write ThroughputCount
Read Requestscloud.oci.filesystem.read.requestsFile System Read RequestsCount
Write Requestscloud.oci.filesystem.write.requestsFile System Write RequestsCount
Read Latencycloud.oci.filesystem.read.latencyFile System Read LatencyCount
Write Latencycloud.oci.filesystem.write.latencyFile System Write LatencyCount
Metadata Read Latencycloud.oci.filesystem.metadata.read.latencyFile System Metadata Read LatencyCount
Metadata Write Latencycloud.oci.filesystem.metadata.write.latencyFile System Metadata Write LatencyCount
Metadata IOPScloud.oci.filesystem.metadata.iopsFile System Metadata IOPSCount
Usagecloud.oci.filesystem.usageFile System UsageCount
IPSec Tunnel Statecloud.oci.vpn.tunnel_stateWhether the tunnel is up (1) or down (0).State
Packets Receivedcloud.oci.vpn.packets_receivedNumber of packets received at the Oracle end of the connectionCount
Bytes Receivedcloud.oci.vpn.bytes_receivedNumber of bytes received at the Oracle end of the connectionByte
Packets Sentcloud.oci.vpn.packets_sentNumber of packets sent from the Oracle end of the connectionCount
Bytes Sentcloud.oci.vpn.bytes_sentNumber of bytes sent from the Oracle end of the connectionByte
Packets with Errorscloud.oci.vpn.packets_errorNumber of packets dropped at the Oracle end of the connectionCount
-cloud.oci.function.function_invocation_count--
Function Durationcloud.oci.function.function_execution_durationTotal function execution durationMilliSecond
-cloud.oci.function.function_error_response_count--
-cloud.oci.function.function_throttled_response_count--
FastConnect Bits Receivedcloud.oci.fast_connect.bits_receivedNumber of bits received on the FastConnect interface at the Oracle end of the connection.Bit
FastConnect Bits Sentcloud.oci.fast_connect.bits_sentNumber of bits sent from the FastConnect interface at the Oracle end of the connection.Bit
FastConnect Connection Statecloud.oci.fast_connect.connection_stateThe values are up (1) or down (0).Count
FastConnect Error Packetscloud.oci.fast_connect.packets_errorNumber of packets dropped due to errors at the Oracle end of the connection.Count
FastConnect Discard Packetscloud.oci.fast_connect.packets_discardedNumber of packets discarded at the Oracle end of the connection.Count
FastConnect Ipv4 BGP Session Statecloud.oci.fast_connect.packets_bgp_session_stateThe values are up (1) or down (0).Count
Related to Oracle Cloud Infrastructure (OCI)
Oracle Cloud logo
Oracle Cloud
Oracle Cloud performance monitoring and optimization.
Oracle Base DB and Autonomous DB on OCI logo
Monitor health of the Oracle Base Service and Autonomous Database.
Oracle Connector Hub signals ingest logo
Observe OCI services with signals ingested from the Oracle Connector Hub
Full version history
ReleaseDate
Improved in this version
  • Resolved an issue that could cause tags not to be imported for all entities.
  • Resolved an issue with VCN tags import.
  • Resolved issue with dashboard links not opening on pure Gen3 tenants.
  • Ongoing security updates
  • Ongoing security updates to the underlying Python libraries
⚠️ Important Change
  • This release requires a Minimum Dynatrace Version version of 1.318.0 or higher.
New in this version
  • Added ALERT_TEMPLATES for anomaly detectors in the Davis Anomaly Detection app (latest Dynatrace only).
  • Added Subnet and vNIC dimensions to VCN metrics and Compartment Name dimension to all metrics.
  • Resolved an issue with proxy incorrectly used when the ActiveGate REST Interface is located on localhost.
  • Resolved an issue causing OCI alerts to be imported multiple times.
New features
  • Added cloud.oci.block_volume.guaranteed.vpus.gb and cloud.oci.block_volume.guaranteed.iops metrics
  • Added out of the box regions identification for: AP Delhi 1, AP Batam 1, EU Madrid 3, EU Turin 1, ME Ibri 1
Patch level changes
  • Resolved an issue where Subnets and vNICs were imported as VCN entities.
  • Resolved an issue causing some buckets and object not to be imported.
  • Renamed Filesystem entities to match their name in OCI.
  • Metrics displayed in Gen2 and Gen3 dashboards are now split by instance instead of tenant.
Patch level changes:
  • Improved metric collection performance in high-volume environments.
New features:
  • Added OCI sub-compartments automated discovery
  • Fixed load balancers tile on the Gen2 (classic) dashboard showing a wrong count
New features:
  • Added support for custom OCI regions in the monitoring configuration.
  • Note this is a ⚠️BREAKING CHANGE: you need to recreate monitoring configurations after upgrading to this release.
  • Changed entity names from IDs to actual OCI names where available, and added tenancy name as dimension for metrics.
⚠️IMPORTANT CHANGE: This extension release requires Dynatrace cluster version 1.313 or later.
New features:
  • The dt.security_context attribute is now propagated to all entities created by the extension. When enabling entity access control based on dt.security_context ensure you set the Grail security context destination property to dt.security_context
  • Enabled the extension to present the Dynatrace Platform (a.k.a. Gen3) entity details screens in the future platform apps that will expect these screens
  • Added missing status code dimension on api_gateway metrics.
  • When configuring the extension, Regions are now chosen from a dropdown list instead of text input.
⚠️IMPORTANT CHANGE: This extension release requires Dynatrace cluster version 1.310 or later.
New features:
  • Added the Dynatrace Platform (a.k.a. Gen3) dashboard
New features:
  • Added option to skip SSL certificate validation; useful when using self-signed certificates
Patch-level changes:
  • More responsive error handling in the fastcheck phase of the new configuration activation
  • Proxy handling fixes
  • Oracle SDK currency updates
New features:
  • Added an option of the OCI alarm ingest. Alarms are ingested into your Dynatrace tenant as events.
  • Added an option to configure monitoring interval. Default 1-minute remains as-is.. You can change it to higher number in order to decrease load on the OCI API, which may be useful to avoid throttling on Oracle side. Please note that loner monitoring intervals affect Dynatrace ability to alert on anomalies on time.
  • Fixed an issue where proxy settings were not correctly applied to the Oracle API client connection
New features:
  • Added possibility of an explicit proxy configuration for the API connection. Note that OCI SDK may still use OS-level environment proxy setting. See Q&A for more information on proxy support.
  • Updated support for Oracle Cloud sovereign regions, to include recently rolled out new regions.
New features:
  • Support for Dynamic Routing Gateway service (DRG)
  • Support for Fast Connect service
Patch level change:
  • Recompiled for compatibility with ActiveGate running RHEL 7.9.
  • Added metric descriptions and sourceEntityTypes
  • Added function metadata tagging
  • Update Dynatrace API calls to use configured communication URL
Added more OCI services monitoring:
  • API gateway
  • Serverless functions
Marking the 1.0 release.
First GA release. We look for your feedback, through Community, on both the extension focus, scope and documentation.
Basics of the basics release - for preview.
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
