Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Mulesoft Cloudhub (Extension v2)Mulesoft Cloudhub (Extension v2)
Gather metrics and topology from your Anypoint Cloudhub applications
Extension
Free trialDocumentation
  • Product information
  • Release notes
Overview
Collect Organization, Environment, Application, Endpoint, APIs and Workers metrics for your Mulesoft Cloudhub apps.
Metrics
  • vCores Production - The number of vCores active on the organization for Production environments
  • vCores Sandbox - The number of vCores active on the organization for Sandbox environments
  • vCores Design - The number of vCores active on the organization for Design environments
  • VPCs - The number of VPCs active on the organization
  • VPNs - The number of VPNs active on the organization
  • Gateways - The number of Gateways active on the organization
  • Applications - The number of Applications on the organization
  • Started Applications - The number of Applications that are started on the organization
  • Workers - The number of Workers for an application
  • Remaining Workers - The number of Workers remaining for an application
  • Requests - The number of requests for an application
  • Errors - The number of errors for an application
  • Response Time - The average response time for an application
  • JVM Heap Used - The amount of JVM Heap used for the worker
  • JVM Heap Total - The total amount of JVM Heap for the worker
  • Thread Count - The number of threads for the worker
  • CPU - The CPU usage for the worker
  • Load Average - The load average for the worker
  • Available Processors - The number of available processors for the worker
  • Requests - Per endpoint and response type
  • Response time - Per endpoint and response type
  • Outbound Response Time - Per endpoint and response type
  • Outbound Requests - Per endpoint and response type
  • API Requests - Per API, response_code
  • API Request Size - Per API, response_code
  • API Response Size - Per API, response_code
  • API Response Time - Per API, response_code
  • API Policy Violations - Per API, policy
  • API Requests by Location" - Per API and Location
Get started
For more information on the installation and configuration, please see Mulesoft Cloudhub (Extension v2) extension in the Dynatrace Documentation.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
Version 2.2.6
  • Fix an issue where the Worker CPU metric utilization was not properly scaled to %. This metric will now report 100 times its previous value.
  • New Platform/Gen3 dashboard bundled with extension
  • Added DQL support for Platform/Gen3 screens
  • Enriched entities with dt.security_context attribute
Version 2.2.4
🐛 Bugfixes
  • Fix an issue where the list of APIs was not paginated correctly
Version 2.2.3
  • Fix an issue where app metrics are not reported when running in demo mode.
Version 2.2.2
🐛Bugfixes
  • Fix an issue where only the first 100 APIs were monitored by the extension
Version 2.2.1
🚀 Features
  • Use the v2 API to gather v1 Apps, which allows the extension to monitor more than 200 v1 applications
  • Added options to disable v1 apps, v2 apps, apis or private spaces data collection
Version 2.1.2
  • Add detailed log and log_level option for the fastcheck
Version 2.1.1
  • Adds logging for the output of the fastcheck
Version 2.1.0
Features
  • Introduce support for Private Spaces VPNs
    • cloudhub.vpn.tunnel.accepted_routes
    • cloudhub.vpn.tunnel.status
No new entities are introduced, metrics can be added to dashboards/data explorer, example:
cloudhub.vpn.tunnel.status:splitBy("org.name", private_space.name, connection.name, vpn.name, vpn.remote_ip_address, vpn.tunnel.local_ptp_ip_address, vpn.tunnel.status):sort(value(auto,descending)):limit(100)
Note, to collect the data, the Connected App needs to have the scope Runtime Manager > Cloudhub Network Viewer
Version 2.0.1
  • Fix an issue where v2 applications were not attempted to be collected if we failed to collect v1 applications
Version 2.0.0
  • Add initial support for v2 apps
Dynatrace Hub
All (876)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
