Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Microsoft Active Directory monitoringMicrosoft Active Directory monitoring
Monitor health and performance of the Microsoft Active Directory, all-on-one.
Extension
Free trialDocumentation
Active Directory dashboardActive Directory dashboard chartsActive Directory analysis screen
  • Product information
  • Release notes
Overview
Get insights into performance and usage of the Microsoft ActiveDirectory services:
  • DHCP, DNS, DFS, LDAP, ATQ, Kerberos and NTLM
  • AD Network adapters and AD/LSA database
  • AD replication status
  • LDAP BIND performance, FSMO consistency, AD database disk usage
  • System-dependent services status like time synchronization, volume health and network adapter health
This extension obtains signals through WMI queries and execution of the PowerShell snippets, depending on where is the source of specific metric. It is designed to work on the AD hosts where the OneAgent is already deployed.
This extension replaces previously available Active Directory monitoring extensions** This Dynatrace extension supersedes both Active Directory services and Active Directory extended monitoring extensions.
Use cases
  • Operational monitoring of your Active Directory services, tenant, for usage, performance and availability
  • Analyze trends and baselines of the Active Directory services usage
  • Raise alerts on anomalies detected
  • Monitor vital AD log signals in Dynatrace
Note that Entra ID (f.k.a. Azure AD) is not supported by this extension. You can Ingest Microsoft Entra ID sign-in logs straight into Dynatrace.
Get started
For more information on the installation and configuration, please see Microsoft Active Directory monitoring extension in the Dynatrace Documentation.
Details
Compatibility information
  • Only on-premises Active Directory deployments are supported
  • OneAgent 1.305+ is required (elevated user permissions support is required)
  • Azure AD is not supported
  • This extension has been verified with Windows Server 2016, 2019, 2022
  • Activate this extension locally on your AD hosts. Remote AD monitoring is not supported.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Shared Resource Availableactive-directory.replication.shared.availablePercentage of replication shared resources that are availablePercent
Replication - Destination Deltaactive-directory.replication.destination.deltaReplication time delta between this server and the destination server.Second
Replication - Source Deltaactive-directory.replication.source.deltaReplication time delta between this server and the source server.Second
Replication - Destination Errorsactive-directory.replication.destination.errorsReplication errors between this server and the destination server.Count
Replication - Source Errorsactive-directory.replication.source.errorsReplication errors between this server and the source server.Count
LDAP Bindsactive-directory.ldap.server.ldapbindtime.binds.persecTime spent to complete LDAP bindingsMilliSecond
LDAP Successful Bindsactive-directory.ldap.server.ldapsuccessfulbinds.persecSuccessful binds per secondPerSecond
LDAP Writes per secondactive-directory.ldap.server.ldapwrites.persecThe rate at which LDAP clients perform write operationsPerSecond
LDAP UDP Operations per secondactive-directory.ldap.server.ldapudpoperations.persecThe number of User Datagram Protocol (UDP) operations that the LDAP server is processing per secondPerSecond
LDAP Active threads totalactive-directory.ldap.server.ldapactivethreads.totalThe current number of threads in use by the LDAP subsystem of the local directory serviceCount
LDAP Client Sessionsactive-directory.ldap.server.ldapclientsessions.totalThe number of sessions of connected LDAP clientsCount
LDAP Searches per secondactive-directory.ldap.server.ldapsearches.persecThe number of search operations per second performed by LDAP clientsPerSecond
LDAP Bind Timeactive-directory.ldap.server.bindtime.millisTime taken to bind to the fsmo role holder using LDAPMilliSecond
LDAP Bind Availabilityactive-directory.ldap.bind.availabilityWhether or not the domain controller can bind to the domain DNS serverCount
Good Network Adapter Countactive-directory.network.goodadapter.totalThe number of enabled network adapters that can ping the Domain DNS Server.Count
Bad Network Adapter Countactive-directory.network.badadapter.totalThe number of enabled network adapters that cannot ping the Domain DNS Server.Count
Total Network Adapter Countactive-directory.network.adapter.totalThe total number of enabled network adapters.Count
DHCP Scope Delay v4active-directory.dhcp.server.scope.delayDHCP Scope Delay v4 in millisecondsMilliSecond
DHCP Scope Addresses Free v4active-directory.dhcp.server.scope.addresses.freeNumber of DHCPv4 scope addresses freeCount
DHCP Scope Addresses Used v4active-directory.dhcp.server.scope.addresses.usedNumber of DHCPv4 scope addresses usedCount
DHCP Scope Addresses Reserved v4active-directory.dhcp.server.scope.addresses.reservedNumber of DHCPv4 scope addresses reservedCount
Percent of DHCP Scope Addresses Used v4active-directory.dhcp.server.scope.addresses.used.pctPercent of DHCPv4 scope addresses usedPercent
DHCP Scope Pending Offers v4active-directory.dhcp.server.scope.pending.offersNumber of DHCPv4 scope pending offersCount
DHCP received renews/s v6active-directory.dhcp.server.v6.renews.persecRate of DHCP renews received by the DHCP Server v6PerSecond
DHCP received releases/s v6active-directory.dhcp.server.v6.releases.persecRate of DHCP releases received by the DHCP Server v6PerSecond
DHCP received declines/s v6active-directory.dhcp.server.v6.declines.persecRate of DHCP declines recevied by the DHCP Server v6PerSecond
DHCP received requests/s v6active-directory.dhcp.server.v6.requests.persecRate of DHCP requests received by the DHCP Server v6PerSecond
DHCP received solicits/s v6active-directory.dhcp.server.v6.solicits.persecRate of DHCP solicits received by the DHCP Server v6PerSecond
DHCP received rebinds/s v6active-directory.dhcp.server.v6.rebinds.persecRate of DHCP rebinds received by the DHCP Server v6PerSecond
ESENT Database I/O reads rate (Local Security Authority)active-directory.lsass.esent.database.io.reads.persec.countNumber of ESENT Database I/O reads per second for the Local Security AuthorityPerSecond
ESENT Database I/O read latency (Local Security Authority)active-directory.lsass.esent.database.io.reads.latency.avg.countESENT Database I/O read latency for the Local Security AuthorityMilliSecond
ESENT Database I/O writes rate (Local Security Authority)active-directory.lsass.esent.database.io.writes.persec.countNumber of ESENT Database I/O writes per second for the Local Security AuthorityPerSecond
ESENT Database I/O write latency (Local Security Authority)active-directory.lsass.esent.database.io.writes.latency.avg.countESENT Database I/O write latency for the Local Security AuthorityMilliSecond
ESENT Log I/O reads rate (Local Security Authority)active-directory.lsass.esent.log.io.reads.persec.countNumber of ESENT Database log I/O reads per second for the Local Security AuthorityPerSecond
ESENT Log I/O read latency (Local Security Authority)active-directory.lsass.esent.log.io.reads.latency.avg.countESENT Log I/O read latency for the Local Security AuthorityMilliSecond
ESENT Log I/O writes rate (Local Security Authority)active-directory.lsass.esent.log.io.writes.persec.countNumber of ESENT Database log I/O writes per second for the Local Security AuthorityPerSecond
ESENT Log I/O writes latency (Local Security Authorityy)active-directory.lsass.esent.log.io.writes.latency.avg.countESENT Log I/O writes latency for the Local Security AuthorityMilliSecond
DHCP received requests/sactive-directory.dhcp.server.requests.persecRate of DHCP requests received by the DHCP serverPerSecond
DHCP received releases/sactive-directory.dhcp.server.releases.persecRate of DHCP releases received by the DHCP serverPerSecond
DHCP received declines/sactive-directory.dhcp.server.declines.persecRate of DHCP declines received by the DHCP serverPerSecond
DHCP failover ack messages received/sactive-directory.dhcp.server.failover.bndack.received.persecNumber of DHCP failover Binding Ack messages receivedPerSecond
DHCP failover ack messages sent/sactive-directory.dhcp.server.failover.bndack.sent.persecNumber of DHCP failover Binding Ack messages sentPerSecond
DHCP binding updates droppedactive-directory.dhcp.server.failover.bndupd.droppedNumber of binding updates droppedCount
DHCP failover update pending messagesactive-directory.dhcp.server.failover.bndupd.pendinginoutbound.queueNumber of pending outbound DHCP failover Binding Update messagesCount
DHCP failover update messages received/sactive-directory.dhcp.server.failover.bndupd.received.persecNumber of DHCP failover Binding Update messages receivedPerSecond
DHCP failover update messages sent/sactive-directory.dhcp.server.failover.bndupd.sent.persecNumber of DHCP failover Binding Update messages sentPerSecond
DFS Replication conflict files sizeactive-directory.dfs.server.replicatedfolders.conflictspaceinuse.bytes.totalTotal byte size of DFS replication service of conflict filesByte
DFS Replication deleted files sizeactive-directory.dfs.server.replicatedfolders.deletedspaceinuse.bytes.totalTotal byte size of DFS replication service of the deleted filesByte
DFS Replication staging folder sizeactive-directory.dfs.server.replicatedfolders.stagingspaceinuse.bytes.totalTotal byte size of DFS replication service of staging folderByte
DFS redundant file replication update recordsactive-directory.dfs.server.replicatedfolders.updates.droppedNumber of redundant file replication update recordsCount
DFS retried file installsactive-directory.dfs.server.replicatedfolders.fileinstalls.retriedNumber of retried file installsCount
DNS dynamic update queued requestsactive-directory.dns.server.dynamicupdate.queued.total.countTotal number of dynamic update requests queued by the DNS serverCount
DNS caching memoryactive-directory.dns.server.caching.memory.totalTotal caching memory used by DNS serverByte
DNS database node memoryactive-directory.dns.server.databasenode.memory.totalTotal database node memory used by DNS serverByte
DNS Nbstat memoryactive-directory.dns.server.nbstat.memory.totalTotal Nbstat memory used by DNS serverByte
DNS TCP message memoryactive-directory.dns.server.tcpmessage.memory.totalTotal TCP message memory used by DNS serverByte
DNS dynamic update requestsactive-directory.dns.server.dynamicupdate.received.total.countTotal number of dynamic update requests received by the DNS serverCount
DNS rejected dynamic updatesactive-directory.dns.server.dynamicupdate.rejected.total.countTotal number of dynamic updates rejected by the DNS serverCount
DNS dynamic update timeoutsactive-directory.dns.server.dynamicupdate.timeouts.total.countTotal number of dynamic update timeouts of the DNS serverCount
DNS written dynamic updatesactive-directory.dns.server.dynamicupdate.writtentodatabase.total.countTotal number of dynamic updates written to the database by the DNS serverCount
DNS empty dynamic update requests/sactive-directory.dns.server.dynamicupdate.nooperation.persecAverage number of No-operation/Empty dynamic update requests per secondPerSecond
DNS dynamic update requests/sactive-directory.dns.server.dynamicupdate.received.persecAverage number of dynamic update requests received by the DNS server per secondPerSecond
DNS written dynamic updates/sactive-directory.dns.server.dynamicupdate.writtentodatabase.persecAverage number of dynamic updates written to the database by the DNS server per secondPerSecond
DNS recursive queries/sactive-directory.dns.server.recursive.queries.persecAverage number of recursive queries received by DNS server per secondPerSecond
DNS recursive query failures/sactive-directory.dns.server.recursive.queryfailure.persecAverage number of recursive query failures per secondPerSecond
DNS recursive query timeouts/sactive-directory.dns.server.recursive.timeout.persecAverage number of recursive query sending timeouts per secondPerSecond
DNS secure update requestsactive-directory.dns.server.secureupdate.received.totalTotal number of secure update requests received by the DNS serverCount
DNS failed secure updatesactive-directory.dns.server.secureupdate.failure.totalTotal number of secure updates failed of the DNS serverCount
DNS secure update requests/sactive-directory.dns.server.secureupdate.received.persecAverage number of secure update requests received by the DNS server per secondPerSecond
DNS TCP responses/sactive-directory.dns.server.tcpresponse.sent.persecAverage number of TCP responses sent by DNS server per secondPerSecond
DNS queries received/sactive-directory.dns.server.totalquery.received.persecAverage number of queries received by DNS server per secondPerSecond
DNS responses sent/sactive-directory.dns.server.totalresponse.sent.persecAverage number of responses sent by DNS server per secondPerSecond
DNS UDP queries received/sactive-directory.dns.server.udpquery.received.persecAverage number of UDP queries received by DNS server per secondPerSecond
DNS UDP responses sent/sactive-directory.dns.server.udpresponse.sent.persecAverage number of UDP responses sent by DNS server per secondPerSecond
DNS unmatched response packets receivedactive-directory.dns.server.unmatchedresponses.received.totalTotal number of response packets received by the DNS server that do not match any outstanding remote queryCount
DNS failed zone transfersactive-directory.dns.server.zonetransfer.failure.totalTotal number of failed zone transfers of the master DNS serverCount
DNS successful zone transfersactive-directory.dns.server.zonetransfer.success.totalTotal number of successful zone transfers of the master DNS serverCount
ATQ Outstanding queued requests totalactive-directory.atq.server.atqoutstandingqueuedrequests.totalCurrent number of requests in the queueCount
ATQ Estimated queue delayactive-directory.atq.server.atqestimatedqueuedelay.persecHow long a request has to wait in the queueSecond
ATQ Request latencyactive-directory.atq.server.atqrequestlatency.persecTime it takes to produce a requestSecond
ATQ Threads LDAP totalactive-directory.atq.server.atqthreadsldap.totalThe number of threads used by the LDAP server as determined by LDAP policyCount
ATQ Threads Other totalactive-directory.atq.server.atqthreadsother.totalThe number of threads used by the other servicesCount
ATQ Threads totalactive-directory.atq.server.atqthreadstotal.totalAll Threads currently allocatedCount
ATQ Average Thread Usageactive-directory.atq.server.average.thread.usageAverage usage of threads in Domain Controller ATQPercent
Database adds per secondactive-directory.database.adds.persec.countNumber of Active Directory Database adds per secondPerSecond
Database modifies per secondactive-directory.database.modifies.persec.countNumber of Active Directory Database modifies per secondPerSecond
Database deletes per secondactive-directory.database.deletes.persec.countNumber of Active Directory Database deletes per secondPerSecond
Database recycles per secondactive-directory.database.recycles.persec.countNumber of Active Directory Database recycles per secondPerSecond
DFS received bytes/sactive-directory.dfs.server.replicationconnections.bytesreceived.persecAverage number of received bytes per secondBytePerSecond
DFS bytes received on connectionactive-directory.dfs.server.replicationconnections.bytesreceived.totalTotal number of bytes received on the connectionByte
DFS files received on connectionactive-directory.dfs.server.replicationconnections.filesreceived.totalNumber of files that were received on the connectionCount
Network Login Profile logonsactive-directory.network.login.logons.countNumber of network logons on the network login profileCount
Number of logonsactive-directory.network.logons.total.countNumber of network logonsCount
Logons per secondactive-directory.network.logons.persec.countNumber of network logons per secondPerSecond
Disk Free Spaceactive-directory.database.diskfree.totalFree disk space of the disk containing the database file.Byte
Total Disk Spaceactive-directory.database.disk.totalTotal disk space of the disk containing the AD database file.Byte
Disk Free Space Percentageactive-directory.database.diskfreePercent of free disk space of the disk containing the database file.Percent
DRA Successful synch requests totalactive-directory.dra.server.drasynchrequestssuccessful.total.countNumber of successful DRA synchronization requestsCount
DRA Synch requests totalactive-directory.dra.server.drasynchrequestsmade.total.countNumber of total DRA synchronization requests madeCount
DHCP Scope Addresses Free v6active-directory.dhcp.server.v6.scope.addresses.freeNumber of DHCPv6 scope addresses freeCount
DHCP Scope Addresses Used v6active-directory.dhcp.server.v6.scope.addresses.usedNumber of DHCPv6 scope addresses usedCount
DHCP Scope Addresses Reserved v6active-directory.dhcp.server.v6.scope.addresses.reservedNumber of DHCPv6 scope addresses reservedCount
Percent of DHCP Scope Addresses Used v6active-directory.dhcp.server.v6.scope.addresses.used.pctPercent of DHCPv6 scope addresses usedPercent
DHCP Scope Pending Advertises v6active-directory.dhcp.server.v6.scope.pending.advertisesNumber of DHCPv6 scope pending advertisesCount
NTLM Binds per secondactive-directory.lsass.server.ntlm.binds.persec.countAverage NTLM binds per secondPerSecond
Used processor timeactive-directory.server.host.cpu.time.processorPercent of used processor timePercent
Idle processor timeactive-directory.server.host.cpu.time.idlePercent of idle processor timePercent
User processor timeactive-directory.server.host.cpu.time.userPercent of user processor timePercent
Number of Logical Processorsactive-directory.server.host.cpu.logical.processorsNumber of Logical ProcessorsCount
Service processor timeactive-directory.service.cpu.timePercent of processor time spend on a servicePercent
Kerberos Replication Partner Countactive-directory.replication.partner.count.totalKerberos replication partners count in Active Directory domainCount
Replication Queue Countactive-directory.replication.queue.count.totalCount of items in replication queue by Active Directory Domain Controller monitorCount
Global Catalog Search Response Timeactive-directory.globalcatalog.searchtime.millisGlobal catalog search response time of Domain ControllerMilliSecond
Replication Consistency Statusactive-directory.replication.consistency.statusWhether or not strict replication consistency is enabledCount
Time Skew in secondsactive-directory.timeskew.secsTime difference between the local domain controller and a target domain controllerSecond
Lost and Found Objectsactive-directory.lostandfound.object.count.totalCount of lost and found objects by Active Directory Domain monitorCount
FSMO Role Holder Consistencyactive-directory.fsmoroleholder.consistencyWhether or not the domain controllers agree on who the FSMO role holders areCount
FSMO Checkactive-directory.fsmo.checkContains a 'message' dimension about whether or not the correct services can be found from the domain controllerCount
FSMO Role Schema Masteractive-directory.fsmo.role.schemaEnabled if the host has the Schema Master role, disabled otherwiseCount
FSMO Role Domain Naming Masteractive-directory.fsmo.role.domainnamingEnabled if the host has the Domain Naming Master role, disabled otherwiseCount
FSMO Role RID Masteractive-directory.fsmo.role.ridEnabled if the host has the RID Master role, disabled otherwiseCount
FSMO Role PDC Emulator Masteractive-directory.fsmo.role.pdcEnabled if the host has the PDC Emulator Master role, disabled otherwiseCount
FSMO Role Infrastructure Masteractive-directory.fsmo.role.infrastructureEnabled if the host has the Infrastructure Master role, disabled otherwiseCount
SYSVOL Healthactive-directory.sysvol.healthThe SYSVOL share's healthCount
Full version history
ReleaseDate
⚠️ Important Change
  • Metric key has been changed from active-directory.dns.server.unmatchedresponses.received.count to active-directory.dns.server.unmatchedresponses.received.total. If you created dashboards or alerts that reference this metric key - please update them.
New in this version
  • Added support to credentials management through Credential Vault.
  • Added new FSMO Role metrics.
  • Added Dynatrace Error Codes.
Improved in this version
  • Improved OS Service Monitoring and Log Ingest Rules deactivation process on extension shutdown.
  • Fixed Replication Partner Count, Replication Queue Count, FSMO Check and FSMO Consistency metrics.
  • Implemented security fixes.
  • Removed .NET commands to allow the extension to run even in Constrained Language mode.
  • Improved detection of elevated-privileges user.
  • Resolved a bug with the active-directory.lostandfound.object.count.total metric.
  • Ongoing security updates to the underlying Python libraries
⚠️ Important Change
  • This release requires a Minimum Dynatrace Version version of 1.318.0 or higher.
New in this version
  • Added ALERT_TEMPLATES for anomaly detectors in the Davis Anomaly Detection app (latest Dynatrace only).
  • Added EndpointStatus for Dynatrace API returning error 404.
  • Improved log ingestion and OS services monitoring by allowing more time for the process to finish.
Active Directory extension release notes
5.2.0
Published Fri Nov 28 2025
⚠️BREKAING CHANGE in this release.
Patch level changes
  • Fix for settings objects not being deleted on extension shutdown. NOTE: The API token provided to the extension should not be used for creating any other settings objects otherwise they will also be reomoved when this extension shuts down. If you are not sure about your API token use, better create a new one and update your monitorin gconfiguations.
  • Changed the DRA metrics type to COUNT metrics, so they show the change over time instead of an accumulating value. NOTE: this ia a breaking change. DRA metrics series lose continuity at upgrade. Make sure to update your monitoring configurations as well.
Past release notes
5.1.1
Published Tue Oct 28 2025
New features
  • Added support for running the extension with a different privileged user than LOCAL_SYSTEM. See hub tile text for details how to use this option.
Patch level changes
  • Removed the requirement to grant the entities.read permission to the access token.
  • Fixed an issue causing non UTF-8 characters to be returned from WMI queries.
5.0.21
Published Fri Oct 03 2025
New features
  • Added additional event IDs for DNS, DHCP and Directory Service
Patch level changes
  • Fixed an issue with extension instability on some systems where extension assets path character length sometimes exceeded maximum Windows OS limit of 260 characters. Affected behaviors included inability to start, inability to update extension configuration, inability to upgrade the extension, potentially also other unexpected effects.
5.0.19
Published Tue Sep 23 2025
Patch level changes
  • Fix to the Unified Analysis screens on Dynatrace Gen2 (Managed), where some chart sections disappeared after last upgrade
5.0.18
Published Tue Sep 02 2025
Patch level changes
  • Minor updates to the Unified Analysis screens for Dynatrace Platform
  • Remove from distribution the Python libraries that are not used by the extension
5.0.16
Published Fri Aug 15 2025
⚠️IMPORTANT CHANGE: This extension release requires Dynatrace cluster version 1.313 or later.
New features
  • The dt.security_context attribute is now propagated to all entities created by the extension. When enabling entity access control based on dt.security_context ensure you set the Grail security context destination property to dt.security_context
  • Enabled the extension to present the Dynatrace Platform (a.k.a. Gen3) entity details screens in the future platform apps that will expect these screens
5.0.14
Published Mon Jul 28 2025
Patch level changes
  • Addressed an issue with incorrectly handled rollups of some metric. Metric name changes were required to get rid of ".count" suffix. Affected metrics:
    • active-directory.replication.partner.count has been renamed to active-directory.replication.partner.count.total
    • active-directory.replication.queue.count has been renamed to active-directory.replication.queue.count.total
5.0.13
Published Fri Jul 11 2025
Patch level changes
  • Fixed bugs preventing ATQ, DRA, Network and NTLM metrics collection under certain conditions.
  • Fixed the query collecting the active-directory.service.cpu.time metric.
  • Fixed a bug preventing tasks from being submitted under a local service account.
5.0.7
Published Thu Jun 12 2025
⚠️IMPORTANT CHANGE: This extension release requires Dynatrace cluster version 1.310 or later.
New features
  • Added the Dynatrace Platform (a.k.a. Gen3) dashboard
5.0.5
Published Tue May 27 2025
Dynatrace Hub
All (877)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
