Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Luna Network HSM DeviceLuna Network HSM Device
Monitor your Luna Network Hardware Security Module (HSM) Devices through SNMP.
Extension
Free trialDocumentation
  • Product information
  • Release notes
Overview
This extension collects infrastructure metrics to monitor the health and performance of your Luna HSM devices. Metrics are collected via SNMP protocol.
Use cases
  • Monitor important device metrics such as uptime, busy time, performance and login attempts
  • Monitor SafeNet Chrysalis metrics including number of events and operations, clients connected, and NTLS status
  • Monitor partition storage info and object count
  • Collect data for licenses, policies, partition policies, client registration, and client partitions
Get started
For more information on the installation and configuration, please see Luna Network HSM Device extension in the Dynatrace Documentation.
Details
Compatibility information
  • SNMP v2c or SNMP v3
  • Dynatrace version 1.310+
  • ActiveGate version 1.301+
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Luna HSM Operation requestshsm.luna.operation.requestsIndicates the total number of HSM operations requestedCount
Luna HSM Operation errorshsm.luna.operation.errorsThe total number of HSM operations requested which have resulted in errorsCount
Luna HSM Critical eventshsm.luna.events.criticalThe total number of critical HSM events detectedCount
Luna HSM Non-critical eventshsm.luna.events.noncriticalThe total number of non-critical HSM events detectedCount
Luna HSM NTLS Statushsm.luna.ntls.oper_statusThe current operational state of the NTLSCount
Luna HSM NTLS connected clientshsm.luna.ntls.connected_clientsThe current number of connected clients of the NTLSCount
Luna HSM NTLS linkshsm.luna.ntls.linksThe current number of links of the NTLSCount
Luna HSM NTLS successful client connectionshsm.luna.ntls.client_connections.successfulThe total number of successful client connections of the NTLSCount
Luna HSM NTLS failed client connectionshsm.luna.ntls.client_connections.failedThe total number of unsuccessful client connections of the NTLSCount
Luna HSM partition storage capacityhsm.luna.partition.storage.total_bytesStorage capacity in bytes of the partitionByte
Luna HSM partition allocated byteshsm.luna.partition.storage.allocated_bytesNumber of allocated (in use) bytes on the partitionByte
Luna HSM partition available byteshsm.luna.partition.storage.available_bytesNumber of available (unused) bytes on the partitionByte
Luna HSM partition object counthsm.luna.partition.object_count.gaugeNumber of objects in the partitionCount
Luna HSM Client Registrationhsm.luna.clientPlaceholder metric for HSM Client Registration info dimensions (only dimension data is relevant)Unspecified
Luna HSM Policyhsm.luna.policyPlaceholder metric for HSM policy info dimensions (only dimension data is relevant)Unspecified
Luna HSM Licensehsm.luna.licensePlaceholder metric for license info dimensions (only dimension data is relevant)Count
Luna HSM Client Assignmenthsm.luna.clientpartition.assignmentPlaceholder metric for client assignment dimensions (only dimension data is relevant)Unspecified
Luna HSM Uptimehsm.luna.table.uptimeThe number of seconds the HSM has been up since the last HSM resetSecond
-com.dynatrace.extension.network_device.sysuptime--
Luna HSM Busy timehsm.luna.table.busytimeThe number of seconds the HSM has been busy since the last HSM resetSecond
Luna HSM Command Counthsm.luna.table.command_countThe number of HSM commands processed since the last HSM resetCount
Luna HSM Admin login attempts remaininghsm.luna.table.admin_login_attemptsThe number of failed Administrator login attempts remaining before HSM is zeroized.Count
Luna HSM Performancehsm.luna.table.performanceThe performance level of the HSMCount
Luna HSM Partitions freehsm.luna.table.partitions.freeThe number of partitions that can still be created on the HSMCount
Luna HSM Partitions createdhsm.luna.table.partitions.createdThe number of partitions created on the HSMCount
Luna HSM Partitions maximumhsm.luna.table.partitions.maximumThe maximum number of partitions allowed on the HSMCount
Luna HSM Storage availablehsm.luna.table.storage.available_bytesThe number of available bytes on the HSMByte
Luna HSM Storage allocatedhsm.luna.table.storage.allocated_bytesThe number of allocated bytes on the HSMByte
Luna HSM Storage capacityhsm.luna.table.storage.total_bytesThe total storage capacity in bytes of the HSMByte
Luna HSM Partition Policyhsm.luna.partition.policyPlaceholder metric for partition policy dimensions (only dimension data is relevant)Unspecified
Full version history
ReleaseDate
✨ New in this version:
  • Update entity links on gen 3 dashboard to link to I&O app
  • Ensure required dimensions exist for entity creation
🪲 Fixed in this version:
  • Metric hsm.luna.partition.object_count.gauge now uses the correct gauge type
  • Fixed incorrect unit set on partition metrics which caused loading issues for the "Partitions" section of the device UA screen
✨ New in this version (1.0.5):
  • Added keyword key-value pairs to the extension.
  • Set Luna device as source entity for all metrics.
Bugfixes
  • Fixed issue with safenet-chrysalis-utsp metrics being captured incorrectly as table OIDs instead of scalar
  • New Platform/Gen3 dashboard bundled with extension
  • Added DQL support for Platform/Gen3 screens
  • Enriched entities with dt.security_context attribute
  • Decreased supported ActiveGate version to 1.301+
Initial Hub release:
  • Device metric collection
  • Overview dashboard
  • Custom topology
Dynatrace Hub
All (876)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
