Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Learn DQLLearn DQL
Learn DQL
Learn DQL
Learn the Dynatrace Query Language (DQL) with hands-on interactive tutorials
App
Try in PlaygroundDocumentation
Learn DQL landing page.Beginner's exercise: IntroductionJSON audit logs exercise: IntroductionRevealed solution: When you're stuck with an exerciseSolved exercise step: Well done!Syntax error: Try again
  • Product information
  • Release notes
Overview
Learn DQL is a Dynatrace Query Language (DQL) learning environment that guides you step by step through a set of exercises. The exercises are suitable for beginners and advanced users alike. Each step presents a specific DQL command or function with a short video or documentation link that guides you through the challenge.
At the end of each step, there is a checkpoint where the app validates the query before advancing to the next step. Because there are usually multiple ways to create a query to achieve the desired result, the Learn DQL app compares the result of the presented query with the result of a reference query. If the results match, you can proceed to the next step. If no progress is made after several attempts, the app gives you hints and, as a last option, shares the whole query with you.
Get started
There are currently two exercises available:
Beginner’s exercise
Prerequisites: You don’t need any knowledge about DQL to run this exercise.
This tutorial teaches the basics of DQL, including the most important commands and functions.
The goal of the exercise: Work on a set of ingested log records, extract information from a log line, and aggregate the extracted data for a time-based visualization.
JSON audit logs
Prerequisites: Completion of the Beginner's exercise.
In this example, users have made changes that are tracked with audit logs. The goal is to identify the types and number of actions users performed.
Goal of the exercise: You'll learn how to parse JSON data and aggregate the records based on information within the JSON structure.
Details
  • Self-service hands-on resource
  • Step-by-step approach
  • Exercises are component-based
  • Additional exercises can be added in the future
DQL Dynatrace Community Forum
DQL Examples
DQL Best Practices
DQL Language Reference
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
  • Package updates
  • Package updates
  • Package updates
  • Make datatable rows interactive
  • Add copy functionality to table cells
  • Fix rows highlighting
  • Update packages
  • Added new Menu Header component
  • Updated tables to DataTableV2 component and added options for resizing and sorting
  • Package updates
  • package updates
  • Improve "A bit of background information" section
  • Fix: "Insufficient permission to access the tenant" for restricted users
  • Add success/failure state for sdlc events
  • minimal updates and improvements
  • New icon
  • Fix DQL validation when comments are present
  • Update security
  • fixed cancelation of run dql query button
Dynatrace Hub
All (884)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
