Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Kubernetes ConnectorKubernetes Connector
Automate your Kubernetes clusters: Delete failed pods and restart deployments
App
Free trialDocumentation
Resolve anomalies with Kubernetes workflow actions such as "delete pods in a failed state". Apply configs, get logs, restart deployments.
  • Product information
  • Release notes
Overview
Automate your Kubernetes clusters with Dynatrace workflows to delete unresponsive pods, restart deployments, describe pods, or apply configurations as you would with kubectl.
Use cases
Kubernetes Connector allows you to remediate anomalies automatically:
  • Kill a pod that's stuck in a termination phase.
  • If workload Kyverno is present in a cluster, but all pods are in a failed state, delete the webhook configuration.
  • Kill pod and trigger redeployment when liveness and readiness probes have not been implemented appropriately
Get started
Follow the instructions detailed in Dynatrace documentation.
Install Kubernetes Connector. Follow the operator-based deployment scenario instructions, which automatically configure Edgeconnect to tunnel traffic securely to your cluster and set up the required connection parameters.
Details
Kubernetes Connector enables you to automate your K8s clusters based on Dynatrace insights.
Define various incident triggers:
  • Use the power of DQL and leverage events to react to situations like a pod stuck in a termination phase.
  • Use Biz-Events as a trigger to react on extended events like a deployment event, failed release validation with Site Reliability Guardian, specific log messages, or external system events.
  • Define a scheduler for periodic tasks.
Kubernetes Connector allows you to:
  • Apply configurations as you would using a kubectl command
  • Get logs based on namespace, pod, or container
  • List resources
  • Get resource details
  • Patch resource
  • Delete resources
  • Restart a deployment
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
  • New workflow templates – This update introduces workflow templates that help you automate common Kubernetes tasks, such as auto-annotating pods with the associated Dynatrace problem ID, adding monitoring labels, removing pods stuck in termination, and forwarding pod logs to Microsoft Teams.
  • Various improvements and dependency updates.
  • Bugfix for Wait Action - Resolved an issue where the Select Menu for choosing a Kubernetes resource was not displaying options correctly.
  • Rollout Restart Resource Action – Introduced a new action that allows users to restart a Kubernetes resource using the native rollout restart mechanism. This provides a more Kubernetes-aligned and flexible way to restart various resource types.
  • (Deprecated) Restart Deployment Action – The previous "Restart Deployment" action is now marked as deprecated. It is fully replaced by the new "Rollout Restart Resource" action, which covers the same functionality and more. Users are encouraged to migrate to the new action for future compatibility.
  • Patch Strategy Selection – The Patch Resource action now supports selecting a patch strategy (e.g., merge, strategic, or json), offering greater control when modifying resources.
  • Bugfix for Connection Settings Form - Resolved an issue where the connection settings form remained open after editing a connection.
  • The First Stable Release - The first stable version of the App is now publicly available, offering robust and reliable functionalities.
  • App Renamed to Kubernetes Connector - The App has been renamed from "Kubernetes Automation" to "Kubernetes Connector" to align with the Connectors concept.
  • Access Control for Connectors Management - Added fine-grained access control for connections, enabling only specific users to have access to connection settings.
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
