Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Infoblox DDIInfoblox DDI
Infoblox DDI
Infoblox DDI
Monitor Infoblox DDI using SNMP
Extension
Free trialDocumentation
Overview dashboardInfoblox Unified Analysis screen
  • Product information
  • Release notes
Overview
The Infoblox DDI SNMP Extension is a powerful tool designed to enhance network management capabilities by integrating Infoblox DDI with Dynatrace via SNMP monitoring. This extension allows network administrators to monitor and manage their Infoblox DDI infrastructure using standard SNMP protocols, providing a seamless and efficient way to ensure network reliability and performance. Dynatrace's Unified Analysis screens provide at-a-glance access and analysis for your Ops, DevOps and IT Admins.
Use cases
  • Improved Network Visibility: Gain deeper insights into network performance and health.
  • Enhanced Efficiency: Streamline network management tasks with automated monitoring and alerts.
  • Proactive Management: Identify and resolve issues before they impact network operations.
  • Reduced Downtime: Minimize network downtime with timely alerts and proactive measures.
Get started
For more information on the installation and configuration, please see Infoblox DDI extension in the Dynatrace Documentation.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Average non-authoritative latencysnmp.infoblox.dns.ibNetworkMonitorDNSNonAAT5AvgLatencyAverage latency for incoming DNS queries during the last 5 minutes where the reply was non authoritativeMicrosecond
Non-authoritative query countsnmp.infoblox.dns.ibNetworkMonitorDNSNonAAT5CountNumber of queries used to calculate the average latencies during the last 5 minutes where the reply was non-authoritativeCount
Average authoritative latencysnmp.infoblox.dns.ibNetworkMonitorDNSAAT5AvgLatencyAverage latency for incoming DNS queries during the last 5 minutes where the reply was authoritativeMicrosecond
Authoritative query countsnmp.infoblox.dns.ibNetworkMonitorDNSAAT5CountNumber of queries used to calculate the average latencies during the last 5 minutes where the reply was authoritativeCount
Access count queriessnmp.infoblox.dhcp.ibDHCPSubnetPercentUsedPercentage of dynamic DHCP address for subnet leased out at this time. Fixed addresses are always counted as leased for this calculation if the fixed addresses are within ranges of leases.Count
Service statussnmp.infoblox.ddi.service.statusPlaceholder metric will also report a value of 1. Dimensions (Name, Status, Desc) contain dataUnspecified
Node Service statussnmp.infoblox.ddi.node.service.statusPlaceholder metric will also report a value of 1. Dimensions (Name, Status, Desc) contain dataUnspecified
Average non-authoritative latencysnmp.infoblox.dns.ibNetworkMonitorDNSNonAAT1AvgLatencyAverage latency for incoming DNS queries during the last minute where the reply was non authoritativeMicrosecond
Non-authoritative query countsnmp.infoblox.dns.ibNetworkMonitorDNSNonAAT1CountNumber of queries used to calculate the average latencies during the last minute where the reply was non-authoritativeCount
Average authoritative latencysnmp.infoblox.dns.ibNetworkMonitorDNSAAT1AvgLatencyAverage latency for incoming DNS queries during the last minute where the reply was authoritativeMicrosecond
Authoritative query countsnmp.infoblox.dns.ibNetworkMonitorDNSAAT1CountNumber of queries used to calculate the average latencies during the last minute where the reply was authoritativeCount
Failed queriessnmp.infoblox.dns.ibBindZonePlusViewFailure.countNumber of Failed queries since DNS process started.Count
DNS Query Ratesnmp.infoblox.dns.ibDnsQueryRateDNS Queries per secondPerSecond
DNS Hit Ratiosnmp.infoblox.dns.ibDnsHitRatioDNS cache hit ratioPercent
Allocation Unitssnmp.infoblox.storage.AllocationUnitsThe size, in bytes, of the data objects allocated from this pool. If this entry is monitoring sectors, blocks, buffers, or packets, for example, this number will commonly be greater than one. Otherwise this number will typically be one.Byte
Raw Storage Sizesnmp.infoblox.storage.SizeThe size of the storage represented by this entry, in units of hrStorageAllocationUnits.Count
Raw Storage Usedsnmp.infoblox.storage.UsedThe amount of the storage represented by this entry that is allocated, in units of hrStorageAllocationUnits.Count
-com.dynatrace.extension.network_device.memory_used--
CPU Usagesnmp.infoblox.ddi.cpu.usageInfoblox DDI CPU Usage (ibSystemMonitorCpuUsage)Count
-com.dynatrace.extension.network_device.cpu_usage--
-com.dynatrace.extension.network_device.sysuptime--
Swap Usagesnmp.infoblox.ddi.swap.usageInfoblox DDI Swap Usage (ibSystemMonitorSwapUsage)MegaByte
Full version history
ReleaseDate
v2.3.0
Minimum Dynatrace Cluster version 1.318
āš ļø Note: This version moves existing DNS network latency metrics to a new feature set called, DNS Latency (5 min averages). To continue monitoring with these metrics, this new feature set must be enabled. After upgrading the extension, edit monitoring configurations and enable DNS Latency (5 min averages) or the new DNS Latency (1 min averages) feature set to continue DNS latency monitoring.
What's new
  • New DNS network latency metrics (1 minute average) feature set, DNS Latency (1 min average). These 1-minute average metrics are now the recommended DNS latency metrics. Customers can select one or both feature sets for DNS latency monitoring.
    • snmp.infoblox.dns.ibNetworkMonitorDNSAAT5AvgLatency
    • snmp.infoblox.dns.ibNetworkMonitorDNSAAT5Count
    • snmp.infoblox.dns.ibNetworkMonitorDNSNonAAT5AvgLatency
    • snmp.infoblox.dns.ibNetworkMonitorDNSNonAAT5Count
  • Existing DNS latency metrics with a 5-minute average are moved to a new feature set, "DNS Latency (5 min average)".
v2.2.7
This version requires a minimum Dynatrace Cluster version of 1.318
New in this version
  • Added 3 new metrics and UA charts:
    • snmp.infoblox.ddi.swap.usage
    • snmp.infoblox.dns.ibDnsQueryRate
    • snmp.infoblox.dns.ibDnsHitRatio
Improved in this verison
  • Improved consistency with instance names
Fixes
  • Fixes topology for Node Services. This version correctly identifies Node Services by Service Name.
Minimum Dynatrace version: 1.313.0
v2.2.0
Minimum Dynatrace Cluster version 1.313
  • Improved Network device name
  • Uptime on unified analysis unit changed to days
  • Add Storage metric Feature Set
  • Fix for Unified Analysis Actions
  • Various improvements to Unified Analysis screens
Fixes to platform dashboard tiles
v2.1.1
āš ļø This version of the extension requires a minimum Dynatrace Cluster version 1.313
✨ What's new:
  • Add Platform dashboard
  • Add dt.security_context to entities
  • Add Platform UA definitions
Initial Hub release
Dynatrace Hub
All (876)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
