Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Google Compute Engine (integration)Google Compute Engine (integration)
Gather Google Compute Engine metrics collected from the Google Operations API
Extension
Free trial
  • Product information
  • Release notes
Overview
This Dynatrace extension leverages data collected from the Google Operations API to constantly monitor health and performance of Google Compute Engine services. This extension combines all relevant data into pre-configured dashboards and provides alerting and event tracking.
This is intended for users, who want to:
  • enrich their monitoring data with metrics and logs from Google Operations API
This enables you to:
  • View and analyze 345 metrics that are specific to Google Compute Engine, like Dropped bytes, Dropped packets, Runnable task count, and more.
  • Build custom dashboards for your cloud infrastructure.
  • Analyze Google Compute Engine logs.
  • Use preconfigured alerting.
  • Set custom alerts that trigger remediation workflows.
Google Compute Engine metric and log ingestion requires advanced GCP integration.
Compatibility requirements
  • Dynatrace GCP integration version 1.0.0+. To enable metric and log ingestion, see Dynatrace Documentation.
  • Dynatrace version 1.256+
Details
Details
This extension package contains:
  • Configuration for Google Compute Engine metric ingest based on your selected feature set (see full list of feature sets and metrics)
  • Topology mapping and service instance analysis view
  • Google Compute Engine predefined alerts for: Google VM Instance CPU utilization [GCP]
To provide correlation and causation analysis all ingested metrics and logs are analyzed by the Dynatrace Davis AI engine, which consumes DDUs.
Get started
To add this extension to your environment:
  • Follow the instructions detailed in Dynatrace Documentation. (Ignore the “Add to environment” button below.)
  • Ensure that you have GCP integration running in your environment and that Google Compute Engine service is configured.
Following GCP integration and Google Compute Engine configuration:
  • The first data points will be ingested by Dynatrace Davis within ~5 minutes.
  • Explore Google Compute Engine metrics in Data Explorer and create custom charts.
  • Activate predefined alerting or set custom events for alerting.
Dynatrace
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Dropped bytescloud.gcp.compute_googleapis_com.firewall.dropped_bytes_count-Byte
Dropped packetscloud.gcp.compute_googleapis_com.firewall.dropped_packets_count-Count
Runnable task count.cloud.gcp.compute_googleapis_com.guest.cpu.runnable_task_count.gauge-Count
CPU usagecloud.gcp.compute_googleapis_com.guest.cpu.usage_time.count-Second
Disk usage in Bytescloud.gcp.compute_googleapis_com.guest.disk.bytes_used-Byte
IO Timecloud.gcp.compute_googleapis_com.guest.disk.io_time.count-MilliSecond
Merged disk operationscloud.gcp.compute_googleapis_com.guest.disk.merged_operation_count-Count
Disk bytes transferredcloud.gcp.compute_googleapis_com.guest.disk.operation_bytes_count-Byte
Disk operationscloud.gcp.compute_googleapis_com.guest.disk.operation_count-Count
Disk operation timecloud.gcp.compute_googleapis_com.guest.disk.operation_time.count-MilliSecond
Queue Lengthcloud.gcp.compute_googleapis_com.guest.disk.queue_length-Count
IO Timecloud.gcp.compute_googleapis_com.guest.disk.weighted_io_time.count-MilliSecond
Anonymous memory usage in Bytescloud.gcp.compute_googleapis_com.guest.memory.anonymous_used-Byte
Memory usage in Bytescloud.gcp.compute_googleapis_com.guest.memory.bytes_used-Byte
Dirty pages usage in Bytes.cloud.gcp.compute_googleapis_com.guest.memory.dirty_used-Byte
Page cache memory usage in Bytescloud.gcp.compute_googleapis_com.guest.memory.page_cache_used-Byte
Unevictable memory usage in Bytescloud.gcp.compute_googleapis_com.guest.memory.unevictable_used-Byte
Problem Countcloud.gcp.compute_googleapis_com.guest.system.problem_count-Count
Problem Statecloud.gcp.compute_googleapis_com.guest.system.problem_state-Count
Uptimecloud.gcp.compute_googleapis_com.guest.system.uptime-Second
Reserved vCPUscloud.gcp.compute_googleapis_com.instance.cpu.reserved_cores-Count
Scheduler Wait Timecloud.gcp.compute_googleapis_com.instance.cpu.scheduler_wait_time.count-Second
CPU usagecloud.gcp.compute_googleapis_com.instance.cpu.usage_time.count-Second
CPU utilizationcloud.gcp.compute_googleapis_com.instance.cpu.utilization-Percent
Peak disk read bytescloud.gcp.compute_googleapis_com.instance.disk.max_read_bytes_count.gauge-Byte
Peak disk read opscloud.gcp.compute_googleapis_com.instance.disk.max_read_ops_count.gauge-Count
Peak disk write bytescloud.gcp.compute_googleapis_com.instance.disk.max_write_bytes_count.gauge-Byte
Peak disk write opscloud.gcp.compute_googleapis_com.instance.disk.max_write_ops_count.gauge-Count
Disk read bytescloud.gcp.compute_googleapis_com.instance.disk.read_bytes_count-Byte
Disk read operationscloud.gcp.compute_googleapis_com.instance.disk.read_ops_count-Count
Disk write bytescloud.gcp.compute_googleapis_com.instance.disk.write_bytes_count-Byte
Disk write operationscloud.gcp.compute_googleapis_com.instance.disk.write_ops_count-Count
Early Boot Validationcloud.gcp.compute_googleapis_com.instance.integrity.early_boot_validation_status-Count
Late Boot Validationcloud.gcp.compute_googleapis_com.instance.integrity.late_boot_validation_status-Count
VM Memory Totalcloud.gcp.compute_googleapis_com.instance.memory.balloon.ram_size-Byte
VM Memory Usedcloud.gcp.compute_googleapis_com.instance.memory.balloon.ram_used-Byte
VM Swap Incloud.gcp.compute_googleapis_com.instance.memory.balloon.swap_in_bytes_count-Byte
VM Swap Outcloud.gcp.compute_googleapis_com.instance.memory.balloon.swap_out_bytes_count-Byte
Received bytescloud.gcp.compute_googleapis_com.instance.network.received_bytes_count-Byte
Received packetscloud.gcp.compute_googleapis_com.instance.network.received_packets_count-Count
Sent bytescloud.gcp.compute_googleapis_com.instance.network.sent_bytes_count-Byte
Sent packetscloud.gcp.compute_googleapis_com.instance.network.sent_packets_count-Count
Uptimecloud.gcp.compute_googleapis_com.instance.uptime.count-Second
Uptime Totalcloud.gcp.compute_googleapis_com.instance.uptime_total-Second
Dropped packetscloud.gcp.compute_googleapis_com.mirroring.dropped_packets_count-Count
Mirrored bytescloud.gcp.compute_googleapis_com.mirroring.mirrored_bytes_count-Byte
Mirrored packetscloud.gcp.compute_googleapis_com.mirroring.mirrored_packets_count-Count
Allocated portscloud.gcp.compute_googleapis_com.nat.allocated_ports-Unspecified
Closed connections countcloud.gcp.compute_googleapis_com.nat.closed_connections_count-Unspecified
Received packets dropped countcloud.gcp.compute_googleapis_com.nat.dropped_received_packets_count-Unspecified
Sent packets dropped countcloud.gcp.compute_googleapis_com.nat.dropped_sent_packets_count-Unspecified
New connections countcloud.gcp.compute_googleapis_com.nat.new_connections_count-Unspecified
Open connectionscloud.gcp.compute_googleapis_com.nat.open_connections-Unspecified
Port usagecloud.gcp.compute_googleapis_com.nat.port_usage-Unspecified
Received bytes countcloud.gcp.compute_googleapis_com.nat.received_bytes_count-Byte
Received packets countcloud.gcp.compute_googleapis_com.nat.received_packets_count-Unspecified
Sent bytes countcloud.gcp.compute_googleapis_com.nat.sent_bytes_count-Byte
Sent packets countcloud.gcp.compute_googleapis_com.nat.sent_packets_count-Unspecified
Egress bytescloud.gcp.networking_googleapis_com.vm_flow.egress_bytes_count-Byte
Ingress bytescloud.gcp.networking_googleapis_com.vm_flow.ingress_bytes_count-Byte
RTT latenciescloud.gcp.networking_googleapis_com.vm_flow.rtt-MilliSecond
Instance group sizecloud.gcp.compute_googleapis_com.instance_group.size-Count
Serving capacitycloud.gcp.autoscaler_googleapis_com.capacity-Count
Current Autoscaler utilizationcloud.gcp.autoscaler_googleapis_com.current_utilization-Count
Container CPU utilizationcloud.gcp.tpu_googleapis_com.container.cpu.utilization-Percent
Container memory usagecloud.gcp.tpu_googleapis_com.container.memory.usage-Byte
CPU utilizationcloud.gcp.tpu_googleapis_com.cpu.utilization-Percent
Memory usagecloud.gcp.tpu_googleapis_com.memory.usage-Byte
Network bytes receivedcloud.gcp.tpu_googleapis_com.network.received_bytes_count-Byte
Network bytes sentcloud.gcp.tpu_googleapis_com.network.sent_bytes_count-Byte
MXU utilizationcloud.gcp.tpu_googleapis_com.tpu.mxu.utilization-Percent
Client Connection Close Countcloud.gcp.istio_io.service.client.gce_instance.connection_close_count-Byte
Client Connection Open Countcloud.gcp.istio_io.service.client.gce_instance.connection_open_count-Byte
Client Received Bytes Countcloud.gcp.istio_io.service.client.gce_instance.received_bytes_count-Byte
Client Request Bytescloud.gcp.istio_io.service.client.gce_instance.request_bytes-Byte
Client Request Countcloud.gcp.istio_io.service.client.gce_instance.request_count-Count
Client Response Bytescloud.gcp.istio_io.service.client.gce_instance.response_bytes-Byte
Client Roundtrip Latenciescloud.gcp.istio_io.service.client.gce_instance.roundtrip_latencies-MilliSecond
Client Sent Bytes Countcloud.gcp.istio_io.service.client.gce_instance.sent_bytes_count-Byte
Server Connection Close Countcloud.gcp.istio_io.service.server.gce_instance.connection_close_count-Byte
Server Connection Open Countcloud.gcp.istio_io.service.server.gce_instance.connection_open_count-Byte
Server Received Bytes Countcloud.gcp.istio_io.service.server.gce_instance.received_bytes_count-Byte
Server Request Bytescloud.gcp.istio_io.service.server.gce_instance.request_bytes-Byte
Server Request Countcloud.gcp.istio_io.service.server.gce_instance.request_count-Count
Server Response Bytescloud.gcp.istio_io.service.server.gce_instance.response_bytes-Byte
Server Response Latenciescloud.gcp.istio_io.service.server.gce_instance.response_latencies-MilliSecond
Server Sent Bytes Countcloud.gcp.istio_io.service.server.gce_instance.sent_bytes_count-Byte
VM Firewall Hit Countscloud.gcp.firewallinsights_googleapis_com.vm.firewall_hit_count-Count
VM Firewall Last Used Timestampcloud.gcp.firewallinsights_googleapis_com.vm.firewall_last_used_timestamp-Count
Monitoring Agent API Request Countcloud.gcp.agent_googleapis_com.agent.gce_instance.api_request_count-Count
Logging Agent Log Entry Countcloud.gcp.agent_googleapis_com.agent.gce_instance.log_entry_count-Count
Logging Agent Retried Log Entry Writes Countcloud.gcp.agent_googleapis_com.agent.gce_instance.log_entry_retry_count-Count
Monitoring Agent Memory Usagecloud.gcp.agent_googleapis_com.agent.gce_instance.memory_usage-Byte
Monitoring Agent Metric Point Countcloud.gcp.agent_googleapis_com.agent.gce_instance.monitoring.point_count-Count
Logging Agent API Request Countcloud.gcp.agent_googleapis_com.agent.gce_instance.request_count-Count
Monitoring Agent Process Labels Sizecloud.gcp.agent_googleapis_com.agent.gce_instance.streamspace_size-Byte
Monitoring Agent is Throttling Processescloud.gcp.agent_googleapis_com.agent.gce_instance.streamspace_size_throttling-Count
Monitoring/Logging Agent Uptimecloud.gcp.agent_googleapis_com.agent.gce_instance.uptime.count-Second
Open connectionscloud.gcp.agent_googleapis_com.apache.connections-Count
Idle workerscloud.gcp.agent_googleapis_com.apache.idle_workers-Count
Requestscloud.gcp.agent_googleapis_com.apache.request_count-Count
Scoreboardcloud.gcp.agent_googleapis_com.apache.scoreboard-Count
Trafficcloud.gcp.agent_googleapis_com.apache.traffic.count-Byte
Hit countcloud.gcp.agent_googleapis_com.cassandra.cache.hits.count-Count
Read latencycloud.gcp.agent_googleapis_com.cassandra.client_request.latency.50p-MicroSecond
Read latencycloud.gcp.agent_googleapis_com.cassandra.client_request.latency.95p-MicroSecond
Read latencycloud.gcp.agent_googleapis_com.cassandra.client_request.latency.99p-MicroSecond
Read latencycloud.gcp.agent_googleapis_com.cassandra.client_request.latency.max-MicroSecond
Compression ratiocloud.gcp.agent_googleapis_com.cassandra.column_family.compression_ratio-Count
Max row sizecloud.gcp.agent_googleapis_com.cassandra.column_family.max_row_size-Byte
Commit log sizecloud.gcp.agent_googleapis_com.cassandra.commitlog_total_size-Byte
Completed taskscloud.gcp.agent_googleapis_com.cassandra.completed_tasks.count-Count
Taskscloud.gcp.agent_googleapis_com.cassandra.current_tasks-Count
Dropped messagescloud.gcp.agent_googleapis_com.cassandra.dropped_message.dropped_count-Count
Exceptionscloud.gcp.agent_googleapis_com.cassandra.storage_service_exception_count-Count
Storage loadcloud.gcp.agent_googleapis_com.cassandra.storage_service_load-Byte
Request latencycloud.gcp.agent_googleapis_com.couchdb.average_request_time-MilliSecond
Bulk requestscloud.gcp.agent_googleapis_com.couchdb.httpd.bulk_request_count-Count
Requestscloud.gcp.agent_googleapis_com.couchdb.httpd.request_count-Count
Request methodscloud.gcp.agent_googleapis_com.couchdb.httpd.request_method_count-Count
Response codescloud.gcp.agent_googleapis_com.couchdb.httpd.response_code_count-Count
Temp view readscloud.gcp.agent_googleapis_com.couchdb.httpd.temporary_view_read_count-Count
View readscloud.gcp.agent_googleapis_com.couchdb.httpd.view_read_count-Count
Open databasescloud.gcp.agent_googleapis_com.couchdb.open_databases-Count
Open filescloud.gcp.agent_googleapis_com.couchdb.open_files-Count
Readscloud.gcp.agent_googleapis_com.couchdb.read_count-Count
Writescloud.gcp.agent_googleapis_com.couchdb.write_count-Count
CPU load (15m)cloud.gcp.agent_googleapis_com.cpu.load_15m-Count
CPU load (1m)cloud.gcp.agent_googleapis_com.cpu.load_1m-Count
CPU load (5m)cloud.gcp.agent_googleapis_com.cpu.load_5m-Count
CPU usagecloud.gcp.agent_googleapis_com.cpu.usage_time.count-Second
CPU utilizationcloud.gcp.agent_googleapis_com.cpu.utilization-Percent
Disk usagecloud.gcp.agent_googleapis_com.disk.bytes_used-Byte
Disk I/O timecloud.gcp.agent_googleapis_com.disk.io_time.count-MilliSecond
Disk merged operationscloud.gcp.agent_googleapis_com.disk.merged_operations.count-Count
Disk operationscloud.gcp.agent_googleapis_com.disk.operation_count-Count
Disk operation timecloud.gcp.agent_googleapis_com.disk.operation_time.count-MilliSecond
Disk pending operationscloud.gcp.agent_googleapis_com.disk.pending_operations-Count
Disk utilizationcloud.gcp.agent_googleapis_com.disk.percent_used-Percent
Disk bytes readcloud.gcp.agent_googleapis_com.disk.read_bytes_count-Byte
Disk weighted I/O timecloud.gcp.agent_googleapis_com.disk.weighted_io_time.count-MilliSecond
Disk bytes writtencloud.gcp.agent_googleapis_com.disk.write_bytes_count-Byte
Cache sizecloud.gcp.agent_googleapis_com.elasticsearch.cache_memory_usage-Byte
Field evictionscloud.gcp.agent_googleapis_com.elasticsearch.field_eviction_count-Count
Filter evictionscloud.gcp.agent_googleapis_com.elasticsearch.filter_cache_eviction_count-Count
GC countcloud.gcp.agent_googleapis_com.elasticsearch.gc_collection_count-Count
Memory usagecloud.gcp.agent_googleapis_com.elasticsearch.memory_usage-Byte
Network trafficcloud.gcp.agent_googleapis_com.elasticsearch.network.count-Byte
Documentscloud.gcp.agent_googleapis_com.elasticsearch.num_current_documents-Count
Data nodescloud.gcp.agent_googleapis_com.elasticsearch.num_data_nodes-Count
Open connectionscloud.gcp.agent_googleapis_com.elasticsearch.num_http_connections-Count
Nodescloud.gcp.agent_googleapis_com.elasticsearch.num_nodes-Count
Open filescloud.gcp.agent_googleapis_com.elasticsearch.num_open_files-Count
Open connectionscloud.gcp.agent_googleapis_com.elasticsearch.num_server_connections-Count
Shardscloud.gcp.agent_googleapis_com.elasticsearch.num_shards-Count
Completed operationscloud.gcp.agent_googleapis_com.elasticsearch.operation_count-Count
Operation timecloud.gcp.agent_googleapis_com.elasticsearch.operation_time.count-MilliSecond
Max threadscloud.gcp.agent_googleapis_com.elasticsearch.peak_threads-Count
Storage sizecloud.gcp.agent_googleapis_com.elasticsearch.storage_size-Byte
Threadscloud.gcp.agent_googleapis_com.elasticsearch.threads-Count
IPC connectionscloud.gcp.agent_googleapis_com.hbase.ipc.connections-Count
IPC queue sizecloud.gcp.agent_googleapis_com.hbase.ipc.queue_length-Count
IPC trafficcloud.gcp.agent_googleapis_com.hbase.ipc.traffic_count-Byte
Loadcloud.gcp.agent_googleapis_com.hbase.master.average_load-Count
Dead region serverscloud.gcp.agent_googleapis_com.hbase.master.dead_region_servers-Count
Live region serverscloud.gcp.agent_googleapis_com.hbase.master.live_region_servers-Count
Block cache accessescloud.gcp.agent_googleapis_com.hbase.regionserver.block_cache.access_count-Count
Evicted block countcloud.gcp.agent_googleapis_com.hbase.regionserver.block_cache.evicted_blocks_count-Count
Block cache hit ratiocloud.gcp.agent_googleapis_com.hbase.regionserver.block_cache.hit_ratio_percent-Percent
Block cache sizecloud.gcp.agent_googleapis_com.hbase.regionserver.block_cache.memory-Byte
Block countcloud.gcp.agent_googleapis_com.hbase.regionserver.block_cache.num_items-Count
Call queue sizecloud.gcp.agent_googleapis_com.hbase.regionserver.call_queue.length-Count
Compaction queue sizecloud.gcp.agent_googleapis_com.hbase.regionserver.compaction_queue.length-Count
Flush queue sizecloud.gcp.agent_googleapis_com.hbase.regionserver.flush_queue.length-Count
Heap usagecloud.gcp.agent_googleapis_com.hbase.regionserver.memory.heap_usage-Byte
Memstore filescloud.gcp.agent_googleapis_com.hbase.regionserver.memstore.files-Count
Memstore index sizecloud.gcp.agent_googleapis_com.hbase.regionserver.memstore.index_size-Byte
Memstore open storescloud.gcp.agent_googleapis_com.hbase.regionserver.memstore.open_stores-Count
Memstore sizecloud.gcp.agent_googleapis_com.hbase.regionserver.memstore.size-Byte
Online regionscloud.gcp.agent_googleapis_com.hbase.regionserver.online_regions-Count
Request countcloud.gcp.agent_googleapis_com.hbase.regionserver.request_count-Count
RPC request ratecloud.gcp.agent_googleapis_com.hbase.regionserver.requests.total_rate-PerSecond
Slow operationscloud.gcp.agent_googleapis_com.hbase.regionserver.slow_operation_count-Count
Thrift average batch latencycloud.gcp.agent_googleapis_com.hbase.thrift.batch_latency.average-NanoSecond
Thrift average call latencycloud.gcp.agent_googleapis_com.hbase.thrift.call_latency.average-NanoSecond
Thrift call queue sizecloud.gcp.agent_googleapis_com.hbase.thrift.call_queue.length-Count
Thrift average slow call latencycloud.gcp.agent_googleapis_com.hbase.thrift.slow_call_latency.average-NanoSecond
Thrift average time in queuecloud.gcp.agent_googleapis_com.hbase.thrift.time_in_queue.average-NanoSecond
IIS open connectionscloud.gcp.agent_googleapis_com.iis.current_connections-Count
IIS transferred bytescloud.gcp.agent_googleapis_com.iis.network.transferred_bytes_count-Byte
IIS connectionscloud.gcp.agent_googleapis_com.iis.new_connection_count-Count
IIS requestscloud.gcp.agent_googleapis_com.iis.request_count-Count
Network errorscloud.gcp.agent_googleapis_com.interface.errors.count-Count
Network packetscloud.gcp.agent_googleapis_com.interface.packets.count-Count
Network trafficcloud.gcp.agent_googleapis_com.interface.traffic.count-Byte
GC countcloud.gcp.agent_googleapis_com.jvm.gc.count-Count
GC timecloud.gcp.agent_googleapis_com.jvm.gc.time.count-MilliSecond
Memory usagecloud.gcp.agent_googleapis_com.jvm.memory.usage-Byte
CPU timecloud.gcp.agent_googleapis_com.jvm.os.cpu_time.count-NanoSecond
Open filescloud.gcp.agent_googleapis_com.jvm.os.open_files-Count
Daemon threadscloud.gcp.agent_googleapis_com.jvm.thread.num_daemon-Count
Threadscloud.gcp.agent_googleapis_com.jvm.thread.num_live-Count
Max threadscloud.gcp.agent_googleapis_com.jvm.thread.peak-Count
Uptimecloud.gcp.agent_googleapis_com.jvm.uptime.count-MilliSecond
Failed requestscloud.gcp.agent_googleapis_com.kafka.broker.topics.failed_request_count-Count
Incoming messagescloud.gcp.agent_googleapis_com.kafka.broker.topics.incoming_message_count-Count
Trafficcloud.gcp.agent_googleapis_com.kafka.broker.topics.traffic.count-Byte
Active controllerscloud.gcp.agent_googleapis_com.kafka.controller.kafka.active-Count
Offline partitionscloud.gcp.agent_googleapis_com.kafka.controller.kafka.offline_partitions-Count
Leader electionscloud.gcp.agent_googleapis_com.kafka.controller.leader_elections.election_count-Count
Stale leader electionscloud.gcp.agent_googleapis_com.kafka.controller.leader_elections.unclean_count-Count
Flushescloud.gcp.agent_googleapis_com.kafka.log.flush_count-Count
Requestscloud.gcp.agent_googleapis_com.kafka.network.request_count-Count
Delayed purgatory requestscloud.gcp.agent_googleapis_com.kafka.purgatory.num_delayed_requests-Count
Purgatory requestscloud.gcp.agent_googleapis_com.kafka.purgatory.size-Count
Maximum lagcloud.gcp.agent_googleapis_com.kafka.replica_fetcher.max_lag-Count
Minimum fetch ratecloud.gcp.agent_googleapis_com.kafka.replica_fetcher.min_fetch_rate-PerSecond
Gaining replicascloud.gcp.agent_googleapis_com.kafka.replica_manager.isr.expand_count-Count
Lagging replicascloud.gcp.agent_googleapis_com.kafka.replica_manager.isr.shrink_count-Count
Leaderscloud.gcp.agent_googleapis_com.kafka.replica_manager.leaders-Count
Partitionscloud.gcp.agent_googleapis_com.kafka.replica_manager.partitions-Count
Unreliable partitionscloud.gcp.agent_googleapis_com.kafka.replica_manager.under_replicated_partitions-Count
Commandscloud.gcp.agent_googleapis_com.memcached.command_count-Count
Connectionscloud.gcp.agent_googleapis_com.memcached.current_connections-Count
Itemscloud.gcp.agent_googleapis_com.memcached.current_items-Count
Evictionscloud.gcp.agent_googleapis_com.memcached.eviction_count-Count
Memory usagecloud.gcp.agent_googleapis_com.memcached.memory-Byte
Trafficcloud.gcp.agent_googleapis_com.memcached.network.count-Byte
Operationscloud.gcp.agent_googleapis_com.memcached.operation_count-Count
Hit ratiocloud.gcp.agent_googleapis_com.memcached.operation_hitratio-Percent
CPU timecloud.gcp.agent_googleapis_com.memcached.rusage.count-Second
Threadscloud.gcp.agent_googleapis_com.memcached.threads-Count
Memory usagecloud.gcp.agent_googleapis_com.memory.bytes_used-Byte
Memory utilizationcloud.gcp.agent_googleapis_com.memory.percent_used-Percent
Cache hitscloud.gcp.agent_googleapis_com.mongodb.cache.hits.count-Count
Cache missescloud.gcp.agent_googleapis_com.mongodb.cache.misses.count-Count
Collectionscloud.gcp.agent_googleapis_com.mongodb.collections-Count
Connectionscloud.gcp.agent_googleapis_com.mongodb.connections-Count
Data sizecloud.gcp.agent_googleapis_com.mongodb.data_size-Byte
Extentscloud.gcp.agent_googleapis_com.mongodb.extents-Count
Global lock timecloud.gcp.agent_googleapis_com.mongodb.global_lock_hold_time.count-MilliSecond
Index sizecloud.gcp.agent_googleapis_com.mongodb.index_size-Byte
Indexescloud.gcp.agent_googleapis_com.mongodb.indexes-Count
Memory usagecloud.gcp.agent_googleapis_com.mongodb.memory_usage-MebiByte
Objectscloud.gcp.agent_googleapis_com.mongodb.objects-Count
Operationscloud.gcp.agent_googleapis_com.mongodb.operation_count-Count
Storage sizecloud.gcp.agent_googleapis_com.mongodb.storage_size-Byte
SQL Server open connectionscloud.gcp.agent_googleapis_com.mssql.connections.user-Count
SQL Server transaction ratecloud.gcp.agent_googleapis_com.mssql.transaction_rate-PerSecond
SQL Server write transaction ratecloud.gcp.agent_googleapis_com.mssql.write_transaction_rate-PerSecond
Buffer pool pagescloud.gcp.agent_googleapis_com.mysql.buffer_pool.num_pages-Count
Buffer pool operationscloud.gcp.agent_googleapis_com.mysql.buffer_pool.operation_count-Count
Buffer pool sizecloud.gcp.agent_googleapis_com.mysql.buffer_pool_size-Byte
Commandscloud.gcp.agent_googleapis_com.mysql.command_count-Count
Handlerscloud.gcp.agent_googleapis_com.mysql.handler_count-Count
InnoDB doublewrite bufferscloud.gcp.agent_googleapis_com.mysql.innodb.doublewrite_count-Count
InnoDB log operationscloud.gcp.agent_googleapis_com.mysql.innodb.log_operation_count-Count
InnoDB operationscloud.gcp.agent_googleapis_com.mysql.innodb.operation_count-Count
InnoDB page operationscloud.gcp.agent_googleapis_com.mysql.innodb.page_operation_count-Count
InnoDB lockscloud.gcp.agent_googleapis_com.mysql.innodb.row_lock_count-Count
InnoDB row operationscloud.gcp.agent_googleapis_com.mysql.innodb.row_operation_count-Count
Lockscloud.gcp.agent_googleapis_com.mysql.lock_count-Count
QCache operationscloud.gcp.agent_googleapis_com.mysql.qcache.operation_count-Count
QCache queriescloud.gcp.agent_googleapis_com.mysql.qcache.query_count.gauge-Count
Replica lagcloud.gcp.agent_googleapis_com.mysql.slave_replication_lag-Second
Sortscloud.gcp.agent_googleapis_com.mysql.sort_count-Count
Threadscloud.gcp.agent_googleapis_com.mysql.thread_count.gauge-Count
TCP connectionscloud.gcp.agent_googleapis_com.network.tcp_connections-Count
Accepted connectionscloud.gcp.agent_googleapis_com.nginx.connections.accepted_count-Count
Active connectionscloud.gcp.agent_googleapis_com.nginx.connections.current-Count
Handled connectionscloud.gcp.agent_googleapis_com.nginx.connections.handled_count-Count
Requestscloud.gcp.agent_googleapis_com.nginx.request_count-Count
Pagefile utilizationcloud.gcp.agent_googleapis_com.pagefile.percent_used-Percent
Blocks readcloud.gcp.agent_googleapis_com.postgresql.blocks_read_count-Count
Commitscloud.gcp.agent_googleapis_com.postgresql.commit_count-Count
DB sizecloud.gcp.agent_googleapis_com.postgresql.db_size-Byte
Backendscloud.gcp.agent_googleapis_com.postgresql.num_backends-Count
DB rowscloud.gcp.agent_googleapis_com.postgresql.num_tuples-Count
Operationscloud.gcp.agent_googleapis_com.postgresql.operation_count-Count
Rollbackscloud.gcp.agent_googleapis_com.postgresql.rollback_count-Count
Processescloud.gcp.agent_googleapis_com.processes.count_by_state-Count
Process CPUcloud.gcp.agent_googleapis_com.processes.cpu_time.count-Second
Process disk read I/Ocloud.gcp.agent_googleapis_com.processes.disk.read_bytes_count-Byte
Process disk write I/Ocloud.gcp.agent_googleapis_com.processes.disk.write_bytes_count-Byte
Fork countcloud.gcp.agent_googleapis_com.processes.fork_count-Count
Process resident memorycloud.gcp.agent_googleapis_com.processes.rss_usage-Byte
Process virtual memorycloud.gcp.agent_googleapis_com.processes.vm_usage-Byte
Consumerscloud.gcp.agent_googleapis_com.rabbitmq.consumers-Count
Delivery ratecloud.gcp.agent_googleapis_com.rabbitmq.delivery_rate-PerSecond
Messagescloud.gcp.agent_googleapis_com.rabbitmq.num_messages-Count
Publish ratecloud.gcp.agent_googleapis_com.rabbitmq.publish_rate-PerSecond
Unsaved changescloud.gcp.agent_googleapis_com.redis.changes_since_last_save-Count
Blocked clientscloud.gcp.agent_googleapis_com.redis.clients.blocked-Count
Connected clientscloud.gcp.agent_googleapis_com.redis.clients.connected-Count
Commandscloud.gcp.agent_googleapis_com.redis.commands_processed.count-Count
Slave connectionscloud.gcp.agent_googleapis_com.redis.connections.slaves-Count
Connectionscloud.gcp.agent_googleapis_com.redis.connections.total.count-Count
Expired keyscloud.gcp.agent_googleapis_com.redis.expired_keys.count-Count
Memory usagecloud.gcp.agent_googleapis_com.redis.memory.usage-Byte
Lua memory usagecloud.gcp.agent_googleapis_com.redis.memory.usage_lua-Byte
PubSub channelscloud.gcp.agent_googleapis_com.redis.pubsub.channels-Count
PubSub patternscloud.gcp.agent_googleapis_com.redis.pubsub.patterns-Count
Uptimecloud.gcp.agent_googleapis_com.redis.uptime-Second
95% latency (1m)cloud.gcp.agent_googleapis_com.riak.latency.95th_percentile-MicroSecond
Average latency (1m)cloud.gcp.agent_googleapis_com.riak.latency.average-MicroSecond
Maximum latency (1m)cloud.gcp.agent_googleapis_com.riak.latency.maximum-MicroSecond
Memory usagecloud.gcp.agent_googleapis_com.riak.memory_usage-Byte
95% siblings (1m)cloud.gcp.agent_googleapis_com.riak.num_siblings.95th_percentile-Count
Average siblings (1m)cloud.gcp.agent_googleapis_com.riak.num_siblings.average-Count
Maximum siblings (1m)cloud.gcp.agent_googleapis_com.riak.num_siblings.maximum-Count
95% object size (1m)cloud.gcp.agent_googleapis_com.riak.object_size.95th_percentile-Byte
Average object size (1m)cloud.gcp.agent_googleapis_com.riak.object_size.average-Byte
Maximum object size (1m)cloud.gcp.agent_googleapis_com.riak.object_size.maximum-Byte
Operationscloud.gcp.agent_googleapis_com.riak.operation_count-Count
Swap usagecloud.gcp.agent_googleapis_com.swap.bytes_used-Byte
Swap I/O operationscloud.gcp.agent_googleapis_com.swap.io.count-Count
Swap utilizationcloud.gcp.agent_googleapis_com.swap.percent_used-Percent
Sessionscloud.gcp.agent_googleapis_com.tomcat.manager.sessions-Count
Errorscloud.gcp.agent_googleapis_com.tomcat.request_processor.error_count-Count
Processing timecloud.gcp.agent_googleapis_com.tomcat.request_processor.processing_time.count-MilliSecond
Requestscloud.gcp.agent_googleapis_com.tomcat.request_processor.request_count-Count
Trafficcloud.gcp.agent_googleapis_com.tomcat.request_processor.traffic_count-Byte
Busy threadscloud.gcp.agent_googleapis_com.tomcat.threads.busy-Count
Current threadscloud.gcp.agent_googleapis_com.tomcat.threads.current-Count
Backend connection successescloud.gcp.agent_googleapis_com.varnish.backend_connection_count-Count
Cache operationscloud.gcp.agent_googleapis_com.varnish.cache_operation_count-Count
Client connectionscloud.gcp.agent_googleapis_com.varnish.client_connection_count-Count
Open connectionscloud.gcp.agent_googleapis_com.zookeeper.connections_count.gauge-Count
Data sizecloud.gcp.agent_googleapis_com.zookeeper.data_size-Byte
Followerscloud.gcp.agent_googleapis_com.zookeeper.followers.count.gauge-Count
Synced followerscloud.gcp.agent_googleapis_com.zookeeper.followers.synced_count.gauge-Count
Packets receivedcloud.gcp.agent_googleapis_com.zookeeper.network.received_packets_count-Count
Packets sentcloud.gcp.agent_googleapis_com.zookeeper.network.sent_packets_count-Count
Nodescloud.gcp.agent_googleapis_com.zookeeper.nodes.count.gauge-Count
Ephemeral nodescloud.gcp.agent_googleapis_com.zookeeper.nodes.ephemeral_count.gauge-Count
Watchescloud.gcp.agent_googleapis_com.zookeeper.nodes.watches_count.gauge-Count
Average request latencycloud.gcp.agent_googleapis_com.zookeeper.requests.latency.average-MilliSecond
Maximum request latencycloud.gcp.agent_googleapis_com.zookeeper.requests.latency.maximum-MilliSecond
Minimum request latencycloud.gcp.agent_googleapis_com.zookeeper.requests.latency.minimum-MilliSecond
Outstanding requestscloud.gcp.agent_googleapis_com.zookeeper.requests.outstanding_count.gauge-Count
Pending syncscloud.gcp.agent_googleapis_com.zookeeper.sync_operations.pending_count.gauge-Count
Full version history
ReleaseDate
Version 1.2.0
Fixed
  • Fixes screen asset duplication
Version 1.1.1
Changed
  • Each multiservice metric (agent.googleapis.com/agent, istio.io/service) split to separate metrics - one per entity type (for sake of management-zone filtering support)
Version 1.1.0
Added
  • Metrics now support management-zone filtering (main entity type specified for metrics)
Version 1.0.4
Added
  • Release notes to published extension
  • Auto publishing extensions to Hub
Support for GCP overview
No release notes
Dynatrace Hub
All (877)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
