Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Gemini Connector for WorkflowsGemini Connector for Workflows
Connect with Gemini and send prompts for further analysis using Workflows.
Technology by Community
Documentation
Dynatrace workflow with Gemini action.Illustrative example querying for log data and asking Gemini for further error analysis.
  • Product information
Overview
Connect Google Gemini with Dynatrace using this action for Workflows. It allows to define a prompt, execute within Gemini and receive and process the result and data within Dynatrace for further analysis.
Use cases
  • Connect: manage connections to Gemini with support for different models (using API key)
  • Execute prompt: define and execute the prompt defined in the workflow action
  • Handle response: store and analyze response
For further details please have a look at our documentation.
Get started
Gemini Connector for Workflows is available as a Dynatrace app to all customers upon request. Please get in touch with your Dynatrace representative if you want to activate Gemini Connector for Workflows on your tenant.
  • Once installed, you can find it as a new action if you search for Gemini in your Workflows app.
Details
Disclaimer: Gemini Connector for Workflows is a community-supported project and is not officially supported by Dynatrace. If you need help, please contact the team via GitHub.
Community
Documentation
By the community
Open repositoryDynatrace community
Copy to clipboard
Related to Gemini Connector for Workflows
Workflows logo
Workflows
OpenAI Connector for Workflows logo
Connect with OpenAI and send prompts for further analysis using Workflows.
Claude Connector for Workflows logo
Connect with Claude and send prompts for further analysis using Workflows.
Gemini logo
Gemini
Observe end-to-end multimodal AI models provided by Google Gemini.
Gemini Code Assist logo
Gemini Code Assist
Boost developer productivity and get code-level insights into Gemini Code Assist
Agentic Workflows logo
Agentic Workflows
Build agentic workflows to automate, orchestrate and govern operations at scale.
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
