Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Explore Business EventsExplore Business Events
Discover and get started with business events.
App
Free trialDocumentation
Explore business events
  • Product information
  • Release notes
Overview
The Explore Business Events app connects you with blog posts, documentation, and other resources to help you understand some of the ways business events are used to address business analytics use cases. Once you’ve defined your use case, the How to get started section of the page steps you through configuration and initial analysis.
Get started
Open the Explore Business Events app.
Details
Blog posts supplement our documentation with real-world examples, inspirational use cases, and how-to guides. Dynatrace One support and the Dynatrace Community help answer your questions and are great places to collaborate. Business analytics value is driven by well-defined use cases, and these resources will help to clarify your goals.
Once you’ve defined your use case, you’ll configure the sources of your business events and how these events should be processed and stored. Dynatrace Query Language (DQL) is used to query and analyze your events, in the Notebooks app or the Logs and event viewer. Custom dashboards transform complex data from your queries into easy-to-understand visualizations.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
Fixes
  • Addressed minor issues affecting filter visibility and the clarity of error messages shown during capture rule configuration.
Improvements:
  • Capture rules validation: Improved rule definition warnings making it easier to identify incomplete configurations.
  • Filter options: Dropdown filters under Settings > Collect and capture > Business Events now populate dynamically.
Fixes:
  • Addressed an issue related to the visibility of incoming capture rules for a subset of users.
Improvements
  • Unified Business Event configuration experience: Business Event rule setup and management is now centralized in a new interface located in Settings > Collect and capture > Business Events.
  • Consistent management for all rule types: Incoming, Outgoing, and Capturing variant rules now share a unified tabular layout, making it easier to view, filter, and organize rules.
    • Incoming and Outgoing rules can now be filtered by Event provider, Event category, rule name, and enabled/disabled status.
    • Capturing variants can now be filtered by parser, content-type matcher, and the existing summary filter.
  • New contextual navigation: Added a “Go to business event capture settings” intent in the Notebooks app, providing direct navigation to the Business Events widget in the Settings app.
Fixes
  • Addressed several minor issues related to permission setup and editing.
Improvements to error messages and other updates.
Improvements
  • Tiles now provide improved user guidance when data is missing, permissions are missing, or when applications need to be installed.
Improvements
  • Application layout has been improved to maintain consistent sizing of content after load or refresh.
Improvements:
  • The “Ingest business event” action in Workflows has been enhanced to support Business event generation through custom DQL in addition to JSON. Creating a workflow step using the "Ingest business event" action now lets you select from JSON or DQL. Selecting DQL allows you to set a default event provider, event type, event category, and provide a DQL query to provide attributes to be associated with the business event. A business event is generated for each result produced by the DQL query. If the DQL result includes values for event provider, type, or category, these override the values provided in the action. Values from other workflow steps can be passed to the DQL statement using the {{variable}} notation. This new DQL action is helpful to generate Business events from aggregated data sources across Grail.
Bug fixes:
  • Users can now use Expressions in the Business event data when using DQL. The use of expressions (using the {{…}} notation) allows you to use data from other steps, or call system functions (e.g. time/date functions), making the "Ingest business event" feature more dynamic. Refer to the Workflows documentation here for more information on Expressions.
  • Users whose Workflows relied on the older version of the “Ingest business event” action can now successfully ingest data from the “Business event data (JSON)” field using the updated action.
Improvements:
  • The “Ingest business event” action in Workflows has been enhanced to support Business event generation through custom DQL in addition to JSON. Creating a workflow step using the Ingest business event action now lets you select from JSON or DQL. Selecting DQL allows you to set a default event provider, event type, event category, and provide a DQL query to provide attributes to be associated with the business event. A business event is generated for each result produced by the DQL query. If the DQL result includes values for event provider, type, or category, these override the values provided in the action. Values from other workflow steps can be passed to the DQL statement using the {{variable}} notation. This new DQL action is helpful to generate Business events from aggregated data sources across Grail.
Improvements:
  • The Explore Business Events user interface has been redesigned to showcase more Business Analytics capabilities and streamline the presentation of information throughout the app. Users are now presented with key metrics from installed apps or guided to install them from appropriate locations when not installed. Users who do not have the required permissions are now guided to relevant resources to resolve access issues. Links to additional apps, settings, DQL intents, and documentation have been improved to simplify user navigation and experience.
Improvements
  • OpenPipeline configuration links now open in the latest Settings interface (instead of the classic interface) to improve the usability of configuring Business events.
Minor improvements and updates.
Minor improvements & updates.
Enhancements
  • Minor improvements & updates.
Enhancements
Improvements:
  • Added new content for Dynatrace Playground
  • Added advanced tracking capabilities
Minor improvements
Minor improvements
Improvements
  • Introduced support for segments
  • All links to settings point now to their corresponding app on the platform
Maintenance
Updates on certain dependencies for security reasons.
Minor improvements
Minor improvements
  • New KPI representing ingested business events
  • Help button
No release notes
No release notes
No release notes
No release notes
No release notes
No release notes
No release notes
No release notes
No release notes
No release notes
Minor bugfixes.
No release notes
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
