Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
EmailEmail
Email
Email
Send out-of-the-box targeted Emails with workflows.
App
Free trialDocumentation
Use Email to send emails to targeted users based on ownership information and enrich the message with further details like event data, ticket numbers, or logs.
  • Product information
  • Release notes
Overview
Email enables you to send emails within Dynatrace.
Define various notification triggers
  • Use the power of DQL and leverage events to react to any problem, security incident, or attack within workflows.
  • Use business events as a trigger to react on extended events like a failed release validation, specific log messages, or external system events.
  • Define a scheduler and be informed at specific time intervals.
Flexible content composing
  • Enrich message information with tags, hierarchy details, or any arbitrary entity information.
  • Leverage the expression builder for simple message composition.
  • Reuse workflow step results, such as creating a Jira ticket and sending the ticket number to specific users
Closed Loop Communication
  • Use ownership information to address the correct user groups and reduce repetitive configurations.
  • Send targeted emails to recipients, use cc to inform additional users or bcc for blind carbon copies
Use cases
  • Send emails as plain text.
  • Distinguish recipients with to, cc, and bcc to clearly separate accountable users and informed users.
  • Send emails to up to 10 recipients.
  • Leverage expressions to target recipients based on ownership information.
  • Flexible message composition with expression builder to add any arbitrary information like tags, topology information, problem details, and much more.
Get started
Install Email. Then, follow the instructions detailed in Dynatrace Documentation.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Email
Workflows logo
Workflows
Full version history
ReleaseDate
  • Added workflow template for sending email notifications for problems
  • Added workflow template for sending email notifications for aggregated error logs
  • Updated dependencies
  • Updated internationalization
  • Added a fallback UI for unexpected errors
  • Fixed markdown to HTML conversion to abort upon payloads greater than or equal to 256 KiB
  • Added support for semicolon separated recipients in expressions
  • Changed the send email intent payload for share button integration
  • Improved internationalization
  • Removed internally used expressions from action payload
  • Added logging of recipients that were rejected when sending an email
  • Added support for formatted emails
  • Prevent splitting by semicolons inside expressions in all recipient fields
  • Improved error message for non-string content input
  • Added send-email intent for share button
1.1.3
  • Renamed app to "Email" (former "Email for Workflows")
1.1.2
  • Group related input fields by headers
1.1.1
  • Grouped related input fields visually
1.1.0
  • Removed removing of duplicated recipients in the "Send email" widget. Duplications are still removed during the action execution.
  • Made App headless
  • Removed email address validation
  • Marked required fields as required.
1.0.3
1.0.2
1.0.1
  • Updated app icon
1.0.0
  • Released Email for Workflows 1.0
  • Send Email action - Removed message truncation after 5000 characters
  • Send email action - Replaced hardcoded environment url with expression
1.0.0
0.2.9
  • Updated dependencies.
0.2.8
  • Updated app icon.
  • Fixed freezing browser tab when entering an invalid Jinja expression.
0.2.7
  • Send email action - Update dependencies.
0.2.6
0.2.5
0.2.4
0.2.3
0.2.2
0.2.1
  • Send email action - Add sample results.
0.2.0
  • Send email action - Use @dynatrace-sdk/client-email instead of fetch API.
  • Send email action - Remove redundant action response field "clientRequestID".
  • Send email action - Add preview suffix to app name.
  • Send email action - Separate "Automated by" suffix by two empty lines.
  • Send email action - Show message from email service on successfully accepted sends.
  • Send email action - Improve error handling.
0.2.5
0.2.4
0.2.3
0.2.2
0.2.1
0.2.0
0.2.3
0.2.2
0.2.1
0.2.0
0.2.0
0.1.1
  • Send email action - Add send email action.
Dynatrace Hub
All (873)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
