Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
EdgeConnect ManagementEdgeConnect Management
Create new EdgeConnect configurations and manage forwarding of HTTP requests.
App
Free trialDocumentation
Edit host pattern of an existing EdgeConnect configuration.Create a new EdgeConnect.Download an EdgeConnect configuration.
  • Product information
  • Release notes
Overview
EdgeConnect allows you to securely connect and interact with your IT environment from within Dynatrace® apps or workflows, whether it is on running on-premises or a private cloud network. This enables you to e.g. access your private network's Jira instance from a workflow and create or update a Jira issue.
The EdgeConnect Management app allows you to create new and manage existing EdgeConnect configurations and define which requests are forwarded to which EdgeConnect instance. The app also give you an overview of how many EdgeConnect instances are connected per configuration.
Use cases
EdgeConnect Management enables you to:
  • create new EdgeConnect configurations
  • edit host patterns specifying the HTTP requests to be handled by EdgeConnect
  • view the availability status of connected EdgeConnect instances
Get started
Launching the app will provide you with an overview of your existing EdgeConnect configurations and options to create new ones, specifying the host patterns of the requests that should be handled by the respective EdgeConnect configuration. After having created the configuration, you then need to start a matching EdgeConnect instance according to the steps of https://docs.dynatrace.com/docs/shortlink/edgeconnect in your target network.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
More resources
Dynatrace EdgeConnect securely connects your local systems to Dynatrace SaaS
Read the latest blogpost
Read more
Full version history
ReleaseDate
  • This app is hidden now and cannot be used any more. EdgeConnect must be configured in "Settings" -> "General" -> "External Requests".
  • Dependency updates
fix: Disable following redirects in HTTP request tests, ref: PS-28324
  • Improved UI of readonly EdgeConnect configurations
  • Host mappings can be configured for an EdgeConnect configuration
  • Improved input hint of allowed EdgeConnect name syntax
  • Improve name syntax hint for new EdgeConnects
  • Show warning message if EdgeConnect configuration is named in such a way that it can't be deployed on Kubernetes
  • Provide instructions how to deploy EdgeConnects with DT Operator. Small styling refactorings
  • Fix for closing the dialog overlay when clicking in the backdrop
  • Display "managed by DT Operator" hint for EdgeConnects managed by Operator and disabledchanges on manged EdgeConnects
  • Fix for Safari problem where download of the EdgeConnect configuration YAML did not work
  • Fix for Via-header parse error when using test-request-feature
  • Improved K8 deployment view instructions text
  • Add URL verification page
  • Show warning when OAuth clients are inactive or deleted
  • Add helper menu with documentation link
  • Add documentation link to deployment description
  • Remove 'tenant' field in downloadable yaml file
  • Add support for creating and rotating OAuth clients for every EdgeConnect configuration.
  • Show host pattern size violations.
  • Replaced deprecated edge-connect scopes by new required scopes
  • Fix naming of necessary token scope for connecting EdgeConnect
  • Show confirmation dialog when trying to dismiss the creation dialog with unsaved changes. PS-7370
  • Add lightweight OAuth client creation UI behind feature flag
  • Show online status and version of EdgeConnects. PS-6275
  • Show name, host pattern, and OAuth client ID constraint violations.
  • Implement creating and editing of EdgeConnect configurations.
  • Add delete confirmation modal.
  • Add custom error message when user operations fail because the user is missing the required permissions.
  • Show empty state if there are no EdgeConnect configurations or no search/filter results.
  • Error handling improvements. PS-6275
  • Fix downloading edgeConnect.yaml file not working on Firefox.
  • Add host pattern hint.
No release notes
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
