Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Discovery & CoverageDiscovery & Coverage
Ensure enterprise-wide visibility. Discover and remediate coverage gaps.
App
Try in Playground
Welcome to Discovery & Coverage.Hybrid cloud and host coverage. Quickly connect all your clouds and hosts.Best practice rules ensure you have the right monitoring in the right places.
  • Product information
  • Release notes
Overview
Prevent unexpected outages by detecting and remediating monitoring coverage gaps across your entire enterprise.
Use cases
  • Connect cloud integrations
  • Bulk installation OneAgent instances
  • Bulk activation of platform extensions
  • Optimize configuration settings
Get started
To get started, select Open. Discovery & Coverage is preinstalled in all Dynatrace SaaS environments.
Dynatrace
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Discovery & Coverage
Google Cloud logo
Google Cloud
Meet your business challenges head on with cloud computing services from Google.
OneAgent logo
OneAgent
The simplest way to capture all observation signals automatically and in context
AWS logo
AWS
Reliable, scalable, and inexpensive cloud computing services.
VMware logo
VMware
Monitor health and performance of VMware virtual machines.
More resources
Embrace enterprise-wide observability and security with Foundation & Discovery
Dynatrace's new app, Discovery & Coverage provides advanced observability and easy-to-manage security across diverse ecosystems. It also enables proactive detection of unmonitored hosts, managed centrally via UI or API.
Blog Post
Full version history
ReleaseDate
1.23.0
  • Fixes sorting in table by IP Address on Network Coverage page.
  • Replaces expanding rows in tables to popup screen to improve UX.
  • Small improvements to clarity of text in UI elements.
1.22.0
Minor Changes
  • Removes support of Red Hat 8, Oracle Linux 8 and Rocky Linux 8 in Install Synthetic ActiveGate form
  • Moves Network Devices table to the drawer component instead of putting it as a sub table to improve UX
Patch Changes
  • Fixes warnings in built-in ActiveGate diagnostic overview dashboard
  • Fixes missing hosts for Hyper-V on Hosts Coverage page
  • Adds info message to OneAgent Coverage bar on Hosts Coverage for multi-tenant users
1.21.0
Minor Changes
  • Adds possibility to choose an architecture for Python in AWS Lambda monitoring setup window
  • Adds SNMP autodiscovery, Network platforms, SNMP traps, Syslog and Netflow options to Configure button on Network Coverage page
Patch Changes
  • Fixes sorting for entities table on Host coverage page
1.20.1
Patch Changes
  • Contains internal changes
1.20.0
Patch Changes
  • Improves performance and security
1.19.0
Minor Changes
  • (Install OneAgent) Adds "Show deployment status" button to OA modal
  • (Network coverage) Increases autodiscovery tolerance to prevent missing devices
  • (Service coverage) Adds intent link for Process
Patch Changes
  • (Network coverage) Fixes an issue with missing pings for network devices
  • (Discovery findings) Fixes the colors of priorities' chart
  • (Host coverage) Fixes an issue with missing clouds hosts
1.18.0
Minor Changes
  • (Install OneAgent) Adds footer with documentation link and Strict Firewall Policy section.
  • (Install ActiveGate) Adds support for browserless Synthetic ActiveGate.
  • (Install ActiveGate) Adds support for Oracle Linux 9 in Install Synthetic ActiveGate form.
Patch Changes
  • (Host coverage) Fixes DQL queries for listing hosts - shows a proper amount of hosts in case of missing extension for particular cloud provider.
  • (Network coverage) Fixes "Poll" action for network devices in case of missing port.
  • (Network coverage) Fixes monitoring configurations table - it is possible now to show more than 20 configurations.
1.17.0
Minor Changes
  • (Install ActiveGate) Remove support of Amazon Linux 2 in install synthetic ActiveGate form
Patch Changes
  • (Discovery findings) Fix filtering the rules by priority
  • (Service coverage) Fix PublicSources column always showing true
1.16.0
Minor Changes
  • GA of Network coverage. Learn more.
Patch Changes
  • (Discovery findings) Fix the queries for database instances when process runs on several hosts
  • Resolve IP address recognition issue that incorrectly classifies private IPs as public
1.15.1
Minor Changes
  • Unify help menu with other applications
  • Support for Ubuntu 24 in Install Synthetic ActiveGate form
  • Remove support for Red Hat 7 and CentOS 7/8 in Install Synthetic ActiveGate form
  • (Install ActiveGate) New dedicated endpoint to get list of public communication endpoints
Patch Changes
  • Remove unused scopes of application and improve the descriptions of scopes
  • Move segment selector from app header to page content
1.14.1
Patch Changes
  • 7f1a994: (Network coverage) Always send user to generic entity via intent
  • cd8f9ac: (Service coverage) More intuitively sorting of coverage
  • 8080f42: (Splash screen) Update use cases of the application
  • 177cc74: (Network coverage) Fixed interval misalignment
  • 20d80b8: (Network coverage) Add "Open with" button
1.14.0
Minor Changes
  • 585017a: Increased the limit for the DQL query results to 25000 instances
  • 8372e7b: (Discovery Findings) Removed confirmation modal for "Set up log ingestion" action
  • eb990bf: (Host coverage) Improved modals for connecting AWS & Azure clouds
  • 0f145f4: (General) Added link to documentation in application header
Patch Changes
  • 4f07ebe: Rename install button in header
1.13.0
Minor Changes
  • d435d9c: Added the Segments functionality over the pages
  • 1354150: (Service candidates) Enabled Service candidates in the application
  • 76dfa5e: (Discovery findings) Rules for logs ingest (AWS, Azure, GCP, Fluent Bit, FluentD) open Logs application instead of showing documentation
  • 4613535: (Network coverage) Added the filter field to the table
Patch Changes
  • 0d26a39: (Host coverage) Fixed sidebar indicator when all clouds are loaded and not set up
  • 1ae912f: (Install ActiveGate) Improvements to Install Synthetic ActiveGate form
  • 4b4179e: (Install ActiveGate) Changed "Show deployment status" button link to direct to ActiveGates subpage of Deployment status
  • 141e281: Update components library and adapted Segments selector to new UI logic
1.12.1
Patch Changes
  • ee540f3: Fix rendering issue in ActiveGate installation modal
1.12.0
Minor Changes
  • d058cf8: (Discovery findings) Added coverage in Discovery findings item in sidebar (showing number of actionable rules for highest priority for which actionable rules were found)
1.10.0
Minor Changes
  • 88c9140: Bundled ActiveGate diagnostic dashboard which will be available in Dashboard app
Patch Changes
  • 82d918a: (Install OneAgent) Improved performance for Powershell download commands for OneAgent by adding the parameter that hides the progress bar
  • 8704137: (Host coverage) Fixed the errors with non-existent relationship for Cloud hosts in DQL
1.9.1
Minor Changes
  • f7af0bd: Show app version
  • e2db16f: (Discovery Findings) Add fluentbit and fluentd rules
  • b3bae9f: (Discovery Findings) Show required permissions for remediation actions
  • e2db16f: (Discovery Findings) Update Kubernetes logs rule to look at containers instead of hosts
  • 88ce313: (Discovery Findings) Adapted the "Hosts with external services" rule to take into account new attribute name "ebpfHasPublicTraffic"
  • e2db16f: (Host Coverage) Add Oracle Cloud
  • 82fa34e: (Host Coverage) Add datacenter filtering for AWS, Azure, GCP, and VMware
  • e2db16f: (Host Coverage) For VMware consider new Extension monitoring in addition to classic integration
  • e5ec303: (Install OneAgent) Support for default monitoring mode selection
Patch Changes
  • 89d0639: (Discovery Findings) Optimized system logs rules for large environments
  • 1e883b6: (Discovery findings) Fixed the error for Istio/Envoy rule
  • bdca51d: (Discovery findings) Stylistic changes related to the rules table
  • 5fc2f44: (Host Coverage) App-only containers are not shown and unmonitored cloud hosts
  • 0e2c7d1: (Host Coverage) Fixed infinite render loop in Connect VMWare Cloud dialog
  • f279b9e: (Install OneAgent) Discovery mode is now disabled for tenants with Foundation and Discovery feature disabled
1.7.0
Minor Changes
  • d3c2ef2: (Host Coverage) Integration status for unused clouds (hosts count = 0) changed from critical to neutral
1.5.0
Minor Changes
  • ecc5fd8:
    • (Discovery Findings) Added rules for Messaging, Virtualization, and Istio
    • (Host Coverage) Added HyperV and Nutanix private clouds
    • Added handling for DQL query throttling
Patch Changes
  • cd6b905: (Discovery Findings) Fix raw values for monitoring modes in instances table to nice names
  • d138d34: (Discovery Findings) Fix incorrect width of install extension button
  • 76e7b7d: (Host Coverage) Fixed incorrect API endpoint on Install OneAgents modal
1.3.1
Patch Changes
  • e540867: Fix tracking the user actions
1.3.0
Minor Changes
  • fdb039f: (Discovery Findings) Added button to reset filters for rules table
  • 9e95359: (Discovery Findings) Clicking on chart series applies priority filter to the table
  • f405f3f: (Host Coverage) Added sorting to hosts table
  • fdb039f: (Host Coverage) Added button to reset filters for hosts table
  • a21f1fa: (Host Coverage) Added filtering to hosts table
  • d294938: (Host Coverage) Install OneAgent(s) button shows number of hosts on which OA should be installed when filtering on the table was applied
  • 80cb291: (Host Coverage) Stylistic improvements:
    • replaced InformationOverlay with TerminologyOverlay in table headers,
    • replaced documentation links in Install OneAgent modal with labels and TerminologyOverlays,
    • wording
  • 3df62f4: Added new button directing to the release notes page
Patch Changes
  • baa7d17: (Discovery Findings) Fix: charts show rules by effective priority - rule with no extension installed has priority INFO
  • 8e66b9d: (Discovery Findings) Added tooltips for priority icons
  • 8e66b9d: Added "alt" and "title" attributes to cloud icons and app icon
1.2.0
Minor Changes
  • 95c4f14: (Discovery Findings) Added handling of rules settings for user without read and/or write permissions
  • 6b5a501: (Discovery Findings) Added Open with button to Other actions modal that allows to open DQL query for the rule in other apps capable of utilizing DQLs
  • a1abe1a: (Discovery Findings) Explain rule moved below the header and wrapped with Accordion
  • 50364f8: (Host Coverage) Added possibility to send the intent to the Discovery & Coverage app which will open the "Install OneAgent" modal and fill the form with data provided in the payload
Patch Changes
  • 5ba9015: Fixed vulnerability CVE-2023-42282
1.1.0
Minor Changes
  • 4301b7c: (Discovery findings) Changed the status filter to multi-select filter type
  • 4301b7c: (Discovery findings) Added filter to search for text used in rule description and title
  • cef8c93: (Discovery findings) Added possibility to apply recommended actions to single host
  • bcb4689: (Discovery findings) Added sorting of the main table and added the new filter by rule
  • 365cadb: (Discovery findings) Added i18n support
  • 0752404: (Host coverage) All detected hosts are shown with a separate column for undiscovered cloud hosts
  • 343548b: (Host coverage) Added tags and properties parameters for OneAgent installation
  • f9cd30b: (Host coverage & Discovery findings) Added i18n support for Landing page, Host coverage and shared components
Patch Changes
  • 4f53f55: (Discovery findings) Merged selection and filtering DQL to a single DQL
  • 4301b7c: (Discovery findings) Changed the rule indicators to be in the colors of the rule priority - only when rule is actionable
  • 988575a: (Discovery findings) Rules are now refreshed from settings
  • 06925ec: (Discovery findings) Removed GKE part from Unmonitored Kubernetes cluster rule
  • 9603fb0: (Host coverage) Unification of DQLs logic
  • 4301b7c: (Host coverage & Discovery findings) Improved error handling - overlay with error message and added the "Refresh" button
  • 7c59580: (Host coverage & Discovery findings) Improved table layout - minor stylistic corrections
1.0.3
Patch Changes
  • 102418a: Improved documentation links on Install OneAgents action (Host coverage)
  • 20896b1: Improved the application description
1.0.2
Patch Changes
  • 61ea83b: Fix the bug with the impossible architecture selection (Host Coverage)
1.0.1
Patch Changes
  • 2276432: Fixed login autofill for inputs above token input
  • e18ea76: Improved layout of Install OneAgents action
  • 80b7e8c: Added rule for Unmonitored Google Cloud logs
1.0.0
Patch Changes
  • 2bfa3f9: Minor changes (removed coloring, updated labels, added missing description, added margin at the bottom)
Dynatrace Hub
All (877)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
