Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Dell PowerStoreDell PowerStore
Dell PowerStore
Dell PowerStore
Monitor PowerStore Arrays for performance and health, with Dell PowerStore API.
Extension
Free trialDocumentation
Dell PowerStore dashboard - at-a-glanceDell PowerStore dashboard - volumes and NASPowerStore appliance performance scorecardPowerStore volumes listPowerStore NAS operational statusPowerStore filesystem with SMB and NFS shares related to it
  • Product information
  • Release notes
Overview
Simplify monitoring of your PowerStore infrastructure. Focus on essential insights into your PowerStore arrays.
This extension is intended for users, who:
  • Use the Dell PowerStore storage
  • Want to extend Dynatrace insights into the storage infrastructure on which workloads depend
This extension enables you to:
  • Monitor your PowerStore arrays using a PowerStore-specific entity model and comprehensive unified analysis views
  • Receive alerts on performance and health issues detected in your PowerStore infrastructure
  • Take proactive actions based on anomalies detected in PowerStore infrastructure before they affect your applications
Use cases
  • Operational monitoring of your PowerStore array using the PowerStore API in Dynatrace, integrated with related insights into the infrastructure and apps that utilize your PowerStore array.
  • Monitor resource utilization and receive alerts for detected anomalies.
Get started
For more information on the installation and configuration, please see Dell PowerStore extension in the Dynatrace Documentation.
Details
Compatibility information
  • A Dell PowerStore array with the PowerStore API available, reachable from an ActiveGate set up in your Dynatrace environment.
  • PowerStore API connection details: Server IP, username and password for authentication with the PowerStore API.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Host Typestorage.dell.powerstore.host.type-Count
Host OS Typestorage.dell.powerstore.host.os_type-Count
Volume Sizestorage.dell.powerstore.volume.size-Byte
Logical Used Sizestorage.dell.powerstore.volume.logical_used-Byte
Volume Used PCTstorage.dell.powerstore.volume.used_pct-Percent
Volume Statestorage.dell.powerstore.volume.state-State
Is Host Access Availablestorage.dell.powerstore.volume.is_host_access_available-State
Host Group Countstorage.dell.powerstore.volume.host_groups-Count
Volume Group Countstorage.dell.powerstore.volume.volume_groups-Count
Mapped Volume Countstorage.dell.powerstore.volume.mapped_volumes-Count
Node Countstorage.dell.powerstore.appliance.nodes-Count
FC Port Countstorage.dell.powerstore.appliance.fc_ports-Count
Virtual Ethernet Port Countstorage.dell.powerstore.appliance.veth_ports-Count
SAS Port Countstorage.dell.powerstore.appliance.sas_ports-Count
Ethernet Port Countstorage.dell.powerstore.appliance.eth_ports-Count
Ethernet BE Port Countstorage.dell.powerstore.appliance.eth_be_ports-Count
Virtual Volume Countstorage.dell.powerstore.appliance.virtual_volumes-Count
Volume Countstorage.dell.powerstore.appliance.volumes-Count
IP Pool Addresses Countstorage.dell.powerstore.appliance.ip_pool_addresses-Count
Drive Failure Tolerance Levelstorage.dell.powerstore.appliance.drive_failure_tolerance_level-State
IO CPU Utilizationstorage.dell.powerstore.appliance.io_workload_cpu_utilizationThe percentage of CPU Utilization on the cores dedicated to servicing storage I/O requests.Percent
Average Latencystorage.dell.powerstore.nas.avg_latencyAverage read and write latency in microseconds.MicroSecond
Average Read Latencystorage.dell.powerstore.nas.avg_read_latencyAverage read latency in microseconds.MicroSecond
Average Read Sizestorage.dell.powerstore.nas.avg_read_sizeAverage read size in bytes.Byte
-storage.dell.powerstore.nas.avg_size--
Average Write Latencystorage.dell.powerstore.nas.avg_write_latencyAverage write latency in microseconds.MicroSecond
Average Write Sizestorage.dell.powerstore.nas.avg_write_sizeAverage write size in bytes.Byte
Read Bandwidthstorage.dell.powerstore.nas.read_bandwidthRead rate in bytes per second.BytePerSecond
Read IOPSstorage.dell.powerstore.nas.read_iopsTotal read operations per second.PerSecond
Total Bandwidthstorage.dell.powerstore.nas.total_bandwidthTotal data transfer rate in bytes per second.BytePerSecond
Total IOPSstorage.dell.powerstore.nas.total_iopsTotal read and write operations per second.PerSecond
Write Bandwidthstorage.dell.powerstore.nas.write_bandwidthWrite rate in bytes per second.BytePerSecond
Write IOPSstorage.dell.powerstore.nas.write_iopsTotal write operations per second.PerSecond
Is Continuous Availability Enabledstorage.dell.powerstore.smb_share.is_continuous_availability_enabled-Unspecified
Is Encryption Enabledstorage.dell.powerstore.smb_share.is_encryption_enabled-Unspecified
Is ABE Enabledstorage.dell.powerstore.smb_share.is_abe_enabled-Unspecified
Is Branch Cache Optimization Enabledstorage.dell.powerstore.smb_share.is_branch_cache_enabled-Unspecified
Offline Availabilitystorage.dell.powerstore.smb_share.offline_availability-State
Average Read Latencystorage.dell.powerstore.volume.avg_read_latencyAverage read latency in microseconds.MicroSecond
Average Write Latencystorage.dell.powerstore.volume.avg_write_latencyAverage write latency in microseconds.MicroSecond
Average Latencystorage.dell.powerstore.volume.avg_latencyAverage read and write latency in microseconds.MicroSecond
Average Read Sizestorage.dell.powerstore.volume.avg_read_sizeAverage read size in bytes.Byte
Average Write Sizestorage.dell.powerstore.volume.avg_write_sizeAverage write size in bytes.Byte
Average IO Sizestorage.dell.powerstore.volume.avg_io_sizeAverage size of read and write operations in bytes.Byte
Read Bandwidthstorage.dell.powerstore.volume.read_bandwidthRead rate in bytes per second.BytePerSecond
Write Bandwidthstorage.dell.powerstore.volume.write_bandwidthWrite rate in bytes per second.BytePerSecond
Total Bandwidthstorage.dell.powerstore.volume.total_bandwidthTotal data transfer rate in bytes per second.BytePerSecond
Read IOPSstorage.dell.powerstore.volume.read_iopsTotal read operations per second.PerSecond
Write IOPSstorage.dell.powerstore.volume.write_iopsTotal write operations per second.PerSecond
Total IOPSstorage.dell.powerstore.volume.total_iopsTotal read and write operations per second.PerSecond
Default Accessstorage.dell.powerstore.nfs_export.default_access-State
Minimum Security Typestorage.dell.powerstore.nfs_export.min_security-State
No Access Host Countstorage.dell.powerstore.nfs_export.no_access_hosts-Count
Read Only Host Countstorage.dell.powerstore.nfs_export.read_only_hosts-Count
Read Only Root Host Countstorage.dell.powerstore.nfs_export.read_only_root_hosts-Count
Read Write Host Countstorage.dell.powerstore.nfs_export.read_write_hosts-Count
Read Write Root Host Countstorage.dell.powerstore.nfs_export.read_write_root_hosts-Count
Maximum Transmission Unitstorage.dell.powerstore.cluster.physical_mtu-Unspecified
Appliance Countstorage.dell.powerstore.cluster.appliances-Count
Encryption Enabledstorage.dell.powerstore.cluster.is_encryption_enabled'0' if encryption not enabled, '1' if encryption is enabledState
Cluster Statestorage.dell.powerstore.cluster.state-State
Operation Statusstorage.dell.powerstore.nas.operational_status-State
File Interface Countstorage.dell.powerstore.nas.file_interfaces-Count
NFS Server Countstorage.dell.powerstore.nas.nfs_servers-Count
SMB Server Countstorage.dell.powerstore.nas.smb_servers-Count
File LDAP Countstorage.dell.powerstore.nas.file_ldaps-Count
File NISES Countstorage.dell.powerstore.nas.file_nises-Count
Filesystem Countstorage.dell.powerstore.nas.file_systems-Count
Filesystem Sizestorage.dell.powerstore.fs.size_total-Byte
Filesystem Used Sizestorage.dell.powerstore.fs.size_used-Byte
Filesystem Used Pctstorage.dell.powerstore.fs.used_pct-Percent
Filesystem Access Policystorage.dell.powerstore.fs.access_policy-Unspecified
Filesystem Locking Policystorage.dell.powerstore.fs.locking_policy-Unspecified
Filesystem Folder Rename Policystorage.dell.powerstore.fs.folder_rename_policy-Unspecified
Filesystem Default Hard Limitstorage.dell.powerstore.fs.default_hard_limit-Unspecified
Filesystem Default Soft Limitstorage.dell.powerstore.fs.default_soft_limit-Unspecified
Related to Dell PowerStore
Dell EMC PowerMax logo
Dell EMC PowerMax
Monitor PowerMax Arrays for performance and health, with Dell Unisphere API.
Dell EMC Isilon - PowerScale logo
Monitor your Dell EMC Isilon / Powerscale clusters through the OneFS API
Full version history
ReleaseDate
Improved in this version
  • Resolved issue with dashboard links not opening on pure Gen3 tenants.
  • Resolved issue with the storage.dell.powerstore.volume.used_pct metric being reported with a wrong value.
  • Ongoing security updates
⚠️ Important Change
  • This release requires a Minimum Dynatrace Version version of 1.318.0 or higher.
New in this version
  • Added ALERT_TEMPLATES for anomaly detectors in the Davis Anomaly Detection app (latest Dynatrace only).
  • Resolved issue with some entities not being imported if the entity list size is high for Hosts, Volumes, NFS Exports and NAS Servers.
Patch level changes:
  • Fixed an issue causing no performance metrics being collected when a specific resolution was unavailable for collection from PowerStore
  • Resolved an issue with user authentication in some Prism connection scenarios
  • Resolved an issue that caused logs older than 24 hrs to be imported into Dynatrace
  • Fixed an issue which caused a warning due to alerts older than 24 hours being imported
⚠️IMPORTANT CHANGE: This extension release requires Dynatrace cluster version 1.313 or later.
New features:
  • The dt.security_context attribute is now propagated to all entities created by the extension. When enabling entity access control based on dt.security_context ensure you set the Grail security context destination property to dt.security_context
  • Enabled the extension to present the Dynatrace Platform (a.k.a. Gen3) entity details screens in the future platform apps that will expect these screens
⚠️IMPORTANT CHANGE: This extension release requires Dynatrace cluster version 1.310 or later.
New features:
  • Added the Dynatrace Platform (a.k.a. Gen3) dashboard
  • Added option to set metric collection frequency
  • Fixed metrics for filesystem which sometimes returned None values under certain conditions
New features:
  • option to skip SSL certificate validation, to allow using self-signed certificates if needed
  • option to provide your own SSL certificate path for API request validation
  • Fixed extension startup issues in some post-upgrade environments
  • Fixed timezone issues in alert timestamps
  • Fixed issue with the extension trying to report alerts that are too old to get ingested properly (2+ hours old).
This is the first generally available release of the Dell PowerStore extension.
Dynatrace Hub
All (876)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
