Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Custom Extensions CreatorCustom Extensions Creator
Create custom extensions with a few clicks
App
Free trial
Create, edit, build, sign and upload custom extensionsCreate monitoring configurations leveraging the Extensions app
  • Product information
  • Release notes
Overview
Custom Extensions Creator lets you create custom 2.0 extensions directly on the Dynatrace web UI.
You can:
  • Create new extensions
  • Import existing extensions from your environment or a file
  • Change metrics, groups, dimensions, feature sets, and more
  • Quickly build, sign, and publish extensions to your environment
Use cases
  • Quickly edit an existing extension and deploy without touching YAML files
  • Migrate a Custom DB Query extension from v1 to v2 with a single click
  • Sign a new extension directly from the browser in the Dynatrace web UI
  • Create a new monitoring configuration
  • Share the extension YAML with your team
Get started
To use Custom Extensions Creator, the user must be granted the following permissions:
  • The AppEngine - User policy.
  • A policy with permissions:
ALLOW environment-api:extensions:write;
ALLOW environment-api:extensions:read;
ALLOW extensions:definitions:read;
Dynatrace
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Custom Extensions Creator
Extensions logo
Extensions
Manage Dynatrace extensions for hundreds of technologies.
Full version history
ReleaseDate
1.5.1
Patch Changes
  • 3fa1a72: Fix an issue with SNMP validation not recognizing the $networkFormat function
  • e6a781f: Users can now manage extension documents directly in the Settings app, and change ownership of extensions if they are documents admins.
  • 3fa1a72: Fix an issue where dragging the mouse outside the yaml editor could crash the app
  • 6b32724: Update dependencies to apply security fixes
  • e96aec3: * Update dt-app to 1.7, includes several fixes and other dependencies updates
    • Improve the create extension modal logic to create valid extension names
1.5.0
Minor Changes
  • 2faecba: Adds the JMX Wizard, users can now create JMX extensions using a step-by-step wizard and mbean navigation
Patch Changes
  • 1557e87: Fix: validate placeholder extension name at import
  • 39b7a52: Changed layout of flexDirection on the SNMP DatasourceModal from column to row, so that the metrics table would resize as it is done in the SQL DatasourceModal
1.5.0
Minor Changes
Patch Changes
1.4.2
Patch Changes
  • Fix an yaml formatting issue that could generate invalid extensions, example when importing the Big IP or Generic Cisco Device extension.
  • Fix an issue where the Accessor field was not showing in the modal for a new JMX metric
1.4.1
Patch Changes
  • Fix app small icon not showing up
1.4.0
Minor Changes
  • Users can now use the app to create a self signed certificate
1.4.1
Patch Changes
1.4.0
Minor Changes
  • Users can now use the app to create a self signed certificate when deploying an extension.
1.3.1
Patch Changes
  • 410f05b: Add a Help section to the app header
1.3.0
Minor Changes
  • 083edbb: Introduce the Documents view to allow users to manage extension documents
Patch Changes
  • 121a64a: Add an ErrorBoundary to handle extension rendering errors.
  • d517df3: Fixed issue where schedule in SQL extensions would not update properly
  • 233de29: Add a searchbar and resize to the group and subgroup tables
1.2.4
Patch Changes
  • Fixed issue where schedule in SQL extensions would not update properly
1.2.3
Minor Changes
  • e00c766: * Update tables and the UI editor to be in a single page
    • Update the app header and fix an issue with the navigation
    • Fix an issue with the cron scheduler where week and month days were not starting at 1
Patch Changes
  • 55c66ec: Add support for schema validation for SQL extensions
1.1.6
Patch Changes
  • SQL - Add a new feature to show available columns when creating a SQL extension
  • SQL - Add support for schema validation for SQL extensions
  • SQL - Add the most recent validation for cron schedule
  • SQL - Fix an issue where var: could not be used in the interval field
  • SQL - Fix an issue where the timeout was incorrectly validated when schedule was used
1.1.3
Patch Changes
  • 5d20d71: * Fix an issue where the interval was validated even when schedule was used
    • Add support for parsing the SQL queries and showing which columns are available
1.1.2
Patch Changes
  • d04a140: Use form validation best practices
1.1.1
Patch Changes
  • 538e7e1: Check for app state size before allowing save
  • 04ceeaf: Fix save and deploy button states
1.1.0
Minor Changes
  • Adds support for a new editor view, allowing users to:
    • Edit any declarative extension extension.yaml file
    • Work with schema support, the editor has full autocomplete and error detection for the extension schema
    • Add metrics metadata, topology, screens, and more
  • Add editor support for all declarative datasources:
    • SQL
    • SNMP
    • SNMP Traps
    • JMX
    • WMI
    • Prometheus
    • JDBC
  • Add UI support for JMX extensions
    • Users can now use the UI to create, edit, and deploy JMX extensions on top of the already supported SQL and SNMP datasources
1.1.2
    • SQL
    • SNMP
    • SNMP Traps
    • JMX
    • WMI
    • Prometheus
    • JDBC
  • Rework the forms for SQL and SNMP datasources
    • Users can now validate cron expressions directly in the SQL extension form
    • Erros should be clearer
  • Fix an issue when signing with an invalid certificate did not produce an error
1.0.2
Patch Changes
  • cfa1418: SQL - fix an issue with the timeout and interval calculation being inverted
1.0.1
Patch Changes
  • 55c2d52: Add support for cronlike intervals
  • Fix an issue where an invalid app state could cause a state reset
  • Allow shares to be stopped even if they were deleted outside the app
  • Show an error message when the timeout is larger than the interval
  • 8e382eb: Show a validation error if interval is greater than timeout
1.0.0
There are no breaking changes, the version is bumped to 1.0.0 to follow Dynatrace's app semantic versioning
Patch Changes
  • Add initial support for the SNMP datasource
  • bf86aa4: Don't return empty states if the state service fails with errors other than a 404
0.0.20
Patch Changes
  • 444a1cd: Remove quoted strings from queries before validating them
  • a61f6d7: Add new app icon
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
