Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Cribl via OpenTelemetryCribl via OpenTelemetry
Ingest telemetry data, including traces, logs & metrics using Cribl Streamā„¢
Technology by Cribl
Documentation
Explore logs using the Dynatrace logs app. Take action and filter by selecting relevant fields directly in the filter bar or the elements from the results below directly. This allows you to quickly filter in and filter out entities.You can create a new QuickConnect destination for Dynatrace within your Cribl Stream Worker Group Routing settings. This will allow you to pipe or selectively route your sources to Dynatrace.Configuring a new QuickConnect destination is simple and fast forward. The Cribl product documentation provides all the required information.
  • Product information
Overview
Cribl Stream acts as a central observability forwarding pipeline, collecting data from various sources such as Splunk, ElasticSearch and OpenTelemetry, to route it to Dynatrace for true end-to-end observability leveraging the OpenTelemetry Protrocol (OTLP).
This integration supports multiple Dynatrace endpoint types, including SaaS, Environment ActiveGate, providing flexibility for different scenarios.
The Cribl Stream OTLP Destination leverages the standardized OpenTelemetry Protocol (OTLP) to transmit data to Dynatrace.
Key features include:
  • Multiple Endpoint Support: Connect to Dynatrace SaaS or ActiveGate
  • Secure Authentication: Uses Dynatrace API tokens for secure data transmission
  • Persistent Queue: Buffer data during connectivity issues to prevent data loss
  • Custom HTTP Paths: Override default endpoint paths for specialized configurations
  • Forwarding Logs, Metrics, and Traces
Get started
Setting up a direct integration of telemetry data via Cribl Stream OTLP Destination takes just a few simple steps:
  1. Get API key to ingest telemetry data.
    • Generate new token with appropriate scope. Refer to Dynatrace documentation for details.
  2. Configure Cribl Stream OTLP Destination.
    • In Cribl Stream, navigate to Data > Destinations and add a new Dynatrace OTLP destination
    • Configure your Dynatrace endpoint (SaaS or ActiveGate)
    • Provide your Dynatrace environment ID and API access token
  3. Route your telemetry data.
    • Create routes in Cribl Stream to direct your telemetry data to the Dynatrace OTLP Destination
    • Deploy your configuration to start sending data
  4. Process incoming data with Dynatrace OpenPipeline
  • Enrich and contextualize data
  • Extract metrics, or create business events from logs, metrics and traces
Please consult the linked Cribl product documentation for additional configuration details.
Details
The Cribl Stream OTLP Destination provides a robust solution for sending telemetry data to Dynatrace, leveraging the standardized OpenTelemetry Protocol. This integration is ideal for organizations that need to send comprehensive observability data, including traces, metrics, and logs, to Dynatrace.
Cribl
Documentation
By the partner
Contact CriblRequest support
Copy to clipboard
Related to Cribl via OpenTelemetry
Dashboards logo
Dashboards
Distributed Tracing logo
Distributed Tracing
Analyze and slice distributed traces by any attribute and from any source.
Logs logo
Logs
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
