Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Cribl via HTTPCribl via HTTP
Cribl via HTTP
Cribl via HTTP
Ingest logs and events using Cribl Streamā„¢
Technology by Cribl
Documentation
Explore logs using the Dynatrace logs app. Take action and filter by selecting relevant fields directly in the filter bar or the elements from the results below directly. This allows you to quickly filter in and filter out entities.You can create a new QuickConnect destination for Dynatrace within your Cribl Worker Group Routing settings. This will allow you to pipe or selectively route your sources to Dynatrace.Configuring a new QuickConnect destination is simple and fast forward. The Cribl product documentation provides all the required information.
  • Product information
Overview
Cribl Stream functions as a central observability pipeline, collecting log data from various sources and routing it to Dynatrace through the HTTP Destination. This integration supports multiple Dynatrace endpoint types, including Cloud (SaaS), ActiveGate, and Manual configurations, providing flexibility for different deployment scenarios.
The Cribl Stream HTTP Destination uses standard HTTP protocol to transmit log data to Dynatrace, ensuring compatibility and reliability.
Key features include:
  • Multiple Endpoint Types: Connect to Dynatrace Cloud (SaaS), ActiveGate, or specify a manual endpoint URL
  • Secure Authentication: Uses Dynatrace API tokens for secure data transmission
  • Persistent Queue: Buffer data during connectivity issues to prevent data loss
  • Custom HTTP Headers: Add tracking information or metadata to your log transmissions
  • Forwarding Logs, Metrics, and Traces
Get started
Setting up a direct integration of logs via Cribl Stream HTTP Destination takes just a few simple steps:
  1. Get API key to ingest logs.
    • Generate new token with appropriate scope. Refer to Dynatrace documentation for details.
  2. Configure Cribl Stream HTTP Destination.
    • In Cribl Stream, navigate to Data > Destinations and add a new Dynatrace HTTP destination
    • Select your endpoint type (Cloud, ActiveGate, or Manual)
    • Provide your Dynatrace environment ID and API access token
  3. Route your log data.
    • Create routes in Cribl Stream to direct your log data to the Dynatrace HTTP Destination
    • Deploy your configuration to start sending logs
  4. Process incoming logs and events with Dynatrace OpenPipeline
  • Enrich and contextualize data
  • Extract metrics, or create business events from logs
Please consult the linked Cribl product documentation for additional configuration details.
Details
The Cribl Stream HTTP Destination provides a streamlined solution for sending logs to Dynatrace. This integration is ideal for organizations that need to centralize and route log data to Dynatrace for analysis and monitoring.
Cribl Stream's flexible routing capabilities allow you to selectively send specific log data to Dynatrace, enabling you to optimize your log management strategy. You can apply transformations, filtering, and enrichment to your log data before it reaches Dynatrace, ensuring that you're sending the most valuable and relevant information.
Cribl
Documentation
By the partner
Contact CriblRequest support
Copy to clipboard
Related to Cribl via HTTP
Dashboards logo
Dashboards
Distributed Tracing logo
Distributed Tracing
Analyze and slice distributed traces by any attribute and from any source.
Logs logo
Logs
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
