Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Control-M Jobs v2Control-M Jobs v2
Control-M Jobs v2
Control-M Jobs v2
Monitor your Control-M jobs execution status.
Extension
Free trialDocumentation
Get a general overview of your Control-M environment and a quick entry to all the related entities through the dashboard included with the extensionKeep track of all the jobs being run on your Control-M instance with the Unified Analysis screens created specifically for this extensionMonitor the status of each individual job and the logs it has produced on the last run to quickly diagnose any issue
  • Product information
  • Release notes
Overview
Control-M enables you to automate the scheduling and processing of your business workflows across various platforms and applications.
Monitor, understand and troubleshoot these business-critical assets with the Control-M extension.
Get started
For more information on the installation and configuration, please see Control-M Jobs v2 extension in the Dynatrace Documentation.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Jobs waiting for conditioncontrolm.job_counters.wait_conditionNumber of jobs with state "Waiting For Condition"Count
Jobs ended okcontrolm.job_counters.ended_okNumber of jobs with state "Ended OK"Count
Jobs being executedcontrolm.job_counters.executingNumber of jobs with state "Executing"Count
Jobs waiting for resourcecontrolm.job_counters.wait_resourceNumber of jobs with state "Waiting For Resource"Count
Jobs waiting for usercontrolm.job_counters.wait_userNumber of jobs with state "Wait User"Count
Jobs waiting for hostcontrolm.job_counters.wait_hostNumber of jobs with state "Waiting For Host"Count
Jobs ended not okcontrolm.job_counters.ended_not_okNumber of jobs with state "Ended Not OK"Count
Jobs with unknown statecontrolm.job_counters.unknownNumber of jobs with an unknown stateCount
Jobs not in AJFcontrolm.job_counters.not_in_ajfNumber of jobs with state "Not In AJF(Active Job File)"Count
Job statuscontrolm.job.statusMetric that indicates the current status of each job. A value of 100 equals a job that ended correctly, a value of 0 indicates a job that ended incorrectly, was not found in AJF or has an unknown state. A value of 50 indicates a job in the middle of execution. A value of 25 indicates a job that is waiting.Percent
Job number of runscontrolm.job.number_of_runsNumber of runs that a job has individually had.Count
Full version history
ReleaseDate
New in this version:
  • Added keyword key value pairs to extension
  • Add credential vault support for username and password
  • Add new filtering parameters to use on the API call: host, host group, application and subapplication.
  • Fix bug with invalid metric lines when parsing special characters
šŸš€ Improved in this version:
  • Added description, cyclic and number of runs as dimensions for all individual jon metrics
  • Added device.address dimension to all metrics as the IP corresponding to the configured hostname, when possible
✨ New in this version:
  • Add support for the dt.security_context attribute
  • Add new platform dashboard
  • Add platform screens
  • Added new metric controlm.job.number_of_runs to monitor the number of runs for each job
  • Added log ingestion for each job individually to track their metadata, start and end times
    • This new feature will be disabled by default as it will potentially heavily incur on the DDU consumption of the extension. It can be enabled by turning the Monitor start and end times as logs switch during configuration on.
šŸ› Fixed in this version:
  • Turning on the Debug flag now properly changes the log level
  • The extension does not capture folders as jobs anymore
New features:
  • Added a new folder name filter. Kept the original client side folder filter, but added a new filter that is query side filtering. Use this when your payloads are above the 10,000 object size limit.
  • Fixed a bug where filtering for jobs and folders would not work correctly
  • Fixed a bug where filtering was not working properly when only folder filtering rules where set.
New features:
  • Log capture for job executions is now optional based on a new configuration parameter. It defaults to False if not set.
  • New parameter to configure how many threads the extension will spin up to capture the job's logs, if enabled. It defaults to 5 if not set.
  • Order Date is now captured for every job, if available, as a dimension of the job status metric and as a property of the job entity.
  • Fixed an issue where the status WAIT HOST was not recognized and stopped the execution of the extension, creating missing data.
  • Added a new metric for counting WAIT HOST status jobs
  • Added chart for said metric to the job's screen
  • Fixed a bug that prevented metrics from coming in
  • Required minimum version increased to 1.289 for both the ActiveGate and the Dynatrace cluster
  • Error events generated by the extension now get attached to the corresponding Control-M job entity instead of to the environment
  • The extension now avoids querying every single job for its log on the first execution and gets only the latest ones
  • Aded a new server parameter that filters API results by its value
  • The extension now iterates through multiple paginated results when the amount of jobs returned by the API is greater than 10000
  • Adapted the extension to use cases where all folders in a Control-M instance have the same ID to report all folders correctly.
  • Fixed a broken link in the built-in dashboard.
  • Fixed a bug where monitoring the first execution of a job would break the extension.
  • Fixed a bug where the resource consumption of the ActiveGate running the extension would increase to unreasonable numbers based on the amount of jobs monitored.
Converted extension to EF2.0:
  • Added a new metric to monitor individual job status
    • controlm.job.status
  • Added feature sets to control metric ingestion
  • Added custom topology for Control-M instances, folders and jobs and their relevant relationships
  • Added UA screens for each one of the entities
  • Added log monitoring for individual job run logs
  • Added overview dashboard
  • Added filtering in the configuration to filter out jobs/folders
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
